This one is specific for your car
http://www.benzworld.org/forums/forums/forum-view.asp?fid=10
Is this Deja Vu or have we had this conversation before ?
Good Luck
PGP
I am a member in the S class forum and have gotten tons of Benz specific help there
I would look at the hoses to see if they have dried out or are loose and are allowing air to leak into the intake.
Funny though, usually the complaint on the six is that it won't idle down when it warms up, not the other way around.
I just bought a new Honda Element, and the inside of the tailgate is plastic. I bought some really heavy duty indoor/outdoor carpet, and I want to cut a piece to glue to the inside of the tailgate to serve as both a tailgate protector as well to give a little padding when sitting on the tailgate.
I was curious if anyone had any reccomendation as to what brand/type of glue would hold best, could easily be removed down the road, but would not do any damage to the plastic on the inside of the tailgate? I have tried several types 2-sided tape, and none of them will stick to the plastic on the tailgate.
3M 77 comes to mind for good holding power, but I don't have any experience removing it after it's cured.
If you want something permanent you can always try to glue down some thin, very hard rubber matting that they use in restaurant kitchens for people to walk on.
I had also thought about trying to apply spray on truck bedliner to the tailgate, but I am not sure how that stuff adheres to plastic. Before I do anything permanent, I am going to get a quote on replacing the inner tailgate panel as a worst case scenario.
i *WOULD NOT* do what you are planning to do.
ok - but it's not me - its you: i'd consider getting the velcro tape available in rolls at Home Depot or Lowes, applying one side (probably the cloth side) to the plastic parts, and the other to the underside of the indoor/outdoor carpet.
You might think about using some self tapping screws. I used some to put some pad eye straps (aka D rings) in my minivan and they have held fine in the plastic for 7 years now.
When you decide to trade or need to trash the carpet, you can just put the screws back in the holes and they wouldn't be too noticeable.
You are going to waste your money putting higher octane gasoline in an engine where 87 octane is recommended.
http://auto.howstuffworks.com/question257.htm
and specifically the patents called out in same (at the bottom).
where does one find a $20 oxygen sensor?
The colored foam on the filler cap is normal condensation, don't worry about it. What you DON'T ever want to see is that kind of colored foam under a valve cover or in the oil itself.
Water vapor is a natural by-product of the combustion of gasoline...if you run out the chemical formula for the combustion process, you will see H20 in the string in fairly large amounts, proportional to the volume of gasoline burned.
We have a 1992 Ford Taurus with the 3.0 engine, with 80,000 miles. The fuel pump quits out of the blue, for no apparent reason, causing the engine to quit. It can, and does quit at any time, with no notice, which means that we can't use the car. It usually starts back up after sitting for a few minutes, but I don't know if my playing around with the wires to the inertia switch in the trunk has anything to do with it starting again or not. I have changed the switch, but that did not solve the problem. When the pump runs, it seems normal, with no unusual sounds or anything. I kind of think that there is a bad ground somewhere, and that the power to the pump is getting interrupted. Is there a fuel pump relay somewhere that I can check? Any other ideas? Maybe someone out there has experienced this same problem and can help me out with this. Thanks, Motownguy.
Don't forget that the pump requires gasoline to keep it cool and people that keep there gas tanks above half way mark have the best luck with making there pumps last. Of course no part lasts forever and yours has certainly lasted you very well.
I'd refill with car cold and sitting in a usual spot. Recheck in 1 week cold in same spot. Sometimes air bubbles work out after a drain of coolant. For my car after refill when thermostat is open hot, they say to rev motor to 2500 rpm 5 times for short period. That would be what happens when yo make a fast takeoff. That probably has burped air out of system.
But you might take the top motor cover off and do a flashlight look on intake manifold edges and all around hoses for leak.
Gunk inside cap.
That happens because of moisture in oil condensing on the cooler filler cap. Clean it and watch.
Go to Auto Zone website and you can look up the part and use their part locator and it will tell you where the part is located.
Otherwise I still suggest refilled to a reproducible cold fill mark and watching for a week.
Remove the cover on the motor, the beauty cover, and look all around the intake to lower metal intake contact and all around the throttle body contact with the intake to see tracks of antifreeze having seeped and dried.
Also check very carefully with a mirror under the water pump inside the pulley for the same. If the water pump hasn't been replaced, that would be a prime suspect first.
If you've not owned the car since new, you can read the date stamp on the plastic intake manifold to see if it has already been replaced.
Which antifreeze have you used in it? DexCool. Has it or the other been changed every two years? DexCool left in too long has been suspected as a problem.
Re filler cap: I can go to my 98 leSabre right now and see signs of moisture on my filler at 135000 miles. I wouldn't get excited unless I cleaned it an it reappeared and if I see a slight milk chocolate/milky look start in oil.
280
First the technician said it could be the lifters/valves, but later, on the invoice, he wrote "retorqued cam caps." I understand this is not the same thing, but the engine is STILL making that noise.
I feel like maybe I'm being a little picky, but that noise doesn't sound right to my husband or me. There was also a reference to a bulletin number in the invoice. Is this indicative of some type of recall -- in other words, has this been a common problem with the MPVs? We've had so many issues already with this car that I wouldn't be surprised -- we've been really disappointed with the amount of time this two-year-old car has already spent at the shop due to various issues.
Anyway, any advice you could give would be appreciated. Thanks!
Thanks in advance
In my opinion, this is enough water to be defined as 'flood car'. Flood cars should be salvaged. In other words, your insurance company should total the car out and pay you for it.
If you keep it, expect to see these kinds of electrical problems for the life of the car.
So, what I am wondering is if a low battery can cause some of the erratic electrical problems I've been having since the van went in the water (see message #2596 for reference).
I'm still waiting on the Insurance Adjuster. With all the rain & flooding we had in Hawaii the last six weeks, I think they are pretty busy. Still hoping the van doesn't get totaled but it may be unavoidable. The interior is really starting to smell so I know there is mold/mildew growing in places we couldn't reach. It's just a bummer.....
Please help someone
Marces
ANY ONE Take a shot at this? Thanks
Who's right and who's wrong here. The warranty runs out May 28th and then I'm stuck.
HELP!!!!!
The Sandman :confuse:
