Visitor Agreement.
I do recall however, that some Cadillac dealers were trying to decarbonize rings on some Northstar engines. I also recall that this didn't work very often, but maybe some of you have been following that more closely.
Hopefully they will start making this stuff available in stores...
http://www.redlineoil.com
I do not know if Redline claims to be 505.01 certified/qualified.
PROCESS:
1.) Remove all the Spark Plugs from the engine
2.) Disable the ignition system
3.) Attach a small dia. hose to a small funnel
4.) Purchase some penetrating oil / carbon solvent from an auto parts store. There are many products on the market.
5.) Pour some product into each cylinder. Be generous with the product. Let it sit in the cylinder and soak. It might be a good idea to let it sit over night.
6.) Crank the engine over and introduce more product into the cylinders. Let it sit again for a period of time.
7.) When you feel the that process has been completed, drain the engine oil, change the filter and refill the crankcase with clean oil.
8.) Install the spark plugs, and re-connect the ignition system. Put an additive in the fuel tank that is designed to dissolve carbon in the combustion chamber.
9.) Start the engine, and let the engine idle till it reaches operating temperature.
10.) Take the vehicle out for a drive on the highway at normal speeds.
I have to say I have never seen blow-by cured from a can. Best I've ever seen a can do is clean up a dirty injector and occasionally free up a sticky hydraulic lifter.
But again, faced with an engine tear-down, I'd even pay a shaman to dance around my car.
I would not even consider this on the newer hyper-controlled fuel and ignition system engines, but it sure made those old V8's that the little old ladies puttered around town in run better!
Maybe on a Model A?
Higher Than Expected Oil Consumption (Clean Piston Rings) #02-06-01-009C - (Oct 23, 2003)
1996-2000 Cadillac Concours
1996-2002 Cadillac Eldorado
1996-2003 Cadillac DeVille, Seville
with 4.6L Engine (VINs Y, 9 -- RPOs LD8, L37)
This bulletin is being revised to add parts information. Please discard Corporate Bulletin Number 02-06-01-009B (Section 06 - Engine).
VIN Breakpoints
Model Year Model VIN Breakpoint
1996-2002 All Above All
2003 DeVille Prior to 3U213641
2003 Seville Prior to 3U215818
Condition
Some customers may comment on higher than expected oil consumption. The typical customer with this condition comments on consumption in the range of 0.946L (1 qt) of oil used in 1600-2250 km (1000-1400 mi) of operation. The oil consumption rate and possible oil consumption areas, as per Corporate Bulletin #01-06-01-011 dated March, 2001, should be verified prior to performing the ring cleaning procedure below. The standard for acceptable oil economy and the method for determining oil economy are outlined in Corporate Bulletin #01-06-01-011.
Oil Consumption:
The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946L (1 qt) in 3200 km (2000 mi). This rate only applies to personal use vehicles, under warranty, maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or 80,450 km (50,000 mi) for Cadillac, driven at legal speeds in an unloaded (for trucks) condition.
Cause
Although there are several reasons for less than expected oil economy described in Corporate Bulletin #01-06-01-011, one area not covered is reduced sealing ability of the rings. Through normal usage, combustion chamber deposits may build up to the point that the movement of the rings could become restricted and prevent the rings from wiping all of the oil off the cylinder walls and allowing it to be burned in the combustion process.
Yada, yada, yada.......
It's another additive, so save the flames. It helped on a car I had back in the 80s. Yeah, I know this anecdotal evidence. But it worked.
For a couple of bucks, it's a cheap try compared to alternatives that ineffective additives or expensive.
I personally use the Rislone as I do fuel additives on a once-in-awhile basis. When I add it at half-quart in new oil, the oil gets dirty much faster because it's working. I sometimes add it when the oil is at 2000 miles and down a quart or less, drive a few hundred miles and change the oil to get rid of the gunk it picks out.
Good luck to you with cleaning the rings.
I hate that stupid oil pump on the 3.8L. Had one wear out the housing and required a new timing cover. The oil pocket for the gears was mis-machined, jambed the oil pump when the engine fired, and snapped the end off the camshaft as it drove the oil pump through the distributor shaft. Whoever designed that pump set up was doing serious drugs.
I appreciate any advice.
So, that leaves either the dealer or and Indy. If your indy works regularly on VW's and Audi's, that would be a good choice.
For now, I'm using my dealer for oil changes (I opt not to fight for warranty coverage later, should there be a problem).
Which ever way you go, since you've just bought the car, I'd ask the tech to make sure that all of the fasteners are in place on that belly pan and to replace any missing ones. It's not fun to have the thing drop down onto the road surface while travelling at interstate speeds!
I am really enjoying the Passat wagon(knock on wood). On a side note, I recently changed two bulbs(headlight and directional) and couldn't believe how easy the access was to them.
If you are going to the dealership, consider bringing your own synthetic oil with you. I do and my dealer doesn't mind. They charge about $15 for the labor, plus the filter, oil disposal, etc. All told, my last oil change was about $45, using approved synth oil. You can find a list of VW-approved oils here:
www.vw.com/SP/pdf/oilchart.pdf
But be warned, some of these oils are not readily available (I've never seen Elf or Total oil in the US). You should be able to find Mobil 1 0w-40 at some Walmarts and some auto parts stores. You should be able to find Valvoline Synpower 5w-40 at NAPA stores (you can order it - Part #966)
And finally, Valvoline's website DOES NOT show VW spec 502.00 approval for Synpower 5w-30, despite it being included on the approved list. Good luck!
PS: If you have the 1.8T engine, there has been a recent TSB that has changed the oil filter to a larger one (formerly used only on VW diesel engines). Make sure you get the larger filter.
So I second the last poster's recommendation to take in your own oil (or at least insist on the Castrol Syntec 5-40 that is available to dealers - this usually bumps the oil change price to $90). And I also second the recommendation to remind the dealer about the TSB that upgrades the filter size. It's amazing how many dealers (or at least the service advisors) don't keep track of these changes. Call me paranoid, but until enough time has elapsed for all dealers to wake up to the importance of the manual's requirements, I'd double check them.
My own humble Golf 2.0 requires 5-40 oil. When I asked the dealer, they said 5-30 is ok too. Fortunately I used Mobil 1 full synthetic, which although it doesn't satisfy the weight range requirement, isn't going to have sludging problems (and of course the normally aspirated engine is easier on the oil than the turbo versions). So obviously there has been a disconnect between what VW puts in its manuals, and what the dealers have been doing. Which surprises me.
Krzys
PS I would imagine buying bulk would be even cheaper.
Krzys
The oil filters these quick lube places use (Fram, Purolator, etc) are basically junk as far as your car is concerned, and should be avoided at all costs.
List is here:
http://www.vw.com/SP/pdf/oilchart.pdf
I just had a LOF and engine detail on my wife's 2000 Ultra. Now the DIC shows 129 psi oil pressure regardless of engine RPM. I have never seen it that high and I have never seen it rock solid unchanging. Is it possible that water from the engine detail has messed with a connection somewhere (all the other DIC indicators seem to be working okay)? Or could they have done something in the oil change to make the pressure that high?
My 04 Bonneville SLE has a gage which typically shows between 60 and 80 psi oil pressure. The gage does sweep from 0 to 120 back to 0 at startup before registering the actual pressure.
Thanks in advance for any info.
Bob
"Garbage in, Garbage Out."
Is there a check valve in the filter that could be plugged and drive the pressure that high? I know some filters have such valves to keep the oil from all running out of the engine after shut down.
Jim
The instructions go on to say Packard suggests the owner use a high-grade medium gas engine cylinder oil and in the Detroit area they use oil with a cold test of under 25 degrees fahrenheit. Oil changes should be every 1000 miles in the summer and every 500 in the winter and the dealer can only charge for the oil, but the labor is free.
This was the warranty on the car: “The Packard Motor Car Company has warranted that for a period of ninety days from the date of delivery to the purchaser it will replace, free of charge, any part claimed within that period to be defective and found by the company to be so upon examination, provided such part is returned to the company within that period for credit or replacement. Such free replacement does not include transportation charges to and from the Packard factory, nor the cost of installing the new part. Tires, rims, batteries, speed instruments and other accessories, being subject to warranties of their respective manufacturers, are excepted from the warranty.”
I know this is not the focus of this board but I found the oil change information interesting, and compared to today’s situations, rather humorous.
The car came from a very reputable dealer with a great reputation for service. According to their records, they changed the oil before delivering the car to me. This is corroborated by the static sticker on my windshield.
So, you can imagine my surprise when, after only 1200 miles of driving, my "change oil" light came on. I checked to oil to see if it was low - it wasn't. In fact, the oil "looked" fine to me. To make matters worse, I drive like a little old lady. The engine has never turned over 3500rpm on my watch.
Has anybody else had this same experience? Should I get my oil changed?
Check your owners manual about how to reset the timer.
In my wife's Tahoe you reset the monitor as follows:
Turn key to on position (car not cranked), depress the gas pedal, I believe, 3-5 times within the span of five seconds. This should reset the oil monitor. Read your owners manual just in case your car varies from my wife's. Good luck!!
