thanks.....
cp
http://www.youtube.com/watch?v=hc3pcDM_JV0
The window tint looks great with the Galaxy Gray color, and I even got the lightest tint available. It does cut the heat down dramatically. Now to find a sunshade that fits the windshield.
The Sandman
How hard was it to replace the door speakers. I saw some instructions, it did not look that hard but kind of a pain in the [non-permissible content removed]?
How long did it take to do one door? Did you need anything special other than normal tools?
If you look at your iPod's headphone plug, it will be a cable with the same plug on both ends.
P.S. Don't make it too powerful. I found out someone crack his trunk hood other day.If you do it. Make sure you sound proof the area where the speaker is.
You might interested to know that the speakers in the new Civic are cheap plastic and the mounting holes are horseshoe shaped so that aftermarket speakers do not fit. I discovered a method to install good quality speakers without modifying the Honda. Plus addition of a powered subwoofer. Details are here:- Part 1. Part3 shows the subwoofer design.
There is an adapter box which is installed under the dash. One side has an ipod dock connector and the other side connects to the cd-changer input of the head unit. I installed it myself, but you can just as easily take the whole unit to a car stereo shop for installation.
Bud.
so i went to my autosound guy and he's hooked me up with DLS speakers (anybody know anything about them?) a kicker amp, kicker 10" bass, a speaker to RCA adapter (Since at this point i'm keeping the stock head unit), a remote power adapter and a befuddling diagram to install it all. (befuddling more because i'm not sure of what i'm doing but too cheap to pay anyone else).
the present plan is to amp the rear deck speakers and the woofer in the trunk, replace the stock ones in the front and just run them off the head unit for now.
i installed the rear speakers using a wooden ring that i cut out of 5/8" plywood. (The DLS magnets were bigger than those pioneers in that link and as such would not have worked with his method - at least not based on rough observation) i screwed the speakers to the wood and the wood to the deck. i got three solid screws through the deck into the wood (get your mind out of the gutter).
i don't know why but the sound i'm getting out of the unamplified DLS speakers has no where near the volume of the stock- good but not loud. i checked the leads and the positive and the negatives are where they are supposed to be according to the service manual. is the magnet too big and needs to be amped?
something else that you should know - the front door speakers are exposed to the "elements" - that is, they get wet when it rains. i believed it was designed to do that since there are rubber gaskets on the stock speaker frames - it's actually part of the seal for the inner part of the door. i found this out after i took the door apart after a rain. the drivers were all wet. any ideas for getting around that (without cutting sheet metal)?
David
i just bought an ipod adapter for the honda civic radio aux port (www.icarkits.com). i'm going to install it myself but i'm having trouble getting info on how to remove the panel to get to the radio. can you share how you did it? preferably with photos but anyway you like.
michael
If yours is a different model or year, you can probably find some other electronic accessory on their website, which includes the dash disassembly instructions.
http://www.collegehillshonda.com/instructions/8th_gen_civ_sedan/indashaudio.pdf
does this sound right? if so, your info and the college hills site schematics should be enough to get me through.
michael
Wouldn't it be great if you could just remove the glovebox, and reach around to the back of the unit, and plug the stinker in?
michael
Don't waste your time pulling all other console part, because you don't need it. :P
The cable you could purchase at dealership. Some of the people at dealership don't know much, just beware of it
The other option is spice to the 6-pin connector (blue)
Feel free to asked for detail explanation or pic. :shades:
thanks. not too late. please do provide a detailed explanation and picts. what do i have to do to get access to this connector? what do i have to remove to get to it? do you know if there is an aftermarket adapter from 6-pin to ipod or do i have to go to the dealer?
michael
Honesty, I don't know the aftermarket adapter is avaliable for market. I seen peoples more splicing and T-tap the harnest. I think you could purchase a single 6-pin from dealership. Because I purchase extra radio harnest last month. :P
michael
If you're simply looking to add the aux jack, then you can order it directly from College Hills Honda, or buy it from your dealer. The part number is 08A60-SNA-100, and you can check out the installation instructions here.
btw, i hear that with many cars getting to the back of the radio can be done by simply taking off the glove comp. and reaching through. anyone know if this is true with the 2006 honda civic or am i stuck with taking off the entire front panel?
I tap 12v power source to my Sirius radio adaptor and hook it at the auxilary jack.
If you wait a 1-2 week, I plan to mock a OEM apple Ipod into the car.
I'm kinder waiting for my fog-light and my exhaust chrome tip to arrived right now.
Complete project are: aux. jack, Sirius radio, courtesy light, 12 cd changer, upgrade alarm system, and neon floor (blue and red) light.
Present & future project: Fog-light, chrome exhaust, Ipod, rear end spoiler, tweeter, and new set of wheel.
The Honda OEM Ipod routed behind the center console and routed up behind the glove comp. You used a a coat hanger or flexible electrical wire and tape the harnest to the hanger/wire and pull from the inside glove panel. :shades:
"anyone know if this is true with the 2006 honda civic or am i stuck with taking off the entire front panel? "
False, radio wise, you have remove 6-7 part to reach it. other wise almost all front panel.
The Good news is that it all snap-on with some screw to it. :P
Do you know if the only way to use an MP3 player in the car is to buy the RCA adapter? I have a '06 Civic LX and was told by the dealer that the hookup was in the glove box but reading off of Honda.com it is through the glove box I think into the back of the radio. I can't find it when I remove the glove box.
Actually first time to forum and now I have found all this great info so disregard above question.
Ok, here is a better question now that I know how I get to the back of the radio. Do these kits come for any other MP3 players except ipod? I have a dell and want to do the same thing.
I had one installed in my EX with Navi today.
I talked with the manager and pleaded my case to get a great discount, he knocked off 1/2 of what I was quoted by the service dept months ago and from other dealers as well.
I was worried about the installation, since I have been reading online how complex the installation is, so far no squeaks, gouges to my dash or any damage to my car. I am happy at last.
If not, its kind of lame - since a typical mp3 cd can hold approx 150 tracks. Though one can organize the tracks in subfolders, even then driver has to manually skip initial folders/tracks.
Has anyone else had a problem with their sub woofer?
I have seen some other cables via google beyond the ones you list. I am going to stop by an electronics store today and see what they have in stock. I'll let you know how it goes.
Dan
I'd appreciate any feedback. I have not purchased anything yet and my wife is wanting something soon.
Thanks for the reply.
Robert
I actually went on a hunt localy yesterday and came up empty and frustrated. No dock connector to 3.5mm Jack solution. Lots of ignorance or bad service. I tried Fry's, Circuit City, CompUsa and Best Buy.
I decided to go with the Pocket Dock solution and ordered it over the web. I'll let you know how that works when I get it.
Dan
Cheers
