A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
The hesitation TSB 0068-08 is for both manual and automatic transmission I-4 engines, and not just 2007s - could be 2008 also.
Several days later, I'm still leaving for a timeline to obtain the parts and repairs. The vehicle has just under 32,000 km on it.
This may be a bigger issue than just myself, as it appears that Toyota issued a Tech Tip TVI2310 in September of 2008 identifying the condition and recommending replacement of the oil line. According to the Toyota document, Toyota models affected can include the 2005 to 2009 Avalon, 2007 to 2009 Camry V6, 2007 to 2009 Sienna, 2008 to 2009 Highlander, and the 2006 to 2009 RAV4.
I cannot understand why Toyota has not issued a recall, nor why they haven't ramped up production of the replacement part (unless this a VERY widespread problem!). It would appear that they don't want to admit to a serious problem, to protect their (past) quality reputation, but they are seriously risking brand reputation, and possible legal issues due to the inconvenience (class action, anyone?).
I have a scan of the Toyota Tech Tip........is it possible to post it to this forum, so that others can see the document?
Recalls are government mandated things that are issued when something could cause a serious safety issue, like a wheel breaking and falling off, to give a simple example. Or some cars (it wasn't Toyota) that burst into flames while parked in your garage.
You could argue that the lack of oil could seize the engine and cause an accident, but it is not likely, or the gov't would have forced a recall.
You have a copy of the TSB, but it is all over the net already if you do a search. It may have been posted in Edmunds already.
All manufactures have issues like this, even Honda and Toyota. But they are still tops in quality, if you look at Consumer Reports and JD Power.
Hope you get the part soon. I think the warranty covers a free loaner if your car is kept overnight.
I also recognize that many recalls are driven by safety, but if Toyota were more customer-focussed, given what appears to be a problem that could impact many, they could probably score more points and reduce brand damage by being proactive. I've been in business for over 33 years, and I'm not impressed with Toyota regarding this matter.
As for Consumer Reports, I'll be doing the Auto Survey shortly.......
It appears that you may have a 4 cylinder Camry, and the problem I've had is, to my knowledge, a problem specific to recent V6 engines. The VVT oil line problem with the V6 engines causes leaks on the outside of the engine, which then leak down to the underside of the engine/vehicle.
If you are having an issue with oil leaks, I suspect that the problem SHOULD be covered by the power train warranty (normally five years) rather than the basic three year warranty. However, these warranties have a mileage limit, so you'll need to refer to your owner documentation.
Hope this helps.
I'm not sure if Toyota knew that the oil line was a widespread or a very small problem. Sometimes, it is hard to tell at first. At least they have the correction and it's an easy fix, once the part is available.
I truly hope you get yours fixed soon, and I trust they gave you a car to use in the meantime? Any other issues with yours?
My '07 CE I4 manual has been great, other than having TSB0068-08 done (25 minute reprogramming of the ECU to resolve an intermittent hesitation). Other than that, perfect, just as I expect. I can forgive this one minor error, and I know it won't cause any more future issues, so I'd still rate it excellent.
I will be doing my wife's Toyota's 20K maintenance as per owner's manual (it is 2007 Camry with I-4 engine and auto-tranny ) . I am OK with most of the items except one . Manual suggests to tighten nuts&bolts on chassis , it says "front/rear suspension member retaining bolts to specified torque " .
Can anyone tell me where I should look for these bolts and torque values (if possible ) .
This site has been a good source of information . I thank all the contributors for their help .
It is a Japanese company !
The Chrysler,Ford or GM car you buy ,especially if it is ASSEMBLED IN THE U.S.A. creates more jobs ( including NON-UNION jobs ) for AMERICANS then the Hondas,Toyotas or whatever built here.
Even the AMERICAN content on the BIG 3 autos when averaged out is MORE AMERICAN then the average on a transplant.
Yes afew transplants have a high American content but again it is just afew.
Not totting the BUY AMERICAN thing here just telling that these transplants are"a joke" in providing real American jobs.
They provide a "token few" American jobs.
And if you purchased a forgien car BUILT OVERSEAS well you did VERY LITTLE to help your fellow AMERICAN worker.
plain and simple.
The profits on the car (probably around 5% or less) go back to Japan. The vast majority of the cost of the Camry stays in the USA.
Now back to the Camry....
Based on what I have been reading about a possible oil line problem, I made an appointment with my dealer to have the oil line replaced with the "up-dated unit," as a precaution! ----- The cost of the service was $290.00 dollars. -------- My extended Toyota warranty picked up the total cost! ------- Since I do an extensive amount of highway driving as a sales person, I did not want to be worried about an issue on a long trip!
Best regards! ----- Dwayne :shades:
My 2007 camry is shifting badly when I start out from a stop is this a issue that many others are encountering?
What exactly is it doing? Rough shifting? Shifting at wrong shift points, going into the wrong gears?
Have you checked the transmission fluid levels, and/or changed the fluid?
Do some extensive reading of this forum and you'll find all kinds of references to a TSB (Technical Service Bulletin) issued by Toyota to its dealerships advising that owners of 2007 Camry, 4 cylinder automatics, are entitled to a free upgrade to the software that regulates their ECM (Engine Control Module.)
This 'modification' was developed to cure exactly the problems you're experiencing: dodgy shifting...hesitation at intersections...strange 'automatic' gear-changing under a variety of load conditions (like going uphill, etc). And it's probably worth doing, given that the hesitation problem alone can be deadly dangerous if/when it occurs in the face of oncoming traffic in a "turning situation".
Be warned, however, that after this TSB is performed on your car, you will probably notice at least one other shortcoming...notably, the engine will shift into overdrive far earlier than it should, resulting in a low-frequency, "grumbling" sound, as though the engine were being "lugged" (which it IS) at low road speeds. (We assume Toyota has done this to achieve better mileage figures!) This one problem CAN be overcome by manually shifting into 4th (by moving the stick to the left) when driving at low, in-town speeds. This is a bit of a nuisance, however....both because of having to put it INTO fourth AND remembering to move it over to FIFTH once you're moving at highway speed.
As I said.....do some creative searching in this forum, and you'll find lots of info on this whole subject.
Good luck!
Michael
Actually the last TSB that was issued (seems like a year+ ago) fixes that 35-45mph overdrive grumbling/engine lugging. It keeps it in 4th longer. Vehicle runs great.
I must be the only 2007 V6 Camry XLE owner that does not have any of the transmision issues that you are reading about on these boards! My vehicle has almost 48,000 miles, and it will be three years old January 2010. By January, it will have about 60,000 miles. On the highway I get at least 30mpg! I am very satisfied with the quality of this vehicle, and I have a great dealer!
Best regards. ---- Dwayne :shades:
Forget the hi octane.......save your money.
The four cylinder engine is sensitive to the load that the A/C adds to its performance, at both higher speeds AND at idle.
Assuming you are never idling more that the duration of a stoplight (if you ARE idling longer than that...shame on you, you should be shutting off your engine instead of idling).....just enjoy the fact that a) you are cool, with your a/c on......and b) you are idling @ even lower RPM's than usual, therefore saving gas.
If you are concerned about performance "off the line" after sitting there idling, just do what I do, which is momentarily turn off the air until you get back up to regular/highway speed. (Performance with a/c OFF is bad enough without making the poor engine attempt "launch" and "cool" simultaneously!
Cheers.......there's nothing wrong with your car! (Hope your dealer didn't charge you anything for the work HE did; if he did, he's either ignorant, or a crook.)
Michael
Put the gear shift selector in "neutral" while waiting in traffic. This will take the "load" off the engine!
Best regards. -------------------- Dwayne :shades:
If you have DBW the transaxle is less likely to fail prematurely but will not be user friendly exactly.
Another oddity is that I had a creaking sound deep in the dash on the passenger side. They took out the entire dash and found a bad weld, so they fixed the weld and put it back together. No more noise so far, but just picked it up today and just drove home.
It's a really nice, fast and comfortable car, but guess I have long-term concerns about quality and reliability, which are the reasons I bought a Toyota in the first place. My 1998 Ford F150 truck has been absolutely flawless with 98K miles, so seems like American car quality has surpassed Japanese or at least Toyota? Maybe this will be the last repair to my 07 Camry? We'll see...
I have the exact problem as you mentioned. I am at 35k and still under warranty. I noticed the noise from the steering when I was getting out of my garage at about 25k or before that. I have mentioned it to the Toyota service guys during the last 3 oil changes and they did not find anything. Any ideas suggestions for me. Was your problem fixed ? Please let me know when you get a chance.
Moon roof, moon roof drains, window/door seals, drain holes in the bottom of the doors clogged, drain holes in the area below the front windshield clogged, leaking heater core, trunk seal defective, etc, etc.
Played golf with some employees of the Southeastern Toyota Distributor back in the early 2000s, and they had many buybacks at their location..In retrospect, this was during the time frame when they built outstanding cars, so we were told.
Never owned any Asian car, and the only Toyota I would buy is the V-6 SE, for the std Toyota suspension is sloppy and gets really loosey/goosey with age..My acquaintance has a 2002 XLE w/4 banger only 77k miles and ,in excellent condition, but the struts are shot, however a/c is solid, no smell, driving position is horrible, gas mileage okay, and it gets an oil change every 5k..150hp engine moving a 3400# car is no ball-of-fire, but it goes from point A to B..Good car for a senior citizen..
Toyota has cheapen their cars dating back to last model redesign which was either 2006 or 2007..They have lost the quality edge to Honda and some other Korean upstarts..
Detroit cars have issues also, and after owning 41 Big 3 creations plus 2 German they have given lots of pleasure with some dispair at times..
Enjoy your cars for under the current Washington quidelines our love affair with the car will end with misery on wheels, and maybe you will think the next time you cast your ballot...
I am truly disgusted with only 23000 miles on this 07 which is loaded to the gill with the liquicell leather and other nice features.....I don't want to keep it.
Is the engine vibrating, or hesitating? Are you stopped at a stop sign and beginning to accelerate? What gear is the transmission in, and how fast are you going when this occurs? Etc, Etc, Etc.
