I have to look at the sound system for about 1 second to see the button I want to push. Now, to look at a map, I don't know how long that would take, probably more than 1 second.
Thanks for all the replies regarding the windshield. I've made an appointment to take my car to the dealership on Tuesday, and now I can go in with some knowledge of the problem rather than just having to take whatever the dealer tells me.
I'll let you all know how it goes.
Here in Massa2schitts, full glass insurance coverage is only $8 per year. Considering all the light trucks on the road without rear mud flaps (i.e., a 12" to 18" gap to hurl road debris at following vehicles), one would be crazy not to opt for it.
I had the rotten egg smell in the cabin of my Toyota periodically since ownership. It was sometimes noticeable in stop and go traffic and when present, it did not make a difference whether I had the AC on recirculate or not. On one of my oil changes, I asked Toyota about it and they looked up a TSB that said bad gas and suggested I change to premium. But I was already using premium, so I just went on my merry way. After some time and still having this problem intermittently, I looked around on the internet includng the Edmunds boards and found there was actually a TSB for replacing the catalytic convereter due to the rotten egg smell. I went back to the dealer armed with this new info. They claimed they did not know about the second TSB and promptly replaced my catalytic converter as called for in the TSB (different part number from original cc). I have not had the rotten egg smell since this change in parts. If all the gas stations I frequent in my area and along my travels suddenly changed the sulfur content in their gas at the same time I had the TSB applied, it would be quite a coincidence.
There are many things that don't make sense to me. Not all owners are having this rotten egg smell problem (or at least not complaining about it). Some Toyota's are still having problems with the smell and Toyota is continuing to replace the catalytic converter. BTW, the TSB states that this repair is done under the emissions warranty (100,000 miles, I think).
Coming to Navigation, if you are on a highway you most probably won't need the navigation except for the exit number. And even if you have to look you can look at the screen well before you actually reach the event, well before when you can make sure that the traffic is clear. When you would be looking at the Nav screen in city driving again, as I said, its manageable. This is not an instantaneous event its a planned event so you will have a choice when you want to look at the screen - like when there is no car ahead of you at which you are tailgating There will be situations where you would need to instantaneously need to refer to the Nav screen. And thats when you wish they install a futuristic Nav screen blended into the windsheild right in front of your eyes.
See, I told you its not that simple. :shades:
I found out that leaving the switch on "Auto" is nice, but it turns on the lights only when it's really dark already.
Lights switched to "On" on the other hand, driving with your full-blown lights on bright, sunny days seems a total waste to me.
So I decided I want my lights to go on automatically when it's getting just a bit darker on late afternoon, or on cloudy days, which would cover also rainy or snowy conditions.
The solution is really simple: I used a black electrical tape to cover the lower part of the round black photo-cell element which is on the passenger-side of the dashboard. That way less light is measured by the elemnet, and it causes my headlights to turn on when they are really needed, and not only at night.
I don't see any "waste" in this practice, other than a light may have to be changed somewhat more frequently. In 45 years I have had to change head lamps, I think, 3 times. So, to take it to an extreme, if I have to change a headlamp every 5 years, that's a small price to pay for the added visibility to oncoming traffic. (Daytime lamps will also burn out). The tail lights being "on" may also have a small benefit to help being seen.
Anyway, having the lights on doesn't cost an increase your electricity bill and doesn't decrease your gas milage. I fail to see a "waste" in having the headlights on all the time.
Theoretically, it does reduce your mileage to run lights and other electrical devices. 1 horsepower is sapped away from the engine to run each 745 watts of electrical devices. But you're right in that it's well worth it, and miniscule anyway.
But now, driving the Sonata, with the Fog-Lights on (the indicator on the dashboard tells me my headlights are on), I feel that on bright, sunny days the headlights are doing absolutely nothing to make my car more "visible"....
But than on an overcast, cloudy, gray day, it IS an advantage. Certainly when it's raining. That's why I made the modification, so that when the ambient light is low, even before dusk, my lights will do the job.
The glass guys the dealership works with might be able to replace it for $225 though if the guy's supplier makes the right kind of windshield.
Are there any differences in quality or anything like that between a factory and aftermarket windshield?
Your agent/company should be able to arrange for the repair at your convenience (i.e come to you at home or work). And they deal with reputable repair facilities; not that you dealer recommendation wouldn't be reputable, but there would be no question that you will have a proper windshield (safety certified) installed in your car.
my guess is that we'll see a new steering wheel and blue lights on the dash. throw in some new colour choices (maybe even a black interior) and you have yourself an '07 Sonata.
I will have it addressed at the dealer soon but very bizzare. Never heard a CD player do that before.
Anyone else get this? Sounds like a failed muting circuit during track changes. Probably something deep in the logic circuits. Heck if its like an airplane or computer it might just go away next time the car is started.
With the technology available now, a manufacuturer could make the dash lights color selectable at the flip of a mechanical switch, or toggling a software switch.
All in all Sonata has been a very quality call overall given the fact that it's in its first year as a re-design. Certain that Hyundai will address several of the annoyances in the '07 Sonata which have already been mentioned on this board.
"Toyota Recalling Camry
The newest edition of the Toyota Camry is being recalled for a problem with the transmission. The problem, Toyota says, involved only a half-percent of Camrys built thus far for the 2007 model year. The new six-speed automatic transmission could lose second and sixth gear during operation. Toyota told Reuters the vehicle still will operate even if the gears are lost, and that the problem usually happens within the first 500 miles of use."
HOWEVER, I don't see any reason to spend another $200 on the Sonata, when the car has auto headlights ALREADY. OK, so it's not the REAL DRL, but you can drive with your light on day and night, and never have to worry about it, since they will shut off automatically when you turn the ignition off.
But it's true, one of the "weird" characteristics about the Sonata's gear is that "hesitation" or rather "dead spot" or "hickup" as others have called it. It happens only when shifting from 1st to 2nd, and some posts appeared here about it, already. Actually I notice the 1st gear being very SHORT, before shifting to 2nd... Some owners have actually reported starting from the 2nd gear (using manual), without any problem...
It looks like NORMAL, since so many have noticed it. I read a post from an owner who has over 5,000 miles on the car, and claims that "hickup" disappears with time (and mileage). Either way, unless you REALLY get to over 3,000 before your gear shifts to 2nd -- don't worry about it.
BUT DON'T EXPECT IT SOON. As ANYTHING in this country, it's ALL POLITICS. Things go very slow there, in DC, when it comes to the REAL needs of we, the people.
I plan to have the auto locks activated (they were used on my 2002 Taurus), and will consider having the DRL activated, too. (I remember a posting a while back by a Canadian reporting bringing a car home (from Florida I believe) who was asking about after-market kits for DRL. He should go to a Hyundai dealer to see about having it activated, rather than trying to possibly mess up his wiring with a kit.)
I'm wondering just HOW does the DRL is working on the Sonata... Maybe one Canadian owner can tell us? How does it work with the Auto lights that we have here in the US?
DRL is great, but the question is, how it is set up.... My daughter's new Civic has DRL, but then she needs to bother turning her headlights on in the evening and turn them off when parking her car... Which is not what I'd like to have on my Sonata....
While we're discussing lights, a great upgrade is the PIAA Extreme White bulbs. Do a Google search... Much brighter than stock bulbs.
Are you saying that with your system I would NEVER TOUCH THE HEADLIGHTS SWITCH, once I turn it to the (which?) position?
In other words, during the day, the DRL would have my headlights on at lower intensity, and when it becomes dark the lights would turn into full intensity?
Also, when I turn the ignition off the lights would automaticaly shut off?
What about the back lights? Are they off during DRL and come on when the headlights go to full intensity?
It is possible to never touch the headlights switch, but it wouldn't make sense to do that. You could leave the lights in position 3, the normal night time driving position, and they will go out when the car is turned off. But that shortens the life of the headlights since the night time beam would be in use 100% of the time. Better to use DRL during the day (lower intensity high beam), and regular headlights at night. In the daytime you're trying to be seen (rather than see), so DRL are fine.
Also, I am a firm believer that a rear deck lid spoiler completes a car, but don't see one available for the Sonata. Has anyone here put one on and if so, what kind and where did you purchase it from?
http://cgi.ebay.com/ebaymotors/2006-Hyundai-Sonata-Lip-Spoiler-OEM-Style-by-Trim- king1_W0QQcmdZViewItemQQcategoryZ33638QQitemZ8060108278QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/06-Hyundai-2006-Sonata-Spoiler-Custom-Style-Led-A- BS_W0QQcmdZViewItemQQcategoryZ33638QQitemZ8060069696QQrdZ1QQsspagenameZWDVW
