Just got a nice compressor and tools for my birthday...
I've seen what can happen.
Anybody remember the old "split rims" trucks used to use? Same advise applies.
But, I never did understand the term "DIY" since, even when I was working in a professional garage, I still did the job "myself." Professionals get hurt just like the shadetree mechanics. Sometimes even moreso because, after doing it so often, you can tend to get careless. I won't even get into it, but it can certainly be a horrible and tragic scene.
2. A first-rate indie shop should be just as good, the only problem will be finding one.
please update me on Audi's improvement in their maint/repair reputation (if any). I am looking at a '05 A8 but I cant have a car in the shop routinely. Any opinions??
Also M3 depreciation after 4-5 years is pretty bad. Historically all the BMW "M" cars do not do well in resale after they age and a new body style has appeared.
I'm sure you can cut these costs---they are only estimates and don't reflect the energy level of people who shop around, use indie shops, do some work themselves,l or even have "better luck" than other people.
I drive a car with a deadly reputation for maintenance costs (Porsche 928) and while it isn't cheap for me to maintain (about $150/month) I am well below the predicted rates because I catalog shop, do some things myself, have a good relationship with an independent shop, and try to nip problems in the bud.
I have 1996 dodge avenger and found my self stuck on the road when the ball joint went bad (it did what the recall said it could do and disconnected). I went online and found there was a recall, thank goodness.
Now the dealership is telling me that the laterial control arm is covered by the recall but that the Lower Control Arm is shot and needs replaced and is not covered and will cost me $600.00.
When the ball joint went out did it prementualy cause the damage to the Lower Control Arm? Do I have any legal options to get the lower control arm replaced for free?
Recall
http://www.recall-warnings.com/auto-content-13449.html
Thank you for any help! -J
So depends on the BMW. If it's an M or a 7 series, you are going to nosebleed now and then, there's no avoiding it once you're out of warranty I don't believe.
the BMW is hit or miss. Some owners like yourself are very fortunate; so was I for most of my BMWs, but other owners have a lot of trouble, mostly it seems electrical glitches, lower ball joints, radiators busting. Not major component failure, but lots of nickel and diming.
Begining in Mid-92, Ford switched transmissions in the Crown Vics.
Early 92s has AODs and from 92.5 has the AOD-E.
The AODE is extremely hard to find nowadays in wrecking yards and is VERY expensive to rebuild!
You may wanna check out the 4.6 Tech area at the
www.crownvic.net website.
Actually, aren't you trying to turn off the auto-headlights, not the drls? (same system, different bulb)
There are still drive in theatres in this country?? Please, come to our town and open one.
That being said, I'd avoid the 92, unless when he means overdrive is going out, he means the tranny is shuddering from worn-out fluid. There are plenty of used Crown Vics/Grand Marquis out there to chose from with a lot of life left in them.
Anyway, I've replaced the TPS and changed the air filter. Any other ideas?
http://www.atk-engines.com/amereng.html
http://www.jasperengines.com/jasper-process.htm
http://webapp.jasperengines.com/webcat/catalog.asp
Jasper quotes $3,634 for the engine, then you have to consider labor (16-18 hours at ?), plus hoses, belts, other junk - (18 hours $75 is $1350).....you're looking at $5200-5500...
The insurance company won't care about the rebuilt engine.
3,634 for a reman engine...wow, have things changed!
Is it me or is it strange that when you purchase a vehicle from a dealer they have their recommended service interval so different from the manufacturer's service schedule on the manual. I would figure that the manufacturer's engineers and testers have pushed these engines enough to determine the appropriate service interval. So in essence, I'd rather follow the manufacturer's recommendations than the dealer's recommendations. And I don't buy the, "Well your are driving in...city which tears up and abuses the car more. Thats why we recommend these intervals."
Some people, including myself like to take better care of their cars than that.
Still, it's hard to say how much longer a car will really last given extra oil changes etc. I guess in my case, I remember the "old days" of cleaning out sludged up engines. I still won't use a certain brand of Pennsylvia oil because of this.
To me, they are glorified Volkswagens that are even more troublesome.
That being said, I do agree they are nice cars to drive.
So find a good dealer or mechanic. And check the Audi A4 Owners: Problems & Solutions board for real world experiences.
