Visitor Agreement.
I put new plugs, distributor cap,fuel filter,fuel pump, spark plugs wires, ignition coil.
fuel pressure on intake is 45 psi. anybody can help me...
this vehicle is a 2002 Odyssey one year out from a total front-end replacement due to crash. any feedback on whether these estimates sound even ballpark-correct or not would be most appreciated.
questions we should ask, etc also welcomed. need to act quickly since car is in shop awaiting go-ahead. we are new in town and took it to a chain tire store for repairs.
car has about 38K miles on it, fyi, and has been driving mountain roads (paved) for about a year
thanks for any help, here or to cav1898@yahoo.com.
Ranger pickups are well know for this - I have one. I just 'ride' the brakes LIGHTLY for about 100 feet when I first drive off after an overnight set. This will heat up the drums, driving off water, and remove the rust.
Other than this (which is 'just living with it'), you might have the brakes shoes replaced and a different brand might give you better service.
P.S. If your car has disk rear brakes, forget everything above. The calipers are probably needing greasing. They are not sliding on the 'pins' and releaseing after application. A good mechanic can fix this problem, and it doesn't require replacing the pad or machining the rotors.
Of course, this is based upon you not actually needing a brake job, on either drum or disk brakes.
If the idler pulleys and seals were replaced 10,000 miles ago, I'd recommend pump and timing belt replacement only. The belt isn't that expensive, it's probably contaminated with coolant, and it has to be removed to access the water pump.
Does any one have suggestions? Is that indeed the temperature light? Any input would be greatly appreciated. Thanks!
The rear only has 75w140 specified for it ONLY for severe duty and towing and only the Mopar synthetic.
Do NOT use 75w140 for the front differential under any circumstances. Always use the correct oil that is in your owner's manual, NOT what the dealer tells you.
Front Axle SAE 75W-90 Multipurpose Type, GL-5 Gear Lubricant. 1.66 L (3.5 pts.)
Rear Axle SAE 75W-90 Multipurpose Type, GL-5 Gear Lubricant. Limited-Slip rear axles require Mopar limited slip additive. Four (4) ounceed ( 118 mL) should be added to the gear lubricant.
Rear Axle - 9 1/4 Inch 2.32 L (4.9 pts.) with traction lock add 118 ml (4 oz) of friction modifier
Rear Axle - 8 1/4 Inch 2.1 L (4.4 pts.) with traction lock add 118 ml (4 oz) of friction modifier
Rear Axle for Trailer Towing For all trailer towing or heavy duty applications, replace the factory fill rear axle fluid with Mopar Synthetic Gear Lubricant SAE 75W-140.
The reason I popped in so quickly is that I JUST (last week) read the manual on that!
I'm glad you can count on your friendly neighborhood dealer to steer you in the wrong direction. Now enters in the problem. I have all ready swapped out the fluids with Amsoil 75W140, rear and unfortunately the front. With this being a full synthetic is there a major problem with it being in the front? If yes, is this something that will be fine for a week (approx 300 miles) or do I need to swap it back before it's driven?
Since it was their recommendation that led you to replace the oil, then they should be the ones to take care of it.
If they tell you it is ok, then ask them to put it in writing that they recommended the 75w140 in both differentials and should there be a problem, that Chrysler, not the dealer will not void the warranty.
While this may seem a little overboard, I have seen warranties be denied for alot less than using oil other than what is specified.
As far as driving it for a week or so, I cannot see any problem with it. If it were out of warranty, I would say leave it until you feel comfortable changing it. But if it is under warranty, then you will want to get it changed out.
Do you know if your Rear differential is limited slip?
If it is, then you need to add the limited slip differential additive or you will have problem with the rear differential.
Some times I also hear a loud squeaky noise coming from the engine compartment. It appears that the belt(s) is making the noise. The noise is more pronounced on rainy/cloudy days. The minivan has after-market belts. Can this be the reason for the noise?
The Nissan dealer says I should replace the PS pump along with Steering rack. Total cost: $1600.
I had a gas station mechanic shop inspect the van.
They recommend that I replace all three after-market belts (PS, A/C and water pump) along with PS fluid flush. The dealer told me that my PS belt is tight.
I am confused. Any feedback or comments would be appreciated. Thanks.
If the steering rack isn't leaking and the pump isn't showing signs of wear (which you can check with the belt off to some extent), I would touch those right now.
And don't have a gas station do the work unless you really have a well-known and thoroughly trained person in there.
If that doesn't work, you could work through the ignition system then. Also you should check the last time you replaced the fuel filter.
After over 2 months of easy starting, this happened again last weekend, after the alarm was accidentally set off by the keyless remote. Is it possible that the alarm could be "locking" the ignition? I silenced the alarm properly, but still could not turn the key for over 30 minutes.
Other related chat discussions I've seen involve not being able to remove the key from the vehicle - but this has never been my problem.
Any help is appreciated!
Two technical questions on this Toyota-
I keep getting a check engine light...been thru the whole ball of wax...new plugs...new ($$$$)catalytic converters (thats right- 2) and now the dealership has turned the light off three times for an EGR valve........does this sound like a permanent fix? Whats the EGR valve do anyway? (Emissions I'm sure)
Second question- The vehicle has 153K miles on it and the Supercharger has been serviced with new (Toyota Synthetic) oil 3 times since I bought it with 55K...I'm about ready to get that service done again...how long can a properly maintained Supercharger expect to last??? That 3000 bill for labor & parts to replace it will make this van a yard ornament once the S/c goes out!!!!
I'm not having any issues with the S/C other than the whining noise...then again maybe thats the 10 year old in the back seat......
THANKS
Having a dirty or non-working EGR valve will cause stalling, poor fuel mileage, and poor performance - cleaning the valve itself may help (versus replacing it).
The supercharger in your van isn't running radical levels of boost, so with proper maintenance (sounds like what you're doing), it should go to 175-200k or more.
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
There is one more perhaps? related thing that happened at about same time - the speedometer does not come off 0 mph until the van is going about 25-30 mph. Friend who's a service writer said good chance the IP circuit board is cracked slightly?
Anyone have any thoughts?
BTW: I did ask the dealer if they'd do something for me since this happened just a few miles after warranty expired. Answer: fat chance.
Now with my '01 Toyota, the maintenance guide does not mention changing the brake fluid.
Even more surprisingly, three various local dealerships' maintenance recommendations, usually overkill that serve the service departments' bottom lines most of all IMO, do not mention changing the brake fluid either.
Has anything about this changed in recent years, does anyone here know?
Was/is it just a VW thing?
How often, if ever, is it really necessary, under normal conditions, to change the brake fluid?
Thanks in advance.
-ss4
Brake fluid article, by Alcan.
Al's article is by far one of the best articles I've seen. Then again, I may be biased.
The article is based on facts, not opinions, so I would pay close attention to what it says.
If you are in a high humidity area, then I would shoot for every 2-3 years. Low humidity areas may be able to go a little longer, but high heat may cause other problems.
Sopman
What's the concensus on simultaneously replacing the fuel pump also? Is it worth it on saved labor charges (as the V6 is already apart?
Appreciate input. Thanks, holiday's best....ez
