Visitor Agreement.
If it is automatic, there is a Park/Neutral Safety Switch located on the drivers side of the transmission.
If it is a clutch, then there is a clutch switch on the clutch pedal.
kshroyer :confuse:
Hazard Flasher: Behind LH Side Of Instrument Panel
Turn Flasher: Behind Instrument Panel, On LH Side Of Steering Column Brace
All I CAN find onljne is the bosch part # B3130-81728
Thx PGP
ECM Code E040 - Open Power Steering Pressure Switch Circuit -
(Engine Control System and Service Soon messages also present)
1. Where is this switch located?
2. Under what conditions is the switch supposed to be open and closed?
3. Can the pressure be tested in some way?
A message "Cooling Fan Fault" is displayed on the Driver Information Center, even though the fan turns on at approximately 230 degrees and apparently turns normally (i.e., free and fast, no binding) and brings the temp back down to normal. Message appears simultaneous with fan activation.
Questions are:
2. Where does the signal for this message originate,
3. what input generates it, and
4. what steps can be taken to correct the faulty indication?
Many thanks for any contribution.
TIA PGP
Any info would be great...Thanks
[1] Tires fitted with 18- or 17-in. wheels are expected to experience greater tire wear than conventional tires. Tire life may be substantially less than 20,000 miles (GS 300) or 15,000 (GS 430), depending on driving conditions.
Is that true? I would have thought the bigger the tire, the more miles before it wore out as it doesn't turn as many times as a smaller tire. Confused..... :confuse:
I know zero about tires aside from the fact that I have Michelins on my car here
Thx In advance PGP
Ask Connor At the Tire Rack
Shifty the Host
RE: Saturn Post # 1345 ---usually when you don't get an answer that means nobody knows. Your problem has so many possibilities that at best someone might make a long guess.
Thanks for any help.
E320 Forum
Shifty the Host
What you may need to do CAREFULLY-- is have someone listening for the noise with the hood open when you start the car---and keep their noses and fingers outta there.
My defrost on the front works, both cold and hot, but none of the other blowers work in the front. Also, the vent in the back works, but only puts out hot air. This just started. It all worked fine before. Could this be a vaccume issue? If so, how can I fix this.
As for warranty I'd drop the oil every 5K like Honda says. Unless you are towing or driving under severe conditions or under extremes of climate you really don't need synthetic oil anyway.
The crystal ball is in the shop, something about the mindreader module not working and we don't know this information.
It's a fuel injected engine. They don't have a choke, automatic or otherwise.
"With regard to mufflers and backpressure, it is conceivable that your check engine light will come on if you change the muffler. Anything (i.e. backpressure) that changes the residence time of the exhaust gases on the catalytic converter can trigger a sensor."
Increased exhaust backpressure can reduce manifold vacuum, which in turn can skew the MAP sensor signal. A simple vacuum gauge can pick out a restrictive muffler.
Idle speed is controlled by the ECU through the Idle Air Controller which allows some air past the closed throttle plate.
