Maintenance & Repair Costs
One thing I didn't realize before purchasing a 1999 A6 (std) with 55k miles was the Edmunds site left out in it's maintenance information was the fact that the timing belt needed to be replaced at 60k miles. I went to the Audi dealership in Tampa, Fl and they indicated it would be $1100 to do the 60K interval. Wow, what a blow for getting such a deal on the car. The normal hourly rate at this location is $90 /hour. No, that does not include a girl and a room.
Timing belt - R&R
1996
All:
2.5 hours
Add:
.2 seal, camshaft
.2 seal, crankshaft
.2 tensioner
Total labor is 3.1 hours. The parts must be gold plated.
(*) rotating rocks in tire treads
(*) wash and fluff-dry all cottonwood seeds in air filter
(*) remove, clean, lubricate, and replace all bolts
(*) align all window stickers
if this is something like a $800 timing belt change due to parts removal, etc. and $300 of plugs, wires, lubrications, and gyrations, that's one thing. but a lot of "dealer recommended service packages" also contain items not in the carmaker's recommended service list, some of which are traditionally laughers in their own right. and yes, parts are often more expensive than they would seem... until you remember that you replace fewer of them and further apart these days.
with that labor estimate alcan found in mitchell's guides, I'm more than a little surprised at the final price.
OTOH, what about also replacing the fancy German water pump at the same time, as many places commonly recommend? That could easily bring you to $1000 at German parts prices.
I'd pay roughly $120 in parts if I wanted to replace the water pump on my '96 E-Class. It would also be a relatively easy fix, as it sits right at the top of the engine and is accessory belt driven, thereby very easily accessible. Definitely a DIY job.
Most of the stuff I had to replace so far (window regulator, belts, bulbs, battery) have not been outrageously expensive.
Parts availability also depends on the manufacturer. I've had to wait for BMW parts, but had plenty of choices for Mercedes. Even the dealer parts were often competetively priced.
Mercedes will get really expensive if one talks about a complete engine take-down or engine replacement. I believe a replacement engine would run me close to $8K. However, I would consider that a very unlikely event.
I have heard that Audi is expensive though - the one Audi I owned I sold quickly - the things I did have to replace were much more expensive than they would have been on a Toyota (window regulators for one)
I have since found out that the price of $126 was high, and that people have bought this part for as low as $80. Ah well, it was a kind of emergency.
Yes, Audi seems to be expensive. A friend of mine owns an Audi convertible and had to pay $400 (part only) for a replacement rear window. I believe I'd only pay around $140 for the replacement on my Z3.
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
I'm curious as to whether or not the Audi dealerships use synthetics when changing oil during the service intervals. Does anyone know?
This discussion is more for members who are looking to check out maintenance costs.
kirstie_h
Review your vehicle
Can anyone tell me service is needed during the 30,000 mile maintenance/tune up.
I would think oil and transmission change, air filter. Is there a need to change axle fluid on front and rear axle?
Dealer wants to charge $450 which I think is high just to do basics and check fluid, belts, etc.
Any feed back appreciated.
Brake4me
I agree... it's too much for what they are doing.
Automatic transmission filter(s) $ 32.70
Automatic transmission fluid $ 11.20
Engine oil $ 11.25
Oil filter $ 5.70
Spark plugs $ 21.60
Total Estimated Parts Cost $ 82.45
Labor Action Item Labor Cost
Inspect/replace Air filter $ 2.25
Adjust Automatic transmission bands $ 62.04
Replace Automatic transmission filter(s) $ 16.91
Change Automatic transmission fluid $ 28.20
Inspect Brake lines, hoses & connections $ 1.12
Inspect & adjust fluid level Coolant $ 2.82
Change Engine oil $ 11.28
Inspect Exhaust system $ 2.82
Replace Oil filter $ 5.64
Inspect/replace PCV valve $ 5.64
Replace Spark plugs $ 39.48
Check level Transmission fluid $ 1.12
Rotate Wheels & tires $ 16.91
Total Estimated Labor Cost $ 196.27
Total Estimated Costs
Total Estimated Parts Cost For Your Area $ 82.45
Total Estimated Labor Cost For Your Area $ 196.27
Total Estimated Cost (excluding tax)* $ 278.72
In addition to the procedures for each indicated mileage interval, Dodge has identified other service operations to be performed at calendar intervals. To view these operations and their estimated cost, click on Additional Procedures.
*This Total Estimated Cost includes the preventive maintenance items recommended by Dodge. The facility that services your vehicle may perform different, greater, or fewer procedures that can affect the cost you incur. For example, engine oil change and filter replacement are commonly performed by dealer and independent service facilities at special prices. These "special price" services do not typically include all of the additional procedures recommended by Dodge at each service interval.
Dealer wanted $425 to do the stuff listed in the maintenance manual.
2) Jim (Future Ford mechanic ) calls @ about 11AM on April 24th & indicates that the CHECK-ENGINE light is on / vehicle “runs rough” indicates that the rear bushings need to be changed / leak in the air-conditioning system / fluids & spark-plugs should be changed since it has passed the 90,000 mile mark. – I told Jim to change the fluids (PS fluid / brake / transmission) an the spark plugs - Jim indicates that this will be about an $870 job.
3) Jim calls at about 12:30 on 4/22 and indicates that the #3 spark plug head is rusted and didn’t come out. It has snapped in two and they (the Dealership) would like to soak it over-night, so that they could insert a special rod into the socket to try to remove the broken spark plug. They retain the vehicle over-night.
4) 10:45 AM on 4/23 Jim calls and indicates that the spark plug remover has broken and that the broken piece of the spark plug is still in the socket. He must now pull the cylinder head he estimates a cost of $3800 including some 17hrs of labor and a charge of $1332 for the cylinder head if he needs to replace the cylinder head. In addition he has indicated that the soonest that I could get the vehicle is on Tuesday, April 27, 2004. That is a full 6 days after dropping it off for an oil change. The labor charge at this dearlership is $98.00 an hour.
What should I pay here ? I believe that the dealership should have to eat the cost of the broken spark plug and all the labor that goes with it. In addition, The cylinder head would be fine if they successfully removed the spark plug... also the Mechanic never called to indicate that he was having difficulty with the plug .. he just continued on until it broke
I am also incurring the costs of not having the vehicle. I have to find other means of transportation, in order to get to work.
I personally would be ready for lawyers at this point, but you would have to haul the truck out of there on a flatbed after paying for everything so far, have an independent mechanic survey the whole mess, and pay him to rectify it.
I think monkeys worked on your car, and they keep getting it wrong. having said that, breaking a plug around 100 thousand is not unusual, and IMHO anybody who believes that stuff about plugs lasting that long should expect to buy new heads or have the plugs drilled out and helicoils installed.
all that said, they broke something or left a vacuum hose off or a sensor unplugged to cause the $$$ light. it sounds like a pyramiding scam. I would be interested in seeing one of the professional long-term fleet mechanics who frequent these boards respond, to see how many "nothing can go right' cases they have had, so I could gauge just how likely that explaination is.
my gut feeling is that Osama bin Laden is the lead mechanic at this dealer, and Satan is their job estimator.
You should only pay for what you agreed to initially, and they need to know that or face the consequences in Small Claims Court or worse, where they will be slaughtered on this one.
PS: Check with your attorney about how his involvement affects your Small Claims suit. Don't take legal advice online here.
Once you have that, then you may want to seek legal advice, as Mr shiftright indicated.
Please do correct me if my thinking is erroneous.
So next step is to take it to a QUALIFIED Mercedes outlet and have it checked out top to bottom. This might cost you from $75-150. Have that shop make a list of the car's needs and estimate what it would cost to fix those things.
Now you have to look at this list with a certain sense of reasonable judgment. Every used car can be found wanting something. The trick is to decide what is really serious and what is improbable to cause trouble. A tiny tiny oil drip or a rear window making noise isn't critical and I wouldn't go spending money trying to make an old car like that new again. It's not a collectible and never will be, so get out of the "restoration mode".
But if it needs new fan belts, or brake rotors, or a new catalytic, well those things are expensiv and you can then use this check out list as part of your bargaining.
With a 300E, if you start out with a good used one, you'll have great luck and there's no reason to presume excessive costs to maintain it. Just bring it in in the Spring and Fall and throw $350-500 each time at the shop. That should do it, maybe $75-$100 a month in maintenance.
But if you start out with a bad one, your grief will never end. You have to be sober about old Mercedes, and realize that replacing the engine or the transmission exceeds the value of the car in most cases.
Any....ANY maltreated old luxury car will cost you money, including a Lexus. It's not cheap to work on these old luxury barges, as they are complex and can be labor-intensive.
But you've picked a really good model.
Value is between $3,500--$5,000 depending on condition. The high end of the range is for very nice cars with no body or interior damages and needing very little in the way of repair.
I'd say your target price for a clean good driver with few needs is around $4,000.
What kind of costs might be involved in overhauling it (rings, bearings, etc.)? What about used low-mi engine vs. new?
We are trying to decide between:
Trading in the V70 for a Passat TDI (diesel) Wagon at $26501
OR
Keeping the V70 for family driving, and buying a Jetta GL TDI Wagon at $19577 for everyday commuting/errands.
We prefer the way the fuel-sipping Jetta drives and handles to the Passat, but the Jetta is crowded in the rear. We love almost everything about our V70 (like it better than the Passat, really). A dealer offered only $3800 for it.
I'd hate to sell it to a private party for much more, and have them come back to us if the engine dies.
So I'd like to hang on to it and buy the Jetta, but not if it's a ticking time-bomb of huge repair costs. If that's the case, we may as well replace the V70 now (in which case, we'd continue to use our '94 pickup truck on occasions when both of us need a vehicle).
As I see it, the $7k spread between the Jetta and Passat covers a lotta work on the Volvo engine, and we've already taken the big depreciation hits on the rest of the Volvo.
Plus, it's quite a bit cheaper per mile to run a Jetta TDI every day than a Passat TDI. This savings should cover the carrying costs of keeping the V70, especially if we're not driving it so much.
My usual car-buying MO is to purchase new and keep for many years. Don't want to hunt for the right used V70; new ones are too expensive.
I just drove the TDI Passat wagon, GLX and loaded, and they wanted 28 for it, so it sounds like you price is pretty good. Road well, but I do wish they had the Volvo seats in the passat!
Passat seats aren't terrible, but they don't match Volvo's.
Same with safety engineering.
Passat scores good marks, but the Volvos have much better head restraints,
plus the anti-whiplash seats, and maybe better side impact protection too.
If the leakdown test is "pretty good", that is, still within factory specs for wear and tear, and the oil consumption is reasonable, say a quart every 2000 miles or so, I don't think there is an ethical issue regarding sale of the car to someone else or a great risk if you decide to keep it yourself.
If the engine is truly wearing out according to the leakdown test, you have to be in the hole at LEAST $5,000. The problem with rebuilding or overhauling the engine (two different things) is that once you open an engine up and lay it out on the bench, you are in a pretty non-negotiable position. You have only two options. 1) Do whatever it needs and whatever it costs (gulp!) or 2) throw the engine pieces in the trunk and sell the car very VERY cheaply.
So I'd be pretty damn sure you know the condition of that engine before you start taking it apart.
Replace the belt?
Let the belt break (perhaps stranding you somewhere when it breaks?) and either drop a rebuild engine in the van or junk it?
If the van is a throwaway, drive it 'til it starts making noises. If the body is in good shape, throw in a reman long block and keep trucking.
I wouldn't invest $500-1000 in the current engine when a motor swap is around a grand more, depending on the source and the shop.
The van in question is a 99 Odyssey that the poster claims has 300,000 miles on it.
It sounds like it is still in decent shape.
The poster thinks it's dumb to spend 400.00 on a timing belt since the Odyssey has little value because of the miles.
And some Honda tech (?)told him he had never seen a T-belt break on these.
Well...I sure have to wonder how many 300,000 miles that guy has ever seen??!!
My advise was to get the belt changed. It WILL break when it's least expected and the engine will STOP at that point quite possibly wrecking the engine in the process.
I pointed out the fact it COULD be a safety factor especially if the poster's wife were driving on a dark wet freeway with a semi on her tail or it were to break in a bad neighborhood.
I just think it's false economy to wait until something happens. Not much different than never changing oil or running around on marginal tires.
So, what do you guys think?
Otherwise I would agree with you.
Even if it's newer and in decent shape otherwise, a van with 300,000 miles on the original drivetrain can't be worth all that much. My '99 with 93k is only worth about $7,000, so let's assume for my question that the max trade-in would be 10k, and the minimum $5,000.
Maybe worth it to change the belt if the van's worth 10k? Not so if it's closer to the $5k number?
But, let's assume there is no safety factor whatever. The car simply dies one day at a stoplight when the belt snaps.
Still...a royal pain at the very least.
If I was that adverse to replacing the belt, I think I would dump the car first, before it broke and stranded me somewhere.
Since I would be the guy who had to replace the belt, I wouldn't have let it go that far.
The cost of replacement for an engine, even a used one far exceeds the cost of replacing the belt. But, if the value of the van was minimal, I might let it go until it breaks and junk the van.
Since it is a Honda (yes, it does make a difference), I would do the work and have it go another 100,000 miles.
Seems like we used to have a discussion about when it was time to junk a car vs. spending money on fixing it, but I didn't see it when I searched earlier.
I would agree that if it is a concern, then selling the vehicle before the belt snaps is a good idea. Maybe use it as a trade in.
You didn't say it was a HONDA....that changes things.
From the sounds of it though, 300,000 miles, the belt hasn't been changed, you have to wonder just how well the rest of the vehicle has been kept up.
If the vehicle is pretty sorry looking, then I could easily see dumping it. But if the rest of it has been kept up, again...assuming it is a 99, then I could see repairing it.
There are alot of variables to saying, would you keep it or dump it.
We had a 99 Chevy Lumina sedan, it had 90,000 miles on it, it was on its 3 intake gasket, even after having an updated manifold and gasket installed (all under extended warranty), we decided to cut our losses and traded it in on a new Impala. Granted, the car was worth keeping, but only 10,000 miles left on the warranty, we decided we were better off trading it in.
Opatience brings up an interesting point too. If this owner was too stingy to pay for a LONG overdue timing belt he probably skimped on everything else as well.
I would like to see this 300,000 mile Odyssey.
A 300K vehicle is just a money pit waiting to happen, Honda or no Honda. ANYTHING can fail at any moment with those kind of miles. Even structural failure is not out of the question, with welds snapping, etc.
NOW, if you wanted to do a real mechanical restoration on that vehicle, that is, tear it down front to back mechanically (assuming the body and interior are VERY nice), that makes more sense than throwing $500 wads at it and patching it up.
My logic? Well, if you spend say $10,000 going through the van mechanically, you can amortize that over the next years of use you will get. Lot cheaper than a new van, too, by 2/3 thirds. And cheaper insurance, you can drop the comprehensive and save an additional $300 a year right there at least.
If it's got 300K on it and is really shabby, I wouldn't do much to it aside from the basic safety requirements of good brakes, tires and a front-end check.
With old extreme mileage vehicles, you have to get into "long term thinking" IMHO, or just give it up. Trying to work the middle of the problem just won't cut it, I don't believe.
So to know if you are getting your $200 worth, you have to ask for a list of services performed on that shop's "tune up". In other words, what do THEY think a "tune up" means exactly.
On my car for instance, at the shop I go to, my tune ups cost more than that, but I get the usual plugs, also they check the distributor cap and rotor (if your car has one of those), the condition of the wires, the basic engine settings---they'll do a scan and check the codes and engine emissions. Also check belts and hoses, look for leaks--while they are in there, and probaby replace fuel filters and air filter, check vacuum lines, etc.
But if all they are doing is slamming in 6 plugs and driving it around the block, no, that's not worth $200.
