Visitor Agreement.
I will go to court tomorrow to sue a mechanic and need technical support from you!
I couldn't start my 95 Ford Probe GT in May 20th. When I turned the key, there was whirring sound. But after several hours and several tries, it started again. The battery was good and jump-cable didn't help. To make sure everything is ok, I brought to a new mechanic to check the car in May23rd, since my own mechanic was very busy that week.
I was told that the alternator was bad. After I paid $413, I picked my car. But after several weeks, the problem appeared again. The car couldn't start but after several hours, it started again.
My own mechanic told me that if the battery is fully charged, if I throw out the alternator, I can still start the car every time.
Obviously, the starting problem has nothing to do with the alternator.
Since that mechanic refused to refund me money, I sued him.
$413 is a lot of money to a student like me.
If possible, could you give me more technical support regardint to this?
best,
zhipeng Yan
:lemon:
Just tell your story, be honest and bring all your receipts. Small claims court often favors the consumer but you must be prepared and NEVER get angry and NEVER interrupt the judge or your opponent.
Took both the intake and return fuel hoses off one at a time and tried to crank, both are getting fuel,
Checked the spark plugs for fuel at the tips, they are wet, not soaked but wet with fuel.
Tried disconnecting one fuel injector to see if maybe it would fire the other 3, no luck.
Finally decided maybe its not a fuel issue and started checking ignition, especially since I replace the rotor and distcap about 2 days before. I took one of the spark plug wires put a piece of wire in it and check for spark against groud while car was being started, I either got no spark or a very faint yellow spark. Next I tried the same thing but this time with the spark plug attached and touching ground, nothing at all that way....
Checked all fuses they all look good, altough I don't know if I have a relay or something I don't know about. Also my 100 amp fuseable link, coming off the positive side of the battery looks good although it seems to be stuck and I can't get it out to test.
What gives? I am thinking maybe a bad rotor or distcap but that doesn't explain the pre-existing cold start problem.... How can I check the ignition coil on a 93 galant, its built into the distributor... also have seen posts about the cam position sensor or ecu board... car is too old to just throw parts and dollars at....
Help my daughter wants her car back....
Shaun
IGN 20A, FP/INJ 20A, PCM/IGN 10A
Does this sound like your problem? Have you solved it?
P.S. The battery is brand new so it's not an old batery.
You may also have to drain your fuel tank.
-John-
-Edit- I don't have a test light for the glow plug terminal. Maybe I should try that out.
I have let the parts places check out the battery, starter, alternator. they say they are all ok? I have cleaned the battery terminals but it does not seem to work.
The car has 120k miles=never had a problem before cranking or starting. Battery probably close to end of its life-I switched out with a newer battery from another vehicle but that did not help with the problem.
95 galant
I am begining to suspect the crank sensor and would like to know if it can be tested????? CAN ANYONE HELP????
I WOULD ALSO LIKE TO ASK FLYBABY IF YOU HAVE RESOLVED THIS PROBLEM?? :sick: :confuse:
I saw your posting from sept. 2005 and i don't have an answer for you....but i am having the exact same problem. I was wondering if you got your problem fixed..and if you did ..how..and how much did it cost?
Can you please get back to me.
Thanks alot
Graham :confuse:
I have a 1994 ford prob gt.
My fuel cutout system was triggered in some mysterious way while the car was parked in my driveway and i can't get it to reset. I've push the fuel reset button (located in the trunk) in and out multiple times but with no luck. I know my battery and altinater are operating fine so this is very frustrating! I was just wondering if anyone had a possible solution to this problem. Please get back to me!
Thanks for you HELP
Graham
Parfeniuk@hotmail.com, parf0860@wlu.ca
After driving off my car for 40 minutes, I noticed that the car did not have any pickup when I accelerated up a hill, and shut it off about 10 minutes later after noticing that the car would not accelerate. I let it rest about a half hour, and it started up okay, and but after driving 3 blocks, the car completely died.
I have a new battery, but the car revs, but doesn't engage.
All the lights come on, radio/turn signal/everything else works.
Any ideas?
:sick:
Has a compression test been done?
plugs wires, distributor cap and crank sensor were okay but the other things have nothing to do with intermittent starts.
Isn't there an ignition module on this model that controls the distributor spark? What about that? It's either on the left fender or in the distributor itself, I forget.
Oh yeah - forgot - 3 or 4 vacuum hoses too. Just keep changing them just in case - must be easy to do. hee hee hee.
The most unnecessary work, oddly enough, has been done by the jeep dealership which I thought would be the most knowledgeable group and best place to take it. I will mention the ignition module to the garage that has it now.
I'll bet it is something so simple too - just gotta track it (the problem)down! AAARGH Thanks
