Mystery car pix
113141618191477
  • andys120andys120 Member Posts: 23,684
    You're right of course. That syling while less moderrn is a bunch more elegant than the Ponton IMO.
    It was the last prewar style sedan
    In the cases of the ponton and the fintail, their styling was obsolete about 12 months after introduction.
    That used to be the charm of German styling, it was always a wave or two behind the
    avante garde. Audi is the only one ever to be really successful at putting up to date styling on German iron. ;)
  • jaserbjaserb Member Posts: 820
    While Mazda was copying the original Elan so successfully with the Miata, Lotus came out with this awkward looking FWD thing and slapped the Elan name on it.
    -Jason
    Correct Jason. The Isuzu powered Elan is sometimes known as the M-00. I've heard that it wasn't a very good Lotus, being fwd and all but it was a pretty decent car if you set aside expectations of Lotus-like cornering.
    As I remarked earlier the Miata may have looked Elan-like but didn't really have the
    "elan" of the ultralight, backbone chassis Lotus forebear. It was more of an up-to-date MG than a noveau Lotus.
  • mrwhipple311mrwhipple311 Member Posts: 58
    Andy -- nice guess.
    I'm kind of surprised no one got this one.
    The car is a Swallow Doretti which, I believe, has some relationship to Triumph. Supposedly there were about 270 of these built in the mid 50's and the house owner owns 8 of them. I have never seen one other than these!
    there were 250 Swallow Dorettis built and you're surprised no one got it :mad: Anyway here's another picture I found of one.
    Got any more like that up your sleeve Mrwhipple?
  • xkssxkss Member Posts: 722
    I'll give you some hints...
    It has an aluminum chassis.
    It is hand-built.
    It is raced by the factory in the American Le Mans Series.
    A '57 Trianok? OK, I was just trying to read the license plate.
    A Panoz. Esperante?
    No offense meant, just saying you guys are good... nothing seems to get by.:blush:
    b&w picture: a Hindustan?
    the blue roadster : definetely a Panoz Esperante
    I'll go with the Panoz, the b&w is not a Hindustan.
    Looks to be a French Ford, which became Simca
    It's a '57 Simca Vedette and, yeah the styling is obviously from the French Ford era which ended in '54. Many later Simcas were Fiat-based.
  • seminole_kevseminole_kev Member Posts: 1,696
    interesting as I don't remember any stock Cadillacs having a hidden front quite like that......then again, I'm not a big Caddy fan either.
    Need a better picture?image
  • michaellnomichaellno Member Posts: 4,120
    Late 60's vintage, I believe. IIRC, they shared a platform with the Olds Toronado; both were FWD.
    That's right, the '67 Eldo was the first fwd Caddy and one of the handsomest Cadillacs of the era, a lot better looking than the Toronado in my book.
    now this is a tough one. Even Bob Holland might have to think twice.
    Note, I'm assuming that everyone else sees a "photo not available" box here.
    I see the pics. I am assuming the license plates give it away
  • kyfdxkyfdx Moderator Posts: 270,911
    I can see them also.. It is an Alfa.. other than that, you got me..
    Not exactly, Fintail. Every Alfa coupe since the 50s has carried the "Sprint" label but these are Alfa-Romeo _________Sprints, (fill in the blank). ;)
    Veloce?
  • subearusubearu Member Posts: 3,613
    yep, not able to see the photo either. but, if I take the image properties url http://www.nordclick.de/images/meldungen/piohjpo_7681620.onlineBild.jpg and paste it into another browser window, I can see a red and grey pair of alfa looking grills :P
    -Brian
    Well it beats me why some of you aren't seeing the picture but here's another picture
    of the Alfasud Sprintimage
    Which was the coupe version of the fwd Alfasud, here's the sedan version=>
    None of the Alfasuds were imported to the US.
    the image will only appear if I open the url for the image in another window. They probably don't handle hot-linking images, my guess.
    I can clearly tell it's not a Pontiac Grand Prix or a a Chevy Sprint ;)
    Still looks like an Alfa offspring of some sort from the front.
    Post #806 appears fine, can see the little black 'vertible.
    -Brian
    Jensen Healey
    Fin beat me out. I knew it was a JH. I remember reading the road tests when they came out. For some reason, I always liked them, although I can't honestly say I ever saw one in person.
    I think some of you more technically proficient posters are using another browser besides IE... Because, I can see all of the pictures..
    regards,
    kyfdx
    (techno-cro-magnon)
    I can see 'em fine using either IE or Firefox. BTW It was a Jensen-Healey, a '74.
    This would have been early '90s. I distinctly remember two things: the Lotus twin cam engine, and more rust than I have EVER seen on a supposedly "drivable" car. If you accidentally kicked the kick panel from inside the car your foot would have gone all the way through the front fender.
    -Jason
    edit: now that I think of it I've seen some running Toyota pickups that were rolling piles of rust held together with duct tape. The JH was pretty bad, though. Even young and stupid as I was I knew that much rust was bad news.
    '50s era DKW.
    Bob
    Close enough, I guess. It's a '58 DKW 1000 to be more exact..
    Try your hand at this?
    Toyota Corona c.1972. I remember when those things were still on the road.
    a blue Audi RS2 Avant wagon.
    -Brian
    Prezactly, the RS2 Avant was designed and built by Porsche so it preceded the Cayenne as Porsche's first wagon, even if it was marketed by Audi, It featured twin-turbos and 400 hp making it one of the fastest cars of the early 90s.
    That was one of the reasons I remembered it was an RS2. I did not know the true designer of it though (thank's for that useful trivia tidbit ;) )
    -Brian
    1960 Edsel Villager wagon
    http://www.edsel.com/pages/edsel60.htm
    Bob
    I get about half your PIX the rest I paste the link into the browser. Is that an Olds?
    PS
    This is a fun thread to follow...
    When I refresh the screen the Pix come through. Maybe a glitch somewhere
    Feel free to join the fun Gagrice.
