If, for example, the window run-channels are binding the window glass because they're winter-frozen, auto-stop will always be on - leading to the condition you're having.
Or it might just be a completely broken unit. Either way, dealer would probably have to change the unit.
-cb
1. When I use the driver's seat heater it emits this weird smell after a few minutes. I wouldn't describe it as a burning smell, but I have no idea what it smells like. It worked fine the first several times I used it over maybe a month before I started noticing the smell. I think the passenger seat heater is ok although it gets used much less frequently so I wouldn't necessarily know if it has the same problem.
2. The auto-up/down function of the driver's power mirror stopped working for a few days, although it's working again now. Even when the auto function was broken, the window would still go up and down, I just had to hold the lever. This just came up from someone else a few messages ago, but I'm curious to see if there are other possible causes.
3. The driver door speaker sometimes sounds horrible and distorted, especially on bass. Usually I turn down the volume (which was probably around 15 to begin with) for a few minutes and when I turn it back up, the speaker is ok. I've noticed this happen on several very cold days, although I'm not sure it was cold every time.
Has anyone seen any of these issues? I'll take it to a dealer next week. I just wanted to get an idea of whether these are common problems.
Thanks for any info.
-cb
(I accidentally posted this in the Quality Control Issues forum, but I meant to post it here, so I'm reposting.)
Oh by the way, don't ever use BBB if you have a consumer related problem, their inept.
Yea,I noticed they are a lot of tranny, radio, & tire talk on this site. I kinda felt out of place. Thanks again,Geri1
Unfortunately I scratched the plastic piece that runs the length of the rear right door (door protector) which is not a big deal but I want to replace it. I already ordered the part online for $28 (which I think is very expensive for a piece of plastic but I digress) and will get it soon.
Does anyone know how to replace it? I pried the old one and there are some clips behind it. But it does not look like those clips will fall behind. Would I have to remove the inside door compartment to get to the backs of those clips? Any help is appreciated.
It is part 8 (and 4 each of 9's) in the diagram below.
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- - cgry1=Accord&catcgry2=2005&catcgry3=4DR+LX&catcgry4=KA5MT&catcgry5=PROTECTOR
(1)Every morning, I stop by a fast food joint for breakfast. Since the weather got cold I've noticed a new problem. The window tracks were lubed as part of a 30,000 mile service. Below 40 degrees, the drive side window fails to go up. -Even when I continuously hold the button in the up position. I have to manually pull the window up while holding the button up.
(2) The power washer jet on the driver's side does not give any water. It did in the past. then, slowed. Now it is completely stopped. The passenger side jet works fine, but, NOTHING comes from the driver side.
(3) The paint on my accord chips regularly. The front hood looks bad. Probably from bugs. however, there are also chips on the sides and trunk lid. And, this has happened since day one. None are bigger than the diameter of a pencil's eraser. The graphite gray paint just disappears and the dark primer is revealed. I live in an urban area and the car does not see gravel roads. This car was built in Japan, so, I am wondering if it is the Japanese paint booth vs. the US paint booth? If so, I will stay away from the Japanese built Accords in the future.
I did purchase the extended warranty. And, hopefully, the first two problems will be fixed. But, I wanted to point out that people are telling the truth about the accord paint and that there are others with the paint problem too.
Help me out here a little bit.
Could you please define "orange peel"
thx
It could just need reset. To do this, start with the driver's window closed. Open it by holding down the button--and then continue holding for 2 seconds after it is completely down. Close the window by pulling up on the switch and again hold the switch for 2 seconds after it is closed. If this was the problem, it should be fixed. Otherwise, take it in to the dealer. I think it needs reset if the battery is ever disconnected.
Wow. We just traded our 2000 EX Ody in. The only problem we ever had out of it was a creaky front passenger seat. Seems like you attract tranny trouble.
Things that make you go Hmmmm..
Any feedback is apreciated.
Another possibility is that the clutch servo cylinder (you have a hydraulically applied clutch) is the problem. This would also be a warranty item, but, again, it would have to be verefied by the dealership personnel before they could submit the fix to Honda for reimbursement.
*In the "old days", sooner forgotten than lamented, bronze bushings were used - they just needed to periodically have a drop of motor oil applied (which most owners neglected to do and most mechanics conveniently "forgot"). Fast forward to twenty-five years ago, or so. Now "self-lubricating" plastic bushings (typically nylon, delrin, or teflon) are used. Guess what? They're not self-lubricating at all after a little dust gets on 'em. Eventually they start binding and ultimately shred to smithereens.
http://images.google.com/images?svnum=10&hl=en&q=%22Orange+Peel%22+paint&spell=1-
Thank you! You have saved me a trip to the dealer. I followed your instructions & now the auto up & down both work.
I bet those instructions are in my owner's manual. I need to crack it open sometime.
Thanks again.
Dave
Sometimes what happens is that cars get damaged on their way to the dealer and are repaired prior to sale (minor damage) and these repairs are what shows orange peel.
But I do see orange peel on various new cars from time to time.
I took it to the friendly people at Carr's Honda in Chicago, they have a body shop there. Their tech came out with the putty knife and pulled the piece off as he was working his way with the putty knife. No scratches whatsoever. The old clips came out with the piece so nothing fell into the door compartment. Then went the new piece in. Took 10 minutes max.
Thanks again!
I am waiting another month or two before bringing it to another Honda dealership and have it checked again. Please post again if you ever find out what is wrong with the car. I will post again if this is ever fixed. I hope I will not hear the same line "they all make that noise". Other than this one nagging noise from the engine, I like everything else about this car.
I read online it is 17.1 but my low gas light comes on around 12.5 gals is this correct? Is Honda trying to be safe with a 5 gallon reserve? I know Toyotas and Mazdas I have owned in the past has a 2 gal reserve aka if it has 15 gal the light would come on around when only 1-3 gal were left.
Ergo: my reserve is circa 3.3 gallons.....FWIW
best, ez..
if you think about it, it may not be immediately noticed, nor if it is noticed - acted upon right away. all the hondas i have owned have been equally conservative.
like you, once you fill up a few times after the light illuminating, you can see if it is consistent and then feel more secure knowing you have a bit of reserve to find an open station.
let's say 3.3 gallons would get you 90miles (30MPG). what would someone prefer instead, only having 1/2 a gallon remaining to be the trigger for the light first illuminating?
I have always had excellent results with Chevron gas, 87 octane. It is a little more expensive than some others but in the long run I believe it's worth it. Besides, Honda recommends it as one of the original Top Tier Gasolines. You do not necessarily have to use it all of the time but maybe every other tankful. Of course you could always stick with your usual gas and use Techron additive as you fill up.
Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.)
Service Bulletin Num : 03036 Date of Bulletin: JUN 03, 2005
NHTSA Item Number: 10003480
Component: SUSPENSION
Summary Description:
VEHICLE DRIFTS TO THE RIGHT. *TT
Hope this helps.
Really? Hmmm.... Based on what evidence? :confuse:
