Quick Links
Quick Links
Are you under 40 and think that you might not be able to afford a brand new vehicle when you purchase your next car? If so, a reporter would like to talk to you. Please reach out to [email protected] by 12/16 for more details.
As for the back cover i had mine stolen and have not gotten a new one yet.
Eight pages of roof rack discussion can be found here:
http://www.msprotege.com/forum/showthread.php?t=123691620
Per Ford:
New or enhanced for 2009: (Mazda 5)
* New Liquid Silver exterior color to replace Sunlight Silver (late availability)
* Sand interior color now available with Stormy Blue and Brilliant Black exterior colors
I was thinking about buying the housing and just mounting a portable GPS in it. Has anybody tried this yet? Would it work?
Question...do you have the Mazda key ON another key ring or other keys attached to the Mazda key? I only carry my Mazda key, house key, safe key and a old stick of computer memory (a DIMM, makes it hard to loose the keys) on a metal key ring. No issues.
Anybody out there have one?
sorry i am not more help. but if you listen to it you can hear what ever is loose kind of knocking like a ball bearing on a string kind of sound as it does an extra bounce lol
Help!
I want to have one set of key junk with everything attached and never think about adding or subtracting bits to it. Just "yes I have keys" or "no I don't". That's been my 40 year habit so I can't change now. It can be chains or ring(s) or nylon straps or carabiniers or whatever in any necessary number, so long as it all hangs together.
I have been using the small Mazda 3/8" diameter metal ring that came attached to the fob, and then putting my own key ring thru the 3/8" ring. Nothing else directly attached to the Mazda key.
We had the Door Actuator replaced. Mazda part#C245-72-350.
The problem has not happened since.
Has anyone installed the Metra dashkit?
Any feedback would be appreciated.
Gideon
I think I may have misunderstood the salesperson on the phone. At first he asked me about whether I had automatic climate control. I was confused by the question and said I had automatic transmission. He then told me he would ask around for me and that I should check online.
After I posted I searched and found this link http://www.the12volt.com/installbay/appguide/2007/Mazda/Mazda5.html
and on the link it said that
Premium Kit 99-7509 2007 Mazda Mazda5 (models with manual climate)
# - Major Modifications may be Required
Perhaps there is an issue with the dash kit and manual climate controls.
Thanks again for the feedback.
Gideon
Do you suppose the kit you're reading about has a more durable finish than the Mazda silver stuff? Ours already looks a little scuffed after only 2 years.
So unless the wires are just sitting there in the dash, it might be difficult to retrofit. On the other hand, you could just leave it in the open position.
Maybe somebody has the directions they could post? I thought the DVD navigation was a dealer installed option, maybe it was a factory only option?
Could anyone share their experience with the remote engine starter kits for M5? Is the one from the dealership the best thing or an after market one? Good recommendations for any specific model/make?
However, its only 2 - 3 minutes of extra engine ON time (less than 2% of overall engine ON). By getting a Mazda5 and not a Sienna or Odyssey with V6, I think we have earned somewhat of a carbon credit that can be applied towards this. :shades:
With a newborn and around freezing temps for 5 months here in Utah, I don't feel bad about using the convenience of a remote Engine Starter.
Anyone with suggestions for a good model/unit for M5?
The remote starter is not a device that I know a great deal about but presumably you know that Mazda offers one for the 5? MSRP is $300 but I found it at Med Center Mazda in AL for $253 plus shipping.
On a side note, I guess you can take the darn rear stabilizer bar completely off and never have to worry about another crunching sound in the rear.....LOL!
My other sugestion was to remove the rear sway bar and then you wount have to hear the crunch from the rear ever. Someone said it may affect the handling but I highly doubt anyone will notice the small change unless they are carting the thing around and pushing the suspension to its limits. The front sway bar is the main bar that shouls always stay in place because it is the thicker one and the one that controls the front suspension and for the most part the entire vehicle's dynamics.
I used to own a 2004 Nissan Frontier in which I removed my rear sway bar entirely to have better articulation on the rear suspension when I went off-roading and I never even noticed a change in stability when driving it on a normal basis in freeways and surface streets, I know that this may be comparing apples to oranges in regards to the two different vehicles, but who knows, maybe removing the rear sway bar (for those who just can take it anymore with the rear crunching noise) may not make a difference either in our MZ5's.
Is there after market companies that perhaps make polyurethane bushings instead of the OEM rubber ones???
I know Energy Suspension makes these types of bushings, but they do not make them for our MZ5s.
Also, did the fix provided in the TSB actually work or is it a waste of time?
I think you should try another Mazda dealer that is willing to help you because the TSB should also apply to 2007 MY MZ5s.
I cannot attest to the rear sway bar bushing replacement fixing the problem because I have never gotten it done, since mine only crunches a tiny bit when it rains and immediately goes away after it dries up. Replacing the fronts however, did fix my "knocking" sound when going up or down a driveway or anytime the road was uneven. I never had the "crunch" noise.
Lets focus and post messages related to those here...
I own a Mazda 5. It's radio looks like this one: http://img219.imageshack.us/img219/7880/1003673no5.jpg . I would like to remove the cassette deck cover to place a magnet behind, put it back and use it for sticking my Mio GPS onto it by the magnet. Could you please describe the way how I can remove the deck's cover? Can it be removed from the front without dismounting all the stuff around?
I would be pleased if you answered my post!
Thank you very much!
Deni
I am in Toronto, and got a 2006 of Mazda 5. I am looking for the rear wiper insert, but have no luck in local Walmxxx or Caxxxxxx Tixx. May anyone let me know where can I get the replacement? Thanks.
Mchow
But for the 10 minutes that takes it may be easier to just buy one from the dealer.
PS do not just get the rubber only(from the dealer) for the back as it costs more than the assembled one.
As far as the drivebelt, I also get a whinning noise (not squealing) when it is raining, perhaps from the water that gets the belt wet and makes the noise when going through the pulleys. Once it is dry it goes away completely.
What mine does that I don't know if anyone elses does, is a weird whining noise similar to the wet drivebelt from the A/C compressor when first turned on, possible for the first 10-30 seconds. Anyone else experience this???
