Visitor Agreement.
I have a 94 Honda Accord.. back brake shoes currently micrometer to .063", a mechanic here says they are sufficient to pass a safety for re-sale..but I am a little concerned .. also the LR brake cable is jammed, the 2 rear control arm bushings are weather worn and cracked with some play, there is a leak in the exhaust ring near the fuel tank, the upper right ball joint has play in it that can be wiggled by hand, and there is a small chip in the windshield on the driver's side, 2 marker lights are also burned out...
1. would you consider this vehicle safe for resale in this condition
2. what is this thickness of new factory brake shoe linings .. to me .063 doesn't seem to be very much.. what would be the expected life of these brakes (.063) at feeway speeds daily?
3. How much does it matter if there is play in 1 ball joint?
What would you consider this vehicle be worth on resale as is?? fixed?
More importantly ..Would you drive this vehicle as described?
If you're not a car dealer, it doesn't matter how safe the car is-you'll be selling it 'As-Is'
2. I don't know how thick they start out, but 7 or 8 mm is plenty of pad, 4-5 is getting thin and 2-3 is replacement time.
3. Depends on how much play there is, but it's not safe to drive a car with excesse play.
4. For sale value-buzz on over to Real World Trade In Values and ask a very helpful guy named Terry (rroyce10)
5. I wouldn't drive it if I could help it.
Oh no,, my childrens lives are at risk,,, please take my $425 and fix it!!! BUt after he finished and I parked the car I noticed a leak on my garage floor? Is it oil? Is it antifreeze? I called them and they said that they had no idea. That week as I drove my car was shaking! Shaking with the accelaration!! Is this a conscience? I returned the next week and he said it was my drive shaft and he could fix it then for $190. Okay .. but what about the leak? He said it was antifreeze and hed needed 2 days to repair it? He just faxed me the estimate.. $3500! What?
New hydrolic lifer/machine shop cylinder head/gasket manifold /gasket valve cover rocker/valley end clam??? the list goes on.. Is this possible. I would love ANY ADVICE!
Jackie
Autoride...... any idea where I can get a set of rear air shocks (part #
22187160) for less than what the dealer wants for them???
A good used set wouldn't be out of the question either....... probably best
for a Yukon with 70,000 miles on the clock.....
Jeff B In Maine
http://img202.imageshack.us/my.php?image=strangefuelinjector3rw.jpg
Buy a factory service manual and replace/repair little things yourself. You have enough sense to get on line and find this site then you should have enough sense to repair little things AND be able to troubleshoot problems with the help of a factory manual. Good Luck, CapnRon
I have posted this message in Maintenance & Repair forums, as well, but thought that maybe LeSabre experts might have some thoughts on my car's problems.
I'm a frequent poster on Edmunds, but have never had one as crazy as this. My '97 LeSabre's check engine light came on a few days ago. The car ran well enough with it on for a few days. The light even went off briefly. However, this morning, the light had returned, and the car refused to shift out of first gear. Additionally, the input to the pedal did not directly correlate with the motor's reaction. Strangest was my fuel gauge, which now randomly meanders between 1/2 tank and empty and settles for awhile before wandering again (I have a little bit less than a half tank remaining). I took it to a local auto parts store where they ran the trouble codes. TPS was listed as one of the codes, and so I replaced it. The car now idles well enough, but still refuses to shift out of first, and the TPS trouble code refuses to be erased when clearing codes with the OBD II. The clearing of the codes appears to have settled my idle, and replacing the TPS has made my pedal input better correlate with the motor's reaction. Additionally, the fuel gauge problem appears to have righted itself, but the car still won't shift out of first.
My friend suspects the problem lies in my Electronic Control Module, but he admits he doesn't know GMs all that well. I have the following questions:
- Does anyone else think this is the likely culprit?
- Would a repair shop be able to use their Snap-On Diagnostics to better pinpoint the problem?
- Is there any sort of traceable relay that might be fouled between the computer and the transmission?
- How likely is it that the problem resides in the transmission (I had it flushed a little more than a year ago)?
I appreciate any thoughts on what's ailing my car. Thanks.
A good indy shop might have the electronics to do the job, but in some cases, IMHO, you are better off at the dealer since they have the vehicle specific tools and software, and access to the GM tech lines, so they have a better chance of geting to the root cause. Might even be cheaper to have them diagnose, if they can do it in much less time.
The reason i asked because i got rear ended yesterday by some idiot tail gater. I was at a stop at a red light and the car probably was going 35 and slowed down too late and hit my rear bumper. My truck seemed to move a little but not alot. Im concerned about the potential damage/strain that this may have caused on my tranny and other internal components regarding the performance of my new truck. Im really devastated as of right now but was hoping to get some quick opinions from here. I will get the bumper replaced. It just has a big dent on it but i dont think it will fall off anytime soon.
Any suggestions?
Don't ask how I did it- it can be done- after 20+ years driving, I did it!
Thank you for your quickest responses.
Have a great day!
Thank you again and have a great day!
I checked a couple of fuses, but have not yet checked the GEM fuses.. Any suggestions?
Joe.
I read that it could be the vacuum leak at the line that has a 90 degree fitting into the intake manifold, but this is not accessible because of the aluminum intake runner that overhangs it. I can't even see under there. The car runs very good, and has improved with all the stuff I did. It recently got 30 mpg on a highway trip. It is rated at 27 hwy.
The day the light went out was after changing the vac tube and ran it 100 miles on the highway with injector cleaner in it. It came on the next day. Still the same code.
I heard that O2 sensor replacement may not fix, or if it does, it doesn't last.
Should I quit worrying about the CEL due the car running good?
I can not emphasize enough the relationship between one sensor and any other sensor in the car causing CEL. My car ran fairly well but progressively worse for 2 1/2 years till it deteriorated to very bad . I found the culprit and changed MAf but code for O2 was the only one remaining in memory.
Now running like a top without replacing O2 sensor and clearing all codes!
Firm beleiver in clearing al the codes
Good Luck
PGP
Yes you have a four forward speed automatic and you should be able to go from 0-60 in about 11 seconds.
I think you do have a vacuum controlled shifting mechanism so yeah, a vacuum leak might hold you in a lower gear.
But check the tachometer readings, that'll tell you.
Today I tried starting the car and it didn’t want to turn over it had a hesitation with some noise and finally started. I have a 2003 Saturn Vue. Any help would be appreciated.
http://www.benzworld.org/forums/forums/forum-view.asp?fid=10
PGP
I am contemplating whether or not to buy my friends 94 camaro 2 door coupe. It is in good physical condition but it has 130,000 miles and eats up oil. Is this a bad decision? And how many miles does a camaro usually reach if taken good care of?
I have a problem with my fuel gauge. When it gets below 1/2 a tank it goes crazy. It will show low and the chime will go off, then in a couple of blocks it will show a full tank. Then back down and so on. I think the sending unit is bad and I can replace it, but for over 200 bucks I would like a second opinion. As long as it has over half a tank it is fine.
Frank
Camaros are cheap to fix but always need fixing when they get old. It's not the sturdiest piece to come out of Detroit and the miles are about enough for the life of the car.
As you probably know, these usually are inside the fuel tank, which on many cars has to be dropped to get to it.
Ask if the $200 get a new sender and fuel pump. The fuel pump is probably also inside the tank. If you are paying for the labor to drop the tank, I would put a new fuel pump in at the same time.
On some units, the sender and pump are one replacement unit, so they will be replace together anyway. But ask before having it done.
Thanks for the reply.
Frank
If you are talking about a BMX used on weekend jaunts through the park ... let's say 20 years?
For an automatic Corolla driven by Aunt Millie to the store and church .... 50k miles?
I sometimes follow an SUV down the mountain on which I live and I know his brakes will be shot very soon and he'll wonder why.
