Visitor Agreement.
Go Scoot
1945 Surgi Drive
Mandeville, LA. 70448
(985) 727-3143, Al Johnson
www.goscoot.com
MAP
From New Orleans I think that is 40 miles due north west across the Causeway. Apologies, I took LA to mean CA LA LA LA LAND. I have had no personal dealings with this shop, but it did make the word of mouth list on www.tdi.com. Hopefully this will aid you in research.
link title
However a cautionary note:
..."VW in their infinite wisdom has decided to install two different types of fuel filters for the A5. They are not interchangeable, and so you therefore must check the last 5 digits of your VIN. If it's 000001-814062 you need this fuel filter:
-Meyle 2-hole Fuel Filter 1K0127434A ---
If it is 814062 or later it's a dealer only item -OEM 1-hole Fuel Filter 1K0127434B --- "...
Again, the best way to determine which type of fuel filter you need is determined by your VIN, so when you order a fuel filter, make sure to include your VIN!
That aside, I do like the concept of changing just the filter element just like the oil filter design. You do not have to change the steel cartridge-saving a whole lot of resources throughout the fleet. I am surprised by the fact that just the filter element seems as costly as the old part.
The paper filter element was presumably the main cost of the filter. The absence of the steel can means that any flaws in the filter element would be visible, enabling detection of a defective filter. Quality control is enhanced.
link title
Can any of you guys comment on the likelihood of VW truly coming to market with the Sportwagon TDI (non-50 state) in summer 2008 and then with the 50-state just one year later? Seems unlikely to me.
FWIW, I'm in a non-CARB state and would FAR rather have the non-CARB version.
Once the diesel geeks buy them up it might be a different story. The bad part I see right now is a 30% fuel efficiency increase vs diesel running 20+% higher isn’t quite the payback it used to be. I’m still gonna check out the Tiguan if the AWD TDI version actually shows up. To date, VW has never offered an AWD diesel here in the states and I’m not holding my breath. But that’s the one I’ll buy if it shows.
Yes, I get into snow. It would be the ulitimate vehicle being able to go where I need to go (i'm sure it would need snow tires) AND get much better mpg than the typical AWD choices out there. Of course if it has a significant mpg penalty it wouldn't be worth it. I can just drive my truck when I'm getting into the nasty stuff which is what I always did with my previous TDI. Say XX required trips using the truck vs a Xmpg penalty for the AWD Tiguan will be the start of the math equation.
My wife REALLY wanted to stick with a 4WD vehicle... but I wanted a TDI. We compromized and got the TDI with the ESP option. Here in Vermont winters, this setup works very well.
Lets not forget that VW has 3 distinct "systems" that help improve driving in slippery conditions.
1) EDL (Electronic Differential Lock) which automatically applys brake on spinning wheel to force torque to other drive wheel.
2) ASR (Automatic Slip Regulation) This system cuts throttle if BOTH drivewheels start to lose traction.
3)ESP (Electronic Stability Control) This system combines ABS with yaw sensors and a steering-wheel-position sensor and can apply brakes on ANY ONE WHEEL. It is almost impossible to make the car go into a skid (I have tried it in snow-coverd parkinglot)
I have tried to "outsmart" these traction-enhancing systems on snowy roads. If I 'dump' the clutch, these systems immedeatly take over and only accelerate the car as traction permits. If I slam on the brakes, the ABS takes over. If I turn too sharp, the ESP corrects the skid. It is almost uncanny.
More about ESP
For your enjoyment, here is VW commercial about ESP.
Video comparing ESP to NON-ESP
Here is a writeup about ESP.
My point? - You may want to REALLY THINK about if you need 4 wheel drive vehicle. All 4WD systems add weight, complexity and reduce MPG. For me, getting up to 56 MPG far outweighs the need to have real 4WD when the other technologies will suffice.
We drive the Cascade mountain passes several times each winter, and during heavy blizzards when the super troopers decide that everyone who is not driving a 4WD or AWD has to chain up, the biggest challenge driving our Passat and Jetta equipped with studless winter tires is to weave our way uphill through the big burly SUV's that are stranded in the middle of the road because their weight and torque are too much for their "mud and snow" tires to hold traction. I don't worry about the super troopers stopping us because we haven't chained up since they are usually helping the SUV's back down and over to a shoulder.
Granted, when the snow is so deep you are pushing it with your bumper, a high SUV or 4WD truck with chains on the front tires is about the only way to go. And of course there are those folks who just really like driving on bad, bad roads. (I have to confess to being one of them.)
I think most folks can get around fine in 90% of situations with the systems you mention. I’m not fond of walking a mile in the snow up hill and can afford to give up some fuel efficiency. So far driving my trucks/suv's, I’ve never had an issue and going down the hills is a breeze with the low-range. If I could get into a high mileage AWD vehicle and not take a major mpg hit all year, I’d give it a good look. The next vehicle I'd consider commuting in won’t get anywhere near what a VW diesel will get so there’s significant savings all around. I tried an ‘07 Civic for awhile and hated every minute of it.
It is a long wait but I am thinking it may be worth it since there is a good chance they will have a version with a manual. This gives me my dream vehicle: diesel on a car chassis giving great mileage, stick shift, awd (which I have no logical need for but a bizarre illogical craving for) and a wagon for handling + space - SUV mileage and corner lean.
Still if the Jetta Sportwagon does have a version initially come out w/o the CARB equipment as suggested here: link title, I would prefer that since I am not in a CARB state and could happily live without the additional expense and complexity.
I currently own a Jeep Liberty diesel (3rd Jeep) and a 2005 Jetta TDI. Without getting into a discussion about pretend 4WDs drives verses real 4WDs, I can tell you that adding a diesel engine to a good 4WD drive makes it a much better 4WD.
The diesel engine pulls so steady through bumper deep snow that you no longer have to focus on traction. The diesel engine is less prone to spinning up the drive train and less prone to bogging down. You just steer and try to find the road.
This may be why some find TDIs to fair well against pretend 4WDs.
Second; As for offroad performance; my 1980 Corolla Auto., RWD, w/o limited slip, and with street tires, was able to negotiate every road I was crazy enough to take it on, very frequently passing AWD's stuck in the... whatever, and never got stuck!
Better driving on my part? - seems doubtful. Other imponderables at work?- probably. Am I still going for an AWD when buying? Yes - for its overall better handling and recovery on wet, slick city streets where I would be doing 90% of my driving.
Better driving on your part seems highly probable since you have been driving for at least 45 years.
so I was driving along at about 120 km/h and a puff of smoke came out of my exhaust and then my engine died.
Had the car towed to the nearest dealership where they told me that the turbo was dead and to fix it would be $2000 - and only after that was fixed, would they be able to tell me if the engine was dead or not.....
Do I have any options other than to go ahead and fix it? I am guessing that the engine IS dead - and I am sure that is not going to be cheap to fix....the car is only five years old and has only 117000 kms on it....
Is this common? Should I just cut my losses and say buh-bye?
If you respond to this - please be kind - I really know squat about cars....that is why I am asking here - tired of being soaked!!
PUH-LEAZE HELP ME!!!
Thanks so much!!!!
It is very unlikely that pieces of the turbocharger got past the intercooler and into the engine.
A TDI engine should be able to idle and run without a turbocharger (with very little power).
Since your engine died, I am thinking that the sequence of envents may have been more like.
ENGINE had problems... then metal pieces from engine got into turbocharger making it blow itsef up. (Keep in mind the turbocharger spins at ~20,000 RPM... it does not take much for it to blow apart.)
You asked for options... If your enigne cannot start and idle WITHOUT a turbocharger. Then replacing the turbocharger may not be enough to get it back on the road again.
If VW screws up this launch, and/or continues to delay, it puts a nail in their coffin as far as I'm concerned. They already have both questionable quality and a questionable dealer network. If they plan on delaying the re-launch of diesel any longer, I might as well just go ahead and buy a hybrid and/or wait another year until Nissan/Honda/Subaru and many other mainstream manufacturers (that are actually considered reliable) have diesel available.
Needless to say, I won't be fixing it.
With out doing any research I would think it would be cheaper to put in a new engine rather than rebuild. Just my WAG.
It cannot be repeated enough times... If one does not replace the timing belt at the reccomended intervals... one WILL end up with a boat-anchor for an engine.
link title
My '94 Jetta VR6: turned on fan/circ.: clanking roaring sound and a foul smell. A couple days later sound disappeared but still no air; heater might be out to. Am afraid to try again. Smell is back. What does this sound like?
Mary in Santa Fe
I recently had to shell out $2000 to replace my turbo that failed due to excessive carbon buildup. I own an 02 Golf TDI with 77,000 miles on it. The extended warranty company is balking at covering the cost due to the presence of this excessive carbon. I take good care of teh car and am pissed. does anyone else have this problem? any suggestions when i sue the extended warranty company? DOES ANYONE KNOW OF A CLASS-ACTION SUIT AGAINST VW FOR THE [non-permissible content removed] TURBO IN MY GOLF?
You will get OVER-INTUITIVE people saying: If these additives were so good,the oil companies would be putting it in at the refinery. The fact of the matter is that they DONT and THEY WONT!
If you drive mostly city,you might want to use more conditioner. The excessive carbon buildup that they are talking about is in the intake manifold. It gets there VIA the EGR system. I disconnected my vacum line so that the valve wont open.I am cocerned about carbon breaking off and getting sucked into the combustion chamber. Just my 2cents worth.
I think it's of more concern if the intake clogs up with carbon. and probably that's less likely to happen now that your EGR is blocked!
