Chase
ps: I'm not trying to talk down LR3 its just my humble opinion. Good Luck Disco05ers!
Power was not a problem with the Lexus it was all the things that it could not do or could not be fixed such as the 1700 rpm vibration drone.
New balls, your service!
jebLR3
Did you turn your Terrain Response knob to the snow/ice position when it happened?
Also most often the grip of the vehicle has more to do with the tires instead of the subtle differences in the 4wd design. True snow tires on icy roads make a world of difference. I know it first handed since our sports car (which used to be completely useless in the winter) on snow tires significantly out performs the X5 with all season S+M tires.
anyone else experience similar problem???
Anyway, it's a typo/error on the web site and brochure. (The web site had many, many more errors; most have been fixed.) This is why you see all those nice "specifications subject to change" disclaimers on documentation; typos & errors happen. Any LR3 SE on the lot would have been exactly the same; didn't you test drive or at least sit in one before dropping 50K?!
It has the adaptive headlights. I'm eager to see how they and the GPS work.
Mike
I have seen a few. But, they do not include the LR3
http://www.mvw.net/lr3/roadtest.php
-Mike
I have already gone through this with LRNA and am not satisfied as well. Good luck. If you get a different response please post it.
Please keep us posted on Imogen!
Just incase you didn't see my previous post my LR3 SE7 has the following: (All are LR original accessories installed by my dealer)
WARN 9.5XT Winch
Winch Compatable A Bar (super strong plastic)
Off Road Lighting Kit (attached to A Bar)
Sill Plates
Rubber Mud/Water Mats
Winch Accessory Kit
Rear Rubber Loading Tray
According to the Land Rover parts disto. for NA, they said that my car is the first in the US to have a winch installed. I have to say it was an adventure. It wasn't complicated but I'm just happy my dealership is so wonderful (Land Rover San Antonio).
First things first it looks amazing. It give the entire front an extreme rugged look. Personally I could care less I needed the functionality. The lighting package is really nice since they come with a couple hefty lamps that really light up the path. The winch is installed really solid. Its botled to the FRAME of the car not the sub frame. I strongly believe it could suspend the car in mid air with just the wire of the winch (winch max is 9500 lbs.).
I went on a trail just after getting the winch and used it to pull out a buddy in a jeep in the middle of the night in a river. With my car in about 10 in. of water (messy, cabin got nasty but clean up wasn't hard at all), I pulled him out even with water all over the winch and remote. WARN makes a really great solid porduct that is very water resistent and lasts forever.
Back to the install I ran into a problem that you need to know about if you are going to get one done on your LR3. The install manual calls for the winch to be installed to the AC blower fan relay in the fuse box. This is kind of a strange install. See typically you would install the winch directly to the battery considering they useally need some hefty amps to opperate. Its obvious why LR wants it on the relay though, they dont want you to be able to use it with the engine off and drain the battery (which is covered under warrenty). Anyway there wiring diagram had a mistake and when spliced into the blower fan relay feeds electric current back into the AC and fried it. So....after replacing my entire AC control unit (only took 2 hours to fix, COOL), they simply installed it like they do on a discovery, direct to the battery with its own relay that turns on when the remote is plugged in. So this allows for the unit to be opperated with the remote. Comes in handy if you flood your engine (yes WARN winches with opperate underwater for a single pull or more). My mechanic submited the entire work around back to LR and they said that they would look at it and might change the install procedure.
Another thing that was noticable after installing the winch was the weight of the car. Now the ride height was totally unaltered as the air suspension compensated for it and kept the car level. The car does handel a little but more "heavier", although it is still incredibly nimble when tossing it down a twisty highway.
The hardware that comes with the winch is stunning. Its holding tray/bracket is made of quarter inch steel and its heftedly bolted to the frame in multiple places; its not going anywhere. The only thing I thought was just stupid was the vinyl winch cover that came with it. I tossed that thing as soon as I saw it. Sure its functional but god its ugly. I am making a cool aluminum cover that matches the angels of the winch tray. Who knows maybe I can stamp them with the W of warn and sell them at the dealership.
Anyway this has been quite winded but its been quite a long process and its great to have my car back since it was gone at the dealership for almost a week. Atleast I got a cool loaner, Disco 04.
If you guys have any questions about any of the acces. I installed above, the winch, off roading feel free to ask. I am currently trying to find a dedicated Land Rover Forum Site to join and post pictures but until them just give me your email and I will send them.
CGP
Nah, that's the ONE thing that is NOT bigger in Texas. The rollercoasters, the guns, the car dealer lots, the supermarkets: everything is bigger, but we make up for it by our tower which is MUCH bigger than that puny little Texas tower! :-))
The road conditions were the absolute worst I have ever seen. We spent 100s of miles on sheer ice, black ice, snowdrifts. We also spent a total of 3 hours stopped in the middle of the interstate waiting for authorities to clear jack-knifed semis. We passed dozens & dozens of SUVs in the ditch and a few cars. 4X4 drivers tend to be cocky and their vehicles were the most popular type found spun out in the ditch.
All those Jeeps, RX300s, Suburbans, Escalades, Expeditions, Excursions, etc. have nothing on the LR3. The LR3 was rock steady with the Snow/Ice setting on. There was a marked difference on ice between regular 4X4 and the Snow/Ice setting. I could actually feel the LR3 tighten up with the Snow/Ice setting on. Between Memphis & Little Rock we exited several times to seek a motel with a vacancy... no luck until we pulled into Little Rock at 4:00AM Christmas eve. If you have experienced ice covered and banked exit ramps + steep, ice-covered driveways in the LR3, all of the complaints on this forum mean nothing when you have experienced the confidence and safety of the LR3s Terrain Response System. The smoothness & rock solid feel of the LR3 on the highway in the worst weather may be more important & a greater achievement by LR, for most drivers than its off-road expertise.
With our little baby sleeping snugly in the back seat, we felt comfortable and very happy with our decision to purchase the LR3.
We drove a total of 2600 miles and on the return trip to Chicago, we drove through blinding rain and fog. The soundproofing, incredible front & rear wipers, and the command seating position made the drive easy and effortless. We strapped our lap top w/DVD between the two front seats and our baby happily watched Lion King & Nemo while we carefully passed semis & SUVs on the road and in the ditch.
This was my first long road trip in 14 years. (We always fly anything over 500 miles.) After driving for hours, I never felt tired, fatigued, or bored. I feel like I could drive to California next week. We are planning a road trip to Quebec this summer to visit the LR training grounds. Can't wait.
Lexus, Mercedes, Jeep and every other 4X4 out there have a lot of catching up to meet the spectacular performance of the LR3.
A couple of small warnings... the on board computer tricked me. I was watching the range in conjunction with the fuel level. After the yellow light came on, we began to look for a safe place to get gas. We traveled more than 30 miles and the range readout was steady. Once we hit 20 miles, all of a sudden the miles scrubbed off very quickly. Before I knew it, we hit 10 miles remaining and then within 2 minutes, we were at zero. After a few more miles, we exited, stopped at the end of the ramp and as I stepped on the accelerator and turned, the LR3 shut off and we barely coasted into the gas station... so lucky.
At the urging of my child hood buddy, we decided to drive through a muddy/swampy field. Before long we got stuck in a muddy bog. I did not turn on MudnRuts + low range until we were stuck... my mistake. We called LR roadside and they sent a truck in 15 minutes to assess the situation. He refused to pull us out unless we paid him an extra $250. We told him to shove it and LR roadside never called back to check on us or report the tow trucker driver's position. We called a friend with a Chevy dually pick-up. He pulled us out. Be careful, don't depend on LR roadside to help you if you are more than 25' - 50' from a paved road.
All-in-all we love our LR3SE.
Do you have to book or reserve for LR training ground in Quebec? Could you please post some information for this?
Yes, the Terrain Response is excellent, I found the same on snow and ice, and yes, indeed lots of spun out cars but not us. As you say - it was the right decision.
I've learned already not to depend on Land Rover support: no-one could tell me what to top off the oil with (synthetic or non-synthetic). They put me through to a dealer who also did not know.
Michael
Plus the 'established' reliability and sweet comforts of luxurious Lexus brand. A sheep with a New fur is still a sheep. I had a 2003 GX470 with 36k which I sold and bought the 2005 with 270 hp. I would not buy a LR unless all the lab mice show me great reuslts in next 12-24 months. LR will show its colors within next 24 months. Btw, all of you who can wait for 6 months to get a LR3 then please wait -40-love!
Basically everything else is the same apart from minor enhancements.
That said, there are many minor & not so minor problems that do not seem to have been resolved with the Lexus.
How many GX470's have been purchased back by Lexus.
Search "vibration" on the GX470 forum.
The GX470 is more a soccer moms car and really does not compare to the LR3 capability.
Both have niggling snags & I wont fault Lexus who seem to stand by their product.
These vehicles are two different animals.
Ordered my LR3 HSE and waited 6 weeks & spec'd as I wanted it. That said so I did with the Lexus.
Another major consideration is the Lexus GX470 is not 179 qualified. Doesn't meet the weight. Oh I forgot that Lexus accidently mislabelled the GX470 weight and had to bite the bullet on that one!
If you searching "vibration" why not also search "clunk" in the Lexus forum.
Two very different vehicles that should be purchased as to what you need! If you want to compare please look objectively!
For all other times, navi screen display was bright and cripy.
1. Pirelli Scorpion Ice and Snow 255/60R18 (see: http://www.tirerack.com/tires/Compare1.jsp?startIndex=0&width- =255%2F&ratio=60&diameter=18&search=true&pagelen=- 20&pagenum=1&pagemark=1&performance=W&x=16&y=- 16 sold out for the season.)
2. Dunlop Grandtrek WT M3 235/65R18 (see: http://www.tirerack.com/tires/Compare1.jsp?startIndex=0&width- =235%2F&ratio=65&diameter=18&search=true&pagelen=- 20&pagenum=1&pagemark=1&performance=W&x=9&y=1- 0
also sold out.)
3. Hakkapeliitta SUV 255/60R18XL (see: http://www.nokiantires.com/newsite/tiresub.cfm?cid=2&sid=1 TBA: to be announced(?)--not yet available. These seem to be the only studded tires in this size and should be very good in the winter.)
Not at all - go for it.
How much does the whole kit weigh? Thanks.
There is a "Quick Reference Guide" pdf that provides an overview of many of the features and options. Not quite as detailed as the owners manual, but something to read while waiting for delivery.
http://www.landrover.com/gallery/downloads/brochures/veh_discover- y/2005_lr3_quick_reference.pdf?sReferrer=I_LANDROVERGWS_REDIRECT_- 2004
One hiccup... this morning after returning to the LR3 after a brief stop, no sound came from the radio. I tried everything I could think of... everything else was working fine (including audio from voice commands), but no sound at all from radio. I stopped and restarted with no results. Then I parked, left the ignition off for about 30 min and when I restarted, the sound returned without any problems as if it had never cut out.
I imagine there was some sort of electrical resetting that occurred... just be aware of this if it happens to you.
off popped the cheap plastic lock cover. One of the plastic tabs is broken and it wont stay on. Silly design feature and its present on all 4 door handles. I also just found out my CD player
doesnt accept CD's and won't load. Gas mileage averaging 13.3 after 1200 miles, not too happy about that. Don't experiment with lower octane regular gas because the truck will run poorly. I learned my lesson!
Ordered our 05' HSE 5 seat with everything except bluetooth & cooler box...April arrival, which is fine for us...It's not like our LX 470 will fall apart before then...
Thanks to everybody for keeping us up to date on their LR3 experiences.
2 questions.
We were told even with the 5 seat package, a 12 volt outlet will be in the cargo area as part of either the convenience package or the rear air package..True or false?
Our salesperson also states that since our service intervals are few & far between, the LR3 comes from the factory with synthetic oil...true or false? If false, we'll probably break it in for the first 2k miles or so, and then change to synthetic. Any opinions?
tia
Synthetic oil: I believe this is false but no-one asked: I asked LR and my dealer and no-one knew!
Michael ( http://www.mvw.net/lr3/roadtest.php )
I only press the button once on mine to open.
Most important for someone with no Land Rover Corp. experience: with gas pump stalls, radio/CD problems, etc., would those of you who already own delay your purchase if you had it to do over again--and would a delay help or make any difference (I could start over, order one, and get the adaptive headlights w/o the cooler--it's -5 to 25F half the year already!), or do you just have to plan on a month's worth of revisits to the dealer for initial-quality fix-its, no matter what? When you're 5 hours (in good weather) from your dealer, that amounts to some inconvenience. Any help or advice most welcome.
