Visitor Agreement.
We own (2) kia 4x4 sportages, both had this problem: Our first vehicle we purchased from the dealership, we had this service within the warranty period, they were very accomodating in service and price (we paid about $65.00 total for the fuel filter replacement, not covered by the service campaign.)
The second vehicle was a pre-owned third party purchase, the dealership correctly noted the service campaign sticker from a prior service visit w/ the previous owner, no coverage. Having some knowledge of what was involved with doing the repair, I ended up purchasing the parts from KIA (gas tank, new screws for fuel pump mounting), job took about 4 hours, cost was approx $235.00 US total. * In my case the fuel lines on the vehicle were in good condition, or the time / cost of the repair would have been considerably higher. I hope the info helps.
Let me know what you all find out.
As a side note, I came across something that stated cat. converters are federally warranted for 8/80,000, so even if you aren't the original owner, you might want to research that so you won't have to pay alot for one.
Oh!! And I'm keeping my converter. Apparantly, they have (or older ones do) metals that the price of is going really high right now. I know someone who had about 50 cars sitting on a property and some stole all the converters and something else cannot remember so they could scrap them. :-(
Thx
Frank
I have the chance of a sportage that's in brilliant condition apart from the engine
Good Luck.
Open the hood and on the left front you will see a relay box . Unplug the negativ cable from battery and remove main engine and fuel pump relays and replace them both with the new relays at the same time. Connect your negativ cable back to the battery and engine should start up.
good luck
About a week ago my brakes went out then my clutch started acting up. Is this related or is it another wild goose hunt my Sporty is sending me on?
Finally fixed the No power up hill problem thanks to you guys and gals on this forum so hoping you have some idea what this might be
Thanks John
& vlv.'s made sure vlv guide is good & vlv sprg. is within Factory spec.s[vlv sprg. is showing to be *aprox '30 Lbs[vlv closed] if install vlv sprg. Shim>under inner & outter>vlv sprg this would bring vlv.sprg. tension CLOSED to '50Lbs , believe that this should HELP???? Don't know what else to do ?
PLEASE , if anybody has any other idea , let us know so can see if maybe will HELP our Problem & if have a diff. idea we're willing to see if possibly could HELP our problem ????
THANK U
butch @butch's auto&diesel machine shop
Good luck
All seemed ok with temp gaige and so on. Any ideas. Just hoping i have bought
a bad one :-( Meant to say sounded like it was something to do with the water.
I am worried about the head gasket now as someone said might be this.
Alternator, PS pump and AC compressor maybe one of the bearing on the pulley is getting bad . I had a similar problem and bearing on tensioner pulley was bad.
Good lock
Also, the check engine light comes on at the 1/4 and full marks on the fuel gauge. However, when my fuel is between 3/4 and just above the 1/4 mark, no check engine light. It is extremely difficult to fill the gas tank because it doesn't breath enough and I have to 'power hold' the nozzle just at the right (very slow) intake level or the fuel gushes out and the nozzle shuts off... to everyone there, it looks like I'm trying to overfill my tank.
I've had the intake pipe checked and there were no clogs or anything that could make a significant flow stop and the air holes just on the outside of the mouth of the pipe are clear, yet tiny.
Any answers on either would really be appreciated. Thanks in advance!
Good luck
