Quick Links
Quick Links
Dodge Ram Cummins Diesel Questions
This is the place for questions and comments about the Cummins-powered Dodge Ram trucks!
kcram - Pickups Host
As far as the stalling, I've experienced no problems due to the fault of the truck, only driver error!
The more I read about issues like this, the more convinced I get that I need to stay away from new diesels. I love to have one, and prices are actually pretty good now, but I do not need this kind of a headache. You can buy a lot of gas for $ 4,500, so the same truck with a Hemi 5.7 might be a lot more economical for occassional towing. And you save $ 5,555 up front too.
You put the key in and turn it to power up the electrical system and after a few sec the orange engine icon starts blinking but it goes away when you start up the engine... 2 out of 2 brand new off the lot doing this...
I have looked for leaks but none are visible.
dalej
- low compression at one cylinder
- worn piston rings
- leaking valve stem seals
If your Dodge dealer isn't helpful, a Cummins shop should be able to diagnose this pretty quickly.
I have performed this recall and well the cable can fray and break that isn't your problem. Likely your idle speed is too low. It's adjusted manually on the pre 24 valve cummins engine. It should be about 750rpm in drive with the A/C on if I remember correctly.
It's proper procedure to check and adjust the idle speed while performing the recall so thats likely why it also fixed your condition kcram.
JT
Completely normal and described in your owner's manual. Now that it's cold, the grid heater (which warms the intake air before it reaches the cylinder) will cycle for three minutes after the engine is started to allow better combustion and less smoke. You'll experience this all winter, nothing to worry about.
Yup, I second that. Perfectly normal, both of our 06 Ram 3500 Cummins do it now that its cold out. They do it on initial start up and if its really cold out they will do it even if they have only been shut off for 5 minutes and restarted. Nothing to worry about, enjoy your truck!
A module in Fuel Injector Pump went bad, the voltage was low when the diagnostic was run. About a $2500 dollar part at the Dealership. My cost? $100 deductible - It was still under warranty.
Yup, we have 2 of them, plus a 1997 F-250 Powerstroke. Three diesel trucks is hard on the wallet, lol. Actually the Rams have been great, the Powerstroke has a mind of its own and a hold on the wallet, it only sticks around because we own it for very cheap $$$.
We didn't intend on buying the 2 Rams, just the one I ordered, but a deal that was too good to pass up and a lot of money offered for hubby's aging V10 changed our minds. The $$$ saved on fuel is enough to pay for his Cummins, that V10 was killing us and we were killing it with the trailers we pull. I think last year he spent almost $10k in gas on that V10. :sick:
Below is a link to a picture of the 2 beasts, his is the red one, mine is black.
Trucks
Amd goodness knows I never would have gone without fog lights... the headlights are just too high up.
I agree, I love my fog lights. We ended up with his truck in a rather strange way, thus he had to take what they had. It was the only 6-spd dually cummins that they had after they sold the 03 that I had a deposit on out from under me.
I was ticked to say the least, we drove 300 miles to get it and walk into the dealership to be told they *accidently* sold it. They put him in the 06 for just $3500 more so that made up for it, a new truck vs a 3 year old/30k miles truck. He's going to add fog lights eventually since he likes them on my truck.
Mine turned 10,000 miles yesterday, not even 5 months old yet.
Your truck is mighty nice, real pretty color. That's the color the 03 was, but hubby was thrilled to get the flame red 06.....flame red is his color. Mine is black because my 10 year old picked out the color when I ordered it, sometimes I ask her what she was thinking!
