Visitor Agreement.
1990 Oldsmobile CS. Replacing crankshaft sensor. Removed bolt, but sensor will not come out, how can I remove it?
'90 Olds Cutlass Supreme,6 cyl,FWD,3.1 (auto) engine - 95,000k
Removed the bolt from crankshaft sensor and attempted to pull sensor free, but would only spin in place and not move. Applying more pressure resulted in plastic casing cracking at which point I stopped. How do I get the old (probably original) sensor out?
1. On cars after '96, mine being a 99 Blazer w/ a 4.3l v6 engine, can you just turn on the electric and run a scan tool? I think I read somewhere that the information concerning problems is stored on the computer in the car.
2. If I can't do that, and if the information is stored on the computer, can I take the computer out of the car to a garage and find out that way?
Year/Make/Model: (1999 Chevy Trialblazer)
Engine: (V6 4.3l)
Transmission: (Auto)
Miledge: (dont know)
Problem: (Engine turns over but wont start. Misfires while trying to start.)
OtherInfo: (I'm replaceing the disributor cap, rotor, spark plugs, and plug wires.)
Check with some of the nationwide/local parts stores. Many loan and rent equipment. I would be disappointed if one didn't loan out an Actron level scanner for do-it-yourselfers to use at home. In this area PepBoys (had an inch-pounds torque wrench for me), Autozone, Advance Auto, and local NAPA and other name brand stores didn't compete by being do-it-yourself friendly. Local Advanced was going to hand me their scanner to do my own scan since one of the counter people wasn't available.
If worse comes to worse, you could buy a scanner and return it. But I would hesitate to do that myself.
lnexpensive Pocket Scanner
This sounds like an overly rich fuel mixture being instigated perhaps by a faulty sensor that fails to tell the computer that the engine has warmed up and doesn't need further enrichment on a cold start.
You'd best not drive the vehicle anymore (not that it sounds like it's much fun) as you will destroy the catalytic converter with all this raw fuel.
thank you for your help
Often with codes people make the assumption that the computer is telling you which component is defective. This is simply not true. Computers cannot do that yet. All they can tell you is which "circuit" or loop or system is unhappy.
A parts house, Autozone, OReilly, PepBoys, etc could easily have parts books that will show what applications work for you.
Or, all of the above businesses have online parts lookup that you can get to via your computer. Look up the part for your car and write down their part number for it. Change the year on the car to the year you are asking about, and look up that part. If it is the same part number, then you are probably ok to use a salvage part from the other years.
The thing is, I hear a scraping sound on the brakes when I brake very hard, but I don't see or feel any fresh scraping on the rotors. It sounds like it's coming from the front and it's only when I'm driving forward. Can it be anything else other than the brakes eating the rotors?
I am going to keep an eye on them and if the grooves get worse, I'm having a brake job done.
Someone said there used to be a source for the lights, but they no longer carried the bulbs to solder in yourself...
If you do take it apart, let us know what bulbs you found...
It seems to only happen when I brake hard on hills. I don't normally brake like this, but I'm checking through a list of things on this car that I might need to have fixed and brakes is about two things down on the list (most of the problems aren't serious, but I like to have things a certain way on my cars). It's possible that it's the rear brakes and I know that rear brakes on GM cars can make this noise if the pads are new or the drums were recently turned. I'm not sure if the drums were turned on this car, though, but it's very likely, and I'm 100% positive it has new rear pads. My Geo made this same noise right after having a 4 wheel brake job and it was much, much worse than this.
lnexpensive Pocket Scanner"
Cool, not only did I find that interesting, I found other things that look like fun, too.
Steering wheel, Steering wheel and trim, Control switch, Neutral, W/o leather Right $14...
There are switches left and right an switches without leather, gray, neutral and oak. Under steering wheel
at
gmpartsdirect.com
rockauto.com didn't seem to have this part...
Without consulting my service manual, those switch replacements may require removing the airbag and that means properly disabling them in a certain manner to avoid injury due to sudden, unexpected detonation (would they ever be expectedly detonated?).
:sick:
Question....In the top of the airbox, above the air filter there is a foam? filter that is permanent according to GM. Can this "permanent" filter be removed for better gas mileage?
It all sounds kinda dicey to me. If anyone has ever done this project I would sure appreciate hearing from you. Thanks in advance, Bill
I drove the car for 4 hours today in the desert and got lots of chances to press on the brakes while going up and down the mountains. I didn't notice any pulling at all today.
THANKS
"Recycling yards"
So, my question is what causes this and what could be the fix for it?
I found a replacement stop lamp switch online for about $35, but I just don't know what is involved to replace it. If it is easy, that may be a relatively cheap starting point.
Or I could take it to the dealer where they would probably want to replace everything.
Yeah, the heater and everything else is off, except the radio. It seems that only the ignition cylinder lock gets hot, the rest of the steering column doesn't seem to be affected, but it could be if I drive longer. Other parts could be getting hot and I just don't notice it. The instrument panel seems to put out a bit heat even with the lights off, also, but not really noticeable. I'm glad the AC is extra cold in my car.
The radio will get hot sometimes on it's own, especially when it's been in the sun, but the CDs get way hotter. It could be because they're closed in real tight in that player. My CDROM drive on my computer is built in a similar fashion and CDs get pretty hot in there, too.
It isn't tough to replace, just tough to get to it. I had to pretty much have my legs straight up over the seatback and my head down in the footwell, flashlight in teeth. Good luck.
EDIT: ok... i just went back and reread. When you originally said "snaps" up, I guess I misinterpreted that. HOWEVER, I also believe the switch may be ok now that I've reread. It sounds to me like you are saying the pedal is not coming back up far enough to disengage the switch.
It sounds like either the pedal is no longer coming all the way back up (spring?) or the switch has somehow gotten too close to the arm. For the simplest solution, I would get under there and take a look at what is going on. You may just need to readjust the position of the switch (I can't remember if it can be adjusted, but I'm sure something could be done).
Sure makes me feel good to know that the local 'yota dealer missed this twice and then told us to keep driving the car!
Thanks to everyone here for their advice.
As for the CDs, someone suggested that I keep them in a cooler until ready to use. That might not be a bad idea. I don't know if the key or the radio heating up are related.
Thanks for any information.
Hi ~ there is a small electrically operated 'vacuum switch' about the size of a pingpong ball mounted on the passenger-side firewall. It has two 1/4" vacuum hoses attached. One routes behind the carb and connects to the Throttle Diaphram; The other is just hanging loose and I cannot discover where it connects. I'd like to know where it connects; or at very least, what purpose it serves so I can deduce where it connects.
THANK YOU
I am bringing my 2005 Sienna mini-van in for 30,000 mile service. I'm noticing the dealer schedule includes many things the manufacturer schedule does not. I know I've read this is a big scam that dealerships do to make extra money.
Here are some of the items:
Automatic Transmission Flush and Fill. The manual just says check this fluid.
Differential Service-manual says for 4WD and manual trransmissions
Brake Fluid Change-manual says INSPECT brake lines and hoses
How often do these fluids really need to be replaced if the manual just says to inspect them. This will add $300 to the service.
