Visitor Agreement.
For reliability, or is one for the fuel gauge and the other for the low fuel indicator light?
I have a 2005 chevy colorado and recently I have an issue that when i drive, the doors will automatically lock on there own and the door chime will sound. Also, the word "doors" displays on the dic. It only happens when I am in drive and actually driving at speed. It does not happen when I am stopped or if the truck is in park. It started out as an intermitten problem but now it is occuring almost constantly as I am driving. I am to the point where I have disconnected my drivers speaker because the constant chiming is driving me absolutely insane.
I have replaced the driver side door/window switch/module and it did not fix the problem. I have also disconnected the battery cables overnite and that did not fix the problem either.
Any ideas on what the cause is? I am at my wits end with this..thanks in advance!
Jason
I had the same problem with my 1995 Voyager with the sliding doors. It was not latching tight enough, so the auto locks and warnings kept going on and off. Like driving a pinball machine. The fix was to adjust the door so it closed tighter, and the connection stayed solid.
2nd owner, no problems in recent years
2 fuel pumps in several months, 2nd one after 22 miles
car won't start
What to fix?
4,800 miles on recent tranny flush & oil change.
As soon as the car left the shop & started up a slight incline, the transmission shuddered.
Two different techs advise that since the computer was reset, due to battery disconnent, the car will have to be driven several hundred miles before it "relearns" our driving habits.
Is this is true & how long will it take before the shuddering stops?
were you ever able to figure out what the problem was with your truck? Mine is doing the same thing.
tyvm, Kendall
Any help is greatly appreciated.
Did you try and get a refund from the local mechanic who said BCM and fixed nothing?
This motor might not have much life left in it. Or, it might run for years more. A 'shade tree mechanic' help would be to use higher weight motor oil in the engine, attempting to maintain a higher oil pressure.
And electrical problems are tough in many cases to find.
If the vehicle has ANY after market electrical items on it, this is what I would first suspect. Non-stock radio. After market security system. A remote start system. Even a trailer wiring package. Anything at all where someone has cut into the vehicle wiring.
You have a current drain. Something is shorting to ground, or something has failed and draws current when it should not. An amp meter that can handle several amps is needed. Pull the battery cable off and put the amp meter in the circuit, in series. You should see a significant current draw, with everything turned off and shut down. Doors closed and if there is an underhood light, shut it down. Then, start pulling fuses. If nothing changes, put the fuse back. Then pull another. When the current draw stops, you now at least know the general circuit that has the drain. After that it gets even tougher. You probably will need a factory service manual with the wiring schemetics to see what items are on that circuit and then start disconnecting them until you find the problem.
I owned a 1995 Deville that would kill a battery in 2 days. Dealer did find the problem. They replaced the AM/FM/CD radio. The battery killing stopped.
Agreed - need more info.
On my own, I have upgraded my gas to 89 and have switched gas stations. This car always was given Sunoco 89 octane. I'm now trying B.P.
Any ideas on what this pinging could be?
This is probably the return line? If the high pressure line, it would instantly blow all the fluid out.
On the second picture, is that possibly a 'crimp' that once made enough contact to hold this thing together, with a nice, snug O ring?
Looks like a connection that justifies all the bad things I've heard about VW's.
Trying to 'rig' something, could you get a jip-tie around that collar and hold it on?
The second part of my question has to do with the mileage. After this latest replacement I noticed that the gas mileage has dropped considerably from about 21 mph to about 15 mph. Is there something in the replacing of timing belts that can so alter the mphs?
Thanks in advance.
so it's very possible that people will use pulley A and belt B when they are not strictly compatible (for instance, some belts have oval lugs to grip the pulley gears and some have square lugs--also the belts vary in width). So the parts suppliers may only be listing one belt, and it may not actually be the right one for the engine you have. It'll fit, and it'll work, but it's not right.
It's a rather complicated table of modifications and if you can't find it elsewhere, it is listed in the Mazda 2000 section when you subscribe to www.alldatadiy.com, which is a good deal for $26 bucks a year, as it allows you access to just about any repair job instructions and diagrams for your truck.
Any idea why the miles per gallon would suddenly drop so much after the repair?
Plus the next two days after the repair I had a heck of a time starting it in the morning. But that's probably because it got really cold (8 degrees F). Maybe related to a head gasket leak it has too,
To answer your questions, on those two really cold days immediately after the repair it had a really hard time starting, but on the days above freezing since it starts normally. It runs good. No smoke except at startup (maybe just steam coming out the tailpipe) The power's average.
I took it back to the mechanic today who was a bit bent out of shape that I was questioning his work. But what the hey, I can't afford to pay an extra $100 - $125 a month on gas for nothing.
Anyway he undid a bolt holding the distributor and rotated it a bit. He said it was too far advanced when I first brought it in and that he had set it correctly but now would set it back to where it was before. He did it with the engine off and without using any instruments, seemed to be making a guess as to where it was before since I didn't see any alignment marks. After that on the way home I noticed that it's running a little rougher.
We seem to have bad luck as far as auto mechanics are concerned.
The carburetors on those Mazda 2000s are devils to fix. That might be part of the problem.
But you would typically see other symptoms. At least I would think so.
Well let's get a timing light on it and at least ascertain that the IGNITION timing is okay. Then we can worry about the ENGINE timing.
Also I'd check to see that the choke is operating correctly---closed when cold, fully open when warm.
And of course, that old bugaboo---vacuum leaks.
That's a joke... but, seriously, you'd think that's voodoo these days. These old school methods are very quickly disappearing from auto shops.
this is an old truck.
i think I still have my timing light somewhere in the Shiftright Museum attic.
It has a few probs but I got it for a good price.
It has a rattle in the driver side front suspension of rough roads but handles well. Looks like it had some work done in an attempt to resolve the issue . It has new tires, ball joints, sway bar, sway bar links sway bar bushings and struts, springs look new too. I can feel a bit of play in the lateral link so I will be replacing it to see if it fixes the problem.
My big concern it the transmission. Around town I get 18-19 mpg and the tranny shifts well and feels strong.
The first time I took it on the highway I was surprised to find that the engine revs at 5000 rpm at 100 km/hr, so it seems it is not shifting to 4th gear. When I back off the throttle, the revs drop to idle but I don't feel any engine braking, if I press the hold button I can suddenly feel a gear change. If I release the hold button and accelerate the tach suddenly jumps to about 3500 rpm before I feel acceleration again. I hope this is a sensor issue and not a failing transmission.
The check engine light is not on and the hold indicator is not flashing. There are no codes shown by my code reader either.
I was told that there are a few things that can cause the computer to inhibit the transmission from upshifting to 4th gear:
1. Throttle position sensor and Throttle closed switch ON
2. Range sensor thinks you are not in D
3. Coolant (<60C) or ATF temp (<20C) sensors (4th gear inhibition signal) 4. Brake switch on 5. Cruise control input into the TCM Have any other Mazda Millenia S owners experienced this problem, if so what was the fix.
I learned the hard way once to always take a used car up to highway speeds before buying. Some things just don't show up around town.
P.S. What kind of a car has an ampmeter it in? I haven't seen a car with an ampmeter since the mid-1970's. Or, are you taking a measurement with an outside ampmeter? If this is what is happening, just after starting, with a somewhat discharged battery, an alternator 'might' be throwing as much as 60 amps to recharge the battery. It should start to taper down to much less, unless the battery is highly discharged. Or you are running a lot of power sucking accessories on the car.
At least it has new struts, sway bar, sway bar links, sway bar bushings, ball joints and new tires.
I think I have the transmission problem figured out.
Turns out what I thought was a 2 to 3 shift was the torque converter locking up.
This it the Problem: Transmission shifts 1st to 2nd but no 3rd or 4th.
Solenoids test ok, They click when 12 volts is applied.
Solenoid A has 12 volts until shift to second, then it goes low.
Solenoid B has 12 volts until supposed to shift to 3rd, then it goes low. Transmission stays in second.
This proves the TCM is asking for 3rd gear, so TCM is ok.
The transmission manual shows this symptom as solenoid B always on or stuck on in the valve body. For a reasonable price, I can either rebuild or replace the valve body and without taking the transmission out of the car, so that's a bonus. I think I'll come out ok in the end.
I'll look closer next time though.
