Visitor Agreement.
I have looked at the intake, but couldn't identify the filter.
If it's the intake manifold, that is definitely harmful to the engine.
But, seeing as how its an '05, no, there is no need to change it yet. (unless you have a habit of driving off road behind a tractor that is kicking up a big cloud of dirt.)
1997-98 Crv Shop Manual
1997-99 CR-V All Model Shop Manual
1997-2001 CR-V Service Manual
What's the difference between them?
Is there any way to get this plug wire off without ripping it out. I can touch it, but do not have the leverage needed to remove the stuck boot. It doesn't appear that there is anything capable of being removed that will allow great access. I'm assuming there must be a tool I'm missing or just some good ole tricks of the trade.
TIA,
-Inet
Some transverse V6s also required rocking the engine forward.
Beyond those extremes, it often helps to have a lift (for underneath access), and even better, the customized tool designed for the application.
When it gets this ugly, I just pay to have a pro do it.
Yep, #3. The steering shaft was in the way, lots of 7 cyl tune-ups on them. GM paid extra to R&R #3 plug until Snap-on released a slightly shorter plug socket with a hex, then cut the time.
1998 ford taurus 3.0 dohc
symptom; car will start fine and run for a while just fine(sometimes for an hour or two) and may stall at any given time without warning. after sitting for a while car will start and run again until it repeats this whole pattern again
new parts since this started;fuel pump,cooling temp sensor
if you have any ideas of what this or may be please let me know.
p.s. fuel pressure is good at pressure release valve
Ask Connor from Tire Rack
thank you
Anyone have any suggestions or know where this swich is?
I'm at a loss with no other ideas. Can't afford to take it to a dealer or tranny shop, but must have the vehicle running by end of this week. Any ideas? Anybody experience this before?
If the clutch master is determined to be functioning, then you have a bad new clutch slave or the wrong one or your clutch fork has a crack in it and is flexing instead of throwing out all the way.
I once took four new slaves out of the box to get one to work. It happens.
http://www.edmunds.com/townhall/chat/townhallchat.html
6-7pm PT/9-10pm ET. Drop by for live chat with other members. Hope you can join us!
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
Anyway, if you plug the slave master, then you just pump it up and use the plug itself as the bleed screw. The plug screws into the slave master, it's not to plug the line itself.
Have you tried a gravity bleed?
I'm working with my son on his '91 Eclipse, 1.8L, manual trans, non-turbo. The darn thing just won't start. He has replaced the TPS, the ECM (it was bad), plugs, wires, throttle control relay (it tested bad), the battery, and tested many more components than have been replaced, including the IATC. The engine cranks but won't start. The distributor is putting out just over 12 volts. The fuel pump is putting fuel to the injector rails, the injectors have been cleaned and checked. The #3 plug is not sparking as strongly as the others, could this be a distributor problem? This is my son's dream car, it's becoming a nightmare. please help!
I'm still not sure I can plug the line off the master cyl. The main line to the slave uses an O-ring and is held in place using a rollpin. No threads to screw a plug into. If I had acces to my Dad's lathe, I could make a plug to fit, but that won't happen quickly.
I'm going to try and bleed it some more tonight and see what happens. I talked to 2 different Ford Service Dept's today and they both said the same thing...keep bleeding the system. Or "bring it in and we'll take a look at it." Yeah...right.
I hate the idea of buying all new parts, again. Especially the slave cyl. It took me over 6 hours to change it. And I've done this before on 3 other Explorers! I've never had a problem like this before.
Fuel filter tool.
Be careful, you can damage the clips inside the fuel line. If the clip is damaged, then NAPA carries replacement clips that go inside the coupler.
Don't get horn-swaggled into thinking that this is a $1200 job....a clutch kit (clutch disc, pressure plate, and throwout bearing can easily be had for under $200 (stock replacement), a performance unit can be obtained for $309...
www.spswebpage.com
Labor is probably less than 4 hours, so figure another $250-280 or so, plus machining the flywheel.
Could the problem be:
1. Distributor (which tested ok)
2. O2 Sensor (unfortunately a 3 wire -hard to get)
3. Ignition??????
My intuition is telling me it's something to do with timing, but the guys at my house have poo-poo'd my notion. Thanks for the help!
so you are saying fuel and spark are confirmed, but no signs of life. If compression also checks out, it almost has to be timing. Even if a sensor was bad, you would at least get SOME sign of life if spark is being put to compressed air/fuel.
fuel & spark have been verified. What is worrisome about the spark is the #3 spark plug doesn't seem to be sparking as strongly as the others. It seemed to be a bad plug, which they replaced as well as that particular plug wire.
When cranked, it sounds as though it will start, but it just doesn't fire up and run. I'll pass on compression test.
Also, interesting thing happens when I tap the break peddle when it's out of gear...the rpm drops to essentially idle speed.
Had the clutch done around 100k.
