https://www.obdfix.com/Login.aspx?ReturnUrl=/Customers/MyPortal.aspx?login- %3dtrue
Every other thing out of their mouths is what a rip-off real technicians are, then they turn around and tell the users they will often still need to go to a shop, as well as their fixes are from master technicians.
If Edmunds is really about helping the consumer they should be exposing them for what they are doing, not endorsing them.
Properly repaired, it does everything a brand new one will for less than the sales tax, and the depreciation of the new one the moment they drive one off of the lot. It's this very misconception that is the root of not seeing the value in having an experienced and capable service force. People who sell cars have an interest in older cars disappearing long before they really needed to, and that makes poeple who can get the customer more life out of their machine(s) undesireable.
Type F fluid is a last ditch, true, but it's not without reasoned thought,
Sorry mis-reasoned. CVT fluid is specifically engineered to have long irregularly shaped molecules. Under pressure they interlock and form a glass like substance preventing metal to metal contact and allowing for the transfer of torque between components. CVT fluids are primarily group V basestocks (polyol-esters) while type F is a group I.
as it is a grippier fluid and the slippage is when the transmission is hot (works great when cold). What's the harm here? That the type F would cause a slipping transmission to...what....slip more?
Only as compared to other fluids of it's day. It's no where near what a CVT fluid must be. Under pressure that type F will simply wipe away and allow metal to metal contact, failure is assured when that happens in a CVT.
Well so what? it's done for anyway. The car just sits in a driveway and gathers dust. Wanna buy an $8000 German planter box?
Fix it correctly and get another five or ten years out of it, while they put the rest of their money that would have been spent on car payments into a savings account.
Given that their only alternative is a rebuilt unit or (bad idea) a used unit, I don't see why advising them to spend $6500 on an $8000 car is a very good idea. The old trans won't be rebuilt in house--it's going for core value.
Think aboutn this, you started off saying the "part" wasn't available. Now you are saying it's going back to be rebuilt. Not without repair parts being available it won't.
Besides, I checked in with an Audi-trained technician and he thought it was a good idea, given this particular car in this particular situation with this particular (near broke) owner.
Again this just ensures it will get a new (to it) transmission. Most technicians have no need to know what fluids are made of, they only have to choose their fluids by the manufacturers specs. It's unlikely he/she would know anything about Type F let alone their own CVT fluid.
But really, do you have your arm cut off before you try antibiotics?
Not relevant to the conversation. You'll throw a couple million at a cancer patient to try and get another year of life.
You as a shop owner, can't put type F in this transmission, because of liabilities, but you could advise it as a "Hail mary" on a dying patient.
No we cannot advise them to try "snake-oil". As the person in a position of greater knowledge it could be shown that we either know, or should know that the type F was a death sentence for the transmission. Therefore we would be responsible for destroying it, and could be forced to pay for it for the consumer. What you suggested would have us get to be portraited as rip-offs.
Well that's easy. People ready to and willing to compromise the security of the components makes it easier for the theives.
Many manufactures by keeping their security systems closer to the chest make their cars less likely to be broken into, or stolen for their customers. When a VW/Audi technician is servicing the security system the scan tool goes blank except for the progress meter. They have no way of knowing what is going on, that information isn't revealed to even them. Which BTW R2R asks that anything available to the dealership technician is supposed to be available to us as well. VW does exactly that, they don't openly release security data to anyone.
I think it's a small step to get the car to phone home. With a 10" screen in the middle of the dash, you wouldn't even need a laptop or phone to view the data on.
As soon as the manufacturers figure out that people will pay for this info, they'll tack a subscription onto the sale or sell you one-time scans for $20 a pop.
And when your radio dies, you can hold up your driver's license to the backup camera and get your info verified at the factory so the scan will release the code to you. :P
There are cases where this can help diagnose a car, and with enough experience be all that is required. But many times it must be backed up with pinpoint testing and it takes a disciplined approach to do that while everyone is screaming "Cheaper, Faster".
Then when cheaper-faster fails (and it usually does) everyone simply points their fingers at the techs saying things like "You don't know what you were doing, You were trying to go too fast, why didn't you take the time to test instead of guess," and on and on. We will never move forward caught in this rut. All of the problems are solved by realizing your demands are founded in misbeliefs and wishes. No matter how much consumers rant, we litterally have to block that out and be professional in order to succeed in spite of their opinions. When techs fail, a large portion of the blame goes right back to the system that is pressuring them away from being disciplined.
You mean incorrectly diagnosed intermittents or random faults. If a light was genuinely false, that would be corrected with a reflash and typically noted with a TSB.
Clearing codes also clears important data that a technician may require for diagnosing a vehicle issue. The codes should only be cleared after all of the information has been gathered.
Then search for answers for codes and see how many of the codes techs are asking for information on are getting any answers at all.
Try and post a plausible answer beyond what would be a best guess for a given trouble code.
And if that is the site you are bashing (obdfix), what makes you think Edmunds is endorsing it?
Let me take a stab at what you were trying to say. Is your original post intending to say carmd.com is useless and obdfix is the one people should be joining? If that's the case, again, obdfix states it is FOR technicians, not owners.
JOIN THE SITE.
Tell them what you need to in order to get approved, which ain't much. Then search and try and gather useful information that a purchaser of their product needs. This is where they are allegedly gathering their information from the technicians that they have to continually bash in order to market their "tool".
Find out first hand just what technicians are doing there.
HINT: you won't find real top gun technicians giving them fixes, in fact your going to find significantly less than what they claim to have available to them.
Join the site.
(As an OBDFix member, I certify that I am working full time in the automotive service industry and have access to the resources of a professional repair facility.)
Join the site. Then tell us what you found. See if it lives up to CarMD's claims.
Do you want us to join CarMD or OBDFix??? :confuse:
BUT....you haven't ever tried this, so you really can't say you know what Type F fluid will do, nor are you the one spending $6500 on an $8000 used car with a terrible reputation for reliability anyway.
I could give many examples where the engineer or shop owner says 'no" but the clever owner experiments and does it anyway, and successfully.
For instance, do you think a Porsche dealership would tell you that if your pulley breaks, that you can drill out the broken stud from the crankshaft end without splitting the case?
No, they won't do that, nor take the risk, nor advise you to try it.
But it works and I've seen it work.
But my point of bringing this up was not about Audis, or whether you or I give sounder advice. There is no one right answer in the complexity of modern cars.
My point was that you can't buy the Audi part that might fix the problem. The owner has no options here.
And that, to me, is flat out WRONG.
Had the same thing with my broken MINI sunroof. The back glass (there are two glass panes) broke. Well they don't SELL the back glass---you have to buy the entire cassette for $1600 + labor (total $2800)
So $2800 for a $100 piece of glass.
infuriating! :surprise:
http://europeantransmissionscom.x-shops.com/shop/product.php?productid=16316&cat- =411&page=1
Fools rush in, where wise men fear to tread.........I think I heard that in a song...
So who forced you to buy a Mini in the first place?
Manufacturers have never been known for going out of their way to make cars easier to repair. They engineer them to be built and sold with their eye's firmly on the bottom line. We simply have to deal with what gets presented to the best of our abilities. Many times when a component is not sold seperately it usually comes down to a situation where the assembly might not be reliably torn apart and put back together succesfully. Remember just because someone might manage to do it once or for themselves, there could be functionality or appearance concerns that would make someone else who was paying for it unhappy with the end result.
As far as your Porsche example, I've seen butcher jobs and components that were hacked up time and time again from all kinds of mechanics and wannabees. Too often people confuse can do with should do.
Also, who warranties the labor when the rebuild screws up?
No matter how you cut it, the Audi owner ends up holding the bag.
As for the MINI sunroof, that's just bad engineering. There's no excuse or apology for it.
As for the Porsche---no, that fix was done by pros, and it worked out great. Good as new. Long live the easy-out.
But sure, amateurs can hack something up. I've seen Porsche connecting rod caps with vice-grip marks on them----now that's scary.
But that kind of bothers me that it won't connect to the apple product. YOu would think if it has bluetooth capabilities, it wouldn't care what it was.
You mean you can't just offer the mechanic a case of beer? (sarc, TIC )
Then we get the "My Uncle, Brother, Cousin, Neighbor....Used to be a mechanic and he said.....It only takes a couple of hours to put one of these in and if I brought you the part I could save myself some money" (sarc TIC continued)
Dang that actually looks funny getting to twist that around and throw back out here. Consumer "experts" told consumers trash like that starting way back in the 70's and it was never effectivley challenged because there wasn't anyway to make the counterpoint heard. Combine that with shop owners who didn't have adequate buisness training and the shops simply rolled over and took the losses on the chin. All of that is a contributing factor to where we find ourselves today, and why some shops are supporting R2R in the belief that it will rescue their floundering businesses. It won't.
The rebuilder does, it's part of their agreement nationwide. Jasper does the same thing, as do many of the quality suppliers.
Then they should have bought a Ford or a GM. Or if they insist that they want to keep on believing they bought an appliance instead of a machine then maybe they should give up on cars, and use public transportation.
Transportation costs money, whether your seeing it go out in monthly payments (thats actually the most expensive way) or service and repair costs it will cost you money to have and use a machine for transportation.
Again, you had a choice BEFORE you bought the MINI and you chose it. If the sunroof issue bothers you, you should try and understand how the dang thing goes about turning the AC compressor on and just what it might cost to correctly address that. Now sure someone will turn around and hack in a solution and be all full of themselves over it, but there are reasons that control of the AC clutch is left to the PCM based on command inputs from the driver and the climate controls and hacking in a fix does create problems elsewhere in and for the system.
I've had to remove a number of broken crank bolts, but no studs since none of the cars I typically work with use a stud there. "Easy outs" work great, when the bolt will still turn out easily. All they are in many cases is a very hard tool broken off close to the middle of a case hardened bolt. Then it takes a lot more care, precision, and experience to get the bolt out than it should have in the first place.
But they would argue that they have done it that way for years and never had a problem before!
I once road tested a vehicle for state inspection and noticed an undesireable amount of play in the steering. I found one of the tie rod ends mechanics wired back together.
After I bought the dongle and failed to connect it, I went searching. As is apple's habit, they lock down every damned aspect of their products, including the bluetooth. Opinion seems to be that a manufacturer of a peripheral has to pay up for apple to add them to the permitted list. Until then, the iPhone just refuses to connect to it.
This sounds like blaming the victim to me. You're really stretchin' here... :P
Automakers make it sound so great, so easy...."we have ONSTAR"...."we offer FREE maintenance!" "JD Powers ranks us first in reliability!"
And then reality sets in when you're facing an expensive repair.
They all have been trying to claim lower maintenance costs as a selling point for as long as I can remember, then when the reality of what repairs do cost is revealed everyone tries to lay blame on shops and technicians.
How do you think the public would react to a car today if they advertised what the average owner can really expect pay each year for servicing?
Oh, now....like consumers are supposed to have pre-knowledge of all factory engineering decisions before they buy a car?
LOL, how about if they just understand that checking and adding oil when it was needed is normal, and that cars break and you'll need someone trained and equipped to fix it and get it back on the road and no, it's not going to be free.
We offer that here too. :shades:
True Cost to Own
Ever tried to take a transmission out of an Audi A8?---well lotsa luck with that. Book rate is 18 hours R&R !! :surprise: That's $2500 where I live, without actually fixing a thing.
Now tell me that's not just nuts.
Mitchell On Demand. 12.1hrs. That's $907 here. For remove and install. There are some additions, they allow .9 to add the rear main seal, and .6 if your installing a reman.
The Remove/Install and Overhaul time is 21.1 that's $1582 and remember I'm the HIGHEST shop in my town and on par with the highest within 20 miles of me.
Here are some A4 and A6 CVT parts, including the CVT chain/belt.
http://www.makcotransmissionparts.com/01J.html
Here are some fun details (scroll down) for tips on just what it takes to rebuild one of these.
http://www.europeantransmissions.com/
Remember too, demand for the parts plays a significant role when it comes to availability. But if you really want something bad enough you can get it. The problem with these CVT's is can you actually do the work if you had the parts?
Pulling a tranny on an A8, nope haven't done one and don't ever expect to. Could I do it? Trust me, I do much more difficult work than that all the time. I'd trade you a set of 6.0 injectors for that transaxle in a heartbeat.
True cost to own should be broken down and shown year by year, with the first five years also displaying the total of the monthly payments. Then when those are gone show what the vehicle costs to own for the next three years while throwing in a transmission overhaul. Then another three years and lets have done all of the struts, springs, and maybe even drop in an remanufactured engine. Then lets run it on another five years with various repairs scattered in.
Now compare that final number to what the consumer would have spent if they had replaced the car every five years and you get the cost to "OWN" and it's a heck of a lot less than what they would have paid out for even the total for two cars using the calculator, let alone three. Using a Ford Explorer, we are talking some $70,000 in the consumers bank account (if not a whole lot more).
Remember people who make money selling cars have no interest in the consmers seeing the facts presented in their true light, people who fix cars for a living rarely get heard and that calculator is a prime example of someone not wanting to tell the whole story. In fact, seeing who wrote the article attached to the calculator, I'm not surprised that it cuts off short of explaining why and how we can really make a difference for the consumer.
TCO numbers can help you predict longer term results. If you have a rig that's expensive to run for five years, chances are it's not going to improve with age.
Shifting gears, this article may be of interest to those of you in the business (well, if you're in the business you already have on the ground experience with this).
Consumers Skip Car Maintenance Due to Tough Economy, Survey Finds (Inside Line)
Some of us (me :shades: ) like to gamble in good times.
Thank you kindly for the belt tip. I'll check it out (trying to help a friend out) and if they really have it, I'll pass on the info. $600 for a belt--that's interesting, isn't it?
Anyway, Audi wont' sell it to you--which was my point.
Myth #1. How do you think they come up with these labor times? Do they actually perform every single possible repair three to five times in order to time them and get an average? Do you think that the O.E's themselves actually study every labor operation?
Myth #2. Have you ever met me? Stood inside my shop and watched me work? How can you be sure what I can and cannot do? That kind of disrespect among techs, towards each other, shops towards each other, the media towards all of the shops and techs combined is one of the greatest hurdles that the trade has to overcome. Are you simply making that judgement because you feel you couldn't do it, or have done it?
This will come across as arrogant and but if it wasn't for that edge of ego, I would have walked away from this trade decades ago. "IF" that time is legit, I'll match it the first time I do a simple R&R of the assembly. I don't waste any time fighting corroded fasteners, I expect to use a torch or inductor to heat them and get them loose and I do that before I put a socket or wrench on them and risk breaking one. (The mini-ductor is a great tool for this). The 1/4 Million I have invested in my tools and equipment mean that somewhere in my box (all precisely placed for quick access) will be the right tool to access any fastener in whatever location I might find it. Combine that with service information on my diagnostic tool cart, and all of the O.E instructions and specs are within easy reach without me leaving the service bay and you should have a picture in your mind that everything about the shop set-up is about making me be efficient.
Anytime I see a transaxle labor over five hours, I check service information for the correct proceedure, and then I take a few minutes to investigate the possiblility of pulling the engine and transaxle together in order to do the job in greater space. I suspect, and no I haven't even bothered to look that this Audi just might be one of those candidates. The intermingling of the engine, transaxle, and final drive might be a real wresling match in the confines of the chassis, but drop all three into the open using equipment designed to do just that and "More work, becomes less work" and the job is not only easier it's more fun.
There are several kinds of experience at play here and product familiarity always has it's own special place which normally plays to the strenghts for a dealership technician. Thirty five years of fixing anything that ever rolled in the door has it's own set of experience that should be respected as well.
Mitchells time is 30% greater than the actual warranty flat rate time which allegedly is how long the job should take according to Audi 7.9hrs. That time I won't make the first time, nor maybe the second. By the third, I'd probably beat the time, but I've always been able to do that.
Studies shows that you can't trust most research.
An EMT will be on site.
The trick is to figure out how they build it at the factory and then create and use a service proceedure that mimics the build process. That's why Ford techs figured out in order to be faster at major enigne repairs on many of the F-series pick-ups, they pull the cab off. GM techs have for a long time raised the bed of the pick-up instead of dropping the tank when servicing the fuel pump, heck we even do that with some models to replace brake lines. Major interior work like R&R a instrument panel, often times made way easier by removing the front seats.
BTW at 7.9, I don't see Audi techs mutinous over the time so there must be a way to meet it or at least be close to it. Top techs learn to figure out easier ways to do as many things as possible and not just fight the tough steps.
We can do your time study any time. Just find someone to pay for it. Three R&R's. One to learn the vehicle, the second to rehearse and try combinations. The third to see how fast it can be done. Then the real test, bring in a fresh vehicle and you'll be surprised at how easy this really should be when the fourth R&R is performed and that's the one you can time. There is a reason that they don't do real time studies anymore and havent for two decades. Imagine what the cost would be to do just this one labor operation. If we needed an EMT it would be for who ever had to write that check.
BTW, "Flat Rate" isn't flat.
I ordered up those Audi CVT parts--so we'll see.
Additions.
.3 for the clutch fork shaft bushings
.1 for the release bearing
.3 for R&R flywheel
As I read your short response, it says to me, that you want to believe everything Shifty is saying in disregard of the fact that I have far from a pedestrian grasp on the trade and how to really go about servicing today's cars. Where you really get it wrong is that I am defending "bad designs". Far from it, I'd be the first to line up many engineers in the desire that some of the trash they have thrown at us get's to be the last thing they see on this planet. (hyperbole) Standing shoulder to shoulder with those engineers would be the writers who really haven't got a clue about what it takes to run a shop or repair today's cars. All they want is to sell their story, so they write it to tell every reader what they think the consumer wants to hear. (You can find good examples of that right on this site)
Opatience summed it up quite well a few responses ago so I don't need to repeat it here.
While you want to voice an opinion and support shifty, I am taking the difficult side of using facts and real world experience to have to show that the stereotypes no longer fit the expectations. Shifty comes from a time where marketing inside the trade largely consisted of undercutting the other shops price and both shops continually claiming that the other had no idea what they were doing. He wasted no time trying to say that I could not handle a basic R&R of a transaxle in an uncommon car, when he really doesn't know me, my experience, training, work habits, and investment towards my career. As someone who wants to represent himself as knowlegable about repairing cars, he needs to learn to respect the real professionals and not stoop to such insulting remarks.
This entire thread is supposed to be about the right to repair act and whether it is needed or not. Supporters claim that the tools, training, and software that we need isn't available to us. The facts are that just isn't true, there is nothing that the dealerships for the manufacturers that I choose to support can get, that I cannot. I currently support GM, Ford, Chrysler, Mazda and Honda all the way up to 2012 model year vehicles, and I have to spend the money to catch back up with Toyota, Lexus, Nissan and Infinity. I'm a one man shop so my pockets are no where near as deep as many others, and yet I have accomplished this over the last 10-12 years through hard work, and thousands of hours of study and training. I'll also say I have accomplished this in spite of all of the "mechanics are just out to rip you off" articles and TV news stories that I have seen through the years.
I don't like all of the expense that I have had to cover in order to take care of my customers, and I damn sure don't appreciate being called a crook for doing so. Your perception that I am supporting bad designs as a result of all of this is really just part of a consumers wishful thinking that everything about fiixing cars is supposed to be easy, and if your really smart, you'd be doing something else for a living. Shifty even went there with one comment about why am I working retail, when the clear answer is because the consumers need people with this kind of training, committment, and skill out here. R2R proponents largely have not been as committed to staying up to date with the technology in the cars, and they incorrectly believe it will solve the gaps in the information that their aftermarket tools have. It won't.
"Ignorance" that's a harsh word but it's hard to think of a better one at the moment. Everything is changing so fast these days that unless someone has had a habit of continually studying all of the new systems for the last twenty years they just don't know what they don't know. I am on the opposite side of that equation as a professional technician, shop owner, writer and instructor.
One way I've tried to explain mechanic's fees is to tell folks that you'd readily pay someone who builds kitchen cabinets a great deal per hour, but squawk when a trained mechanic has to R&R superchargers, reprogram ECM modules and re-assemble a hundred pieces on the floor that have to propel you at 80 mph safely. :P
Parts is parts.
Screw the flatpack together with my Harbor Freight cordless drill. :shades:
I've been a car nut for decades, ever since I was four years old. I spend a lot of time reading about cars, but, to my regret, I have little mechanical aptitude. If I had good mechanical aptitude I'd be doing what you're doing for a living. Therefore, we approach this discussion from different points of view.
I generally agree with what you say, in terms of the amount of knowledge and skills required to be a good auto technician today, and the misperceptions that much of the public has. Nevertheless, on the topic of designs, I think Shifty is correct in saying that some cars are more complex, and, thus, more difficult and expensive to repair than they need to be. He cited his Mini's sunroof and the (FWD) Audi CVT transmission as exampless. I think both examples are inexcusable, and the fact that Mini and Audi are premium brands should mean that these components should be more durable than their counterparts in mass market cars.
If I'm working an outdoor construction site somewhere, maybe I don't mind my cheap Harbor Freight drill walking off so much as my Panasonic EY6406.
Right to Repair ballot spot approved by state secretary (massrighttorepair.com)
