2006 Toyota RAV4
1222325272892
  • jkinzeljkinzel Member Posts: 735
    Jerr, I can not judge a Toyota diesel as I have never been around or ridden in a Toyota car equipped with a diesel. On the other hand I must respectfully disagree with your thoughts on diesels.
    “But diesels are damn noisy and shaky, need special care during winter, require more often oil changes”
    Diesels have a different sound over gas and may seem louder because one is not use to it. They can be a little noisy when cold.
    I have ridden in diesel pick-up and VW Jetta TDI and have not noticed any more vibration than in any other car.
    If my information is correct, most people using synthetic oils are getting 8000 to 10000 miles between oil changes. This is on the Jeep Liberty diesel.
    Most people with Liberty diesels and VW TDI’s report no problems starting them in -5 and -15 degree temperatures.
    Diesels need different but no more maintance than a gas engine plus have the advantage of being 30% more efficient than gas as you stated.
    If I can cut my fuel consumption by 30%, I’m going to go for it.
  • jaxs1jaxs1 Member Posts: 2,697
    How thirsty? Four-cylinder with FWD is rated 24 miles per gallon in town, 30 mpg on the highway, 26 in combined driving; with 4x4, 23/28/25. V-6 with FWD is 22/29/25; with 4x4, 21/28/24. Toyota specifies "87-octane unleaded or higher," meaning you have to burn premium to get the advertised power, but the engines run fine on regular.
    http://www.usatoday.com/money/autos/reviews/healey/2005-12-01-rav4_x.htm
  • shopper74shopper74 Member Posts: 1
    Anyone seen any 2006s in the Chicago market yet? I've searched the online inventory of most of the local dealers and they don't appear to have any yet? Thanks.
  • hit_the_roadhit_the_road Member Posts: 65
    Yeah...premium to get the advertised power, but what about the MPG rating? :confuse:
    There was another story saying the 3.5 was tested for fuel economy while running on premium.
    Generally, engines that are optimized to run best on premium lose both power and fuel economy when run on regular.
  • vincekellervincekeller Member Posts: 28
    This is just a bunch of BS. Do you have any test data to back up your claim?
  • elfinneedelfinneed Member Posts: 5
    you guys are getting boring...has anyone talked prices lately????
    Engines that are made to take advantage of higher octane fuel adjust the spark advance as needed.
    When the spark advance in adjusted to compensate for the lower octane, lower fuel economy occurs along with reduced power. No engine damage occurs and it is perfectly safe, so the manufacture does not "require" you to use premium fuel.
    Since Toyota recommends premium to get maximum performance from the V6, that indicates it is an engine that adjusts for the octane as needed.
    http://www.cars.com/carsapp/national/?srv=parser&act=display&tf=/features/trutha- bout/gas/todaysgas1.tmpl
  • jimd4jimd4 Member Posts: 877
    I read that the EPA now requires that you test MPG with the grade you say the car uses...ie 87 oct for RAV4 2006.
  • fnamowiczfnamowicz Member Posts: 196
    Naperville toyota has two, one is a limited loaded with moon roof and leather.
    I walked out when he wanted msrp.
  • beantownbeantown Member Posts: 228
    With regard to diesels running more efficiently than gas powered cars.....how efficient is it really when you are paying 50 cents more per gallon for your gas in the states if you want diesel as opposed to regular?
    And re: the mpg issue for cars using regular as opposed to 93 octane....you've got to be kidding me. Cars.com?! They are hardly an authority. For every Cars.com out there that says regular takes away mpg and damages today's engines, I could show you 5 articles from knowledgable sources that say exactly the opposite.
  • larneslarnes Member Posts: 59
    Have you ever owned/driven a 4cyl. Camry or driven the new RAV? They are far from being "noisy". If you have/had (owned/driven this 4cyl) these are claims you would not be able to substantiate. Also, this 4cyl has enough power to satisfy a majority of buyers.
    I have indeed owned/driven 4-bangers and they were all "buzzy" at a certain RPM. Never driven a Toyota, but I'm sure they are much quieter than the older ones. It's something I hear when researching cars.
    Up to a few years ago buying any foreign car was not an option until I learned how many "foreign" cars were built here and how many "American" cars were built there. Of course today's younger people I'm sure couldn't care less, but next month I'll be 66 going on 25 and come from a more patriotic generation. But I digress :blush:
    When the time comes and if I go for the Toyota, I'll try the 4 just to be fair to myself, but I know in my heart of hearts I'll buy the 6. I used to race sports cars and still get a kick out of driving and I'm not above sticking my foot in it from time to time.
    Cheers,
    Larry
    By your theory, bigger engines should get better mileage and last longer because they run a lower rpm.
    That makes small engines pointless since you will spend more money on gas and the frequent engine replacements from all the extra wear they have to withstand.
    Check the RPM at 60 MPH (or any other speed) on both the 4 and the 6. I'll bet the 4 is running at a higher RPM. Just like a 5' guy running with a 6' guy. The shorter one has to take more steps to keep up.
    The new Cad DeVille (I think that's what it is) which is a very heavy car with a Northstar V-8 is rated at 25 highway MPG. Are you saying that putting 4-banger in the same car you'll get better mileage? I know that's a stretch, but I'm trying to make a point. Also, look at the gear ratio. If I'm not mistaken the 4 is geared lower, hence higher RPM. So, is a higher revving engine going to last as long as a lower reving one? That's all I'm trying to get across. :P
  • kdhspyderkdhspyder Member Posts: 7,160
    This is accurate. You can expect any Toyota engine 4c, V6 or V8 to take you well above 200K with no problem. A quarter of million miles is a good number. Thats 15 yrs at 15K/yr. I've had 4 4c Camry's since 1990 and all have made it easily into the 185K to 225K range without a peep. Nothing.
    The do rev louder when accelerating for the reasons you mention but when overdrive kicks in around 45 mph you can run all day or 15 yrs at 2000 rpm at 65 mph in dead silence. With 15 yrs of driving them 40000-65000 miles per year this is fact.
    I also have a 3.3L V6 Highlander and I believe it's in the 1800 rpm range @60 mph in OD. I'll verify it.
    RPM is not everything.
    If larger engines were the way to increase fuel economy, they would have figured that out long ago. Just keep making engines bigger and bigger and lower the rpm and you get higher mpg!
    The larger engine requires more energy for every revolution which uses more fuel and each revolution puts more "stress" and wear on the engine than a smaller, easier to spin engine does. You can try to mitigate this with taller gearing so the engine turns over less often, but more mass flat out cannot move with less energy.
    So, you cannot so simply say that just because an engine spins faster that means it uses more fuel or will wear out faster since there are other factors that are not equal.
  • wybuaawybuaa Member Posts: 12
    anybody have bought the RAV4? could you post your price? plan to buy a Base model 4*2..
  • jsprovjsprov Member Posts: 1
    I also like the Sport but want the automatic climate control. Have you asked a dealer how much it is to install?
  • flyingnflyingn Member Posts: 213
    I have a new Rav4 Limited. There is no way a dealer can unstall the limited ac system in any other mode;. There a lot more to it then bolting on something. Theres the pollon filter, dual zone system etc etc. Its not gonna happen.
    We love out Rav4.. amazine suv..
    Frank
    So post some MPG figures so we can keep heveryone in debate here untl more RAV4s arrive and we can buy a V6 Sport and have fun!
    Good luck with the car.
  • jarekjarek Member Posts: 24
    You guys are optimistic about gas prices in incoming 1 up to 3 years. Lets consider $5 a gallon and then you will feel a difference...
  • SporinSporin Member Posts: 1,066
    I can't believe anyone would bash the toyota 4cyl. Toyota built their reputation on the back of the 22r and 22re and it's subsequent interations, right up until today.
    It's a Factory Installed Option ( FIO ) only. As the above poster stated it cannot be added. A specific model either has it or it doesnt.
  • nedkellynedkelly Member Posts: 18
    I really like the Sport version. I can't see why toyota doesn't offer some of the Limited versions options.
    Like leather wrapped steering wheel, dual zone air conditioning, and heated seats. Some of these are standard on the Limited but aren't even offered on the Sport?!
    C'mon Toyota at least offer them as options on the Sport version. You have nothing to lose and more money to make!
  • cara6cara6 Member Posts: 9
    I am new here and would love some feedback.
    My current dilemma is between a 2004 CRV w/15.5k miles for $18.5k vs buying a new Rav4. I like the new Toyota better but price is a big concern. I’m going to see if the CRV owner will go down $1k in price today (they are moving out of the country on the weekend). I may need to sell the car in two years so that is a factor too.
    Any thoughts appreciated!
    first 1/2 tank fillup at 180 or so miles netted us 21 mpg in mixed driving:)
    Frank
    no question.. RAV4. I drove both many times and it was not comparison..
    Frank
    The RAV4 will be new, nicer and quieter.
    If you get the CRV for the right price and you already now it's likely you'll need to sell it in 2 years, you will lose much less money at resale time buying the used CRV instead of buying a new RAV4 now.
    If both are of equal displacement and equal fuel burn optimization then both will/can produce equal HP/Torque at a given RPM.
    The only real advantage to a 4 cylinder is less complexity and therefore cheaper "build".
    The only reason for going to 6 cylinders is to avoid the roughness/vibration of an equivalently sized 4 cylinder if higher HP/torque is needed.
    I agree, I have never owned a Toyota but the grouping of basic nice to have options like climate control and leather and heated seats to a model is a pain. By the way if you buy the upscale JBL stero you get the leather steering wheel it seems. Of course you can do it yourself or get a shop to do it for you for less than $75 bucks I suppose.
    Have you driven the Sport?
    I haven't seen any v6 sport models yet. That's what I'm waiting for. But I'd really like to get the leather steering wheel and dual climate control if possible.
  • ohwhatafeelingohwhatafeeling Member Posts: 15
    Ok, I'm looking into getting the new V6 with third row and leather. I keep finding conflicting information as to whether this is possible.
    On Toyota.com, under features for the RAV, the footnote for Third Row says ("standard on V6 models, optional on four cylinder models.") Ok, fair enough. BUT if you go to price the car out on Edmunds (can't do it yet on buyatoyota.com) the small print for the leather package says that it is NOT available with 50/50 split and stow third row.
    So, does this mean that you can't get the V6 in leather? Because that would seem odd. Or does it just mean that the third row ITSELF is not available in leather? That would be ok, I suppose, since the third row isn't going to be a seat I use all the time.
    But if I can't get the first two rows of the Rav in leather if I get a third row, then I can't get the car because the availablility of the third row is the only reason why I'm looking at the rav in the first place. I could just go to the highlander (and I've got one picked out) but I'd like to be able to make an accurate comparison....
    The whole thing just seems odd. Why would the third row be standard on the V6, which, presumably, is a car that the more upscale rav4 is buying, if you can't get it in leather, too? Odd, odd, odd.
    Any information would be VERY helpful.
  • dc_driverdc_driver Member Posts: 712
    First off, is the CRV an EX, or LX? 5sp, or automatic? If the vehicle is an EX with an auto, then the price is decent but you may be able to get it for around 18K.. If it is an LX, you are overpaying..
    If price is a big concern and you may only keep it 2 years, I think you should get the used vehicle versus the new one. Personally, I think the new Rav is a better looking vehicle but all things are not equal in this case, and new cars depreciate much faster than used ones.. Not to mention your payment...
    Since there has been alot of discussion here regarding MPG and EPA not sure if anyone caught this, but the EPA is being mandated to change their testing with regards to MPG. The tests are supposed to better reflect real world driving conditions (normal driving behavior, wind resistance, driving over 55mpg, etc).
    I have always felt that the city MPG were always off by 2-3mpg for all the cars that I drove but the highway MPG were fairly close.
    As for this board, I think it is ridiculous to say that the V6 will get the same MPG as the 4cyl becasue the 4cyl has to "work harder".. If that theory was correct then I think Toyota should offer a V10 to save gas while boasting performance :)
    I do not own a Toyota (yet) but have driven plenty of 4cyl and 6cyl Camry's. The 4cyl gets better gas mileage and is not very noisy.. I would definitely consider a 4cyl Rav...
    Someone on this forum made a good point earlier. What if gas costs $4-5 over the next 1-3 years? That 2-3 mpg savings adds up really quickly....
    Thank you so much for everyone's help!
    <<First off, is the CRV an EX, or LX?>>
    It's an EX, automatic and in excellent condition. I've looked at quite a few and this is practically new.
    You said "If price is a big concern and you may only keep it 2 years, I think you should get the used vehicle versus the new one"
    I know- this is an unknown factor unfortunately.
    I just talked with the Toyota manager and can get the Sport 2WD (which only comes with the 'DJ'- 6 cd, tonneau cover and side airbags) for $22,235. The MSRP is $23,589.
    I asked him hypothetically- if I had to sell the car in a year what he thought I could get & he said $19k (& basically said this was an educated guess)
    Anway I'm totally going back and forth on this!
    Also, I'm paying cash tho that doesn't seem to help me at all with the Rav4.
    Gas probably will not go to $4-5 per gallon in the US.
    The last time it went to over $3, it went right back down again and then people went back to shopping SUVs.
    Maybe not.. it's crawled back up to ~$2.50 without so much as a peep from anyone. so it just inches over $3.00 and holds there for a while... then..$3.30.
    Interesing debate. But you gotta look at your individual priorities first and foremost.
    If you want not just fuel economy but also more *range*, lower up-front costs, and lower insurance costs, go for the perfectly adequate 4 banger. Remember when the top engine in the Suzuki Sidekick Sport made 120hp? And that was an upgrade? Base models had something like 90hp IIRC.
    If you want big-time performance or just plain haul a lot of stuff, opt for the V6. You might even find it operates smoother. Trade-offs? Who cares with that big grin on your face?
    No point debating this, if someone else's priorities are different than yours, you'll never talk them into what you prefer.
    -juice
  • absolutboy20absolutboy20 Member Posts: 24
    My understanding of the third row from when you were able to "build" the Rav on the toyota site prior to its debut was that the third row seat is an option on the v6, not a standard feature. If I recall from that site, I do remember if you choose a third row seat as an option, leather seats are not available. I agree that Toyota should offer leather and third row as an option, making the third row cloth but it doesn't seem as though that is going to happen. I can't confirm anything because I have as much info you as you do, and salesman are always the worst people to ask. Guess we will have to wait and see.
    Toyota would never mix and match cloth 3rd row seat with leather.
    If you want leather that badly, you can get cloth and 3rd row and then have leather added through the dealer or aftermarket directly.
    Maybe later in the year or next year leather and 3rd row will be available together (likely with a vinyl 3rd row seat).
  • rossm1rossm1 Member Posts: 14
    I looked at the new RAV4 and it seems very small inside
    Looking at the specs it looks good but in real live
    it looked much smaller than my honda accord (2001 which is not that big) specially in width
    The legroom was ok but the shoulder room I thought was small
    What your impression?
    Ross
  • edgoredgor Member Posts: 31
    I am being offered a 2WD, Toyota 4cyl Ltd. w/option A package (SAB, moonroof) for about $24K. That includes the destination charge but not tax, title, etc. The guy told me the invoice was ~$23,500 but I checked Edmunds and came out with an invoice of ~$22,950. So I asked where the divergence came from. He read through stuff and the figures were the same as Edmunds, and then he came to a $584 charge for "Toyota Dealer Advertising" which was not listed on Edmunds. He says all the dealers charge this. Is this legit? If so, what "should" it cost? One of the other dealers I'd talked to mentioned this TDA, too. Thanks.
    "If the advertising fee appeared on the invoice, it was an actual cost that the dealer paid and therefore a legitimate expense. Since ad fees are regional, Edmunds.com does not track or provide such local fees."
    FAQ
    For grins, ask the salesperson how much the utility bill fee or the telephone bill fee is. :-)
  • explorerx4explorerx4 Member Posts: 20,970
    since you are paying over invoice, ask the salesperson to show it to you. that way you can see if that is the actual charge.
    steve is right, advertising charges are not included in the edmunds invoice price.
    Are you sure you are looking at a 2006 Rav4?? The front legroom is th esame as the 2005 but the back room is larger then the CRV and the Highlander.. Its VERY big inside. 21% more larger inside then last years Rav4.
    Frank
  • saqsalmsaqsalm Member Posts: 17
    On the RAV4 Limited V6 Limited, the 3rd row seats are an option (its not standard with V6). If you opt for 3rd row seats, you can't get the V6 in leather. Only way to get both 3rd row + leather is to get leather installed later on by the dealer, after ordering your V6 with 3rd row but without leather.
    I'm contemplating purchasing the RAV4 4x4 V6 Limited. Toyota's website and RAV4 brochure states its Electronic On-Demand 4WD control disengages at speeds over 25mph. Would the On-demand 4x4 still kick in if I'm driving at high speeds (say, 60 mph) and come across a slippery patch? Feedback would be most appreciated. Thank you.
    No in this case it's the Traction Ctrl and VSC which will save you. See Toyota's website for an explanation or see the RAV brochure there is a description of them there.
    I drove another Sport AWD I4 today. Thought all around handling and road noise were very good for sport type suspension. 4 is very quiet at idle and cruising. Some noise under full throttle but not bad. Performance is fine I guess for city driving and hwy cruising. Acceleration from 45-65 is not great to me but adequate with 2 people in car. It was night and the lights and instruments seemed good. The tires on this one are Yokohama GEOLANDER "G91" I think it said. Does anyone know about these tires? Could not find them on the Tire Rack. The other one I drove had Bridgestone Duelers.
    Anyway for me the V6 is probable choice but it all depends on what your looking for. Dealer says V6 comes in a month but they do not show any V6 RAV4s on their "comming in list". Dealer had 6 2006s. The really do not know much about them actually. I was trying to find out if the optional mirror included built in Homelink like some Toyotas but the did not seem to know.
    Want MSRP which is a not for me but I a not in hurry.
    Agreed, but they all seem to be singularly baffled that somehow one could not get a third row AND leather.
    The reason I want it is because it wears so much better with kids and food. I also just like it. And if I can't get it, then I'm getting a Highlander. But it would be really, like, super cool to know that ahead of time and I'm getting really frustrated that I can't have the information from Toyota that would permit me to compare these vehicles side by side, apples to apples.
    I pulled up the specifications pdf from toyota, and in the column of the car I want (model 4453) there are literally blanks up and down the sheet. They're not filled in. A salesperson told me that he had it on good authority that the options/standard features on the V6 4X4 Limited will be the same as the 4cyl 4X4 Limited, but even assuming those things, I still can't find out if I can get leather AND a third row.
    The problem is, if I can't, I really would just prefer to get the Highlander than do aftermarket. And if I'm in Highlander-land, I would prefer to get the car by the end of this month to take advantage of the $1000 cash back.
    The last remaining issue (though it should be the first) is that I can't get anybody to give me a firm MSRP. Not that I'm paying MSRP, but I can then make a reasonable comparison to the Highlander, MSRP to MSRP.
    How incredibly frustrating.
    I'm hoping that there's someone here who is familiar enough with the Rav4 models as they are debuting that can shed some light on this issue, but it might just come down to waiting to see a 4cyl third row Limited when it actually hits the dealerships to find out if leather is available, hope that this occurs prior to Jan 31, and then take a calculated risk on the V6 version of it that I can get it in the same option levels. I'm not in any rush to own, but I'm ready to strike immediately.
    Would anybody like to offer any advice as to the relative differences I'll see between a V6 Rav4 Limited 4x4 and the same Highlander, comfort and convenience-wise?
    the highlander has a really, really small 3rd row. i can't believe anyone actually would buy the rav4 or highlander because either has 3 rows of seats.
