Let's keep the discussion here so that everyone will benefit.
SUVs and Smart Shopper
I am from GM Customer Service. Have you had the vehicle scanned for codes? If so, what did it say? Thank you,
Mariah GM Customer Service
Mike
Any ideas on what may cause this?
LER
Wife said that earlier in the day, she rolled the window up and "it kept going after the window was already all the way up." She meant the window motor kept going, even though the window had completed its upward travel. (She was still pressing the window button.)
The ABS light may be a sensor but quite often is bad connection or other wiring issue within the system.
Jean
Is the BCM a self-repair, or is it a shop job? Because I'm really thinking about selling my Azteks now (we have 2) and I can't sell it if it doesn't have a working odometer! (Salvage title law)
As for the BCM, You can change that but it has to go to the dealer to be flashed so it knows what options are on the car. Let me know if I can help.
I have 2005 Aztek and I experienced identical problem as you describe. Any thoughts about what is causing it and how to fix it.
Stanko
Oops almost forgot, if you click on guides near top of messages forum and type BCM for search there is a good article on replacing it.
