Visitor Agreement.
1. How do I disable the daytime running lights?
2. On the top row of buttons on the overhead console the left one is an "ON/OFF" switch. What does it do? Nothing in the handbook.
-luvmyGT
Back to the tensioners if you don't mind. I was going through paper work from the purcahse of the Cavalier, and interestingly I now find out that just before I purchased the car, it had a new tensioner put in. Now I am TOTALLY baffled. This means that in the course of a year, 5 tensioners have been put in...4 by one mechanic and one by another and its in need of another now. I'm wondering now if I should call GM as apparently theres something VERY wrong....I am sure 2 mechanics couldn't of fouled up this many times. Any ideas? Any suggestions? As you stated, it is a cast part, but one that keeps going kaput...I'm a woman, have NO idea what's under that hood, but I do know this isn't normal at all....at this rate I could be replacing tensioners at the rate of once a month. Please respond, I'm at my wits end. (Other post now the door locks are broken too....talk about Fed up)....thanks...
I'm thinking, if not, have them do it with a written warranty on parts and labor.
Thanks in advance.
I'm following the Haynes guide for 1984-1988's and also an online service (alldatadiy.com). Everything has been disconnected according to the books, but something on the intake side is still apparently attached. When I pump the hoist I can see the exhaust side seperating slightly, but the intake side stays firm. :mad:
The books recommend leaving both manifolds attached when removing the head ... any opinions if that's easier?
Any advice, I'd appreciate.
Now I am off to figure out what those codes mean.
Does anyone know what the codes 7 and 8 are?
Thank
It seems that the engines keep more momentum, then air.
http://www.teamdelsol.com/technical/techstuff/vtec/
Anyway, there are various types of VTEC out there, but all relate to varying the camshaft profile to get the "best of all worlds" in everyday driving.
VTEC is not a Honda invention. Simpler versions were introduced in regular passenger cars by Alfa Romeo in about 1980 but more for emissions than performance.
I have a 1993 Saturn SL1. The transmission jerks going into second. When you sit idling there seems to be a fairly strong vibration holding the steering wheel and if you hold your foot on the brake and put it in reverse as it shifts you can see the motor rock and holding your foot on the brake as it's in reverse it makes a heavy clicking sound almost as if the fan is knocking on something. It's that fast and consistent of a sound. Once you put it in drive and accelerate forward after jerking into 2nd and drive a little ways it goes away. When you slow down and stop you can hear it and up until you cut it off you can hear it. If you start the car and just sit it doesn't do it. Drives fine except the jerk in 2nd. It has 139000 miles on it. Can anyone help?
Any possible solutions out there?
It is the engine, mainly the exhaust system, cooling down and contracting. The steel then pops, snap, and creaks as it cools down.
I'm surprised you have never heard this in one of your cars.
You need to get this fixed. The noise 'almost as if the fan is knocking on something' probably is the fan actually KNOCKING ON SOMETHING!
Because of the broken mount, the motor is moving farther than it is designed to move, and probably hitting the shroud around the fan. No good.
Does anyone know where the connectors for the shift control solenoid valves are located? All of the connectors behind my battery have corrossion all over them....could this be it? :confuse:
looks like a piece of metal that was screwed inside to the back of the
lighter loosened. I have taken the two screws out from the bottom of the
colored dashboard plastic near the cup holders. What else do I need to do
to remove the plastic area?
Thanks in advance
or
Fuel Pressure Regulator. It's on the fuel rail. Remove the vacumn line, when you get it started and it's idleing. If any fuel comes out of the regulator, it needs replaced.
or
Fuel filter needs changed - a load of dirty gas has plugged it up.
Get a pressure gauge on the fuel system. There is a schrader fitting on the fuel rail. The dealership should know how to deal with this problem.
What does it mean when a vehicle doesn't like to back up an inclined driveway - the engine revs but the transmission just slips and doesn't really make any progress. Going forwards it doesn't have this problem to nearly a large of extent.
New transmission? Low on fluid? $25? $2500?
The vehicle in question is a 1999 Jeep Cherokee.
thank you
Ford is only one of numerous carmakers who've made the switch to composite intakes. BMW, Mercedes-Benz, Volkswagen, General Motors, Chrysler and others have been replacing metal with composite intakes for almost a decade. Today thermoplastics, essentially nylon 6/6 and nylon, have a 35% share of global air intake manifold applications, with aluminum accounting for almost all of the rest. Broken down by region, plastics have the highest share in Europe (50%), the smallest in Asia (less than 5%) and around 40% in North America.
As with any emerging technology, some engineering and application problems have been encountered.
Thermplastics typically weigh in at about 30% less than the metal parts they replace and weight reduction is necessary, especially for those such as yourself who claim that they "LOVE and must drive a HUGE car". Hmmm.......
Can it be reset? Help! I can't leave the car anywhere until this is fixed ... frove 40 miles back home to where the work was done, and they're "thinkin' on it" ...
If you mean you have blue smoke coming out one side of a dual exhaust system, that's most often worn piston rings or, under conditions of high vacuum (engine coasting in gear), work valve guides or seals.
So clean your PCV valve thoroughly and if that doesn't help, do a wet/dry compression test or better yet a cylinder leakdown test.
It's an easy engine to rebuild or even just "freshen up" with new rings if the cylinders aren't egg-shaped.
When trying to start the starter is clicking
