But hey, if it gives you peace of mind, by all means, do it.
2) yes, there is an air leak, almost certainly around the door seal to the car, potentially the leading edge of the door either near the top or straight in front. a little air leak, one that generally doesn't let rain in.
if ever I get my shirts together, I will take a little ultrasonic receiver I built over 30 years ago and use it to find the location (s) of my own one in the exploder. my receiver is similar to the occasionally-found ultrasonic stethoscope that some shops have. you might also use a piece of garden hose or fuel hose held up to your ear to scan the edge of the door frame and find this leak.
if you can drive with your phone !! screech!! //swerve\\ on, you can do this. best to do it on a back road with decent paving and little traffic.
The accessories to improve mileage and extend engine life board is full of gizmos to marvel over.
I've searched all over and I'm overwhelmed with "how it works" information. We know HOW it works - we just have to show the class WHY it works.
Maximum Boost: Designing, Testing, and Installing Turbocharger Systems by Corky Bell
Forced Induction Performance Tuning A Practical Guide to Supercharging and Turbocharging by A. Graham Bell
Supercharged! Design, Testing and Installation of Supercharger Systems by Corky Bell
Auto Math Handbook: Calculations, Formulas, Equations and Theory for Automotive Enthusiasts by John Lawlor
Supercharging, Turbocharging, & Nitrous Oxide Performance Handbook (Powerpro) by Earl Davis, Diane Davis
The Step-By-Step Guide to Engine Blueprinting: Practical Methods for Racing and Rebuilding by Rick Voegelin
http://www.amazon.com/exec/obidos/tg/detail/-/0837601606/qid=1084- 556003/sr=8-1/ref=pd_ka_1/102-7274801-8235347?v=glance&s=book- s&n=507846
Thanks again.
Good Luck.
As for safety issues, I don't think there's anything to worry about unless you start hearing very loud whining noises and you totally ignore that for a considerable amount of time until you hear horrendous, ear-shattering noises and for some reason decide you still want to keep driving until the whole gearset explodes through the casing.
But given that you sound like a reasonable person, the worst thing that I could think of is a rather annoying noise and perhaps some gear-play clunking. There should be plenty of warning before anything so drastic as a lock-up.
But ultimately you either have to get rid of the dealer or the car before your warranty runs out, or start consulting a local attorney about your state's Lemon Laws.
could be spark, could be a vacuum leak or a gooped EGR valve or a PVC valve issue, could be a loose or mildly oxidized/corroded electrical connection, could be lots of things.
any additional information would help. thousands of sensor readings, computer diddles, and environmental variables are calculated each second on a modern engine system, and it's not as simple as good window/broken window to determine what could be a budding problem.
I bet they are using a spraycan of paint to mark the existing locations of the axle to the springs, and thus repeating the hose-up with a new diff and housing every time.
not really sure how you'd insure you positively align the drivetrain with the frame if you start from scratch, I suspect it's by measurement from a feature of the frame. they ought to do the fourth warranty replacement by that method, and maybe even replace the complete rear axle assembly instead of just the diff.
If so, is there any particular brand that I should consider?
I live in the Washington, DC area.
Help!
Turboshadow
cracked, loose, or broken exhaust manifolds will have a high-pitched whistle or cracking sound like no muffler and the treble turned way up.
your old friend the oil leak would indicate if you had a leak involving oil galleries.
you might be able to sniff exhaust in the radiator, also, on a cracked manifold or head using an exhaust gas analyzer probe held near the radiator neck.
if none of these appear present, you are probably OK, but as we all know, life is hard and then you die. buying a used car always carries a bit of risk. nobody ever sells a perfect car unless they're desperate for money.
Turboshadow
Sure, I am being over cautious; I could probably afford the Corolla, and probably the job situation will become much better, but I am an engineer and by nature don't rely on probablies.
The Alero would fill a need, fill it cheaply, and while no paragon of reliabilty, fill it for as long as is needed.
Turboshadow
Good luck on the car thing.
Us propellorheads in the world do think a lot differently from most. I used to work at a place that was 95% salespeople and it was tough! I ended up telling the sales manager of one group, "If I had that sort of power over time and space, I wouldn't be working here," when he had promised something that was impossible to a custumer. He didn't get it.
Good luck to your son! Engineering is a noble profession and we need all we can get. Very few young people are interested in the feild anymore, which is a real pity.
Turboshadow
Architecural/mechanical engineering is a close second, so we'll see what happens.
pessimist: the glass is half empty
engineer: you need a smaller glass
Civil engineers build targets.
That was always my favorite since I worked on missile launchers and explosive missile components.
Turboshadow
He understands the whole thing well, as do I, and his info level, from a confident speaking voice, went over the teacher's head - mission accomplished!
Thanks again, vcheng.
I'm not so sure I agree with that comment. If the point is to really understand something, why should it ever be "less technical"? I mean, you don't shorten equations because people don't understand the long version!
I think the teacher intended a less technical breakdown and got many examples from students where a teeter totter or a scale was used - that's a little to simple! This was a danged senior physics (honors) class! I'd hoped that the class (teacher included) had set their sights to a higher standard.
http://www.edmunds.com/townhall/chat/townhallchat.html
6-7pm PT/9-10pm ET. Drop by for live chat with other members. Hope you can join us!
kirstie_h
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
