See the link below
http://www.collegehillshonda.com/artman/publish/article_173.shtml
Mrbill
Thanks for the explanation. My last (and one and only) Accord, a '96, exhibited the periodic headlight dimming at night, but I'd had a '73 Ford Galaxie 500 that did the same thing. The Ford shop manual said it was normal, so I never followed up on it with the Honda. The factory Delco battery from Honda only lasted six years. Curiously, my '03 Sonata started life under my tutelage with headlight dimming, but eventually stopped after several months. That battery (a Korean made Delco variant branded, "DelKor") is over four years old. Now I wonder whether the Sonata's ELD pooped quietly on its own. If so, Korean cars are wonderful - they fix themselves.
Why would it not be covered under the warranty? You are under 36k miles, right?
He needs to clarify why he believes the warranty won't cover it.
i personally don't see how it could improve FE much unless it causes some disconnect of the drive to the alternator which i assume is always engaged and consuming energy from the motor / reducing FE.
then again, if you unload the alternator electrically, i suppose their could be an unloading of the mechanical torque / energy caused by the field magnet arrangement and getting those electrons to their load...
I tried to lift up the air box cover after taking out the 4 screws but cannot get enough clearance to take out the air filter. What is the procedure in your Helminc accord OEM service manual for 2004 L4 model for air filter replacement? How to remove the hose from the box and reinstall it back? I see a spring clip around the hose but don't know how to remove it. :confuse: Thanks!
I'm also having the window creaking problem, so when I take it in again for the steering column rattle, I'm going to ask them to replace the body and door seals...from what I've read on other posts in this forum.
Here is a generic link that will show you what the parts look like. link title
My '03 Accord developed a steering columnn rattle or jiggle around 40k miles.
The dealer replaced the tie rod ends (ball joints) and the jiggle went away. The car was out of warranty & I opened a case# with Honda. They "goodwilled" the labor & parts since this is ridiculous for a brand new Honda or any brand.
The Hondas of today are not the cars they used to be.
Parts to loosen: all 4 screws of the air box, and big bolt holding the fuse box. The fuse box needs to be loose so you can push it aside with the air box. You need to push hard against the air box to clear the fender edge. Swinging the air box towards the battery won't work because the fender clearance narrows further, making it impossible to lift the air box.
The alternative procedure is to disconnect the various rubber tubes from the air box, but this looked more labor intensive. So I chose the first procedure I described, but not without thinking how user-unfriendly it was.
A dumb question I'm sure, but I just want to confirm...when the dealer replaced my steering column, the tie rod ends wouldn't have been included in what they replaced? Just want to make sure they don't try to tell me they already did that (although they have been fairly helpful). What all does replacing the steering column include?
The remaining causes of noise/looseness would be the steering and suspension parts starting with the steering gearbox all the way to the wheel bearings. Chances are, however, that the defective components are limited to a) the suspension ball joints, b) tie rod ends, and c) steering rack bushings. Less likely to fail is the steering gearbox.
Unless you regularly drive on "washboard" or rutted road surfaces, suspension and steering parts normally last a good 120-150k miles, even more for a Honda.
The current generation Accords, however, have had some abnormal manufacturing defects. My 03 V6's engine mount failed at about 20k, and there's suspension rattling that comes and goes (dealer says it's the brake pad tensioners which they can't do anything about).
In any case, I would attempt goodwill repairs as blackexv6 did considering that your problems are atypical of Honda and could be safety-related.
Seems like this is a common thing with dealers. They tell people there is no solution to their problem, when they don't know how to fix the problem. I also have an 03 V6, and it does not have this rattle, or any other rattle. I would try another dealer, and see if they have more experience with your problem.
Of course another dealer may not be necessary. You can bring your car to the same dealer 5 times, and not get the same level of service each time. All "techs" are not created equal, unfortunately.
Funny you mention the rutted road surfaces. I do hear the rattling noise from the steering column on smooth surfaces at times, but there is a 10-mile section of I-20 (both Eastbount and Westbound that has a rutted surface (although it's not really deeply rutted, but it's not as smooth as other parts of I-20). It's the only place that I'll be 100% sure to hear the noise every time I drive on it. In fact, I made the Honda technician ride 40 miles roundtrip with me to that part of the interstate to be absolutely sure they heard the noise.
This is the 5th Honda I've owned and I have noticed a difference in quality in the last two (2000 and 2005 Accords). I'm fighting the urge to get a new Chevy Tahoe or Acura TL. The only reason I haven't done it is that I'm about $6K upside down on my car right now (mostly due to the negative equity we rolled into the loan at the start). I know my husband is getting tired of hearing me complain about the rattle and I'm getting sick of hearing it!
Any one have any ideas why?
That said ;-), I'll have the dealer look at the entire front-end system of your car from the hub assembly to the steering column. The steering column may just be transmitting noise/vibration caused by another part/s. That the rattle was eliminated temporarily may have been due to the disassembly & reassembly process where the real culprit part, not necessarily the steering column, was tightened but not enough.
Logic behind this suggestion is that the steering wheel communicates other unrelated problems like unbalanced tires, warped rotors, loose wheel studs, etc.
Let us know what develops, and good luck.
The more time you are stopped, the worse your mileage will be. Keep in mind that the EPA assumes an average speed of 20 MPH in their City tests, if you aren't covering that speed, you likely won't get above the low 20s in MPG.
What kind of mileage did you experience with your previous vehicles, was it below EPA estimates also? If so, I'd say nothing is wrong. If you were maintaining at least EPA estimates in your last vehicle, I'd go to a dealer, or at least a qualified mechanic and have your car checked out, because there may be a problem.
I only ask about your city route because one person on another thread complained about his mileage in his new Mercury Milan; what he failed to tell us is that he lives in Manhattan, NYC, NY! He was getting something like 14 MPG.
The distance from my home to work is between 10-12 miles but it takes me at least 60mins.
I usually fill up my tank on Sunday evening or Monday morning, but by Friday I would have used up half of it and covered only about 120 miles !!!!!
10-12 miles in an hour is much worse than NY.
You could probably bike it in less time and get the benefit of the exercise.
if i were getting horrific highway mileage, i'd be looking at condition of air filter, tire inflation... then condition of injectors (can one get stuck?), cat convertor efficiency, 02 sensor operation, and perhaps even engine timing. i don't know if a vehicle could be set up with out-of-spec timing and you not notice it, but someone claimed recently in one of the ODY forums that was the case in their van. yikes!
but city / stop-and-go? fuel efficiency could be highly variable based on too many things to control. i wouldn't use that as a benchmark against EPA estimates myself.
I'll post my findings
You'll likely get used to it since you are driving it every day now; it can be a life saver in panic braking (a split second of brakes grabbing the rotors can mean the difference in stopping safely or being the next car in the pile-up.
I highly doubt that it is the car's problem, simply because I experienced exactly what you have told me. Now, I have over 13,000 miles on my 2006 EX and LOVE it!
.....the previous posts on 7th GEN touchy brake feel are spot-on........even somewhat conservative. My linear rocket ship AV6 6M (better numbers than my '69 Corvette) at 20k still has really touchy brake feel.....doesn't take much pressure to feel those pads glom onto rotors..........
...great car.......
best, ez..
I would check your air filter as well. that kind of driving will get your filter dirty. A dirty filter can rob you 1-2 mpg.
Miles Driven / Gallons used
instead of with gauges.
Fill tank (do not round off to the nearest dollar) stop at the first click-off.
Reset trip meter to zero.
Drive, at least until the low indicator light comes on.
Fill tank again (if possible use the same pump, and stop at the first click-off).
Write down number of miles on trip meter, and number of gallons from gas pump (before leaving the gas station).
Divide miles by gallons. This will give you an accurate mileage.
Going by the fuel gauge, or the low fuel indicator, is very inaccurate.
There is also one scratch just below the paint surface. Will leave that to a professional.
Thanks, I'll pick some Meguiar's Scratch X tomorrow and try it out. The graphite color does a great job of lessening the appearance of the deeper scratch, it's just the tan paint that has to go.
I am personally in the safety camp as far as DRL's are concerned and something which is automatic and functions as a safety device for myself and my fellow drivers seems like a good thing. I hope that you will reconsider your efforts. Take care. Ralph
The main thing that annoyed me with DRL was the inability to run the ventilation system in a parking lot (engine off) - without those darn lights coming on, draining the battery. You can't run the ventilation system without putting the ignition key in a position that will turn on the DRL lights.
Steve (LX 4Dr 06 Accord)
Set your parking brake when you turn the car off. When you turn the car back on, the lights don't turn on until you disengage the brake.
