It seems to happen at start-up most often - the car will idle a little bit roughly, misfire, and light-up the idiot light on the dashboard. I've also noticed some hesitation lately. The car has always bogged down a bit if you put your foot in it too quickly, but has done so since it was new and I've always attributed it (perhaps incorrectly?) to either the electronic throttle or the traction control nanny. Of course, I could be wrong (wouldn't be the 1st time).
Mechanic says the car has stored misfire codes for all six cylinders (P301 through and including P306) as well as "lean bank" codes for both banks each of the times I've brought it in. It has NOT stored an Oxygen sensor code or anything else. He cleaned the EGR valve and ran a solvent through the tubes/runners that the gases flow past the EGR valve in but Mr. Idiot Light is back again. We're now going to replace the EGR valve on the theory that it may be sticking at start-up, but I'm not convinced this will work.
Anybody seen a TSB on this issue or have any other ideas about what could cause all six cylinders to store misfire codes and double lean-bank codes without an O-2 code? The only other thought I had was a fuel pump but, I'm an amateur and this problem has progressed way beyond my skill level at this point. I like my mechanic, but I'm gettin' sick of seein' him so much.
Thanks! :sick:
Just thinking out loud... best of luck!
Nor is the dealer any panacea. My mechanic called his friend - a master-tech over at the dealership where I bought the car - for an opinion and when he described the problem the tech said "hey man, we're changin' O2 sensors for that - we do a ton of 'em." I should add that, when the car was new, one of the uptake 02 sensors was replaced under warranty so, at least one of 'em has already been changed.
I'm still not convinced its not the fuel pump - can anybody dissuade me from that point of view?
-FS
Another shot in the dark, my 98 Corolla starting having acceleration and cruising issues, with abrupt acceleration and cruising was impossible without having to constantly move the gas pedal up & down. After a few weeks of this problem the engine light starting coming on. Took the car in and they discovered a bad pedal position sensor (PPS) in the car. Once they replaced the PPS, everything was groovy.
I've seen complaints before with rocks puting holes in the condensor.
When I got my 04 Accord, I placed some screening (3/8" hardware cloth) behind the bumper. I sprayed the screening black before installing, and unless you get down low and close to the bumper, you can't see it.
Mrbill
But my dealer didn't do a thing for me until I contacted American honda and opened a case number. Geez!
This is a known problem. Contact American Honda even if your dealer is on the ball. If they are not, complain! and make yourself known. Honda will fix it cuz it's a known issue. My dealer said they've done LOTS of these trannies on these cars.
But I have to say, my dealer really messed it up.
Let's revisit this topic for a moment! Suppose your Accord, had a design flaw that allowed normal rain water, (not flooding), to seep into an ignition component in the engine compartment, causing it to fail. Would Honda be responsible for the repair, and the correction of the design flaw? ----or ---- Suppose your Accord's air intake system, had a design flaw that allowed dirt to enter the engine, thus causing extensive damage, would Honda be responsible for the repair? The answer to both questions is "YES"! The A/C component problem is the result of a design flaw that allows road gravel, "kicked up by trucks" to enter the grill area, and damage A/C components. YOU, as the owner of the vehicle, did not design the grill area, nor did you alter the grill area. You simply drive the vehicle, on the paved roads of the United States! This is a "Honda Design," and the problem exists because of that design! Simply put, Honda is responsible for the repair, and also for the correction of the problem, if they want to eliminate future repairs to that component. ----- Best regards. ---- Dwayne
the policy. I doubt that a simple query would prompt a rate increase. Even if it did, that's why you buy insurance. They will up rates periodically, usually as a group anyway. In my case $600 buys 6 months on my policy.
After seeing the complaint here a year ago about the same thing happening to their car, I did the modification to my car. I also have been more aware of what other cars have in the front end for condenser protection. For what I've seen, the Accord isn't any better or worse then the majority of other cars on the road.
If a stone hits your headlamp and breaks it, is Honda liable since they didn't use a plastic that is more resistant to stones? If your last car was a Saturn, and now with your Accord you have two large door dings, would you feel that Honda should be liable since they don't use dent resistant door skins? The same argument can be used with just about any damage.
Your always at risk for a hole in the condenser from a rock, a nail in a tire, a stone chip in the windshield or numerous other damages that can happen to a car.
I would also be concerned with submitting a claim to your insurance agent. If you did, and a short time later you were in an accident, two claims in a row could put you at risk of a huge increase in insurance cost, or worse, cancellation.
Mrbill
I was going to say something similar, like when my blinker on my 1996 got busted by a rock (the rock was even still sitting IN the blinker when it got hit), I got incredibly lucky and only had to pay for the part (the blinker housing), and the service manager installed it himself. I would expect to have to pay for any rock damage though. It's like hitting a pothole and ruining a wheel. It isn't the wheel's fault, meaning it's not Honda's problem. Same goes true for windshields, paint, etc...
You can try an inquiry with Honda, but I doubt you'd get far with getting reimbursed.
Honda is not the only car on the road this can happen to. We did have this very thing happen on our Pilot, and I installed a mesh screen afterwards to keep it from happening again. Its simply bad luck and life with a car. I've read of identical occurences on other makes and models, as well.
it has happened to people i know, even myself. it's wrong but it happens.
my advice, if the cost of the repair is consistent (i'm not saying identical, could be several hundreds apart 3, 4 or $500 between deductable and cost of repair) - i would seriously consider NOT reporting it.
it seems silly and counter to the argument "but that is why you buy insurance". i know this.
YMMV.
Rusted rotors? I've NEVER had ANY vehicle that didn't come straight off the lot with rusted rotors. The edges and center where the pads don't touch are rusted all the time. Where the pads do touch gets surface rust every night and it burns off the first time I use the brakes the next day. It was that way with my first car 15 years ago, and it was that way with all 17 cars I've had since then.
Just what kind of cars are in your lot? I can go out to my lot here and find hundreds of cars from various makes with rusted rotors.
Maybe the problem is I don't understand what you are referring to.
Tell you what, here is a picture of my Volvo's Brembo rotor. I see rust around the edge and in the center (again, where the pads don't touch). This is what I thought you were referring to. Did I not understand your post?
http://www.geocities.com/xcab_99/DSC00059.JPG
A little research showed that Wikipedia addressed this: "...A rust problem has been prevalent on the Accord since its introduction in the 70's, yet the design flaw remained until 2003. This flaw caused the Accord to typically form rust in or around the rear wheelwells. Repairs can reach into the thousands depending on the severity of the corrosion."
I respect your opinion as this forum's member, however I am not happy to be driving 28K vehicle with visible rust and future expenses. All visible metal should be protected. Yes, I expected it to be rusty eventually in 3-4 years, but not on a brand new vehicle.
On top of that, if you want to drive ugly rusted car - it is your choice (freedom). I just wanted to know folks that this is a problem, as well as pointed out the other issues. I would agree to deal with this problems and abysmall service for a car which cost 13k.
http://geocities.com/ussoftwarepro/blog.html
Thanks for any info.
Lea
My understanding of a wheelwell is the opening around the wheels (sheetmetal) not the rotors or rims.
Yes, Hondas did have serious rust problems in the 70's (wheelwell sheetmetal). For what I remember, they even did free rust repairs since it was so bad.
The rust you show in the pics are of the brake rotors. The second pic seems to show the inner side of the rim? (a little unclear to me)
Is that an alloy rim? If so, how can it be rusty?
For what I've read, some rotors are plated in the non-pad contact areas. Honda doesn't seem to do that.
Mrbill
I live in WI where they love to dump tons of salt on the roads. My 04 did see one winter, so they should show rust by now if they wern't coated with something, although I don't think they have any sort of plating.
Mrbill
Mechanic finally changed the EGR valve. So far it hasn't coded (yet) and the idle seems smoother overall. However, it still runs a little rough when it first starts cold and I'm afraid this problem may not yet be fully solved.
-FS
"D3" works similarly to "D", except that it limits the gears to only 1, 2, and 3. It can be useful in hilly/curvy situations where engine braking is useful, as well as to prevent gear hunting in low-speed situations (below, say 40MPH).
"2" keeps the car in 2nd gear, and it will not return to first gear for any reason. This is useful for starting out in icy/snowy conditions, and provides further engine braking for low-speed heavy-braking applications (VERY steep hills).
"1" holds the car in first gear. Using 1, 2, D3, and D, the car can be shifted much like a manual.
Read your owners manual, it will tell you the same thing I did.
Also, it is safe, if not particularly healthy for the transmission, to use these gears as long as you are below 6,500 RPM, aka the REDLINE.
Also, as others have said, that does not look like rust to me. I found that same stuff on the inside of other wheels I've had and it can come off with alot of scrubbing. I found a plastic brillo pad (ummm... like a scotchbrite pad?) and rubbing alcohol works best. Just don't scrub too hard or you'll scratch it. this is dirt, grime, and caked/baked on brake dust.
I've already showed you BREMBO rotors with that rust. So I'm not sure how else to help you out here. Brembo is considered one of the best on the market. And here they are with the same rust you are showing on your accord. So, again, THIS IS COMMON AND NOT ACCORD-SPECIFIC. there is NOTHING wrong with your car!
I own a 2004 Honda Accord-4cyl sedan. The first maint. service was done by the dealer where I bought the car. Then the next oil change was done at a gas station but I bought synthetic oil, and the oil filter myself. Now there are 20K miles on the car and the maint. required light is on.
My question is since synthetic oil was used the last oil change, do I have to keep using synthetic oil--which is very expensive.
And, if I take the car to a non-dealer to perform the service how I find out what else besides the oil change should be done at 20K miles
Thanks in advance
1). your owners manual has recommended service intervals based on your usage (city / highway, warm / cold climate, start cycles / trip duration).
2). edmund's maintenance guide:
http://www.edmunds.com/maintenance/MaintenanceServlet
Sarah
Anyways, as your aware of, Hondas warranty doesnt cover "abuse, misuse, accidental damage, or acts of God"
If they did stand by the part, it would have to be a goodwill repair. I'd rather save a goodwill repair for something BIG like a failed tranny. I'll bet they keep a database of goodwill repairs.
Mrbill
Once Mobil 1 became a full synthetic, he found he had little argument as to why Amsoil would be any better.
I am sure Amsoil may have some properties that exceed even Mobil 1. But when you consider a full synthetic exceeds the best petroleum based oils in many areas that are not even critical for normal driving conditions, there is little I can see any other more expensive synthetic can do for you other than make your wallet lighter.
Yes, Mobil 1 is used in million dollar racing engines too and the apple does not fall far from the tree. It is most likely a race formulation that is very expensive, needs to be changed with every race, at a minimum, and probably not as friendly in sub zero temps or stop and go driving. The things the Mobil 1 you find on the shelf do very well.
Thanks in advance for the help
Getting the plugs out of the plastic cover over the bumper/radiator may be a little bit of a pain. The plugs on my 04 had a phillips looking cross in the center, turning them didn't back them out till I pried up a little on them while turning. Once out, the rest of the plug pulls out.
Mrbill
My new Accord with about 450 miles is making a poppingnoise/rubbing noise/cracking noise from the front suspension area or near the brake pedal @ about 5 mph - when backing up or moving forward. I also hear the noise when making turns at very low speeds. I will bring it in tomorow or Tuesday. Any thoughts or ideas? Maybe something with the suspension being too loose/too tight? Is this the popping noise related to the welds from the 2003s? Thanks.
My 2006 EX with 8,100 miles has done this since day one, also.
