Visitor Agreement.
Hello, I am living in Gulf Country, I was driving a Honda Accord and I bought my Camry Mid Range (GLX)last month, here the models are GL, GLX & SE. I have 2-3 questions :
1). While driving in traffic (slow moving), I found the Gear Shifting panel area(where the writings of Gear P, R, D etc) is getting heated, it is just in a small area but getting quite hot..!. There is no problem in normal driving. Can anyone advise me what is the reason, is it normal?
2). As they claim the new camry's suspension is improved and redesigned but I feel it is stiffened from previous model (I used to drive my brother's camry 2005), is that also normal?.
3) When driving more than 100km speed the wind noise and road noise are disturbing, can it be rectified?.
It would be very appreciated if anyone can reply authoritively.
Matthew
(2) Generally, "improved" suspension means stiffer. That improves handling, especially around corners, but also increases "road feel" which most people see as harsher.
(3)Camry's are known for wind noise. Over 60 MPH (which 100km is, but most in the Gulf area use MPH) it certainly gets more noticeable. Try gently pulling down from the top of the door gaskets, out from the sides of them, with the windows down. Run them up and test drive it, see if that helps. Often the problem is the seal not being seated when you run them up after you hit speed, and the pressure inside isn't great enough to seal it completely.
On such a new car, the dealer should be equipped to handle the wind noise issue easily enough. You should also check the plate inside the driver's side door for the proper inflation level for your tires, not the side of the tire. Too great of pressure will greatly increase the road noise as well.
Thank you so much for your detailed reply. So I don't need to worry about this shift box heating. Althouhg I noticed no malfunction signal appeared and it does not affect vehicle performance when the box gets heated.
For the windnoise, I will do accordingly as you advised.
Many thanks again and best wishes.
Mathew
when it's cold, i would imagine they'd run the engine a little richer based on air temp.
hmmm.
Does anyone have a fix?
I also have the front ticking or rattle noise coming from my front dash/window area. I saw a TSB out on this and it look like a lot of work to fix this problem? Has anyone used this TSB?
I have to say I'm not very happy with this product. I think Toyota is very over rated. This is my first Toyota and I'm considering selling it to get rid of the headache
Buyer beware!
~alpha
Any way I am now back in contact with Toyota corporation and waiting for them to call me back.
That's an odd statement, considering:
1. The new Camry has 4 wheel disc brakes. No drums at all.
2. Brake drums have nothing at all to do with a car's tranny.
You either misheard him or they are really messing with you.
In any event, sounds to me like you were treated more than fairly. Not excusing them denying the problem, but like I said above, two other service managers haven't either. They paid for your rental, extended the warranty and even made one of your monthly payments.
It is always maddening when mechanical problems hit us in a new car, but in my book they get A+ for going the extra mile in taking care of you, in spite of the initial trouble.
:lemon: :sick: :P
Although a pain in the [non-permissible content removed] for you, I can understand them, ignorant about the problem at the dealership, either because they aren't keeping up with the service bulletins (most likely) or never getting it, replacing the original tranny with another thats the same.
I imagine he won't have a problem getting approval for another payment, and of course, extending your warranty. You might ask him about getting you a future credit ($500-$1000) on a new Toyota in the future. They often do that as a customer service ploy.
I have not looked at my Camry Manuals to see if they have a break out diagram of the transmission, too much going on right now.
No, not really, substantially cooler, COLDER, intake airflow will have substantially the same effect as switching to a higher octane fuel.
The dealers are recommending that owners experiencing the downshift delay/hesitation switch to a higher octane fuel to help alleviate the problem. A higher octane fuel will result in the engine being able to operate under load at a lower RPM, higher gear ratio, without knock/ping due to engine "lugging".
So in some COLD intake airflow instances, more "often" tha otherwise, the engine can remain in the (just previously) "upshifted" ratio, however briefly, when you reapply pressure to the gas pedal. Even a brief period of engine RPM above idle will result in a higher level of ATF pump pressure/flow and so now when/if the downshift does occur due to progressively heavier gas pedal pressure it will be smooth and "seamless".
After the valve body replacement, the flares occurred even after the engine was warm, and the cold engine flares were 1000 RPM in magnitude. On one occasion, when I pressed the gas after coasting momentarily and making a right turn at a busy intersection to go up a hill, the transmission refused to engage, and the car slowed nearly to a halt. After about 5 seconds of the motor spinning helplessly while the transmission was disengaged and while other drivers were swerving around me and honking angrily, I heard a "bang" under the hood, and the car lurched violently forward. I called the dealer, and they asked how many miles I'd driven since the valve body replacement. I said about 500 (the car was less than 2 months old, and had only 3.5K miles on it). The dealer told me that the transmission needs more time to learn my driving style, and that I should see if the problem goes away after a few hundred more miles. Being an engineer, I knew this was BS, and rhetorically asked the man, "If the transmission will not shift properly until driven by the same person for about 1000 miles, then won't every Camry that's just rolled off the assembly line and is sitting at the dealer's lot with less than 100 miles on it shift erratically during each test drive? Would Toyota design their cars so that they don't work properly until a thousand miles after they've been test driven by numerous potential customers?" He then told me to take the car in.
Prior to the next service appointment, the transmission went from bad to worse. The flares occurred during 2-3 and 3-4 shifts, the transmission frequently failed to engage when pressing the gas after coasting or after stopped at a light, and, when driving at a constant speed of 20-35 mph on a flat road, it would erratically jump between gears (seemed to be 2nd and 4th) every 5 or so seconds, causing the tachometer to pop between 2K RPM and 4K RPM every 5 seconds.
After inspecting the car, the dealer said I needed a new transmission, and ordered one. I called Toyota's Customer Experience line, and told them I wanted a new car. I said I'd read about numerous people having problems with repaired V6 Camrys, and people having problems with 4-cylinder Camry transmissions, so I wanted a Hybrid Camry (different drive-train). I also said that I did not think it fair that I paid a new car price for a car that will undergo major disassembly at a dealer and no longer be "perfect". Toyota flatly told me they would not do this, and that they were only obligated to keep fixing my car as long as it was under warranty. I then asked if they'd pay some or all of the cost difference if I traded the car in for a Hybrid Camry. Again, I was told they wouldn't do this, and that Toyota Corporate has no control over what my trade in would be worth or what I'd be charged for a new Hybrid Camry. The dealer working with Toyota Corporate then told me my new 2-month old Camry that cost me $32K was only worth $24.5K, and that the Hybrid would cost me $28K plus $1.5K tax. The dealer was sympathetic and courteous, and I understand they need to make a profit. I again called my Toyota Case Manager, and reitereated my request, mentioning that I'd bought *9* new Toyota/Lexus vehicles during the past 15 years, and that I'm losing faith in the company. The Corporate Case Manager conceded that I've been a "tremendous Toyota customer", but that all they can do is keep repairing my car, since it is under warranty.
This time, my car was in the shop 2.5 weeks, since the transmission was backordered. Prior to picking it up, I called the Toyota Case Manager again and asked if they'd buy back the car or pay the difference if I traded it in for a Hybrid Camry. Again, no luck. When I finally got it back, not only did it flare during the drive home, but I found that the dealer had screwed up my car:
* The paint on the entire roof and hood had faint scratch marks (like swirl marks, but straight) - someone had likely used a paper towel to wipe it off after washing it.
* Three hoses under the hood were just dangling next to the clips to which they were supposed to be attached.
* A plastic device on the air intake system had a big scrape on it, with a thin piece of plastic curling up like a partially peeled potato.
* Some plastic clips supposed to secure plastic in the wheel well were missing.
* The holes into which several screws went that were supposed to secure the plastic cover under the engine were stripped.
* A metal heat-shield that was supposed to be secured at both ends to a tube that ran near the hot exhaust system was only secured at one end.
* A black greasy scuff mark was on the driver side door sill, and a some black marks are on the center console next to the shifter.
* Clear grease marks (hand prints) were all over the passenger side of the dash board
* A piece of weather stripping supposed to be under the cowl (plastic under wiper arms) was pulled out 2" and snagged on a large bolt in the engine bay
* A grimy screwdriver lay in the engine bay that had the inscription on its handle, "There are no loose screws at Walter Johnson High School".
I am totally torqued at Toyota. This is the 9th new Toyota/Lexus car I've bought for myself or wife in the past 15 years, and will be the last ever unless they start putting customers first. Now I want to trade this thing for something else more than ever. :lemon:
i'd go back to the dealership and ask to speak to the owner and the service manager together.
At least you got a quality screwdriver out of the deal.
2003 – 2007 model year Toyota vehicles. 2004 – 2007 model year Scion vehicles.
If a creak, tick, or rattle noise is heard at the top or bottom of the windshield, the source of the noise may be the two windshield stoppers bonded to the top of the windshield or the windshield retainers bonded to the lower edge of the windshield. This bulletin provides the recommended repair procedure to eliminate these types of noises from the windshield area
'07 Camry v6. 400 new miles on second transmission.
Mostly better. No flaring. A little hesitant. But it did completely slip out of second gear a couple of times about a week or so earlier. Fortunately this time it did not 'slam' back into gear. Also, when I start out after the car has been sitting for a few hours, the transmission slips (like when you ride the clutch) in 1st and 2nd. By the time it gets to 3rd. it behaves normal.
So, I have no faith in this transmission at the moment.
Plus it continues to engine brake (on full throttle lift) half the time and not the other half, and then unlocks tranny as my speed drops below 25mph; which changes the braking effect in mid-deceleration and I feel the car 'slip' forward.
What a royal mistake in buying this Toyota. This is my first and last Toyota.
Is there nation-wide recall around the corner? Please say yes.
9/18/2006
This did NOT work for my SE V6. The dealer took both the top and bottom ones out and the "rattle" is still there. I believe that it is something to do with the Defrost vents and/or the 2 center air vents. The rattle sounds like HARD plastic.
This started when it got colder outside and lessens when the "vents" become warm.
Let us know how your dealer tries to fix it.
Sound localization is a tricky thing and can be influenced by materials, seat location, interior structure, etc.
I'd have a spouse or friend drive and sit in the passenger seat. I bet you'll be able to get a better handle on the source of the noise then.
Just to document the beginning of my 2007 Camry V6 transmission saga. :-)
This afternoon, I called my Toyota dealer in Indianapolis. I explained to service the issue I had with my transmission's 3rd-4th flare. Told them that it does just like described in TSB TC008-06, except it only does it once after a cold start instead of for approximately 5 minutes as described. That it started at about 1200 miles, and at present with 2800 miles, it's gotten no worse, and that I avoid the flare by starting out cold in sequential 3rd gear, and let up on the gas for a moment to let it go into 4th smoothly. The put it in Drive and drive normally until the next cold start.
I asked him if he's seen much of this issue come in? He said he'd seen some of these transmissions that had some real issues, but he didn't elaborate on how much success they'd had fixing them.
He went on to tell me how I could expect the flare to "get better" as my transmission learned my driving style. (I'm only telling you what he said )
Then he told me of taking a new 2007 Camry home to let his wife drive it, and she parked it in the garage and told him that this car's transmission "shifted funny" and she didn't like it. He said that so many people are having trouble getting used to the different way this new transmission shifts, but that there really isn't anything wrong with it.
Lastly, he asked me to bring my car in and he'd have a tech go for a drive with me to confirm that I likely didn't have anything to worry about.
This is just for the record.
I have my own personal opinion about this, but will leave the reader to decide for theirself.
This is very annoying problem. I read the TSB at a dealership and it seemed to be a lot of work. My dealership told me they never did any work like that.
I can also say my second trans is not working properly.
RPM flare, hard engine breaking, ect
A recall would be nice?
The problem was that people don't go looking for a discussion with "camry" and "woes" in the title, they go looking for a discussion with "camry" and "repairs" in the name. That's all there is to it.
That said, how 'bout we get back on topic?
the question is valid one. it has to do with consistency. why should the camry have a problems and repairs discussion group, when many of the other vehicles have a discussion group with problems and solutions?
in fact, the Woes forum was named such i believe because of people having issues following the introduction of the model. there really weren't solutions being offered at the time for the shifting / hesitation problems people were experiencing.
We are trying to make the names of our discussions easier to find when people do searches. More people will look for Camry Repairs than for Camry Solutions or Camry Woes (with or without the word "problems"); that's just a fact.
I don't want to derail this discussion any further. We have a new name here, but we don't have a new subject.
Everyone should certainly feel free to email me with other comments, but this is the same discussion as it was since it was first created. So let's just continue on with the questions, answers, issues, problems, repairs, woes, solutions anyone is having with their 07 Camry. :-)
Doing that, the more "normal" problems and repair solutions are up-front, here, for newbies to find and read the already tried and true solutions, and these other two or three issues are by themselves, with the attendant topic digressions and in-depth give and take among our more advanced and technically-minded users.....
Again, we don't need to get sidetracked with this detail. Feel free to email me if you want to talk more about it, but meanwhile, let's carry on, please.
Could this click have something to do with the anti-lock braking system? Vehicle skid control? It also has the push button start/keyless entry system.
