Chrysler Pacifica: Problems & Solutions
What problems have you encountered with your Pacifica? Please share any solutions!
1) FM reception is poor - I will have the service department determine if there is a problem with the radio, antenna, or neither - in which case it's just bad design and I have to live with it. I have 2 other Chryslers (T&C, Gr. Voyager) which never had this problem.
2) On some cd's I notice static in one of the tweeters, other times it looks like the center channel is out-of-phase. Again, this is only on a few cd's. I think this is going to be a tough one to figure out since most mechanics are probably not audio enthusiasts and couldn't hear the difference even if it was pointed out.
3) I noticed right from the start that the steering wheel has to be slightly off center for the car to drive straight. I'm not sure if there is supposed to be a certain tolerance or whether the alignment is off.
4) There is a distinctive knock/bang sound when I change gears from park-neutral-reverse.
I'd appreciate any feedback from anyone experiencing similar problems.
Otherwise, I love this car!!!
#3 we (this is my wife's car) have the same issue. Steering wheel is mis-aligned slightly to the left. Wheels do not appear our of alignment however (there is no "pull" needed to keep the car tracking straight). What results though is if a quick course correction is needed, she tends to over-correct which can be dangerous. I was waiting for the 3K miles service to have this looked at.
#4 I will check on this weekend as this is the second or third time I have seen comment on the "bang".
2,000 miles on the car and loving it so far.
Pietras
The message below is from the Honda Pilot Owners board. Perhaps it will be helpful.
marklud "Pilot Owners: Problems & Solutions" Jun 9, 2003 8:08pm
So my question is - has anyone have the same problem with Pacifica or it's just the two I drove?
Ford had a noise problem with 1996 Taurus - there was loud whistle from windshield at 70mph. Ford quietly fixed it under warranty but only for people who complained. So - if we don't complained - they won't fix it.
I found by opening my sunroof to the vent position helps. For most of my driving I rely on the climate control system to do its job, and keep the windows closed.
1)- First time in the shop at 500 miles-Hard to start and when it did start, chugged and puked when I drove over 30 miles per hr.
~Service tech said that the computer was sending a "bad code" They essentially "re-booted the computer" problem kind of solved, still has trouble starting from time to time.
2)This seems to be a reoccurring problem with a lot of Pacifica owners, but my FM reception is terrible!!! I live near San Francisco and the radio stations are pretty powerful here (wattage wise) There is no excuse for the poor reception!
~Service department said that there is nothing that they can do "It depends on where you are in relationship to the radio tower" Duh!!!...Funny, every other car I own has no problems
2)Rear passenger speaker has an annoying buzz
~Fixed, new speaker
2)Rear passenger cup holder was broken. (Didn’t find out about it until passengers sat back there.
~Fixed, new cup holder
3)Fluttering noise from left front wheel well at freeway speeds.
~Still in shop, service mgr said that there is a loose something?? Solution; some kind of permanent tape that will hold down what ever is flapping!! Tape???? Give me a brake!!
4)Knocking sound when shifting from park to reverse and from reverse to drive.
~Still in the shop. First they said that they have to "re-torque" the front axels and change the gaskets. They did that and it didn't fix the noise. Their next step was to bring in a "master technician" from Los Angeles. He used electronic ears to determine that it was a power take off unit (sounds made up to me!) This "PTU" Is not a standard part so they said that they have to take the part off of the assembly line and the part should be here by Thursday or Friday. Well, as I write this, it is 3:30 on Friday after noon June 20th. The part is still not here, and I do not have my car. It has been in "the shop" Since June fifth! I've requested a new car and they said that they "reported" my concern to the regional manager and he would contact me. Still nothing!!!
Anyone else have experience with this type of situation? What should I do?? I would appreciate any input.
wife of mikeymike1
I'm waiting for my first service appointment to get these resolved. Was your speaker buzzing all the time?
The speaker was bad no matter what I was playing from the start. A suggestion...don't wait until the service appointment to have the knocking sound looked into. It took my dealership three weeks and multiple missed promises and huge headaches to finalize the repair. If your service center has problems fixing it, ask them to call Stoneridge Chrysler Plymouth in Dublin Ca.
Good luck!
Mike
As for the wind noise, I am familiar. I currently lease a Volkswagen Jetta and if the front windows are closed when opening the rear windows (one or both), the noise is horrible. The first time I heard it, I thought it was something going on with the car but I soon realized that it was not the car. I opened the sunroof tilt and that alleviated the problem (also, opening the front window(s) slightly alleviated the problem as well.
I am not thinking about purchasing until around November (when I plan on starting talks) or December (when I hope to purchase). So, I hope these problems will be corrected, as far as the FM reception and the speaker(s). I may have to get the Satellite Radio if reception does not get better. I am also hoping to take advantage of end of the year incentives.
played James Taylor DVD concert in 5.1 and no center speaker problems. No shifting sound problems at all. still breaking in so under 55 mphs all the time. a bit under powered on take off ... its geared pretty high so it hesitates on take off.
OH FM receptions seems OK here in Pittsburgh (as good as my Highlander was)
Isn't the sound system awesome in this car? I love playing Sting's concert DVD even while I'm driving, who cares I can't watch the video screen, at least I can play the darn thing, most cars you can't even play DVD's just for the audio. Curious to know though if the video monitor displays even in the closed position. I don't seem to notice any latch or button that could trigger it to turn off when closed. Anyone know if the display is constantly on when a DVD is playing even with the screen up?
I tested it by playing the DVD in a dark location and I could see the movie showing even though the screen was flipped shut !!!
the DVD I tried to see myself it seems to keep on no matter how far I close the screen up to the latching. hmmm wonder if it gets hot if you play dvds with it closed ? (see post above)
Earl
Do you think the Kia uses a better quality than the Pacifica?
My Sedona has a very beautiful factory towing kit that I bought and installed at home. The kit was $ 400 and the hitch went on with not drilling in about 10 minutes. The wiring adapter took about 5 hours since you have to work slowly and carefully as you disassemble the various panels to gain access to the left and right side tail light connectors. The power travels under the car with a long fused and jacketed power wire. The instructinos were very well written.
I wonder if the Pacifica will have this soon?
The Sedona can tow a combined load of 3500 lbs for cargo and trailer.
The Tow hitch is better quality then an after market solution, its just the installing dealer was not that good as its the first one they did (can U say guinea pig) ...
I got only 2 keys with my Pacifica
I was hoping the dealer may have forgot to give me a third key
mine is coming off (looks like double sided sticky tape is all they used to keep this thing on) :-(
I ordered the 7 wire round as I can get a converter to 4 wire flat if needed but dont think you can go from 4 wire to 7 wire.
what do you mean its tucked up under the bumper for the wiring harness. I have yet to see one installed.
I can't find how to make my display go into the split screen mode. Does anyone have a clue how to do this? When I give it a destination, I just get a display that shows the upcoming turn, even if that turn is 20 miles away! That isn't very valuable if you are trying to plot your progress.
All help appreciated.
The map will be the normal display, but when you get close to the next turn, the split screen will display.
This way you see the big picture until you need the split screen.
The only way that I know of to operate the power is to push the button on the key or the button on the overhead.
My salesman did say that I could open and close it manually or under power but just pushing closed or using the latch to open.
