Visitor Agreement.
Sounds like either an idler pulley bearing (not such a big deal) or a loose belt.
How much of a job is it to change out the shock/strut assembly? I've seen it listed on line as just a replacement shock, or a strut assembly. Looking for any "got you's" on doing the job. I have a set of coil spring compressors and will order the replacement shocks once I scope the job. (Might as well change both out at the same time).
Any tips/references sincerely appreciated.
I've noticed in their catalog that they offer something to fix "saggy rear suspension" on particular models. Never really paid much attention to it since it doesn't apply to mine, so I don't know the details.
Mounts, axles, CV joints are all good and the engine does not move or shift around. Going into Drive also does it, but not nearly as bad.
The engine idle is fine and it shift good one you get it into gear, with no slipping.
This is the TH425 and I have not been able to find anything at all about it on the net.
Please help
who's to know?
seems like more and more people are sensitive to poor mileage with the cost of fuel... maybe there's a specialist that does ONLY this sort of root cause work.
if not, i imagine there would be a business there, but people wouldn't be too interested in paying much for the analysis. don't know how much is possible through an OBD-ii reader alone.
But the question really is, IF it was a head gasket, why replace the engine unless daughter just ran the engine regardless of all kinds of noises, alarm bells, overheating, etc that blown head gaskets tend to signal.
Blown head gaskets are no strangers to the Dodge Neon. So here's what I'd do.
Determine for sure the head gasket is bad.
Pull the head and examine the engine internally. Unless a rod is knocking, chances are you can machine the head, change the oil, flush the coolant, slap on a new gasket and have a car again.
The used engine routine isn't all that great an option in this particular case because these engines are prone to head gasket failure. So, if you have a 1995 used engine, what have you got here?
More like $1,000 for a 1995 Neon, maybe $1,500 for a mint one from a dealer.
http://www.car-part.com/cgi-bin/search.cgi
The windshield wipers on our '93 Ford Tempo go on at random intervals, turning the rear left turn signal on and causing the front left headlight to dim (we got pulled over for this last night). Is this a wiring problem that can easily be fixed? We're well aware that this car is . . . not up to regular standards. There seems to be many electrical problems with the car, including its inability to lock or roll down the windows.
I can't find (a) where do I put this hook/bar/screw thing and (b) where can I buy one?
And, how do you know the switch is the problem? Your motor may have quit. If you tear into it, pull the connector to the motor. There should be only 2 wires. Put a volt meter across these wires at the connector. Push the window button for up. (With key 'on' of course.) There should be 12volts there. Push the window button for down. There should be a -12volts there. (In any case the voltage should reverse for up and down.) If you get these reverse 12volts, the switch and wiring are fine. And the motor is dead. If you don't get these voltages, the problem is in the switch or wiring.
I've never done this, but I've heard a local mechanic desribe it on the radio... a web search might really help you out.
Good luck,
-Mathias
I'd expect a round dent in the front bumper if much pressure is applied to the tree!
I think I'd put blocks in front of all 4 wheels and torque a little or put on emergency brakes and try a little torque, brakes and park.
I wouldn't worry about denting the bumper.
BTW, today I was driving somewhere with my wife, but in separate cars.. so at the light, I had to ease up until I touched her bumper... which she didn't notice. Then started to push. Just a little. She did notice that.
It was hilarious, trust me.
No idea too dumb to try,
-Mathias.
Honda Odyssey Problems and Solution Forum
MrShiftright
I took it to get it smogged and the tech said that the CO levels are too high and it might not pass smog and that the reading was 2.75% when it should be at the limit of 0.82%
Any suggestions to get it to pass smog?
