In quick succession - On (not Start)-Off (not Lock)-On-Off-On
Then watch your odometer display. Any codes will show there (P follow by a 4 digit number).
kcram - Pickups/Wagons Host
i recently had similar a problem , wouldn't shift from 3 to 4 then erratic shifting... i replaced the governor sensor, governor plate and the 3-4 shift sensor. not cheap.. so i went to a dead trans at the wreckers... took out the parts i wanted... works like a charm. i replaced all three parts as i was told by trans shop that it SHOULD be any one of those parts.. i know, i know.. used parts in a trans... but i had to !!!!
my best guess is the 1-2 shift sensor.. or governor sensor... i had a 3-4 shift sensor problem... would only go 1st and 2nd gears no shift to third... it's in this forum somewhere.
i went with used parts!!! lol, i was BROKE... and it still shifts like new....
try a good auto wreckers, these things go without reason both new and used....
It is on the part that the throttle cable hooks to on the engine.
THE ISSUE: after running for a little while the transmission starts to slip out of OD, and the tranny feels like its in nutral and the engine revs way up. then when i put the rpm down it sometimes catches back into gear, there is also a wierd grinding sound coming from the tranny while driving which increases in sound with speed. sound stops when i turn OD off? the worst day ever with the truck happened yesterday after i drove like 20 miles straight, it slipped so bad i couldnt even take off from a stop as if it was in nuetral. Ive heard this is because of the tranny cooler lines, also some valve and sensor? anyone have the same issue and know of a solution. if not im just gonna get a used tranny with 100k on it for $400
98 dodge ram 3500 duelly
If anybody has any suggestions or have had this problem and can help, please let me know.
If all the mechanicals check out and there's no sign of overheating fluid, delayed shifts are usually a computer problem of some sort. And for the non-dealer shops that worked on it, I'd want to know if they changed or added fluid, what kind they used. If it was anything except Chrysler ATF+4, that can cause serious problems.
:confuse: :confuse: :sick:
:shades:
check out the post and ... GOOD LUCK
