Diesels in the News
12627293132171
    jimlockey, dude. there has been more diesel news in the last few months than for many years. many press releases about current/2007/2008 diesel plans. edmunds has carried them all on their news pagss. perhaps those announcements get lost in all the arguing in this forum, but so what? they are mostly "preannouncements". i don't believe *any* USA diesel "pre-announcements", due primarily to the CARB-factor.
    the CARBies will find a way to raise the bar just enough to prevent 50 mpg diesel cars from being sold in the CARB states.
    my favorite recent diesel press release is the one about the 50-state-legal 2006 toureg TDI. i think there are only 750 available, but they can be sold through 2007 too - in CARB states too. i think VW really had to pull a fast one to make this happen before the CARBies found a way to prevent it.
    go VW, it's your birthday!
  • kdhspyderkdhspyder Member Posts: 7,160
    For the benefit of goodcrd :P
    Toyota claimed the little hybrid would get 60 miles per gallon in city traffic, not just the 45 many consumers were experiencing."...
    This statement is selfserving to the axe that Consumer Affairs wants to grind. It writes this, the highlighted text as if Toyota pulled this number out of the air. As everyone who's familiar with this whole subject knows it's the EPA which determines the ratings by the testing it uses. Toyota and all the other manufacturers only do what the EPA tells them to do.
    It's a small nuane but it's important. These numbers are the EPA's show only. The manufacturers have nothing to do with the results.
    For an entire year the Prius probably does get 45-50 mpg depending on the driver and the specific conditions for that vehicle. My average for the past year, 36000 miles, is 48.6 mpg so I don't have any problem with the new EPA regs saying 45-47. That's reality given todays driving with the new tests.
    Yes, even in the 2003 TDI (Jetta in my case) to make it into this country they were forced to so called detune or make the diesel engine less efficient. The effect limited the HP and torque by a significant amount (10 hp/40 ft #'s). This made the 6th gear or double over drive not viable. Further this made the oem use a less stout clutch system. So a system in Europe that could get better mpg actually came into the country less capable, both in power and drivabililty and made it less probable to get the best fuel mileage.
    IN THE REAL WORLD. !! ??
    It depends on how and where you drive.
    If you drive at 70 mph into a headwind in winter there is no way you will get close to any EPA number because of the physical factores against you; neither diesel, nor hybrid, nor gasser. It's impossible to overcome to overcome the effects of drag, wind and temperature.
    OTOH I have averaged as much as 65 mpg over a 50 mile trip in perfect EPA ( old ) conditions.
    Both are REAL WORLD conditions. I've experienced both in the real world.
    This is the key point you continue to ignore.
    Nearly no one drives in perfect EPA ( old ) conditions. If you could then you would match or exceed the EPA ( old ) ratings no matter what vehicle you drove. It really is that simple.
    I can take any Prius that's in good condition and attain the old EPA numbers with no effort at all; ditto the Jetta TDI, TCH, Malibu, Land Cruiser or Dodge Ram.
    Again going back to YOUR posts, using YOUR logic, what is flawed about a very repeatable procedure?? Looking forward what "FLAW/s" did they identify to make the new procedures... FLAWLESS?
    The procedures themselves were not flawed by the prior standards. The application of the meaning of the tests was flawed - given today's conditions. The tests were likely done perfectly whether they were done by the EPA or the automakers.
    What did these result mean? Nothing! Drivers rarely drive the way the EPA posited back in the 70's.
    I think the majority of Prius owners (that are dissatisfied with the mpg) would be tickled pink to get 60/50 mpg IN THE REAL WORLD. or even 55 mpg! (average of the two figures)
    48.6 mpg to my mind is WONDERFUL, However it is -7 mpg from the average and -12 mpg from the city rating or -13% to -20%.
    While this might be academic or 20/20 hindsight question how many more or less Prius would have sold if instead of 60/50 it was more realistic at 45/47 ? Additionally if that were true, do you think folk would be happy to get 48? That is to keep in mind what Larsb said about 48 before= 48 after?
    I am glad you agree with my "REAL WORLD" definition. And that the new definitions does not make the new ratings FLAWLESS.
    ..."This is the key point you continue to ignore. "...
    NO and not even close!! This is the point about the advantages of diesel that you are systematically ignoring. The real world results of diesel are on par (42/49) So for example if I want 50 mpg in a longer distant trip, the TDI can go 80-90 mph. At 50 mpg how fast is the Prius going? Again to vary another variable if both went 65mph what would the mpg be for both.
    Let's for the sake of clarity remove what you are stuck on; and that is Prius hybrid. If my diesel TDI were rated at 60/50 or 50/60 mpg and I only got 48? I would be a bit more than upset. Knowing what I know the expectation would be to be at PAR = 50/60. Again to further illustrate the TDI 's epa is 42/49 I get between 44-62. In a daily commute I get between 48/52 which is above PAR. I am a happy camper.
    As I have explained before the EPa average number of 55 is predicated on a 55/45 split between City and Hwy. My own personal EPA average is 52 mpg because I drive 85% HWY / 15% City. The whole concept of a weighted average is foreign to most of the US population so the EPA dumbs it down to 55/45, stating YMMV.
    So if 52 mpg is my own personal EPA what do I get? Well in EPA conditions during the Spring, summer and early Fall I averaged about 51 mpg ( 85 Hwy / 15 City ). This was not 52 mpg because I chose to drive on the speedy side of the EPA limits averaging about 62 mph iso 48 mph so I lost 2% of my nominal expected FE.
    Now during the colder weather my personal EPA average is about 44-46 mpg depending on how cold it gets. So my results are actually in perfect conformity to the OLD EPA values and testing procedures when taking into account the weather factor that was ignored back in the 70's.
    But I reiterate most ( 80-90% ) of the US population has no clue as to the meaning of what I just wrote. That excludes all current interlocateurs of course.
    Under the probable new EPA guidelines I will exceed them by 10-20% all year long.
    Actually if you look back in my posts I've not said one single word about diesels at all.... nothing.
    As you know from past posts I would jump to a diesel burning biofuel in a heartbeat and especially to a hybrid diesel sometine in the next 5-7 years. I've always said that diesels and hybrids accomplish the same goal just in different manners. The results of the Jetta TDI and the Prius are almost identical.
    I am happy that you obtain such above average results with your TDI as I do with my Prius. :shades:
    Not to be a party pooper, but this IS a diesel thread!! :)
    Another reason why I think that folks would benefit from CHIOCE of the diesel OPTION in market segments they are interested.
    Of course I do know HOW to drive FOR mileage. For me over the last 84,000 miles, the really neat thing about the Jetta diesel is I specifically do NOT drive it with fuel mileage (necessarily) in mind.
    Not Yet says Jerry Flint
    Like the rest of us, Jerry has an opinion on diesels.
    The way I see it is this....
    Honda, Subaru, BMW, Toyota, Nissan, Mercedes, VW, Audi, Dodge, and Chrysler will all introduce new diesels in the USA within 3 years.
    Diesels are not going to immediately take over the market, however, they are going to be a popular choice for those seeking to use to fewest resources and obtain the highest fuel economy.
    Automakers know that they would pay a huge monetary fine and even WORSE, they would lose in the eye of the public if ever shown to have "lied" on an EPA MPG test. No carmaker would ever do that because of the negative consequences for their bottom line.
    Do you mean like Toyota trying to cover up the steering problem in over a million vehicles, that caused some deaths? Or Chrysler trying to cover up problems with their mini-van doors. Or Ford and Firestone trying to cover up problems with the number ONE selling vehicle in America. It is naivete that would believe for a minute that the car manufacturers do not fudge on the EPA & safety tests. Unless you believe that they just happen to beat out the competition by 1 MPG in actual testing. The precise tests the EPA lay out may be done in a foreign country and we are supposed to believe them. Bah Humbug! 85% of the tests are done by the manufacturers. And you believe they were all done precisely according to EPA regulations. Hmmmm :shades:
    You ever wonder why the diesel cars are under estimated by the EPA tests and the Hybrids are over estimated? Why the mileage incentives are offered to hybrids and diesels with strings attached that keep the diesel cars from getting any of the tax breaks?
  • larsblarsb Member Posts: 8,204
    gary says, "You ever wonder why the diesel cars are under estimated by the EPA tests and the Hybrids are over estimated? "
    No, I don't WONDER and neither should you. Here are the answers to those two questions:
    1. The EPA test for the hybrids allowed them to run in A) optimal temperatures so the the hybrid drivetrain was engaged during the tests, which means higher MPG, and B) no hard acceleration and lower speeds during the old test meant the hybrid was not pushed or stressed and the hybrid systems combined with the small gasoline engine meant higher MPG numbers during the test.
    2. The EPA test for the diesels A) used lower speeds so that the "low rpm at greater highway speeds" which is where the diesels get their MPG advantage never came into play.
    It's not some grand conspiracy Gary, it's just NOT and the sooner we accept that the better our lives will become. Harboring all these cynicisms and being a doubting Thomas all the time is not good for one's emotional well-being. :shades:
    As far as your comment about the tax incentives, well, as far as I know there were no strings attached to the diesels. They qualify for the incentives too if they were clean enough and high-mileage enough. Let me look into that and I will get back to you.
    Just as I thought Gary - the diesels failed to qualify because they were just not clean enough:
    Also, for the first time, tax incentives will extend — in theory — to "clean diesel" cars. But in reality, no diesel now on the market would qualify because none meets the air pollution standards. That may change at the end of 2006, when ultra-low sulfur diesel fuel is expected to hit the market along with new diesel technology. Clean diesel cars could catch on: J.D. Power and Associates estimates that hybrids and clean diesels together will account for 11 percent of the U.S. market by 2012.
    Which car on the market will carry the best tax incentive? The Honda Civic GX, which runs on compressed natural gas, will garner a $3,600 tax credit, according to ACEEE, which has long touted the vehicle as the greenest car in America. But annual sales number only in the hundreds, partly because there are few CNG fueling stations. Not to worry: Congress also is providing up to a $1,000 tax break for a home fueling station, which siphons natural gas from the home furnace line straight into the Civic's tank. The typical cost: $3,400, plus $1,000 for installation. Even with tax breaks, alternative fuel is costly.
    Clean is more important than high mileage, since the GX is not a high mileage vehicle but is super clean and thus rates the MAX tax break available at $3,600.
    Get those diesels clean enough and the tax breaks will come.
    And the hybrids got the big tax breaks with over estimated EPA mileage tests. What's new?
    When it comes to government, in any form, I will remain a doubting Thomas. That won't keep me out of heaven. I just never watch TV anymore. That keeps my stress level down. I work in the yard to relax. I read Edmund's when I need to have a laugh.
    "Get those diesels clean enough and the tax breaks will come"
    I see this attitude as (sour grapes) an indictment of the generation (30 plus years) ago, conscious decision and subsequent failure by regulators to embrace diesel (and its developing technologies) for the passenger vehicle fleet.
    You of course know the specifics even though you wish to ignore it.
    Gasser technology for example took 30 plus years to so called come up and do the Prius. The greatest thing you can say about it is it uses a tiny engine (atkinson cycle) that is OFF 20% of the time!! :( The bad news is the batteries used in its place to power the extra equipment needed for it to be off 20%, take us further down the pollution and throw away path. Also predictably it raises the cost expotentially and to add insult to injury increases the FREQUENCY of that expotentially higher cost. :(
    Another might be the USA government (executed under the Clinton administration) did give R and D of 1.5 BILLION dollars after tax monies for the biggie three to do a blank page design to prototype and test of course, for a high mileage power plant. Each of them independent of each other came up with a 70 mpg plus product, which all HAPPENED to be diesel. So of course at some level for the actual money expended the feeling might be this WAS a tax credit. Keep in mind that 1.5 billion government meny is a 3.0 billion before tax. Again the regulators who didnt get together with the other regulators on another area of the FED gov put the kibosh on diesel for it was decided (at that time) diesel was not part of the longer term policy. So in effect we the taxpayers paid 1.5 billion dollars (really more than 3 billion) for three prototypes and probably a library of paper documentation-all sitting on shelfs in storage. To add insult to injury we look to the Europeans and to a lesser extend the Japanese for so called "modern" diesel technology. Not that they do not have good to great products, but the USA is more than capable to develop this at home. Cummins is one example, CAT is another. My take is that is disgusting on many many many levels. The good news in nexus to this web topic, is it is getting very hard to ignore the alternative fuel benefits, and 25-75% diesel advantage.
    Look, I don't give a hoot about all the old historical stuff.
    What I care about (and we all should) is making cars which meet TODAY'S emission standards, TODAY, in the world we live in TODAY.
    When these cleaner diesels finally DO that, then they will qualify for the tax incentives. That's all I'm saying and all I care about - CLEAN AIR NOW AND IN THE FUTURE. DIESELS TOO if they are clean enough.
    The MB Blutec diesel has been demonstrated as cleaner than any equivalent gas vehicle. Yet CARB is balking. Why do you suppose that is?
    Personally I am ready for a simple EV. To make a gas or diesel vehicle that complies with all the Emissions BS equates to a throw away vehicle. 5 years or 100k miles it is in the recycle bin. Good for the economy bad for the environment.
    You know that is absolutely fine. The problem however is the anti diesel sentiment remains as a residual from that "old hysterical stuff"
    So the regulators indeed see it as capitulation for EVERY diesel advance.
    The real question to ask is how is gasser allowed that uses more resources and pollutes more while diesel is banned and uses LESS resources?? I think you already know the answers.
    According to one industry expert, it's because the regulators dont trust the drivers to keep the urea bag changed. It's that simple.
    And they shouldn't have to trust owners for something that critical to the cleanliness of the exhaust; many of whom may or may not give a darn about the environment.
    That's like trying to sell a plug-in hybrid that is only clean when it runs on electricity and trusting the owners to always keep it charged.
    There was a story about that a couple of days ago but I cannot find the link.
    That is an average once a year (15k mile) urea fluid check. It may last a lot longer than that. It is factored on the driving habits of the individual. No different than if the catalytic convertor in your car quits working. You are spewing out pollution. That only gets checked every two years in CA. Never if you have a hybrid. That was one reason I went for the hybrid PU truck. Quite simply it is the bias against diesel cars that blocked it initially. So we keep driving our gas guzzling SUVs in CA till CARB gets their head out of their posterior. I still see more new PU trucks and SUVs in my subdivision, than new small cars.
    This is incorrect. The tests are just physical procedures that have been well known for 30+ years. There is no conspiracy, there is nothing hidden.
    I can take any Prius in the US which is in good working order and attain the current EPA results in real life ( EPA ) conditions. It is the easiest thing in the world to do. I do it several times a day.
    The obvious question is why then don't most drivers get the very optimistic EPA values? Because they choose not to. It's all a matter of personal choice. It has nothing to do with the vehicle or the manufacturer or the EPA or anything else. It is mostly dependent on the driver then secondarily on outside physcial forces not foreseen in the ( OLD ) EPA test.
    This is a very good article that condenses a lot of good info into one article.
    Clean Diesel set to Spring like a Big Cat
    ruking, thanks for passing along that historical stuff - i think you are "all over the ball" on the subject.
    i think the feds don't have the tradeoffs quite right: USA & allies *should* suspend tightening clean air regs until we win the current WW4. imho a crucial aspect to that is decreasing oil imports with the help of hybrids, diesels, conservation, CNG-cars, electric-cars, biodiesel, solar/wind/nuclear-charged electrics, and even some of that mostly-a-scam E85 fuel. that opinion is a top reason why my family's primary vehicles are both VW TDIs. (soot locally, act globally).
  • chevy598chevy598 Member Posts: 162
    Kdhspyder (or anyone with a Prius), From what i'm reading you own a Prius, and I have a two questions.
    How many mpg will you get in a Prius if you drive 75-80 mph?
    How fast is the top speed in the Prius?
    I'm not trying to knock the car. I'm just curious.
    On I95 N & S where everyone does about 75-80 I get about 44-45 mpg in good weather with no wind. My normal Highway speed is about 62 mph and I get about 50 mpg.
    I've had it up to 90 but not for long ( too many cops ). I believe it's been driven as fast as 115 mph as a stock vehicle.
    Please add me to the list. I posted my mpg (TDI) both in the now defunct diesel vs hybrid thread, here and others and since folks are bring up hybrids also in this thread, to encourage or try to get a clear and concise SWAG both hybrid and (other folks') diesel. (last posted in IS THIS THE DAY OF THE DIESEL? ) Strangely (or predictably)the hybrid response is... silent. Of course we have heard from those so called "extremists" who want to go 35-45 mph to try for 100 mpg in the middle of a deserted desert road. However I take a more so called "real world approach" to this (not that a deserted desert road is not a reflection of real life or world) and to be fair KDSpyder has responded with 45-52 mpg, so what say ye OTHER Prius owners? :)
    Any car that averages over 45 mpg highway should qualify for tax incentives. We have such a huge dependency on foreign oil, that it is ridiculous any vehicle with great mileage be excluded. I our government should have no bias towards any high mileage vehicle, regardless of the powertrain or emissions.
    kdhspyder, Thats still pretty damn good mileage. I didn't think a Prius got that kind of mileage at high speeds.
    Ruking1, you are 1000% right about the government raising emission standards on diesels. It's ridiculous that states keep raising standards on diesels when they offer so good highway mileage. Our dependency on foreign oil is to serious for us to abandoned diesel technology that would have passed with flying colors 5 years ago.
    I think the new clean diesels will qualify for tax breaks when they hit the market. From reports even with new emission controls the Jetta should be in excess of 40 mpg and the Passat in excess of 30 mpg. The other diesels may be too far out to meet the 2010 deadline.
    I'd go along with a permanent incentive for
    .. any auto that averaged over 45 mpg;
    .. any SUV that averaged over 35 mpg;
    .. any truck that averaged over 30 mpg.
    I think proportionality should be part of the equation. So for example if a savings target exceed a target proportionality, par or more or less tax incentives. Of course there are probably a lot of ways to look at it also. So using the SUV eg., SUV's are 12% of the population. So if the average SUV gets 15 mpg the new mpg of 35 mpg is a 1.33% better or savings of 57%. Yet if the average auto is 27 mpg, and the new mpg is 45 or 67% better or the savings is only 40%. EG small cars for example are 25% so it is conceiveable cars/small cars could use MORE fuel, if the proportionality angle is not worked.
  • texasestexases Member Posts: 11,196
    I'm as interested as anyone in diesels, but don't blame the government for slow availability. Diesels have, until very recently, had much higher particulate emissions, something that's been found to be linked to lots of health problems. I share the concern that people won't refill the urea - it's not like the rare failure of a cat converter, it's required yearly. This is where Honda's urea free technology could be a major advance.
    Here's a question - do the new diesels still stink? I hate following the current crop of diesel pickups.
    I'm no expert on diesel emissions, but every good you use in America was shipped across country by a diesel semi. There are millions of semis running the roads of America, and I'll bet they have higher emissions than diesel cars. That's not counting the 1/2 million a year new pickups with diesels being put on the road, or the 50% of passenger cars in europe.
    I'm all for saving the environment where we can, but at some point we have to make exceptions. I can't believe small cars with diesels are going to damage the environment any worse then it is now. I just read humans exhale 20% as much co2, as the average car gives off. The average human exhales 1,963 lbs of co2 per year.
    If we gave automakers a more realistic bar, they might actually reach for it. Instead only a handful of companies even try to meet USA standards. Imagine where we would be if America embraced Diesel cars 30 years ago. Global diesel emissions would be lower then they are now. Some of that technology would have been be transferred over to semis, and that is really making a difference!!!
  • winter2winter2 Member Posts: 1,801
    I have a 2005 Jeep Liberty Limited CRD and it does not "stink". In fact it is odor free. Even with the previous S500 fuel, it was odor free and produced no visible smoke, even under load.
    The engine in the CRD is designed to run on S15 diesel fuel.
    As to the issue with Bluetec and the AdBlue additive, I think Daimler will come up with a way to handle this problem. In the EU filling stations that sell diesel fuel are also selling the AdBlue additive so that resolves the issue of keeping the AdBlue tank full. That would be a good solution here but it is more likely that the solution will be available in containers of several liters each that the owner can use to fill the AdBlue tank.
    How often does the AdBlue need to be filled?
    Couldn't it be filled as part of routine service at the dealership?
  • jkinzeljkinzel Member Posts: 735
    I would think any auto maker can set up a system for AdBlue that forces maintenance. I have a small Honda generator that shuts its self off if the oil level gets too low. Maybe not the best thing for a car when going down the freeway a 75mph.
    A really irritating alarm sounds when the tank is near empty and will not go off until filled.
    Any number of options could be used to force the owner to make sure the AdBlue is maintained.
    Also, like any alarm or safety system, it can be over ridden or disabled.
    I don’t think making AdBlue system EPA/CARB compliant is the issue. Making the system economical and easy to maintain might be the bigger problem.
  • qbrozenqbrozen Member Posts: 33,816
    I'm not sure I understand what you are stating. MBs with adblue are available right now in 46 states. So, from what I can see, EPA is all that is preventing it from being sold in all 50 states. And, as far as I know, adblue is not expensive and its as easy as pouring it into a tank.
    It's not the EPA. It's California, and 3 other states stopping sales. The EPA has no problem with current diesel emissions.
    Your correct and I had forgot about that. I was thinking more in terms of the CARB rules.
    I was not refering to the adblue as being costly so much as a system that would appease the CARB states. My understanding is that they (CARB) have an issue with the system not being maintained by the owner and for that reason they are not signing off on it.
    Please correct me if I'm wrong.
    Merry Chirstmas everyone
    There are a few very verbal government opponents to diesel cars. They have managed to set the bar to where the bulk of the population do not get a choice in the matter. If you look at the EPA website you will see that the most popular cars in America 5 years ago had higher emissions than the current diesel cars. Yet the high mileage diesels are banned. Millions of these higher polluting CamCords are still on the road. I cannot believe that the real powers in this country are interested in saving fuel.
    "I cannot believe that the real powers in this country are interested in saving fuel. "
    I would totally agree. So for example, those very same government officials point the peasants to MASS transportation. Do you know what most MASS transportation is run with? DIESEL !!! AND UNMITIGATED DIESEL at that!!!!???? Do you know why they are NOT implementing hydrogen fuel cell buses at a faster rate??? Hydrogen per gal (weight) is 18 dollars per gal!!!! A hydrogen fuel cell FX Honda (Civic size) gets 22 mpg. So how much do we think a heavy duty 45 passenger on up bus would get???? :)
    If it only got what a diesel got (6 mpg) the cost is expotentially prohibitive!!!!! So if one does the proportionality 50 mpg-diesel/ 38 mpg-gasser /22 mpg cost $3/$2.70/$18 /6 mpg diesel $3/
    equals 2.27 MPG @ $18 hydrogen????? Now would that equal $7.93 per mile vs (3/6) or .50 cents per mile!!!??
    Our municipality paid (at the time 10 years ago) 36,000 dollars per year for participation for the municipalities employees to use (fast) passes. 300 employees can literally not use their cars to get to WORK!!! THE PASS WAS AT NO COST TO THE EMPLOYEE!!!! All an employee had to do was ASK for a fast pass. FREE !!!! NO BODY (at the time) I mean no body uses/used it!!!!!!!!!! One guy actually used it, (for a half a year), but he retired (mid year) !!
    Yet government officials point with pride how we promote all the latest transportation initiatives, yada, yada, ad infinitum. So 10 years hence do you think it costs more or less? Do you think it has gone up from .0033% participation? Actual participation for the half year is .00167% :)
    Our elected officials get a $400 per month fuel allowance to use their own personal transportation. I say give em a fast pass. The taxpayer is already paying $36,000 for for almost laughable and unintelligible participation :)
    Slowdown there Kemosabe........let's keep things in perspective......
    Let's not knock mass transportation for the pollution. One City bus, even with "dirty diesel" fuel, pollutes far far less than 25 people driving themselves to work in a normal car or in a diesel car.
    And hydrogen fuel cells are not ready for prime time - still in the "million dollars per vehicle" range.
    I know Gary is against hybrid buses, but they are in use all around the world and the studies are all showing that those buses are a hit with virtually every agency which is using them.
    Mass transportation has a lot of problems which are not related to diesel and which I will not get into on this forum, but believe me when I just say this: people want their freedom more than they want a free bus pass.
    As far a pollution though, mass transit usually passes muster.
    Well, I didn't even give the good news. We paid $500,000 for a clock holder in a mass transit parking lot !!! :) At least a 500,000 gold brick odd house has some utility. :) I could post a picture of it, but it would be correct only twice a day. :) I'll let you guys do the % calculation of being correct that would be.
    eh ... i should stick to just saying "the gub'ment" cause i can't keep all the acronyms straight.
    You are correct. i think its an easy and economical system as far as the owners would be concerned. But, for some reason, that's not good enough for "the gub'ment." ;)
    I would submit the issue is a total strawman. SHAM, call it what you will. All they really need do is to put this type (diesel ) system on the routine emissions inspection cycle that gassers are on, where as now diesels have been exempt. One of the reasons for the periodic GASSER check is foremost to COLLECT REVENUE. Lower priority is to check the emissions, which by fed law MUST last/PASS a min of 10 years or it shall be fixed IAW with the FED and oem warranties. The secondary priorities among others is to check to make sure owners, etc. have NOT removed the emissions systems!!!!!
    To me it is clearly citing of a technically to enforce the (ANTI )diesel exclusion for as long as possible.
    As I understand it, AdBlue usage under normal driving conditions is about 15K miles between fillups. The more you put your foot in to it, the more AdBlue you will use.
    I believe Daimler will make AdBlue servicing part of the normal maintenance routine.
    Just put an audio alarm system & dash warning. When near low(1000 miles), alarm beeps for 5 seconds when you start the car. When completely empty car beeps every 10 seconds untill filled. I't will annoy you into submission.
    If AdBlue gets 15k on one fillup, and is part of normal servicing, you're good. Jiffy Lube, Penzoil, Fast Eddies, and Valvoline will all service it during regular matinence. There always looking to sell you something at an oil change shop.
    An alarm system is a great idea.
    As to Jiffy Lube, Pennzoil, and those places like them, would you really trust your car to them? I have heard and I have read too many horror stories about them.
    I go to the Chevy dealership for oil changes on my Impala, and those guys don't miss a beat. If Gm had an AdBlue system it would be topped off at every oil change, and if they missed it 5k later the computer & audio alarm would let you know its empty.
    Could even have a reset sequence at every fillup. Like GMs oil life monitor.
    How expensive is AdBlue, and how much is needed per 15k miles?
