Bluetooth Technology
                    Sometimes referred to as "Personal Area Networks" this short-range radio frequency interconnect technology is all the rage with drivers.
Here's the place to discuss Bluetooth!
Specifically...related to automobiles and Acura (RL & TL).
I just got a Kensington wireless finder plus gizmo for finding wifi hot spots (saves having to turn the laptop on).
It also sniffs for Bluetooth, but I haven't had that light illuminate yet.
Are there any recommendations for bluetooth car audio systems - radio / CD combined with bluetooth phone?
...or one step further - any (non built-in) systems that include radio / navigation with bluetooth (dialing and personal directions from the nav screen)?
Thanks for any info!
I love the Bluetooth HandsFree in my wife's TL so much, I went search and bought a Motorola portable speaker HF800 for myself. And it turns out to be even easier to use than TL's, but of course the sound quality not as good. I think Hands-free speaker would be one of the best application of Bluetooth.
Acura TL and the new RL has this system built in. And they are nice you can talk and drive without the headset in your ear. Mercedes has the handfree system for long but did not use the Bluetooth and you have to have the right phone to plug in a socket. With Bluetooth, you just have your phone in your pocket, and it hooks up as soon as you get into the car.
my RL ?
http://channels.lockergnome.com/mobile/archives/20050108_motorola- _v710_class_action_lawsuit_for_crippled_bluetooth.phtml
Lexus a nexus between cars and phone viruses? (CNET)
"works very well"? Can you transfer phone contacts from you Verizon phone to the TL?
2004 TL. it works perfectly other than the fact that my incoming call numbers (&
other data) don't show up on the dashboard LCD (a shortcoming for this
particular model phone which i already knew about before purchasing). The calls
come in crystal-clear for landline or other cellular calls. Also, the audio is very
loud! Be prepared to leave the volume setting between 02 & 05, unless
you want the whole neighborhood & its traffic to hear your intimate
conversations. (Don't learn the hard way like i did; I'm in the doghouse with
the Mrs.)
Go here:
http://www.handsfreelink.com
Click on the PHONE COMPATIBILITY link. (since not all BlueTooth phones will work
with the TL).
Research which phone models you like.
Hope this helps!
No need to keep trying V710 with Prius (or any vehicles with Bluetooth support). It does not work in terms of transferring phone contacts, files, etc. because the OBEX support was deliberately turned off by Verizon. There is a class action in California on this. Join the club.
Since Prius does not allow keying in phone contacts by yourself, you are left with no other choice than dialing the number yourself when the vehicle is stationary.
It mutes the radio and auto answers the phone. OK...great so far.
I have heard that you can load the phone numbers one at a time.
Is this possible and how?
If it is not possible, how do you put phone numbers in the phone system on the Lexus?
I just can't figure it out. I am willing to manually put in one number and name at a time, but cannot figure out how????
H
As you know, there is only one Verizon cell phone that has bluetooth feature and I don't wish to pay for the expensive phone (710).
I was wondering if there is an adapter that will turn my Motorola V60 phone so I can use bluetooth handsfree feature in my new lexus RX330. I saw quite a few of those adapters but they were mainly meant for headset for the respective manufacturer (Jabra, Motorola etc).
Please let me know your suggestions or experience
for a low cost solution.
Thanks in advance
Abhijit
There is a real concern a phone virus transmitted by blue tooth could end up invading the vehicle computer systems.
There is concern in some quarters but it's another question entirely about how real it is. At this stage it appears to be a theoretical possibility with precious little in terms of specifics.
annoying - the econnect seems pretty cool. WHat Motorola phones are bluetooth enabled?
V710 on Verizon.
Bluetooth connection for receiving and sending calls works great.
You cannot load phone book. You can use one touch dialing while driving, if the numbers are put into their proper one touch area.
Have done new FW upgrade yet. This seems to correct ringer problem.
H
Does the two work together with the 2-way or is a head set needed?
I have heard that the Nextel 930 with have Blue tooth built in, all the older ones need to have something added?
Does anyone know?
Regarding your concern, we regret to let you know that you will not be able to synchronize information from your V710 with your car via Bluetooth. Although the V710 is a Bluetooth enabled phone, Bluetooth is simply the connection that allows two devices to “connect”. Profiles are the software built into devices to enable communication between compatible devices. This is important because if two devices do not have the same profiles, communication will not be possible. The V710 has the Handsfree, Headset and DUN (Dial Up Internet Connection) but it does not have the OBEX profile that allows you to exchange information via Bluetooth.
This means that, due to the lack of the OBEX profile, the V710 phone can only support Bluetooth capability for pairing-up with the handsfree or head device and for using the phone as a modem. It cannot be used for data synchronization like phonebook and calendar, not for media transfer, like pictures and ringtones.
However, we are happy to inform you that later next year, a solution should be available, that should allow you to transfer information from your V710 via Bluetooth.
We apologize for the inconvenience this may cause you.
We hope that you find this information useful and we remain at your entire disposal for future questions you may wish to ask.
If you have further questions or need additional assistance, please contact our Cellular Information Center at 1-800-331-6456. Our business hours are Monday through Friday from 8:00 AM until 7:00 PM CST.
I went with Cingular (Verizon lost me as a customer!) due to Bluetooth. I have V551 and it works great with Prius. There is no way to enter phone book manually into a Prius. Therefore, transfering phone contacts is very important to users.
I heard the battery does not last very long per charge. Watch out for that.
I'm looking into getting an Acure TL and I'm exploring the options.
Thx
One is voice activated in the phone menu via the Blue tooth. The other one is in the navigation system well hidden under:"personal addresses". This is the the left bottom option on the "menu" screen!! It took me a while to find it. It is great since you can program a bunch of your friends phones and their addresses, like in your PDA, then you can use the navigation to dial these number for you ( you can do it by voice as well). It is usefull since you do not have to program all your numbers in the phone book via blue tooth. It is a pain to remember which number for which friend!! and also it is difficult to command the blue tooth voice activation when you have a bunch of noisy kids in the back!! the nav can make it easy, you can use the buttons( touch screen) or joy stick.
If you have a nav system, try it , it is really cool!!
