Visitor Agreement.
Same as the beetle, before they went to IRS.
Warner
All that said, almost all cars today handle better, go faster and are more efficient. Tires and supsnesion technology have come a long ways.
Civic Mileage arate at 30/40 and the hybrid 505/50. I have friend who just go the 2006 Hybrid and gets about 40 mpg with his teenage son driving normally!
Go to the Accord mileage forum. There is guy (Wayne Gerdes, ala EXCEL) who says he can easily get 43/48 in a V6 Accord. I have a 2006 Civic Si on order and I would be pleased just to get EPA of 23/32.
CgCheer,
MidCow
THAT SUCK ANY THING COOL ON THE DX IS EXTRA.
You are right the main purpose of even having a DX model is to brag about the low end pricing on the Civic line of $14,560 and nothing else!.
DX
• 1.8-liter, SOHC i-VTEC® 4-cylinder engine
• 140 horsepower @ 6300 rpm
• 128 lb.-ft. of torque @ 4300 rpm
• Drive-by-Wire Throttle System™
• ULEV-2 (Ultra-Low-Emission Vehicle)
• 100,000-miles-or-more tune-up interval
• 5-speed manual transmission
• Available compact 5-speed automatic transmission
• Control-link MacPherson strut front suspension
• Reactive-link double wishbone rear suspension
• Power-assisted rack-and-pinion steering
• Front and rear stabilizer bars
• 15" wheels with full covers
• P195/65 R15 89H all-season tires
• Daytime Running Lights (DRL)
• Anti-lock braking system (ABS) with Electronic Brake Distribution (EBD)
• Dual-stage, dual-threshold front airbags (SRS)
• Front side airbags with passenger-side Occupant Position Detection System (OPDS)
• Side curtain airbags
• Active head restraints
• Outboard Lower Anchors and Tethers for Children (LATCH)
• Immobilizer Theft-Deterrent System
• Integrated rear-window antenna
• Power windows
• Tilt and telescopic steering column
• Driver's seat with manual height adjustment
• Two-tier instrument panel with tachometer
• Front 12-volt power outlet
• Rear window defroster with timer
• Fold-down rear seatback
• Maintenance minder system
Cheers,
MidCow
Compared to DX, LX adds:
A/C with air filtration system
Stereo head unit (DX has speakers & wiring)
Cruise Control
Power locks with programmable auto lock/unlock
Power mirrors
Security system w/ Remote Entry
body-colored mirrirs/door handles
floor mats
1" larger wheels and wider tires
If you can live without A/C, the DX is a good package which includes all the safety features and even power windows at an attractive price. It's a decent car. But it will be hard to find one because I don't think they are making very many.
But in most areas, A/C is going to be a necessity and the other LX stuff is nice to have, so the LX seems like the sweet spot for overall value and amenities to me. Plus, I think reselling a car later without A/C would be harder-- unless you happen to live somewhere with mild summers like Northern Montana or something (never been there, just guessing).
AC, IIRC was $1300+ as a dealer add on, at one of the lowest price places I went to.
Personally, I tell the aftermarket person 'no thanks' but there are some personal issues with that as well.
http://www.handa-accessories.com/civic06.html
http://www.collegehillshonda.com/civicsedan/2006_electronics.htm
http://www.cheaphondaparts.com/shop/category.asp+SID+1+Category_ID+1403
There are others if you search online.
If you are looking for a paint sealent or fabric protectant, Resist-All is a major company that does it for many dealerships. IT costs the dealership about $140 for interior and exterior. Dealers usually charge $500 or more.
Does anyone else have this problem? My engine sounds like that of an old worn out car with mechanical lifters. This is while driving and not just normal idle noise.
My dealer has been excellent but between this problem and the growling noise that won't go away I really have my concerns about this car.
double sixes,
ModCow
1.) Can anyone either recommend getting the full hood mask or not?
2.) With the '06 being a new year model any opinions on extended warranties?
3.) Any wiring suggestions for Sirius Sportster?
Thank you in advance for any help.
Congrats on the new Civic. It should be a wonderful car for you, and I think you'll notice the quality of build difference between it and the 2000 Hyundai that you were driving. I had a 2000 Hyundai Elantra Wagon and could definitely tell the Honda was a higher quality vehicle. (I had a 2004 Civic that I recently traded in on the 2006 Civic EX auto). As far as your Sirius radio, I'm not sure what size the sportster is (I have a different model), but what I did was just route the antenna wire between the front seats, under the floor mat in the back seats, tucked it under the front of the back seat and down the side of the back seat(in my case I used the driver's side seat, but it doesn't really matter which way you go with the wire) and into the trunk (routing it up above the other trunk mounted stuff to keep the wire out of the bed of the trunk). I also pulled up the weather-stripping (carefully) on the top lip of the trunk and ran the antenna wire directly up the center of the back window to the magnetically mounted antenna. The whole thing took me about 10 minutes. Then, as far as radio location, I mounted it (using velcro strips) directly in front of the shifter in that little area that looks like it was made to have the radio there. It's simple because you have a power outlet right there so there's not a big mess of wires all over the place. I just use the FM transmitter on my radio and it works great. If I ever have reception problems I can just plug it in directly to my AUX port (this is on the EX model only, though). It looks good where it is, didn't take long for the whole installation and was pretty simple from start to finish. Hope this helps!
Warner
Im taking mine in soon.
I don't know if you have the "growling noise" at 1500 rpm but when I talked to Honda about it, they said it may just be a normal characteristic. I asked the Honda factory person if he meant that if all of their cars failed to start would that make them normal just because they all had the problem? Of course, he said "no" but my point to him was that just because all cars exhibit a problem, it doesn't make the problem acceptable.
The best place (appearance wise) would probably be just below the windshield wipers where it would be outdoors for good reception, yet still out of obvious view. They won't install it there, you will need to have it moved or move it yourself.
I am going to purchase a drivers side seat cover and I also
just order a two tier dash cover. My girlfriend wanted me
to buy a toyota which is what I was driving a 1983 toyota
tercel hatchback which I still have and it's up for sale.
I just thought I would sign in to brag about my Honda.
If anyone out there can give my any feedback, all is welcome. Regards, Owen3
I did my own installation (which took less than a half hour from start to finish) and installed my antenna directly above the BACK window. It's hardly noticeable, and through the back window the antenna wire looks like a rear-defroster wire; again not noticeable at all. I NEVER have a problem with receiving a signal in my car. I have NO idea why they'd want the thing installed on the front window, especially in the driver's line of sight.
Warner
Exactly. The wire runs under the trunk lid weatherstripping and up the back window (on the outside of the window) and is a magnetic antenna that simply sticks to the metal roof, just above the back window. I'll see if I can get a photo to show you, but it probably won't be until at least later this evening.
Warner
I would appreciate any insight on this not so big problem, but it is a new car and I don't feel the transmission should be doing this
http://delphi.com/pdf/consumer/skyfi2_installation_manual.pdf
I installed Delphi's magnetic mount on my wife's car, above the rear window.
Yep, my '06 Civic EX does this as well. I agree with travis77's post....and don't worry about this a bit. All things considered, I think the auto trans in the '06 Civic is the best auto trans that I have driven.
Warner
Thanks again
To put it simple - they are ripping you off. I just put in an XM ready aftermarket radio in my other car. The radio came XM ready - I had to buy an XM adaptor for $50 and the antenna for $50 - total $100 and I was ready to go.
