Lost? Ask a Host for Help!
18911131455
    Head over to the Honda Accord Group. Since you didn't mention what year the car was, you'll need to choose the appropriate maintenance & repair discussion that you'll find there.
  • recierecie Member Posts: 2
    Is it possible to lock your key in the trunk of the 750 LI?
  • patpat Member Posts: 10,421
    Did you do that?? :surprise: Hope not!
    Check with other 7-Series owners in the BMW 7-Series group and see what they say.
    I didn't but a friend did. The were told when they bought the car that your keys could not be locked inside. They had locked their car and when they closed the trunk remembered that the keys were in his jacket...in the trunk. The car stayed locked.
    That happened to me one time - I was with some friends on a weekend trip and the driver, forgetting that her keys were in her pocket, threw her coat in the back of the car and slammed the trunk shut. The rest of the car was locked. We were there for three hours waiting for a locksmith. :sick:
    Do come by the 7-Series group and talk to other 7-Series owners!!
  • rudy10742rudy10742 Member Posts: 1
    My 1995 F-350 crewcab w/460 engine 39,000 miles, while garaged, the fuse #8 blew I lost speedo read out, over drive lite on shifter blinks and it shifts VERY hard? Need help!
    Check the Ford F-Series topics. Use the "Add a Discussion" link on that page if you don't find suitable matches.
  • jorgecjorgec Member Posts: 6
    My 1996 Buick Riviera with 29200 miles has a problem concerning the oil light it comes on then goes away after the car is driving awhile any feedback on this problem.
    The mechanics says he can't find find the problem and that the oil is fine
  • gonecruzangonecruzan Member Posts: 13
    I was wondering how dealers figure the pricing for a lease. Is there a general formula they use?
  • hime74hime74 Member Posts: 4
    Can anyone please help me in solving my problem. I have a 2003 yaris and only recently factory cd player stopped working. It can not read cd's. Is there any way to clean it from the inside. How can I take the factory cover off? :(
    Start here:
    How to Calculate Monthly Lease payments
    and ask whatever questions you'd like.
    MODERATOR /ADMINISTRATOR
    Review your vehicle
    Here's a good place to post your question:
    Toyota Yaris - Audio, Stereo questions (iPod, Speakers, AUX, etc.)
    Review your vehicle
  • lisaissweet01lisaissweet01 Member Posts: 2
    I have a 92 Audi 100. This car has been running pretty good for the most part. Suddendly the fail safe mode came on and it keeps blowing the #14 fuse.
    Could you please help with this problem?
  • handball54handball54 Member Posts: 1
    Distributor cap rotor on 1997 Nissan Sentra is frozen. Securing screw is removed, but rotor will not pull off. Don't want to get frustrated at such a simple thing and try to pry or hit it and create damage. Will heating up the engine entirely be of help? Any other tricks because this is ridiculous?
    Hey Jorgec, hope you are getting some help in the synthetic oil discussion. I don't see a Riviera discussion - you may want to try the Electronic Gremlins: Electrical Problems That Are Driving You Crazy discussion in case there's a wiring or sensor problem.
    Try the Got a Quick, Technical Question? discussion.
    I'm thinking the same Got a Quick, Technical Question? discussion for the frozen cap; try a search over in Nissan Sentra too, in case it's a recurring problem.
    You could ask Sentra owner and host Pf_Flyer for help, but he tends to grab the BIG hammer. ;)
  • fire_fly35fire_fly35 Member Posts: 2
    177,000 miles, bought it used in March 06' Do not know if it has ever had a trans flush, nor do I know if it has had a timing belt replaced... Here is the problem, when It is shifting it seems to hesitate, then it will almost jerk, then go into the next gear and will continue to run fine as long as I'm driving, but if I have to stop, and then resume it will do that each time it has to shift gears??? Help!! :cry:
    Check the Honda Accord group for relevant topics. You should also have a look at Transmission Traumas?.
  • fishbaitfishbait Member Posts: 1
    Hi- Does anyone have a PDF manual for a 1993 Rodeo 3.2L V6 4x4?
    I want to change the timing chain on my "new" used vehicle. If not a pdf file how about a schematic of the front and removal/installation guidelines for the timing belt? Any help would be appreciated.
    Fishbait
    Try asking in the Isuzu Rodeo Problems & Solutions discussion.
  • danielidedanielide Member Posts: 2
    I need information on how to install a 93 Ford Escort radiator. Here are the complications/problems that most auto part store can't give me answers to my 93ford radiator installation:
    1. the connector 'from the fan/motor' on the radiator is missing.
    2. I do not know where "radiator fan/motor should be connected to 'on the engine or other area'(it looks like the previous owner 'jigger' a wire to the battery to run the fan on the radiator).
    3. there is a open '6 (small)hole/female" connection with nothing connected to it..on the 'passenger side' of the 'front' right side of the engine.
    4. the dealer (not much help either)that there are 3 different types of ways the radiator can be connected to a 93 ford escort! a. above the back left(drv side) ? >>not sure on the other 2.
  • bfennbfenn Member Posts: 4
    My car has a garetts T25 Turbo and a heavy duty clutch on it. It is 3 years old. Whenever I floor it(or really get on) the gas, around 3.5 rpm where the turbo kicks in, my car briefly looses power in a big THUD that shakes the car. It does it in 2, 3, and 4th the most. Does anyone have an idea if its the clutch or turbo?
    Check whether other owners have experienced similar problems in Mazda Protege5. You may also want to visit Turbochargers & Superchargers: Theory and Application.
  • scott73scott73 Member Posts: 3
    My 2003 Expedition power adjustable foot pedals don't move anymore. Since the fuse that controls it controls the seat, and the seat moves, I'm thinking a relay. Any suggestions on how to find the problem. I can hear the click when I push the button, but no movement
    Have a look at the Ford Expedition group. You can post in the Expedition Maintenance and Repair discussion, or you can create your own if you'd like. The Add Discussion link is on the right just over the discussion list.
  • nabbernabber Member Posts: 7
    I was not sure where to post this message. We are buying a Honda Odyssey and got a great price quoted. Everything seems okay with the deal (the price is about 1K under invoice). Anyway, the dealer called today and asked if I was worried about the mileage on the car when we picked it up. He says it should have less than 150 miles on it and the reason is because he has to drive it over from another dealership. He said the new car warranty would extend the extra 150 miles (36,0000 plus the mileage when we picked it up). I am also worried the driver might abuse the car on the trip. Does this sould right? Should we worry? What is the maximum mileage for a car to be considered new?
    We actually have to drive to the Bay Area (about 3-1/2 hours) to pick up the vehicle. And this is a rather expensive purchase!
    You can discuss that with other Odyssey owners in Honda Odyssey 2005+.
  • meg7meg7 Member Posts: 7
    Our local Toyota dealer did some repairs. Now they say we need additional repairs, etc.
    I'd like to post a specific question because I need some help negotiating with the dealer to bring down the repair costs. Where do I post it? Thanks.
    Also, if it helps, it is mostly about the power steering system, but also involves the valve cover gaskets, timing belts, etc.
    Head on over to the Toyota Avalon Group and choose the appropriate discussion(s) that you will find there.
  • pdurnianpdurnian Member Posts: 5
    I need help with leasing a 530ia BMW and aren't sure where to post my question..can you direst me to the correct forum
    THANKS! pdurnian
    I see that you already found the correct place in the BMW 5-Series Lease Questions discussion
  • drollydrolly Member Posts: 32
    Sorry, I saw this after already posting in a forum, but...
    Where might I get help finding a what a reasonable (or unreasonable offer) for a used car would be, namely a BMW 325i or Acura TSX. Looking through the "price and experiences" threads seem geared toward new cars.
  • kyfdxkyfdx Moderator Posts: 271,167
    Try posting a description of the cars in question here:
    Real-World Trade-In Values
    We have a couple of experts in used car values there. Once you know what a dealer has in the car, you can extrapolate a fair price to pay.
    regards,
    kyfdx
  • edharris99edharris99 Member Posts: 1
    I have noticed that frequently (especially when first starting to drive) my display will indicate that I am either charging the battery or just using the battery. However, instead of reading 99MPG it shows a low number corresponding to what it would be if running just on the gas engine. I don't see this as much after a while. Is the display wrong and the gas engine is actually running or is this a software error on the MPG reading? If a software error, then the average MPG readings may be way off if you mostly do short drives (to/from work) and are mostly running on battery. Any comments on this?
    Since you didn't mention what car you are driving, try going to the Browse By Vehicle search box on the left sidebar, and enter your make/model in the form and hit Go. All the discussions relating to your car will be listed.
    Pick a likely discussion and post your MPG display question there.
  • floridagal2floridagal2 Member Posts: 14
    My husband's truck started to make a howling noise rececently upon going 30 mph and above. He thought it was the transmission, so it had the fluid changed. Still noisy. Since we've done may repairs to keep this old truck going, we're afraid it's more serious this time. Any ideas?
    Florida gal
    That's a puzzle - I'd go to the Ranger Group and look through one of the discussions listed there - there's a transmission and general problems discussion that would be places to start.
    Thanks. We'll try that.
  • momof11momof11 Member Posts: 1
    We are looking at trading our 1992 15 passanger van for this 1991 Ford F150 Lariot-Our Van needs a starter[70.00] and the dealer says he will tow it up and take 500.00 off the Ford Lariot for the Van.Plus he wants 850.00 for the truck.Asking price is 1395.It`s a bit beat up-of course for year and price but we are looking for a double seater 4x4 w/cab for secondary truck..
    Problem?The check engine light is on,dealer said he drove it 200 miles from where he JUST bought it in a package deal and had no problems but really doesn`t KNOW the vehicle.
    It also staulled out 3 times during the two test drives we gave it.But other then that it seems to run good.85,000 miles
    It has 2 gas tanks and they don`t know if first one works or not but it doesn`t have a gas cap-so COULD that be a problem with the CEL?He said they only put gas in second tank but will switch tanks and put gas in it to check if I want?
    Don`t want to pass a deal but is this something to walk away from or work with?
    We are going to PA where they have emmissions check.
    my e-mail is my11blessings@peoplepc.com
  • tr8162tr8162 Member Posts: 1
    I need to know how to unlock a child lock on a 1995 Trans Sport SE mini van?
    Is there a button how does it unlock, it's lock on the sliding door and I need to unlock ASAP?
    thanks!
    Try asking in one of the discussions in the F-150 group.
    Try one of the siblings discussion like Oldsmobile Silhouette or the Chevrolet Lumina Problems & Solutions one.
    Start in F-150 Owners to see what other owners have experienced. F-150 Owners should also help and you can get some good tips in Purchasing Used Vehicles.
  • sammy18sammy18 Member Posts: 4
    I have a 98 ranger, 2.5 engine, 5 speed. For the past year I have been fighting a problem with my idle. When outside temperature rises above 50 degrees my idle jumps way up when I come to a stop. Sometimes, when I'm driving through a parking lot I can travel 35mph without touching the accelerator. I have changed my IAC valve twice and cleaned my throttle body and intake.
    Any suggestions?
    Sammy
    Head on over to the Ford Ranger group and post your question in the Ford Ranger: Engine Questions discussion.
  • lbh1993lbh1993 Member Posts: 2
    Hi, My son lives far away and we are trying to install a starter over the phone which is next to impossible. Can anyone tell me how to install the new starter on his 1993 Nissan truck? I would appreciate any help on this. L.B.
  • engine28engine28 Member Posts: 3
    Can anyone help me i have a code of po401 insufficent flow to the egr valve on my 1999 ford escort replaced all parts associated with egr system light still comes on.
    You want to stop by the Nissan Pickups Maintenance and Repair discussion.
