like it was supposed to be there,not an after market look.
I have seen a few others post the same question but no answers yet. Let me know if anyone has any suggestions with this situation.
and yes the plugs in front are INPUTS and not OUTPUTS. you would need to find out where the wiring in the back is fed to the overhead screen and tap that to use and external video screen
Another note for those who have the standard radio w/200 watt amp: you can purchase the 380 watt amplifier ($264.00) and it will plug right into to the existing wiring harness. You'll gain quite a bit of power and surround sound. The seven speakers are the same whether you have the base or premium radio. The subwoofer makes the 8th speaker in the premium system. I'm waiting for an aftermarket solution for the sub. Chrysler cost is about $90 for the sub and $190 for the housing that holds it. Didn't price the other extras grill, screws, clips, etc for mounting.
Want to have a second monitor ... so if the hearness is RCA, I can just use splitters to split the signal to the existing overhead screen and a new screen
I am basically wondering if I would cut through the ceiling material if the wiring for the factory LCD would already be there.
I picked up the remote and 2 headphones for $60 + $10 shipping.
as far as CS668 questions. I think he is asking if the they put the factory wirinig in already to the roof if you dont have the DVD monitor option. I am sure you would hate to cut the roof liner just to find out
the connector OHPacifica is saying is probabaly just what you need to plug into the DVD unit to get to the Video and Audio Out lines. ... I am guessing that this plugs into a nother Molex female plug that runs to the roof mounted DVD screen. Weather or not this wiring run exists in all cars .. hmm good question.
If the wiring to the roof is not there then I would opt for the seat mounted LCD.
Hope you have a good winter. I'm from Minnesota so I can relate a little :-)
Wiring, DVD Jumper, Instrument panel 04869298AB
Wiring, DVD to Screen Up to 3/03/03 04886399AE
Wiring, DVD to Screen After 03/03/03 04869431AB
The first cable is what actually plugs into the back of the DVD player. It lists for $69.70(paid $52.28)
The DVD to Screen lists for $47.85(paid $35.89). This is what we ordered first as we were deceived by the description. This is actually the cable that would plug into the flip down screen.
I did cut the cable (opposite end of what plugs into the DVD) and soldered on RCA connectors from Radio Shack. This plugged right in to the box for the Sony monitor. Here is a pin out for the DVD player and wiring harness.
1 Grey/Tan Fused B(+) (didn't use, used power from 2nd row power outlet instead)
2 Yellow/Grey Igition/ACC signal
3 No connection
4 No connection
5 Grey/Lt Blue Video Control(didn't use)
6 Grey/Orange Video Signal(This is center for RCA connector)
7 Grey/Dark Blue Video Return(didn't use
8 No connection
9 Violet/Orange Video Play Signal (didn't use)
10 No connection
11 No connection
12 Shield (This is outside of RCA connector)
1. where can I find the proper trim piece/ dbl din and wiring harness?
2. what functions will I give up? will I lose the auto mute via the nav system & steering mounted controls?
3. What are the better speakers to fill the current spaces and can I still add the subwoofer?
4. Will I have to lose the current DVD/CD changer in this process or can I keep it as an add-on to the new system?
Navigation System?
All Wheel vs. Front Wheel?
Leather Upholstery?
Heated Seats?
The other accessories I got:
front air deflector - was unsure about this but it is a nice one, molded in the shape of the Chrysler wing logo
mud flaps all around - got the gray ones, they match the plastic on the car perfectly, only get black if you plan to paint them
chrome tail pipe tip - very nice looking, should be standard equipment!
wheel locks - not sure if anyone steals wheels any more but since I got the premium chrome factory wheels I decided better safe than sorry
Also - dealer tried to charge 4 hours labor to install the above. I had them go back to the Mopar book and look up the times recommended. They came back and cut my bill in half!
But don't you think that when you spend over 35k on a car you can expect a little bit of high quality?
Why would I have to retape all my CD just to let it sound correct?
I don't think I have to compromise quality when spending that money. If DC is not willing to cooperate on this, then maybe my next car won't be DC anymore!
My wife she bought an Acura TSX, her audio system sounds excellent! her car was only 27k!
The Original DVD number was 56038 642AE.
The New DVD number is 05064 033AA
Is this consistent with any one's new Pacifica? It is still missing some local streets, including the one where I live is not in a mapable area.
I thought that the newer ones were higher alphabetically, like ending in AG...
Anyone??
Thanks in advance.
Jim
So I will ask for the AG or later release. boy it would suck to get the update and pop in the AF release and be in texas and not have ANY data !!! umm kinda of a small state to miss ..LOL
I was wondering if the base model is pre-wired for the foglights. I know the stalk switch isn't installed, but a separate switch could be installed.
