19091939596473
    edited March 2012
    Again I do not know what you mean. The 3 series diesel is gone for 2012. Now for other diesel oems like MB/VW/ etc. BMW (BMW still puts out the X5) really a good market for all they wish to produce.
    You're right, Edmunds' price is for 2011s. There may be a few left.
    They're probably rebooting to get the diesel in the new body style.
    +2mpg is not enough, though, given the $9k or so jump in price. Hopefully they're tweaking it for even better than 36mpg highway.
    34mpg on the 328i is amazing, though. Diesels biggest competition may end up being small DI turbos.
    edited March 2012
    ..."34mpg on the 328i is amazing, though. "...
    You might find it amazing, I find that (34 mpg) weak.(for a 2.0 L 255# ft, not that 255# ft is weak). The (old) 09 VW Jetta TDI is rated EPA 29/40 mpg and posts 42.33 mpg. @ 236 # ft. Newer Jettas (2012) are EPA rated @ 42 mpg. So just on the EPA rating (highway,y I presume) that is 17.6% (old) to 23.5% better mpg. A quick look posts app 12k cheaper.
    36 mpg for 425# ft of torque is closer to my "amazing. You would think that BMW enthusiasts would know what 425# ft really means. I am sure a lot of the performance heads would un click the 155 mph governator. ;)
    You and I will probably agree to disagree, which is fine. There are many other European BMW's that get way better than 34 mpg. Too bad they only allow in the "dumbed" down versions.
    What BMW needs to bring over is the 320d, about 50% better mpgs than the 328i 4 cyl turbo gasser, according to their British web site.
    edited March 2012
    Now 51 mpg would be plenty to pine about !!!! (if your numbers and my math is correct, I will preemptively stand corrected if not)
    That cuts the 2009-2012 VW Jetta TDI 40-42 to shreds.
    Why get a Prius at those mpg's?
    You ignore HP, though.
    With good gearing (in other words, in any BMW), HP matters also.
    The TDIs you mention offer good economy.
    The 328i offers good economy and good performance, too, for less than a diesel in the same car will cost.
    edited March 2012
    No HP is not ignored. We both know which is higher and which is lower. However, that is what you say is happening.
    One is a turbo 4 cylinder the other is a I 6 twin turbo diesel with 1 L more displacement. If you don't see the comparisons and contrasts here, lets move on. I really can't help you, or add to your preferences.
    I would get the 328i if I were aspirational and anti diesel. The 335 D obviously is a much smaller demographic. It is much smaller than even BMW calculated. But I think that was the reason for the 2011 D offering; to gauge the market. I am sure that if one studies and contrasts both the 335D is probably much better built than the 328I.
    You were comparing your TDI to the new Bimmer DI turbo, both are blown 4 bangers.
    The Bimmer may produce similar torque but MUCH more HP and performance.
    The TDI you mention offers ONLY economy. We can say performance is adequate at best.
    The 328i offers economy (34mpg highway) and performance (no comparison).
  • lemmerlemmer Member Posts: 2,689
    I can't think of any performance car I like that has a considerably higher torque than horsepower number. Ultimately, I like an engine to have a little excitement to it. Diesels just don't. Lots of torque is nice if you have lots of horsepower or if you are towing a horse trailer or something. Other than that, I can't think of any great use for it.
    edited March 2012
    A fair reason of why we like/dislike cars that we do. Having driven 3 (75,000 miles, 177,000 miles, 33,000 miles), 385 hp/385 # ft of torque, 90 hp 155#ft and 140/236 # ft diesels, it is really what you want and have to do with them. So if you prefer one and or not the other, that is fine. I like and can do and do all three (more actually but that is beyond the discussion at hand).
    I frankly would seriously consider the V-8 turbo to twin turbo diesel, if Corvette ever decided to do one. But as you will agree, they have never done one. The issue also might be akin to cursing in church.
    edited March 2012
    Older diesels may have been wheezy, but newer ones have certainly improved a lot in that regard. They still don't rev as high as gassers, but they don't need to.
    Any how, DI and turbo tech are helping gas cars produce lots of torque and improve mileage at the same time. That 328i makes 255 lb-ft at just 1250rpm, and keeps revving up to 5000rpm to reach it's 240HP peak, so torque doesn't drop off for a lot of revs.
    A friend of mine used to talk all the time about "area under the torque curve". In other words, peak torque is fine, but what you really want is a plateau that is high but also WIDE, that way you get good torque for a lot of RPMs, and when you shift you don't fall outside the sweet spot and suffer turbo lag.
    The Bimmer peaks at 1250rpm but does not drop off until after 5000rpm. So you have a lot of useful, accessible torque.
    I'm off to search for torque curves....should be interesting/educational to compare them. :shades:
    edited March 2012
    You can really say the same about older gassers. In that sense, I do not miss the good old days for either diesels OR GASSERS. Although I think the cats meow (bee's knees) would be a late 80's MB 300 TD !!! Running on ULSD is a huge improvement. Even better than GASSERS switching from leaded regular/premium to RUG/PUG.
    Found it:
    If you can't see the image above here's the URL:
    http://www.kilometermagazine.com/artman2/uploads/1/n20-horsepower-curve.jpg
    It makes more torque than the old 6 cylinder did all the way up to 6000rpm or so. The plateau starts at 1250rpm and doesn't start dropping until 5000, and even then it doesn't drop off quickly. So you can shift at 4000, 5000, even 6000rpm and you're getting good torque all the way. The RPMs will never drop below 1250, too.
    From the 'tex, here's the (euro spec) VW 1.9 TDI:
    http://i5.photobucket.com/albums/y173/iieey/19tdicurve.jpg
    And here's the 2.0 TDI:
    http://i5.photobucket.com/albums/y173/iieey/20tdicurve.jpg
    They're not as flat as you might think. The plateau is actually pretty narrow. With the 1.9 you're good from about 1500 to 2500 rpm.
    The 2.0 is a little better, you have from roughly 1500 to about 3000rpm, so it breathes a little better.
    But with either of those diesels, by 4000rpm they're getting wheezy and beyong 4k they're out of breath.
    So good peak torque, but no broad torque curve for either diesel.
    British have the 335D getting 53.3 Miles per Imperial gallon on the Highway. Which is about 44 MPG US. How can our EPA estimates be so far off? I guess the Europeans just know a heck of a lot more than we do about diesel and saving fossil fuel.
    The EU tests give much higher mpgs than the EPA test, even after adjusting for imperial/us gallons. The Prius tests 20% high, so you might cut another 20% off, should be close.
    BMW sells that 320d for not much of any premium over a gasser, probably reason #1 we won't get it! Reason #2 is that it'll still need the urea system, I'm guessing.
    I wonder if euro spec models are geared taller? They do have autobahn speeds, while we deal with 55-65 most of the time.
  • andres3andres3 Member Posts: 14,168
    edited March 2012
    and promise to sell you the diesel at $2.99/gallon for the first 3 years you own the vehicle.
    That would help in CA.
    it's the old story---the one explanation that we diesel lovers find hard to accept---Americans do not like diesel passenger cars.
    edited March 2012
    55/65 mph, you are joking right? You have never struck me as a blind senior citizen !? ;) Shoot around here, you'd best be doing 75/85 !? Just back from a run to a client and was in the slow lane (merge path of the CHP's favorite hide). BIG mistake, as he was TEARING out of his rolling downhill slot. I had to pull to the extreme right lane (TURN LANE #6 of 6 of a 6 lane freeway (two lanes turning, ah, I was not turning) otherwise he'd be right on my six. No code, must be the lunch break.
    If I had to do 55/65 mpg, I'd be pulling easily 50/55 mpg in the 09 TDI and more like 60-65 mpg in the 03 TDI.
    edited March 2012
    Hey Gov Arnold did that in CA off of Gov Davis' promise of raising car registration fees. Arnold as I remember won in a landslide. DAMN he kept his word too. I am sure Davis would have kept his word also. :sick:
    Didn't do Arnold much good. His luster wore off quickly in California. He did get one of his Hummers to run on hydrogen, however. :)
    I think he was hired so they could finally blame the republicans.
    edited March 2012
    You cannot be married to a Kennedy and be a real Republican. I think he wanted to be one of the good guys, and just could not overcome the pressures.
    Being fair to Ahnold. He was up against an entrenched legislature of anti business and for me the worst thing was ANTI DIESEL Eco nuts. That worthless bunch of hacks at CARB making rules to keep diesel cars out of CA. Then they find out their top guy is a fraud and a LIAR. How many billions of gallons of fuel have been wasted the last 20 years on gas engines wasting our precious resources?
    edited March 2012
    I really think that is the worst thing. The green eco anti diesel regulator's, etc al don't even believe their own toxic spew. So much so, they have to doctor their own results. The operative behavior is they say you should burn LESS, but given RUG/PUG and ethanol mandates (that they regulate and mandate) and boutique blending they actually burn far more. To boot, is it is far more than diesel. On the other hand, They know that RUG to PUG is factorially DIRTIER than ULSD !!!!
    What I always come back to is the history of gasoline. If the statistics are true that nearly half of a barrel of oil is gasoline. What would happen to the oil industry in the USA if we had 50% diesel vehicles like the EU? We would be flushing gas down the drain like they did 100 years ago as a useless, dangerous byproduct of oil refining. I see it as a balancing act/conspiracy of sorts. That said it is good that the manufacturers are making baby steps to get more miles out of a gallon of gasoline. It is an uphill battle with the Feds pushing ethanol into the picture. My understanding is Brazil has cars that get decent mileage on 100% ethanol. That still leaves the huge problem of transporting the stuff to market.
    Give me a diesel SUV and I will shut up. :blush:
    there are 19 gallons of gasoline in a barrel of oil, which is 42 gallons.
    there's actually no shortage of fuel in the US right now. Our largest export is gasoline, diesel and jet fuel.
    Indeed the enviro/eco cons can tell their fairy tales all they want, just allow choice in the passenger vehicle fleet. The abundance of fuel and its EXPORT is an overwhelming indication that most to all of the enviro/cons utterings have been fairy tales.
    Well that works both ways, since it also shows that drilling will not bring down gas prices. It all points to the fact that politicizing our energy policy has been a huge mistake. We are awash in misinformation and our vision is completely myopic.
    In some rational country, like say Germany, (or at least a country where they can agree on something) a multi-energy approach with a longterm, long-time view of things will probably work out the best. "We'll have 20% of THIS, and 10% of THAT, and 40% of THIS gradually decreasing in 2020 to 25%, and we'll put X dollars into developing THIS by 2035 and Y dollars into subsidizing THAT".
    edited March 2012
    Yes a while back I posted a truism (but really a joke) about fuel prices. The upshot is almost ANY reason, the prices go UP. Needless to say, the policy is for the prices to go UP. So the solutions really lie in working backwards from that knowledge.
    The truth is since noncompliance with that policy is a felony and since it is federal you can be threaten with federal time, i.e. (lovely in Leavenworth KS, this time of year). This stuff is conducted in absolutely utter seriousness.
    So the interesting thing about Germany is the bureaucratic fixed costs are even higher per gal than here. Truth is it should be cheap to do this.
    I think it's not in any one entity's control--it's a mix of speculation, bad energy policy (we've never had a good energy policy in this country, ever) and of course the fact that prehistorical plants are no longer making oil for us.
    edited March 2012
    I think the policies are pretty plain, the ones benefiting the most just might not want the facts and answers in public policy discourse. One portion is as long as the government is getting its outsized shares and maintains its strangle hold regulatory control, that IS the energy policy. One small example of many is it takes 5 to 7 years to get a oil drilling permit on Federal lands. On private lands i(in TX for example) 2 to 3 days). One guess as to which permits cost more over both the short and long terms.
    I think that goes unnoticed is the fact that speculation can bring down the prices just as much as it is blamed for driving UP the prices. In fact, shorting is probably as democratic as going long, even as shorting is demonized/vilified.
    Another is there is never any talk of scaling back taxation. Indeed the governments levying taxation as an aggregate make more monies, volume and percentage from a gal of gas than the oil companies that bring it to markets.
    Now this might be misused as being an oil apologist position. It is not. It is obvious the companies make literally millions to billions. But the facts remain GOVERNMENTS make FAR much more than the oil companies and at literally no cost.
    So the latest policy du jour is really no secret. Secretary Steven Chu, Ph'D has on any number of occasions and as a matter of policy (4 to 8 years, if re-elected, or if the policy is continued) has said fuel prices in the US should be as higher (if not higher) than Europe's which is currently 8/9 dollars US per gal. We should be also doing EVERYTHING we can to get there FASTER (higher prices). Now depending on how one looks at it he is either 3 to 6 dollars behind, so hup a huppa or 2 to 3 dollars ahead of the BHO administrations goals. The small details is that the population is experiencing hardships at 4/5 dollar per gal gas, from his inagural starting point of 1.75 to 1.80 per gal. So naturally, they need to blame that hurt on the usual cast of suspects - good fall guys/scape goats, while all the while pushing or putting in place the conditions which drive the prices inevitably higher.
    Now the US being WAY beyond the middle east of natural gas, really throws a monkey wrench into the whole "perverted" equation.
    Right now the mathematics are .75 cents per gal (equivalent natural gas to RUG PUG @) EPA 27/38 mpg and $4.00 RUG/PUG @ anywhere between EPA 28-36 mpg. (both EPA's are Honda Civics, NG/RUG.
    The math indicates a SEVERE difference, in favor of natural gas.
    Natural gas .00277-.0197 cents per mile driven
    as compared to
    RUG .14.3-.111 cents per mile driven.
    So in terms of per mile driven, RUG costs app 563% more !!!!!
    Now diesel gives "gas" to RUG/PUG ! ?
    So do you think the price equalization process will be the key to using natural gas as a clean fuel alternative fuel for passenger vehicles? My money is on YES !!! That of course is BEARISH for the American consumer. :lemon:
    edited March 2012
    that's correct. Fuel prices should theoretically be higher than they are because they do not take into account the environmental and health damage costs, which the government must correct (federal or local) and you and I must pay for.
    The concept that speculation can drive down gas prices sounds suspiciously like 1980s voodoo economics with some lipstick on it. :P
    Maybe Americans need to stop yearning for impossibilities regarding gas prices and instead start to make the necessary life changes and consumption chagnes to deal with what we call 'reality' at the moment?
    Gas prices are not going down, not ever. We all know this deep down. They may drop a little, herea and there, but they will relentlessly go up and up.
    So why not prepare now?
    So get that diesel car if you can, drive smarter and go greener in every way possible.
    The future will belong to the country that uses existing resources in new and efficient ways. New fortunes will be made by anyone who figures out how to shepherd resources in imaginative new ways.
    small case in point: Some company is marketing a drip irrigation system for your home that receives signals on weather conditions and adjusts the water supply daily accordingly. Not expensive, supposedly saves up to 20% water usage in gardens. Multiply by X million gardens--that's a lot of water.
  • busirisbusiris Member Posts: 3,490
    On the irrigation system comment...
    My system has a rain-sensor monitor on it that allows me to adjust the need for irrigation based upon recent rainfall amounts. Once set, it's automatic until I adjust it again.
    The cost of this option? Less than $20, installed in less than 5 minutes. And, these are widely available at Home Depot, etc.
    Yet, how many times have you seen systems churning out water in the middle of a rainstorm?
    Because water is cheap in so many areas, most feel it's easier to use the water than being more efficient. Now, if the user was actually paying the TRUE cost of water, he would be a lot more motivated to use it more efficiently.
    The same goes with fuel. Our transportation systems would be completely different if we actually paid the true cost of the impacts created.
    I often laugh at those who complain about AMTRAK losing $$$$, yet at the same time ignoring all the hidden cost imbedded in airline travel.
    So the answer is really easy. Position accordingly.
    I turned my irrigation system off before winter. If it does not rain I hand water. I have neighbors paying $400 a month to keep a lawn green. I am too cheap for that. Water my fruit trees and Veggies, and plant drought tolerant landscape plants.
    The only diesel I use is in my little Kubota tractor. Very handy moving top soil, mulch, firewood etc. About 5 gallons a year.
    This is probably why we will continue to gravitate to an urban culture--too expensive to commute to work for one thing....the whole living/automobile/commute thing is shifting.
    edited March 2012
    Well no. There has been a 50+ plus (emphasis on the PLUS) year policies in place to remove people from more rural/remote places. It is just if one goes at ones own accord for say economic reasons, one can hardly point to the "big bad government as bullies (etc etc)
    The policies actually began to be executed more recently with the Indian "pacification and reservation concentrations". The practical side of this was to make it safer for emigration of "the early settlers. " It is called many other things but that but i think one gets the concept,so as one can tell not SO recent).
    So in fact it takes way more energies to build, maintain, and as you are saying to "bulk up" urban areas, than it does to maintain life in more rural/remote areas. Again a very interesting concept, used in an entirely different context is MOST telling and indicative but is almost totally ignored in energy use terms. Once can see those modern cities at night captured in sparkling space satellite digital images, while North Korean cities aee virtually DARK.
    So no unless we are willing to live like North Korean cities, we are using far more energies, living in urban area's. So for example the LA metropolitan area vs the capital of North Korea, who do you think uses WAY more energy?
    The gravitation to urban areas is happening all over the world. I think it is economically driven--of course, the economics in each country is different, but the general goals are the same---there are more opportunities in cities for young people, and the young of course, define the future.
    It costs more to live in cities, but you make more---and if you can go anywhere in the city for $2 bucks, the savings of not having a car, or renting one now and then, or sharing one, or buying a motorbike---these are significant.
    And of course, electric cars or say small Smart cars running on diesel---these work a LOT better in cities than they do on freeways.
    edited March 2012
    My sense of this is that you were talking USA? I was responding in kind and on topic?
    If you want me to address the world, I can do that also. But I will not in this reply post.
    If that were true, they (cities) would have legalized golf carts and golf cart size vehicles LONG long long ago. Pretty disingenuous when the Vespa is the motorized metaphor for city travel, being emissions control and noise abatement are very minimal !!??
    So for example, Vespa as modernized metaphor has been true (for me anyway) app 46 years.
    About 75-80% of the US population is considered "urbanized" and it's growing slowly in that direction. So the vast majority of us sit on about 3% of the land.
    That closeness is what causes all the problems. Crime is much more profitable where you have more people to rob.
    But crime is also going down all over America (FBI stats). New York is one of the safest cities in America right now.
    Actually cities are appealing to people I think as they offer transit hubs and cultural vitality.
    However, it's not all clear cut migration. There's an "in and out" migration going on here, with younger people heading for the cities inner cores and older folks going to smaller urban hubs.
    You can be living in a city of 50,000 and still be considered "urbanized".
    My point was that the trend to small cars is not only about MPG.
    I agree. If I lived in a city I would probably have no vehicle at all and rent one when I needed it. I went for several years in the 1980s renting a car for my 3 weeks off from work. I would fly to Hawaii, AZ or CA and rent a car for less than I could own one. And it would be where I needed it. For a while when I was spending my time in Kona, I kept a storage and a bicycle. Only rented if I wanted to explore the other side of the Island. Never liked renting small cars though. I rented a Geo Metro once and took it back the second day and got a bigger car. I hated that little piece of crap. I did want a Mazda Miata, and never was able to rent one.
    When I think of horrible cities, I think of DC, Detroit, Philadelphia, Los Angeles, Chicago, Miami. Never had the desire to go to NYC.
    DC and Chicago have a lot to offer tourists but for mass transit NYC has the most extensive network by far (old, but you'll never need a car).
    I'm talking speed limits. Around here that's what we see most of the time.
    edited March 2012
    Anymore one needs a scorecard to keep track.Score Card
    I just normally ask the locals (who what why where and how) the real ones are. Or, where do the Jackie Gleason's like to chill out. ;)
    Neat map.
    Note that the populated areas have the lower speed limits. Here in MD it's 65.
    My point was we don't have limit-less autobahns here, so cars aren't geared for true high speed cruising, I'm talking 100+ or more.
    Those tall highway gears could also be making euro MPG numbers higher when it comes to a government test (which won't approach those speeds).
    edited March 2012
    in CA they are *very* real. Of course, some highways are stricter than others in terms of # of patrol cars, but 5-7 over and you're likely to be ticketed in most cases.
    the old "What if they are all doing it" is no consolation---they'll just pick one or two out of the speeding pack--catch as many as they can.
    And if you did 100 mph in CA, you'd be on a chain gang.
    Here in MD the magic number seems to be 12 over.
    So with a 65 state limit, you do 77 or more and you're pretty much guaranteed at least a speeding cam ticket.
    On the news the other day I hear they were adding 13 more cameras, makes you wonder how many they have in all....
    edited March 2012
    ..."My point was we don't have limit-less autobahns here, so cars aren't geared for true high speed cruising, I'm talking 100+ or more. "...
    Increasingly that is so in places that actually have autobahns. Indeed the real suggested limits are 80 mph (expressed in km of course).
    I have really not seem much C/C data. It is more like you have to look for needles in haystacks to find them AND compare them yourself.
    So for example, 03 TDI Jetta:
    1. European has 6 speed manual vs 5 speed US
    2. 100/110 hp/ 177# ft vs 90/155# ft
    3. bigger injectors
    4. 2 more mpg.
