disconnect the battery
remove the cooler
remove the cup tray
removed and lift up the lower console (cooler holder)
remove piece around gear lever area that has the rubber seal
remove (pry back) both side covers for console lower sides
on top of the column of electrical connectors is the BCM lying flat. Remove the two large connectors from the driver's side and pop a couple of tabs so the column pushes out the passenger side for access.
swap out the BCM and then reverse the steps above
Note:I re-installed only the screws I felt were required so if I ever have to change the BCM again it would take less than an hour.
However, the wheel sensors are not cheap as they are built into the wheel hub and you have to have that whole assembly replaced for several hundered dollars. My problem seems to be the sensors keep going bad. I don't know whether it is a quality control problem of the replacement parts or some other malfunction in the system.
Good luck with yours.
Gary.
Gary.
I have the same. Driver's side REALLY wet after rain.
Dealer wants a couple of days to find.
Can You Help??
Interior Water Leaks
Dealer kept telling me if it's operating they can't do a diagnostic on it, so I have to bring it in while it's nonoperational. One day I was two miles away from the dealer and the system was nonoperational for 3 days, when it SUDDENLY started again (No going over bumps, just driving). Finally got it in to dealer, waited an entire day, they said open circuit at control head assembly, and that was replaced, I was ready to go! When the car was driven to the pickup area for me, I got it, SAME THING, NOT WORKING!
They kept the car for 2 more days, (they said they had problems because it would keep kicking on and they couldn't diagnose it) said they found an open at ignition circuit and found BCM blocked. Replaced ignition switch and BCM and reprogrammed to GM specs. I picked up the car, and, you guessed it, two days later it's like nothing was done, same exact intermittent problems are back.
I'm hoping someone can help. I'm not as technical as some of you guys out there!
We bought our Aztek new in 2003 and started having problems that same year...so many problems in fact that we filed lemon law on it, and GM agreed it was a lemon :lemon: . Only problem was GM wanted me to pay a usage fee to "buy it back"...that was like $2800.00 which I didn't have :mad: ...so we kept the vehicle, bad move!!! The car spent over 68 days in the shop the first year! Nothing but problems since then...brakes (3 times in one year), hubs (3), rotors (3 times), tires (2 sets), coolant leak, battery, rear hatch, Check engine light, SES, ABS, paint peeling (in 2003, no less), gas gage, bearings, gets stuck in park (daily), radio light is failing, tranny problems, electrical...and the list goes on and on! :sick:
So many of the same things that are noted by tons of customers on this site alone...how can they (GM) get away with this??? :confuse:
Seems like we could all get together and file a class action suit or something!
Started with noise and felt like vehicle wasn't going to stop...kind of like the brakes were pulsating. Then ABS light came on. Replaced the LR hub since computer stated it was the LR speed sensor. Worked for about 2 hours and problem is back...no light yet though. Taking back to shop so they can search for a wiring problem, or maybe a bad part...but have already spent $375.00 on the hub replacement. And just fixed coolant leak 2 days prior was another $605.00...we have spent thousands on repairing this car over the time we have had it.
We have had so many problems (I posted all of them on a another post) but we have already replaced both the front hubs/bearings twice also!
So, not sure what we will do or if we will be able to fix this problem...but if you find out anything different please post it...
We bought our Aztek new in 2003 and started having problems that same year...so many problems in fact that we filed lemon law on it, and GM agreed it was a lemon . Only problem was GM wanted me to pay a usage fee to "buy it back"...that was like $2800.00 which I didn't have ...so we kept the vehicle, bad move!!! The car spent over 68 days in the shop the first year! Nothing but problems since then...brakes (3 times in one year), hubs (3), rotors (3 times), tires (2 sets), coolant leak, battery, rear hatch, Check engine light, SES, ABS, paint peeling (in 2003, no less), gas gage, bearings, gets stuck in park (daily), radio light is failing, tranny problems, electrical...and the list goes on and on!
The lights on my radio have quit too...don't know what to do about that?
We have been through 3 batteries...just make sure you keep your receipt!
And the hard shift thing is another problem that we have experienced...GM won't fix...convienently they "can't duplicate the problem".
First I love my aztek, but
what kind of retarded monkey designed the electrical??
my fan blower is losing stages 1,2,3
Not sure how much that will cost to fix?? I can guess but i dont want to
and the drivers side window is stuck up or down it depends on the cars mood
I am thinking about getting ahold of a new switch and putting it in myself not sure if it can be done??
I really could use some advice here. when my blower loses stage 4 and 5 and my window is stuck up its going to be a crappy summer
I found a few switches on ebay and it looks like that panel is just screwed on.
anyway thanks for any help you can give.
I'm having the same problem with my ABS. Had the wheel sensor replaced and the problem reoccurs, in my case, several days later. Please let me know what they find is wrong with yours so I can direct my mechanic to look their also.
Gary.
My name is Gary. My wife and I purchased the second Aztek our dealer was able to obtain when they showed up in 2000. It's a FWD red GT version. We still own it and it has 136,000 miles on it.
We like our Az (although I still take a lot of ribbing from friends about the looks) and it has held up reasonably well (better than I expected for a GM product.)
We have had a number of issues over the years (air conditioner coil, blown head gasket, and then that traction/ABS system that we are still struggling with - see other threads).
We just purchased a new Toyota Sienna and plan to give the Az to my teenage son.
Thanks for providing this forum to discuss our "unusual" vehicles!
-Gary.
We had the part replaced twice and it just started up again the other day. I can't believe the parts are that bad! (then again it is a GM!) I suspect there must be another problem. I plan to take it back in a another week or two when the system fails totally and have them do more diagnostics.
Do you know if it is possible to just disable the ABS system and convert the car to normal braking? What would happen if you took the ABS fuse out? I'm seriously considering that if they can't find and fix this problem. I really don't want to sink any more money into this vehicle.
-Gary.
fixed for a week thing also
SUVs and Smart Shopper
I couldn't open my gate either until I disconnected the battery terminal and reconnected it. The tailgate problem started after a few weird events. One day when it was raining, I stopped at a convience store. When I shut off the engine the dic light came on with the hatch ajar message. I checked it and found it still closed. Then one day I came home from work, used the key fob to lock the car. I came in the house. About 15 minutes later the neighbor came to the door and reported my headlights were on. Sure enough, they went on by themselves. Lo and behold the next time I went to open the hatch, it would not open. I disconnected the battery terminal again. It reset the BCM and the hatch opened. I am of the opinion that the BCM is bad.
The wires appear to fit into it through a series of jacks. I have no doubt the issue is a switch problem not wiring.
the window works if i push the switch to the side.
so I think i will try to order aswitch assembly and install it myself.
Any tips before i try it??
My BCM (2001 Aztek) has been slowly going berserk for the past several months. Right now I have to pull the BCM fuse and reset it to open the back hatch. After the interior of the vehicle warms up, the security system goes off, the lights flash and you can hear the BCM resetting the whole system (clicking sound) as the panel goes on and off!
Ive bid on 4 on ebay only to lose out to the same guy each time!!!!
I really hate those salvage people hording parts.
here i sit in the summer with no window or fan blower and some guy has about 10 sitting on his shelf while he is sitting on his butt watching HEE HAW.
sorry had to vent.
I havnt had any luck finding one for under $150 new
and my repair guy wants to charge me $300 to fik the window switch.
any ideas before i just break the window and go window free and waterlogged?
The problem with the aztex switches is very simple and there is a reason why it mainly happens to the drivers side window.
first Ill explain a bit about myself. I am an sculptor and a resin caster, so i have a bit of knowedge about plastics and solvents.
The problem is with a tiny plastic rocker buried deep within a switch, and it rests on a spring.
the part most likly costs a fraction of a penny to make
The issue in my view lies with the power windows automatic roll down feature. All of the switches are identical exept for one part. the drivers side has a small lever that is clipped onto a standard switch.
this lever requires a bit more tension to draw down so a lubricant is used.
The plastic rocker appears to me "Injection molded styren"
the same material model cars are made of.
the lubricant is yellow in color. Indicating it is sulfur based and oil based.
"OIL BASED SULFUR LADEN LUBRICANT DISOLVES STYREEN AND MOST PLASTICS"
stupid pontiac should know that
so I pulled a rocker from the rear window switch and made a Silicone mold of it. then cast a bunch of high density plastic rockers. I replaced my erroded rocker with my new one and the window works great. I plan on keeping a baggie of rockers in case this happens again.
so all in all it cost me $2 to do what a mechanic would have charged $250 to do.
If anyone has this problem send me an email joshua@knuthart.com
Ill walk you through the process and you can save your money to fix some of the other TEK issues. at the very least you can swap out a rocker from another switch it takes 5 minutes
Thanks for the help all and i guess not buying a switch was a blessing in disguise.
now on the the stupid fan
That sounds like a great candidate for our Guides section!
To my understanding the car is fine with the AWD off and no ABS.
Would these two dashboard lights cuase future problems if not taken care of?
