Visitor Agreement.
FWIW, I may have a bigger problem.
I have been driving with my low beam lights on for years now. I just think it’s safer to be more easily seen even though I have not had a problem without them for all the years I drove without them on during the day. However, because of this they burn out more often. I’ve replaced both low beams on the ‘05 XG350 once and one of them twice (2 weeks ago) because of this late habit I’ve acquired. The cost of those lights for that car is pretty small (about $7/8 each) but that won’t be the case when I lose one on the Genny. The last time I checked, one of those will cost me around $90 each minimum. Son #1 has asked me a couple times about whether I still think it’s a good idea, given the cost, and I do but I’ll admit that I won’t like it when I have to replace one, I’ll tell ya that. :sick:
I thought “daytime running lights” would have been standard equipment by now but they aren’t. I think GM started that feature in the mid ‘90s.
But, one thing I am not sure of, is whether they actually last longer than regular bulbs?
I do have them on my 2000 Acura TL (156K on that now), and as far as I know (having only had it a little over 2 years) it never had a bulb replaced. I suppose I should ask my sister who was the original owner!
I was stunned that my Genesis didn't have DRLs. My 99 S10 has them and its fairly stripped down (crank windows, etc).
What I do know is that they perform loads better than standard headlamps.
"Do not touch the surface of a quartz halogen bulb with
bare fingers, as the quartz surface will be exposed to
the salts and oils in the hand. This will cause a weak
area and lead to premature lamp failure. If you happen
to contact the bulb with your fingers, carefully clean
the quartz surface with a gentle solvent such as alchohol."
http://www.teklight.com/FAQ_s/faq_s.html
Other sites basically repeat this precaution, with even
less of an explanation as to the dynamics. These sites
can be found in the search results I've provided below.
These sites include:
USHIO.com
"Do not touch the Halogen bulb surface or inside reflectors
with your bare hands. Oils from skin can lead to breakage
or shorten the life of the lamp. Use clean gloves or lint
free cloth for installation and removal."
http://www.ushio.com/safety.htm
TopOneMall.com
"Bulb Care: Do not handle the glass part of a halogen bulb.
The oil from your hands or any other residue on the glass
can cause the bulb to burn out prematurely. If you
accidentally touch the glass clean it immediately with
isopropyl alcohol and a lint-free cloth."
http://www.toponemall.com/94310wutonmlihgedba.html
Page 10 of this pdf file from Helios, Proteus & Apollo
Lighting Systems:
"Do not touch the new bulb with your fingers; using a
cloth to hold the bulb, gently push it into the socket.
If there is any doubt that the bulb may have been
contaminated by your touch, you should clean the bulb
before its first use. Take a clean cloth dipped in a
small amount of rubbing/isopropyl alcohol and gently
brush off the bulb surface."
http://www.halcyon.net/manuals/helios-proteus_webmanual03.pdf
And, finally, and directly to the point of your question,
from SandCastleDesigns:
"Touching a halogen bulb with your bare hands will ruin it."
http://www.sandcastledesigns.com/tipofmonth.htm
Darn. Well, at least jmonroe and kirstie are still keeping the faith.
I did want to nominate the Volkswagen (now on topic) mini Darth Vader commercial as my Super Bowl favorite. Very cute. Though I thought it odd/dangerous they'd start a car with a small child in front of it.
The Kim Kardashian commercial got the sleaziest ad award. Can't believe they'd put something like that on t.v during family programming hours. :sick:
Sleaziest was the Serta ad - "it's better on springs".
The full commercial is 1 minute long and it's even better. http://www.youtube.com/watch?v=R55e-uHQna0 That little kid is a good actor.
The Mini "Put it in the boot" was pretty sleazy as well. I'm surprised they got away with some of the content.
I guess that means my 73,000 mile 2007 Mazdaspeed must be German and my 108,000 mile 2004 X3 and 124,000 mile 1995 3 Series are Japanese- seeing as how the Mazda has cost more to repair and maintain than the two BMWs combined...
:P
The game itself was great. Once again a good game - a relatively recent phenomenon which has made the whole Super Bowl thing work loads better.
I was rooting for Green Bay mostly because Ben Roethlisberger does not play for them.
Yep, I learned all about that back in the '70s and early '80s- on every car I bought I would replace the crap sealed beams with Cibie or Hella E-Code lamps- for off-road use only of course...
As a matter of fact, I even slapped a set of Hella E-Codes on my Wrangler; I absolutely HATE poor headlamps...
I wonder if there were any good 'Super Bowl' car deals to be had in Dallas?
Yeah but those where the old Ike dollars that were also used for small manhole covers. Todays dollar coins aren't much bigger than a quarter.
You could just rip them out by hand.
Another nasty NYC area trick (not exclusive I am sure) was for mechanics to remove your airbags and disable the warning light. Most people just wouldn't notice the light didn't activate when you start the car.
I do remember now it being an (expensive) issue.
Well...I did say there are exceptions and you seem to have found one. Me, I go with the percentages.
Given how I seem to baby a car when it comes to maintenance, I might even be able to live with a German car but I'd rather not take the chance.
My only complaint about DRLs is the inability to temporarily shut them down when we tour some of the Christmas light displays each December. Until this year we've always had at least one vehicle without DRLs, but now we're stuck with both cars having them. Maybe some painters tape will do the trick....
Richard
To stay on topic: It gets expensive to operate all of those Tahoe's and Escalade's carrying the security guys.
Richard
Richard
I have saved thousands of dollars not buying GAP insurance and with over 30 years of driving never lost a cent due to insurance not paying off a total loss.
Hope that when you get the new Sonata you don't total it on your first day!
It probably loses 25% of it's value when you drive it off the lot! :sick:
I thought DRLs were supposed to be a great safety feature, and prevented lots of accidents.
I have noticed driving in Florida a lot of old codgers drift over the line into oncoming traffic....and this happens on narrow bridges - at least in one case. I will say, one guy that did it was a young guy with his baseball cap on backwards.
Also see lots of people driving while talking on their cell phones in Florida (don't know what the law is down here)....and they aren't driving very well. On the highway one lady took the right lanes at the split in the road, realized she should go left, flew across 2 lanes of traffic and a grass median, drove along the gravel, and came up on the road just ahead of me...while she continued to talk on her cell phone. The Fusion has good brakes thank goodness!
Richard said -Me: (In a somber tone) Mr. Richard died last week. Could you please remove him from your mailing list?
Fezo said - When are they reading the will
I think he was looking forward to getting an SRX.
I’m not so sure about that. I think he had his hand out for anything that fell free from the Will and I do mean “free”.
The complaints are that having to carry 4 new dollars returned as change is too much. People have to b*&^% about everything nowadays.
$1 and $2 coins aren't much of a problem. Getting 4 $1 bills in change is worse in some ways. Your wallet gets so thick it is uncomfortable to sit down....and it sticks out in the rear.
The looneys and toonies are slightly larger than a quarter and are light.
Think of it this way, instead of carrying nickels, dimes and quarters around one looney covers a lot of change. I keep a bag of change in the car for meters, car washes etc.
I am using American money in Florida and I think having $1 and $2 coins is just easier. Also, different colored bills is better, I have probably handed out a few $20s instead of $1s on the toll bridge.
Um, no. The Packers beat the Bears. And hey, there were plenty of Secret Service guys anyway. W was there.
True, but I really think he was hoping for the SRX.
I on the other hand will never be disappointed when it comes to inheritance
money. I don't know where it will ever come from and I don't expect any to come my way.
If someone wants to leave me an SRX or other fine car, that would be alright with me, but it will be a bonus, and would be a very nice surprise.
Don't expect anything and you won't be disappointed.
That describes my wife to a tee!!!!!
I worked on the Naval Base, Norfolk, VA and I remember being asked to dim to parking lights for a decal check back in 2000 while driving a 2000 Z71 pickup. I asked the guard to look and see if he could find a way to cut the lights off. He couldn't.
While the engine is running, the only way to turn off the headlights was to apply the parking brake. Strange, eh?
There is a commercial Christmas display located in a park in my region. They charge you by the car. They have small squares of cloth with magnets sewn into the top edge that they put over DRL's before you drive through. They remove them on the way out. Works pretty slick.
Not always. If I didn’t know better I’d say I saw (BARELY) that guy in my Burgh last night. How people can drive without their lights on at night is beyond me and I’ve seen this too often lately. The worst was seeing this twice in December cruising at 70 MPH on the PA Turnpike at 5:30 PM. :mad:
2013 LX 570 2016 LS 460
The lights in the Jeep Wrangler are crap. A few people have put in HID kits and the difference is amazing. However, one guy recently installed LED lights. WOW! They are so much better than HID's. Of course, they are over $1000.
(This is from another Jeep forum. As per Edmund's rules, I cannot post the link to it)
:P
The odds are against it.
Plus if I go that route I have some leads of some used 2011's.
That's easy to fix.
Richard
Imagine the sounds that would come from him if you left him your old computer? We couldn’t print those words here nor is there an Emotorcon for them. :sick:
Perfect! I can just see Fezo arriving in a new rented suit, with his entire family, thinking he is going to be driving home in his new SRX. Be sure to leave him a $5 off coupon for the nearest Steak and Shake too!
