Got a Quick, Technical Question?
17980828485114
  • dcw41dcw41 Member Posts: 5
    2002 tracker 4 cyl, auto, 25k mi. My lights don't work using the switch, but the daytime running lights and high beams work.
    I've replaced fuses, relays and even the multi function switch.
    Down to my last dollar. Please help.
    I think you should spend your last dollars on some electrical schematics. It's probably a different fuse or relay than you've been looking at.
  • sportyfssportyfs Member Posts: 3
    hi, i just had my 2001 honda accord V6 sedan Automatic serviced for 30K this past weekend, it currently has 40000 miles on it. dealer changed my transmission, brake fluid and antifreeze; however, the very next day, all of my gauges dropped and stopped (went below zero) working for a Second, then everything came back up. this happened while i was driving about 30 miles/hour in the city. then this morning it happened again, really scared me, felt like the airplane is about to crase in the movies.......... i asked the dealer, they said my battory needs to be replaced since it's 7 years old............ is it true ?? thank you so much for any inputs.
    You should have the battery tested to see what condition it's in. If it's causing a big load on the alternator while charging then it can manifest itself in strange ways like your seeing. Seven years is a long time for most batteries.
    thank you so much for your advice. i'll take my car to the shop and get it tested this weekend.
  • suvshopper4suvshopper4 Member Posts: 1,110
    Also could maybe be a loose ground cable.
  • tripp5tripp5 Member Posts: 4
    I have a 2004 Passat Diesel 4 cyl.
    The alternator pulley disintegrated and I'm trying to replace it. It has a 10 pt star type mount surrounded by a spline. I have bought a replacement alternator at a salvage yard which already has a new pulley attatched. I have not been able to get the pulley off of the alternator, so I thought it might be easier to just change out the alternator along with mounted pulley. Unfortunately I cannot get the old alternator off. It's mounted with two bolts, however the lower bolt is too long to clear the metal fan housing which appears to come off the shaft of the water pump. Does anyone know the secret of getting the lower mounting bolt off. What do I need to take off to get it to release the alternator. Or for that matter; how can I get the pulley off?
    Also where can I get a good service manual; one of the parts stores seem to carry them.
    You could call these people:
    http://alldatadiy.com
    and see if they have info on the Passat Diesel. I didn't see it in their lineup but....
    Not an easy car to find a manual for, since there are so few of them around.
    You might check with the dealer for the manual, also try your question in the Carspace "answers" forum.
    http://answers.edmunds.com/default.aspx
  • ernies1ernies1 Member Posts: 4
    2001 nissan pathfinder
    2.0
    auto
    98k
    the fuse for the cigar lighter keeps blowing using the proper fuse when i plug any type charging unit into it (ig:gps or phone chargers) also the other acessory plugs located in the rear and the center counsel does not work at all can anyone help thank you
    You've got a dead short somewhere. Do all the auxiliary plugs run off the same fuse? If so, I'd start at the fuse box and look at those connections and even behind the box. Then I'd pull each auxiliary plug out and see if any wires have shorted or burned.
  • bhill88bhill88 Member Posts: 1
    2004 Honda Civic LX 5sp manual 65k miles
    Problem: Instrument panel light behind fan speed switch is out. Can average skill mechanic replace this light ? How to get at light bulb ?
    try plugging in the accessory BEFORE turning the key! it's possible you are not aligning the accessory with the recepticle, and it's shorting upon insertion.
    hey thanks for all the in put i will try everything that was suggested thanks again to all
    i'm sorry, this is all new to me, what is it mean by accessory ? and "aligning accessory " ? thanks
  • foadafoada Member Posts: 1
    Year/Make/Model: 1995 Nissan Pathfinder SE
    Type & Size of Engine: 3.0l V6
    Transmission Type: Auto
    Mileage: 79k
    Problem: Recently I purchased this vehicle and its got a strange lights issue that could be something simple. At time when I hit bumps the lights, floor and ceiling, flicker with the bumps I hit.
    The more I push the gas the more it stays on/flickers...but also it will stop flickering if I crack open the moon roof, and start again when I closed it, and even rarely it will still flicker/turn on/off till I play with the sunroof or the gas, and then its back to only staying off when I have the sunroof open...
    Its the Open Door light that comes on the dash, and it flickers along with the lights...I've tried playing with all the sensors and for some reason none of them seem to effect what happens besides the sunroof...and I dont think that has a sensor?
    Any help is greatly appreciated.
  • peter337peter337 Member Posts: 1
    I have a 9hanks 5 T Bird V 6 the ignition has no tention I can start the car but I can't shut it off. I can take the key out when it is running. I have to pull the distrib cap wire to shut it off and i have to pull the positive off the battery so the dash lights won't drain the battery. Need Help and an Idea of what it might cost to fix???? :
  • 0patience0patience Member Posts: 1,712
    My first thought would be that the ignition switch is bad.
    It is located at the lower section of the steering column.
    A lot of times, the bolts that hold it will get loose and allow it to move.
    an accessory is something that didn't come with the vehicle. ;)
    typically though, we think of cell-phone chargers, ipod power supplies, invertors that convert 12volts DC to 115volts AC to run a laptop or DVD player, a high-intensity search light, a portable pump to pump up tires or inflatable toys for the pool, etc as accessories which might plug into the "cigarette lighter".
    once upon a time, people smoked (a lot). now, less. ;) but seriously, back when the cig. lighter was made of a thin metal coil. when you pushed it in, it would literally connect the + and - sides of the battery together through the coil. This would cause local heating of the coil. When it reached a high temp, it popped out, and you'd light your cigarette, cigar or other smokes with it.
    then we got savvy and deemed smoking hazardous to our health. the cig lighter became or was re-engineered and relabled the accessory socket, and it was fused with the ability to handle much much lower currents (because what we plugged into it wouldn't need as much power as a coil on a cigarette lighter). also, manufacturers made the thing powered only with the car's ignition turned on, so it wasn't possible to run the battery down if you left something plugged in with the car off.
    smart.
    i guess way back when, people liked to light up their smokes with the engine off.
    anyway:
    so then, today: when you have a cell-phone charger or other device with a male plug, it has two conductors on the end of it (one on the outside of the plug, and one which is a probe at the tip of it). both are spring loaded to accomodate slightly differing sizes of female recepticles and maintain a good contact when you drive and go over bumps.
    sounds good anyway. :blush:
    continuing: generally people blow the fuse of the accessory outlet or receptacle (female part which is a part of the dash) because they insert the accessory plug (male which is part of the accessory cord) initially at an angle (this is called mis-alignment) and the tip of the plug shorts the conductors on the inside of the female receptacle.
    generally the mis-alignment is temporary since as the plug is forced further in, the plug and recepticle mechanically become more and more in alignment. so the risky period of insertion is the beginning of the act.
    :shades:
    logically then, it follows that since the accessory plug receives no power until the ignition of the vehicle is actually turned on, if you plug in your accessory device before starting the car, you will not short out the receptacle, you will not cause a lot of current to flow in the wiring of the recepticle, and thus you will not blow it's low-rating fuse which protects it (generally from an accessory that develops an internal short).
    lets say the accessory outlet wasn't fused. when the accessory developed a short, the weakest part of the electrical link, perhaps the socket, but perhaps the wiring to it would start to heat, melt and could start a fire, or just plain create a open circuit, and it would be very problematic to report that to you insurance, or find the location of the burned wiring. so the fuse protects you from yourself and your accessory.
    i hope this clarifys the situation.
  • richardsonrichardson Member Posts: 92
    Very informative. Really enjoyable read.
  • victor_gallaghvictor_gallagh Member Posts: 7
    My 2002 Lincoln Navigator, 5.4 L V8, with 105000+ miles, suddenly lit the "Check Engine Light. I read the codes and "P0171 & P0174" are listed, basicly both banks are running lean. Now I don't have a clue as to where to look to solve these codes. Any help would be great!
  • ramrod2ramrod2 Member Posts: 6
    While reading about new 2009 models there was a statement that MDS had extended speed limits to 70 mph. Does this mean that my 2006 with MDS stops working above 65 mph as the trucks booklet says?
    That's what I've tried to say in the past in a lot fewer words. I guess I'm not as patient as you are!
    maybe you could tell I had a little fun with it. thanks for the kudos.
    i think lots of people end up blowing fuses for the accessories circuit because they plug and unplug stuff with the ignition on. there's just too much room to angle the plug improperly when inserting it into the recepticle and short the socket with the tip of the accessory plug.
    there, that's better.
    And sometimes coins find their way into the socket. Especially if children are in the area.
    But don't use your finger to dig around in the socket checking for a lost dime. Get a flashlight and shine it in there.
  • oppopp Member Posts: 2
    2005 Kia Amanti 3.5 6cyl, auto 59K
    How flexable is the 60K timing belt change, any problem going to around 63K.
    The interval to change it is the "recommended" interval.
    So going 3k extra miles may not hurt it.
    But then again, it could go any time.
  • eboyeboy Member Posts: 1
    1999 Ford Taurus SE wagon, V6 3.0 OHC, auto, 55k mileage,
    Good solid,versatile & comfortable car.
    Power steering started leaking, then lost power too. my amigo put in new ps pump unit and do have good power but when engine is turned off the ps fluid is pressured out the top of pump cap area ? drove car for 2or3 short errands, whine detected on 2nd day and had to add alittle fluid. obvious leaked fluid on top of cap. no pressure valve that I can see on new ps pump ?? any suggestions or diagnosis would be greatly appreciated.
    eboy ATx
    1. Is it being overfilled and spilling out the top when it heats up?
    2. More likely, there's air in the lines causing the fluid foam up and spill out the top of the pump. That would also explain the "whining" and the fact that you had to add fluid after some use.
    I don't know about a 99 3.0L, but the Taurus 3.8 I had back in the 80's had extremely long lines which took some time to bleed the air out after replacing them. Could be similiar with a pump replacement.
    If heat kills batteries, why are they always konking out in the dead of winter? :sick:
    Well cold weather doesn't kill them or even harm them, it just decreases their efficiency. So in very cold weather they are trying their little hearts out, but they're doing push-ups with one arm.
    Excessive heat, like say the brilliant people who put the battery right next to the turbo outlet (I will NOT mention Saab at this point)--excessive heat probably (never cut one open) warps the plates inside, and shorts them out PERMANENTLY.
    So, IMO, cold is just putting them gently to sleep but excessive heat is a hammer to their heads.
    Good analogy shifty. My cold cranking amps are low on my Buick (per dealership). Dealership highly recommended a new one at $170 installed. Like you noted, getting it started is like doing push-ups with one arm. It struggles a tad... but turns over. The low end battery in it now isn't even 2 years old. I'm guessing if this battery makes it thru the winter it will be okay till the following winter. I'm cheap... but wouldn't want to be stranded in no mans land either. :(
  • tbpdptitbpdpti Member Posts: 1
    Hey all, I have a 95 Toyota Corolla. It is in great shape, but it is starting to show its age. Earlier this summer, I was changing the drum brakes in the back, and I noticed that the hydraulic fluid was leaking from the right rear strut housing.
    Now that it is colder, I have noticed that the car's back right hand side is acting up. The car has no excessive swaying, and the shock dampening still works fine, so it appears as though the strut is still working fine. What is happening is that the car, when passing over any type of bump at all, will make a very loud thump as it (the bump) passes under the back right tire. It almost seems as though the shock is not working, and that the whole maybe fifth of the weight of the car is just dropping. This is not the case, however, as the typical "bounce" is still there. My best guess is that some of the hydraulic fluid has leaked, and that the remaining amount has been having problems with freezing. To give an idea, if the temp is around 15F or less, then this happens. Above this temp, this doesn't happen.
    Also, I (gently) went over a bump both forwards and backwards, and the same thing has happened.
    Is this correct: The strut needs replacement? If so, what is a typical cost for replacement? Thanks a bunch.
    ~~Dan N.
    Sears or your local AutoZone probably have a 5 or 10 year battery with higher crank amps for $80-100 (probably less) and AutoZone for example will install it free.
    $170 Geesh
    I went over to AutoZone late yesterday. They have the Duralast batteries which are suppose to be pretty good. The sales guy there said he couldn't install the battery because it would mean taking out the fuse box and removing a metal bar, something they aren't allowed to do. So, I'll probably pull it out and exchange them in the next day or so.
  • imidazol97imidazol97 Member Posts: 27,728
    Check the EverMaXX battery at Walmart also. I got one with 950 cca or more (that car's gone right now so I can't check), and it was relatively cheap and has lasted almost 7 years doing great. This is for my leSabre. I think It has an 8 year guarantee.
    Neighbor changed his Gran Prix battery and had to work to get it out. I don't think he had to remove a fuse box!
    Struts are basically a shock, with a spring wrapped around it.
    The spring will always provide the bounce, they rarely go bad if ever.
    The shock has hydraulic fluid inside, and it's purpose is to dampen (or slow) the movement. In the first stage of going bad, the fluid leaks out and it fails to work as a shock any more and doesn't slow any up and down movement. In the second stage of going bad, the shock mechanically fails and brakes. In the case of a car with a strut that is a huge problem, since the strut is actually one of the suspension pieces keeping the wheel in place.
    If you know it has leaked fluid, replace it. If it was mine with a bad rear strut, I'd replace all four and be sure to get it aligned since the struts are part of the suspension and effect alignment. They're probably original and 18 years old now,
    and all the struts have been over the same number of bumps. This is assuming that the car doesn't have any other major mechanical problems that is forcing you to have to swap it out.
    Almost all reasonably decent tire or repair shops do this type of work. I've even done it myself a number of times on vehicles over the years. It's just a little dangerous when you are taking the strut apart, you need to have the right tool to hold the spring compression. Care not taken, you'll have some spring or metal parts flying across the garage and if it hits a body part, toast.
  • okko1okko1 Member Posts: 327
    batteries with a low chemical charge in cold weather will freeze and damage the battery internally. this can usually be seen if the battery appears to have frost on it.
    The strut is blown. You'll need a pair of them for the rear.
    If there are clearance problems on a battery upgrade one could consider the Optima line of batteries.
    'batteries with a low chemical charge in cold weather will freeze and damage the battery internally. this can usually be seen if the battery appears to have frost on it. '
    Ha, Reminds me of trip many many years ago to VT in the winter. Guy that traveled with us had an issues with the little wire on cable and had to run with either lights or heater on, not nice . In the AM when his car wouldn't start (at around -26F) we opened the hood and covers on battery were propped up on incn or 2 stalagmites (or is that stalagtites sp chk). We had to take it out and let it thaw inside the house on the heater vents for a few hours till everything melted back down into battery.
  • bor4bor4 Member Posts: 1
    I have a problem with my Jetta. I have oil coming out of my blowoff and it just started smoking. I can smell the oil burning. I haven't replaced my thermastat yet but I don't know if that has anything to do with it. Anybody have any ideas.
    Oh I think those valves have a diaphragm don't they? Those will blow out at high boost. I think aftermarket ones correct this problem.
  • joem5joem5 Member Posts: 201
    I adhered Stoneguard plastic protection on fog lights and I can't get it off.I just peeled back the paper and pressed it on.
    However, the halogen light made a round spot on Stoneguard from heat.
    How can I get it off, and replace it with new lens protector?
    Thanks, :sick:
  • phtaberphtaber Member Posts: 3
    i had taking the car for inspection and when they did the emissions it show up not ready they told me to take the car for a ride about 100 miles and come back , it did the same thing what could it be ? help please
  • qbrozenqbrozen Member Posts: 33,800
    need more info.
    What exactly did it fail for? (meaning, which emissions and how far off were they)
    could be a vacuum leak, could be O2 sensor(s), could be cat converter, could be ... well, alot of things.
    that is all it says when you try to test it they dont get any reading i have taking it to 2 differnt places with the same results
    They don't get any reading???
    Ummmm... uhhhh... ahhhh...
    Ok, how about this ... when the car is running, can you FEEL the exhaust coming out the tailpipe? Is the car REALLY loud?
    the car runs great not load good gas milage planty of power no other problems
    Is the Check Engine Light on?
    Or has it been on in the last few hundred miles?
    bolivar is alluding to the fact that your emissions system is in a "not ready" state, because perhaps, the cel was on and was reset by a scanner. thus, the system needs to sample various parameters again to determine if the emissions system is in a ready state. it's possible the system is not ready because you recently replaced your battery. -or- the system is detecting a pending problem.
    this document describes generically why a vehicle may not be ready and a generic "drive cycle" to put the vehicle in a ready state if the cel is not on:
    http://www.nysdmv.com/broch/c114.pdf
