Visitor Agreement.
Tim
Found an old computer in a backroom on this small miserable atoll. Guess I'll be able to post once in awhile. Flying on an Air Force C141 is not one of life's greatest pleasures. If ever offered that opportunity, make sure you decline even though it be free...BTW anybody heard from Red lately. Been kind quiet without his sometimes "anal" responses...LOL
Dean
Maybe you just are expecting something else?....but the shift points sem right on the money...
What rear end you have?
- Tim
Since none of you addressed this on this site thought I'd throw it out for general consumption. Octaine PREVENTS fuel from igniting. Higher octain is used to prevent autodetonation (knock) in higher compression engines. 87 should work as well as 93 in almost all new cars. The problem with high octain fuels is the method used to achieve it. Alcohol is not good for aluminum engines or engine components and that is what goes into a lot or "cheaper" high octain fuels.
Don't just take my word for it, though. This too easy to prove to yourself. Fill your tank up all the way to the top with 87 and run it down to the warning light. Figure your gas mileage. Do the same with the 89 or 93 and see if your mileage improves by more than 1 MPG. If it does, stay with higher grade. If it doesn't, you're wasting your money.
My $.02 worth,
Phil
Phil
I don't care about MPG...just power.
- Tim
http://www.toyo.com/tire_basics/plus.html
I think I am going to try the Toyo. They have a 500 mile free trial for some tires. If you don't like them, they will exchange for something else.
Dustyone
My 2 Lincolns.
-Jarvus
The other Dean
As we now have Onboard Diagnostics Second Generation (OBD II) on these trucks, the inter-relationship of the sensor signals and speed at which the computer runs increase the complexity of operation and control. TIM however may have a different situation however as his is a 2500 and as such (outside the boundaries of California) may have, like, "OBD II Light".
BTW for those who disconect the battery, keep in mind that the computer that you are clearing of the Block Learned Memory Fuel Trim (Short and Long), due to some modifications of intake or exhaust, WILL ALSO clear the "Start Up Self Check Data"!! GM refers to this as "System Status - Complete Yes/No". What it means is that the last time the vehicle was driven, the "Monitors" completed each test. Pass or Fail, but they completed. If you disconnect the battery and clear the memory, the system does not know that the Monitors completed!
What does all this techno-babble mean? If you disconnect the battery, do not take your truck to get a Smog Check or Emissions Certification until you put some serious miles on it!!!
Page 6-2178 Volume 3 of 4 has a complete description regarding the drive procedure necessary to get the "System Status" to complete. My experience shows that even though you try to drive the "cycle" within the specific parameters for 12 minutes, the scan tool may still show a "Fail" on System Status. A good long drive is necessary.
Sorry about the long post, just the Training Instructor coming out.
Matthew
chevy4me, i've got 13,000 on my generals (jelly
wheel belts) and they're wearing fine also. only
problem is that they were wearing in the center.
now i'm down to 32 lbs. (cold) and they are
wearing a bit more uniform.
...red
ordering?
...red
I currently run 93 octane, HPIII, 160 thermostat. Mileage avg. combined 80/20 high/city 16 mpg. But it's not the true reading. Truck came with 255/70R16 and upgraded to 275/70R16 without reprogramming for tire size change. Truth being that prior to HPIII programming, truck did not run well with 93 octane, rather 87 was best. After programming, 93 is definitely the best choice.
Dean
'00 LS xcab 5.3 3.73 2wd
JBA headers
Gibson sweptside exhaust
Granatelli MAF
Airaid
New rack and pinion; control arms
and waiting for Zummo PV with Magnaflow....
Indigo Blue LT Z71
Graphite Leather
Locking Diff.
265 WOL Tires
Went by the lot today with my girlfriend and found it - couldn't wait until Sunday to see it.
Looked great. Thanks to all for the info and entertaining posts over the past 6 months
Byran
I am going to cop out and say that use what the Owner's Manual recommends. Based on what I have experienced over the years of driving my own plus GM rental cars on business, unless you do some extensive and well thought out modifications, such as those that Dean performed in #281 to his truck, it is best to stick to what is in writing. There have been some compelling posts regarding higher octane being both distructive and a waste of money. Something to think about. I have been reading the "Silverado" subject since back in January and there have been many comments on octane recommendations. There is a wealth of practical experience on octane usage. See if others offer their thoughts.
Bryan,
I echo congrats and enjoy!!!! See if you can hold it under 200 miles a day! LOL Once you start driving your truck, you don't want to stop, or drive anything else! I rent from National since they have Silverados on the Emerald Isle.
Matthew
I could swear it had better highway power with 93.
- Tim
Dean
etc. Thanks
Paul
Matthew
mine were tighened to specs. other nuts and bolts
within the underside of the truck were tight also
with the exception of a few bolts that needed
retorquing anyway from the truck being in use.
Boy, this topic has gotten boring.
...red
http://www.teleweb.net/mgdvhman/
- Tim
You have been doing a great job over there. That is a lot of work.
Blackmax200
Torque wrench is supposed to be used to only tighten, not loosen nuts...
red..
glad to see you still have the time to stop by...
Dean
Any suggestions on brand or anything? Also anyone know how the install goes (TIM dont even open you mouth). ANy help on this matter would be greatly appreciated thanks
Ryan
kyle
kyle
hmmmmhmmmmmmmmmmmmm
hmmmmm
mmmhmhmhmh
m,mmhmhmhmhmhm
..( I can't open my mouth..per Ryan)
...But if I could....I'd say babs would have boxes installed any way!
what you need a tool box for?.....Lego sets?
- Tim
Kyle no tail light guards yet im calling again today.
I know it takes more than 3m tape to install them. Craftsman makes some i might check out. Thanks for all your constructive criticism guys. I guess i had it a coming
Ryan
All out input is done out of Friendship babs!.....REALLY!
- Tim
Octane - "in writing" in the 99 shop manual it says to run 91 octane. This will not cause your engine to run hot/cold, foul plugs, and/or build carbon. What it will do is allow maximum spark advance, which produces max hp and fuel economy. When pulling rated GCWR with my 4.10 rear end 4.8L'd motor in 4th gear at 3200 to 3500 rpm I get severe ping that doesn't go away (even after software upgrade).
I had resigned myself to running premium (even though the owners manual says 87 is ok) when towing. I just read the shop manual's recommendation of >91 octane and at least my curiousity was answered as it appears these engines are designed for premium.
PS. Ever notice the bores and strokes for the small block family of engines. The 5.3 is a stroked 4.8L and the 6.0L is a bored 5.3.
I'm probably gonna run premium full time..... Based on a really small sample (ya, I know), my fuel economy is up 10% on the current tank of fuel at 400 miles......
I ran 93 for 15K miles...then decided to try 87 with gas hike....last time I remember checking MPG..it was about 12.5...last tank with 87 was 13.2...but that's not an average.
Maybe I will try several tanks of 93 and check it again?
- Tim
With an order # I can call GM and get verification of build week, right? Does anyone have the GM number to call? Thanks.
Denny
Good luck see the 2 tones are being built. Hope your truck gets done real quick.
Ryan
You may have to give me the name of your dealer and salesperson, so I can order my truck thru them. I've never been to Spfld IL. or for that matter east of Spirit Lake, Iowa. Could be fun trip.
Last Friday I went to the largest Chevrolet dealer in the Seattle area. Went to Brooks Chevrolet (7th largest Chevrolet dealer in the US). They were going to get back to me if they could order my two-tone Silverado LS. I have not heard from them yet. My local dealer is still trying to order it, and still getting a rejection. I hope he is not trying to order the LT.
Keep me updated on status of your truck.....
-David
I had my severe ping occur in central NM on I40 running uphill pulling the travel trailer with two dirt bags and bikes in the truck along with a bunch of riding gear. Elevation was >5,000', suspect ping would have been worse at lower elevations due to higher effective cylinder pressures.
first order took 3 wks. for gm to pick it up. and
it was 2 more wks. for them to give a tpw. the
second order was picked up by gm the very same
day that the dealer put in the order. also got a
tpw (target prod. wk.) the same day. it just
depends on when they're building what your
ordering and that all options are available.
hopefully you're not like me and have patience.
i'm the kinda person that's use to overnight
deliveries, and waiting for my truck was really
agonizing. at least the next one i order i'll
have no problem cause i already no what to
expect. it was with great thanks to all the guys
here that i made it through the wait. everyone
here is not only helpful but entertaining as
well.
...red
Paul
Check your profile. I sent you a reply (below) and it bounced back to me.
The place I go is as good as ANY factory paint job, and better than
most. he also guarantees his work for life (part of being in the State
Farm system in California). I have had work done by him and you cannot
tell anything was ever done, both on my '99 Silverado and my wife's '97
Chrysler convertible.
That would be a good way to get two-tone if you want it.
Personally I don't like two-tone unless it's black on black...
Richard
