Visitor Agreement.
That's an attempt at humor, guys...
1. Put away the tools.
2. Close the hood.
3. Have an adult beverage and think about something else.
Dave
B. Can I mix ordinary tap water with antifreeze?
Yes, tap water is commonly used for mixing with antifreeze, however, deionized water or distilled water is preferred. Do not use water softened with salts to mix with antifreeze.
Steve, Hos"
I'd leave the kids somewhere else and
just kick back myself...
1) Depths are the same between the plugs so nothing is stuck there
2) Hex nut not visible hence rusted Hex nut of Plug
3) Now the bad news, using a small wire I was able to rotate the rusted hex nut !, which only implies that the rust has severed it the from the main body, which means the plug cannot be removed as the metal from the threaded portion is attached to the hex nut portion. The only way is if the torque has reduced I may be able to hold the tip of the plug to remove the plug by rotating the tip oif the plug and hope the ceramic can take tht torque.
It looks like a bad situation, looks like no choice but "heads off"
Photos are located at
http://ca.pg.photos.yahoo.com/ph/faziz_2000/album?.dir=/7ba0&- .src=ph&.tok=phq9s9BBzcoQe7Co
Earlier Link was not working
http://ca.pg.photos.yahoo.com/ph/faziz_2000/my_photos
My feeling is that it will not, this the reason that it was rounded off to begin with - looks like a musclebound monkey with an air ratchet fired that sucker up good...
I don't think they did though....
Go to Sears, buy a 21mm for your torque wrench setup, try it on the parking lot - if it doesn't fit, walk back inside and get the correct one - just keep your recp't!
I think the shade tree mechanic finally got our car fixed (dealership didn't have a clue).
He changed the Fuel Pump Module and put a new fuel filter on the car. Lo and behold, that wasn't the problem....it died again 3 times to the car lot. The mechanic was in the back so we waited for him, well we left the car running in idle until he got with us. Well, the car started sputtering and the RPM gage started jumping erratically and idling very rough. When he finally got to us, the car was still doing it. He automatically went straight to the Mass Air Flow (whatever you call it) and unplugged something on it and the car completely died. He said if it was right the car would stay running with it off. So he ordered the part over the weekend and took it in on Mon.
After tinkering with the car, he let it idle and nothing popped a code. So, he finally got the idea to change the year on the scanner back to a year or 2 older and wa-la, it had popped 2 codes....the mapping sensor, or something to that name and something else...well he fixed them and the car hasn't messed up yet. We really haven't had a chance to drive it all day, due to work, but so far, no dying..yyyeeeaaahhhh.
So, in other words, change the year back on the scanner and it may just pop something up. :-)
Anyway, thanks for all the info guys, if it happens again, I will gladly come back here for your advice.
Have you checked the fluids to make sure they aren't crossing paths (i.e., a bad head gasket)?
I would say that the sudden and extreme change in oil consumption is either going to be a blown head gasket or a leak.
But something leaking at the rate of one quart per 800 miles should be showing a gawd-awful mess under the car or on the chassis underneath. That's a pretty good leak.
That's a quick way to tell if it's going out the tailpipe visibily.
Have you tried topping it off again and see if it goes down again?
Are you experienced at changing the oil on a regular basis? The only reason I say this is because, and I do apologize if you already knew this, but its not an uncommon mistake for beginners: a new oil filter does need to fill up with oil from the pan. So if you drain the oil and remove the old filter. When you put on the new filter and fill the oil, it will show full at first. But after a bit of running time, the level will go down because now the filter is "wet" and that's where the oil is "hiding."
Park to Reverse. The van moves really slow and increasing the engine rpm has no effect. Then it might not do it again for days. The dealer says they want it to do it for them if I bring it in. I turned down purchasing a 2000 Venture for this same problem (we noticed it on test drive). My sister-in-law also has an 02 Silhouette and says that her van does this once in a while also. Any ideas on the cause?
I appreciate any ideas you have. Thanks,
Lou
ps: I have not been able to find the cables for a sedan either. If I found them, can they be adapted to work for the wagon?
My wife has a 2002 Elantra GLS, auto that she drives to work. It is time to get the timing belt replaced, so I called the dealer for a quote. I asked about replacing the timing belt and waterpump (I assumed that the waterpump was belt driven by the timing belt). He tells me that the waterpump is not driven by the timing belt, so it would not need to be replaced as part of the timing belt service. My wife and I work opposite schedules, so I haven't been able to actually look under the hood to verify this. The only other vehicles that I have owned long enough to need to change the timing belt were Hondas - and I know that the timing belt did drive the waterpump on those. Does anyone know if the Hyundai service advisor is correct in saying that the timing belt does not drive the waterpump on a 2002 Elantra?
CRESSIDA BRAKE CABLES -- I'm quite surprised that the dealer can't get these parts for you. Have you tried more than one dealer?
You could also probably have the cables made up, depending on whether or not only the inner core was broken or rusted. If you need the whole "sheath" as well, then you have to keep trying through dealers, or, worst possible case, get one from a wrecker and have the inner cable replaced.
hard to say more about it without seeing how it is constructed on that car.
in the message box. Attempting to select different range using pushbuttons has no effect. The 4WD will work in any select range if the message box is not lit, which is whenever it feels like it. Unpredictable at best. How do I troubleshoot? Local parts store (we read codes) said they would not be able to pull code for this.
I have a 2000 Honda Accord Coupe V6.
Any suggestions?
In this case, it does say something useful.
It says what every mechanic will probably tell you, take it to a dealer or qualified repair shop.
Is it possible to query the codes for anything more definitive?
No.
Does anyone have experience with this problem?
Yes, alot of experience.
I really hate to pay the $79 "diagnosis" fee that the dealer charges to even look at a customer's car.
Then find a reputable qualified independant shop that is experienced in airbag repair.
Bottom line, there is nothing that you can check or do to repair the airbag system. Any attempt at trying to mess with the system will probably either get you hurt or do more damage to the system.
1). When I accellerated moderately to heavy---about three seconds into that a light that said "!brake" came on and chimed three times. What does that mean? The salesman thought it might be related to the traction control.
2). After driving (especially highway speeds) when I began to brake to slow to a stop, a medium-pitched whine developed (it almost sounded like an air raid siren or an old time fire engine!) It was fairly loud and noticeable in the cabin. That noise continued until I came to a complete stop. I did not notice it standing still, under accelleration, or at at speed.
Any ideas? None of these things were present in othe other 97 Riv. I drove.
Dan
Anyway, as far as what damage might have occured, I'm not sure, personally. Maybe someone else does. I have heard its bad to have too much oil. The rough running obviously means it was doing something to adversely affect the vehicle.
Mechanical damage from overfilling on a high mileage engine is going to be extremely difficult to prove. I've seen gasket failure and catalytic damage but never an actual mechanical breakdown. But I suppose anything is possible. It's just not one of those 2+2=4 kind of things.
Thanks and sorry for the long reply. I found a local BMW service specialist that did it for $800 out the door. $600 for the unit the rest mainly in labor.
With a 60k maintanence that takes this years repair and maint total to $2k. Sure hope the the end for a while...
