I have a 97 Jeep Wrangler with 135K miles and the check engine light came on, the code that came up is 12 and I belive it says that the Power Control Module has recently been disconnected. Where is that?
It's the electronics box on the engine side of the firewall on the passenger side of the vehicle. However, that code can also come upo if the battery has been recently disconnected too.
my '97 started losing power when shifting through the gears and would not rev past 3,000 rpms. It would not do more than 55mph. Press the accelerator and ...nothing. It would spit and sputter a bit but, no increase in speed. This started after I noticed a noise coming from underneath which sounded like a broken clamp rattling on the exhaust pipe. After climbing underneath, the noise was coming from the muffler itself. Loose/broken baffle? Would this cause the loss in power and not allow the engine to rev? :confuse:
Are you sure it was the muffler? While it could be a loose baffle, those are also the symptoms of a bad cat.
mac is pretty much dead on. If you take a rubber mallet to your catalytic converter (located pretty much directly under the passenger seat), and it sounds like marbles, you found your problem. A bad cat will suck power, and likely be cause for bad emissions. if your TJ is under 80,000 miles, I BELIEVE it is covered now, even being an older TJ... Check with your dealer.
I have a '97 wrangler 4.0l 6cyl. When I turn the heat on its starts to make a wind up noise than sounds like a snap. I think the wiring is a bit messed up, but there is only on temp which is HOT! Theres also an ongoing sound of rocks rolling in what I think the two upper heaters above the radio? Any ideas to what the problem is or maybe a solution????
PLEASE HELP!!! I have a 1999 jeep with a 2.5L. On Saturday it stopped running. All it would do is crank. I started to test it i tested the fuel it was good then the ignition and the wildest thing happened. I put a adjustable spark tester on the coil wire and the thing started right up. It had a great ark about a 1" long. I took the tester out and it would not start. put it back in and it ran great. took it out and put on a plug wire no spark! I'm pulling my hair out please help
not sure on the heat thing other than perhaps your cable on your slider for your HVAC isn't connected and it is stuck in the hot position.
For the rattling, you may want to open up your dash and reach in there. You MAY have dirt/rocks, something in there that fell in while top was down/off. Those telescopic mirrors and a flashlight may help you look further down into the ventilation ducts.
yah, i had the rattling start early in the winter, and as time went along, i'd find kernels of dog food laying in the floorboards, i figured the mice were carrying dog food from the pens into the wrangler...
i set a few traps, caught a few, and it stopped... the rattling has stopped...
Hi I have a 1999 Jeep Wrangler 4.0 6cyl I hit a big chuck hole and my gauges all quit working speedo, fuel , and check engine light came on so I pulled over and shut it off waited a min and started it back up the gauges started working again but check engine still on so turned off again waited a min tried again and all is working what could this be Thanks
You probably just jolted the main electrical connector on the back of the instrument panel. However, to be on the safe side you should check for codes. AutoZone will do it free if you don't have your own reader.
Ive been having some trouble with me heat in my '97 4.0l 6cyl. Where is the wiring for the heat or maybe the core?? under the dash or under the hood??? cant find an outline or manual anywhere on the internet.
Can you elaborate on the issues? Not blowing hot? Only certain speeds work? Only certain vents? Details would help. It may not be as complex fix as you think.
That's a shame, but it doesn't describe anything to which a meaningful answer can be given.
Most of the wiring for the HVAC is in the dash, though some is in the engine compartment. The heater core is located inside the HVAC housing behind the dash.
I have had a 1998 jeep wrangler for the past 5 or 6 years. A few years ago it started to have problems after start up. After driving about 100 yards it will start dogging out and sometimes lurching forward. Seems to do this almost every time i start it up. If i happen to be sitting still when ever it happens the RPM's will just go real low and quickly come back up and this will happen for maybe 5-10 seconds and then stop. It seems no one has ever heard of jeeps doing this, so our mechanic has had to look far and wide with very few answers.
Ok, Im having a problem with my 4wheel drive linkage. The other day the old man and the kids went out 4wheeling and the shifter went loose. I have a 97 wrangler only a 4 cylinder. When they got home and after taking it apart we found that the shift bushing (factory rubber) was cracked and off. We have since replaced that but now after replacing the bushing with the new plastic one (they do not make the rubber ones anymore) we can not get the dang thing to stay in 4wheel. It just pops out. Please let me know what you think. :mad:
I have a Jeep Wrangler X with only 24,000 mi. on it. The only problems I have had with it so far is badly warped rotors that I noticed the day I drove it off the lot. They fixed it but after if was out of warranty I had a similar problem that I had to pay for. No problems with it since but I have not put very many mi. on it. I was just wondering if those that own 2006 Wranglers with more mi. on it then I have, have had any problems that I should look for down the road.? I also notice that the windshield seems like it is easily chipped. I have two cracks, one on the drivers side and one on the bottom of the drivers side. Both happened while driving on the highway and a car and or truck kicked up a pebble that hit it. I am 60 and never had this happen to any of my other vehicles that I have owned over the years. Are they fragile or what? One would think that since many take them off-road and its likely a rock will hit it, the windshield would hold up better. Just my opinion.
I have a '03 Wrangler and apparently the rear wiper switch was broken. When I pressed it, my dashboard lights including the light in my gear box shorted out immediately. My gauges, turn-signals and other misc. items on the instrument panel still illuminate (i.e. symbol indicating brights are on). I checked and double-checked all the fuses and everything looked ok. I just got back from the dealer and they said the rear wiper switch caused a short circuit in instrument panel cluster and for $900 (+ labor) they can replace the entire instrument panel I would have thought a fuse would pop before the instrument panel short circuit. Does anyone have any other knowledge / experience of this happening? Thanks and happy trails.
No, although I'm sure it must happen occasionally; and you're correct, it's not a fused circuit.
My first choice would be to look at the circuit board and see if it was something obvious and easy to repair (or have repaired), like a blown circuit ribbon that could easily be soldered.
Next, I would consider fitting a used instrument cluster (which must be from an '03). There's one on eBay at the moment for $200. If that option wasn't available to me I'd purchase a new cluster from one of the many online Mopar dealers. It's part # 56047016AB and seems to sell for around $580.
Finally, if you tell your current dealer that's what you're going to do he may also sell you the cluster at a competitive price.........and of course you need to replace that faulty switch (part #56007249 / MSRP $21.00).
Well, after much worry, I made a fist, and hit the top part of the instrument panel. Not hard enough to hurt your hand. I am a woman, so start easy, then just try it. It worked for me and something I have to do periodically. I will be driving down the road and every gauge on panel goes suddenly off. ... Oh by way, the gas gauge is not to be trusted. Count your mileage and fill up with gas by that. Also put it in shop to fix low air flow through vents. They could not find anything wrong with it as in the vents being obstructed. So in cold weather, it doesn't get warm for about 10 to 15 minutes and even then I have to dress warm.
A better way is to remove the black plastic around the cluster, remove it, then clean the contacts with a qtip and rubbing alcohol. Apply some dielectric grease to keep good contact and reinstall. Some have mentioned that giving the pins a slight twist will help ensure a better connection too.
I have cleaned my pins exactly once on my 97 and I've had NO problems, other than the gas gauge going up/down, but that is due to the sending unit in the tank itself. I'm too lazy to worry about that - it's correct 95% of the time.
MECHANIC INSTALLED A NEW OEM MASTER CYL. & SLAVE WITH LINE AND JEEP RAN FINE ON 1ST. TEST DRIVE. 2ND TEST DRIVE CLUTCH WOULD'T DISENGAGE.
Please don't SHOUT!
You could check that the pedal still engages the master cylinder push rod, and that the slave cylinder is still properly located and connected to the release fork.
However, personally I'd take it back to the mechanic to let him take care of it.
Thanks for the info!! I found an auto electronic specialist in the area and they are going to diagnose the problem and at the very least give me a second opinion. If I need a new cluster, I will try negotiating the retail price down to something more economical. Thanks again.
I have a 1997 Jeep Wrangler with a 2.5L engine. It was running great but recently would not start. The engine turns over but acted as if not getting fuel. When I cleaned and pressed down on the fuel pump fuse, the engine caught and was able to drive it. Now when I try to start even while applying downward pressure on the fuel pump fuse, the engine starts and immediately dies. The engine will only catch if pressing down on the fuse and if NOT depressing the gas pedal. As soon as I try to give it gas after the engine starts it just dies faster.
Any codes being thrown? I had a problem with my 97 2.5L and it was the throttle position sensor (had something to do with the huge mud puddles I was driving through that weekend). Other than that, perhaps take out the FP fuse/relay and make sure all is clean and making good contact.
Unless you want to drop the tank I suggest you just fill up and drive it as normal until the sender frees up. You can monitor your fuel level by mileage, assuming you have a rough idea of your mpg.
I assume I have gotten the computer chip (located under the hood by the battery) wet while off-roading one day and now I have a problem w/ the alternator not recharging the battery.
From what I understand, the alternator runs to the computer chip then relays to the battery to recharge it. The jeep starts up fine (so long as the battery has juice) but the battery will not keep a charge.
Yes, the alternator works just fine. I believe its the computer chip that is the culprit.
My question however is does anyone have any idea's on how to perhaps by pass the computer chip and connect the alternator directly to the battery to recharge?? Could it be possible to fit a GM alternator on the Jeep b/c those alternators have everything on them that is needed to connect directly to the battery to recharge it. Any idea's or solutions would be greatly appreciated.
ps. I know I can send off my current computer chip and get it fixed for around $350 + tax.
Are you getting any code? I saturated my engine area and threw codes for my throttle sensor. Never had issues with recharging, just keeping it running.
Kind of, but the PCM doesn't handle the full alternator current. It receives an input from the alternator's secondary rotor field and its ground, then using additional inputs from the battery voltage sensor and line voltage it regulates the alternator output by cycling the ground path to control the strength of the rotor's magnetic field.
While it's possible that the EVC (Electronic Voltage Control) circuit in the PCM may have failed, it's far more likely that the fault lies in the wiring between the PCM and the alternator, either an open circuit (broken connection or bad fuse), a short, a high resistance connection, or a bad ground.
First you need to check for codes, which may point the direction to the problem.
However, to answer your question, it's possible in theory although the PCM will permanently be showing charging codes. I've never done it though.
Any info . have 1998 wrangler ck light on, drive down the road the air bag light goes on, ck light goes off but the gauge go down "sometime" all( speedo/tack/oil ).There is always a light(air bag or ck light). Had a friend scan for codes. He thinks the dealer is the only way to go?? Any help be for i do that Thanks
Sounds like you have two problems. The first affecting the gauges is likely tied to the large round connector at the rear of the instrument panel. It needs to be unplugged and all the flat male contacts tweaked by about five to ten degrees, which will give a more positive connection when reconnected. Also, inject dielectric grease into each socket before reassembly.
Assuming there were no codes found then the most likely cause of the airbag light and corresponding 'check' light is a failed or failing clockspring. This also often has the effect of causing the horn and cruise to work intermittently or not at all. The clockspring is actually a long flat connecting cable wound like the mainspring in any clockwork mechanism, and it's contained in a cassette housed in the steering wheel. This enables electrical contact to be maintained between the steering wheel and the vehicle while the wheel is being turned. It's easily replaced, but it's critical that you disconnect the battery for at least five minutes to allow the firing capacitors for the airbags to discharge before you start disassembly.
1997 Jeep Wrangler TJ ...fault code keeps coming up with open injector circuits on 1-4 all cylinders ...obd codes P0201,p0202, p0203,p0204 clears but reappears after it warms up ...will stall out but does restart...could this be the start of a PCM failing or do I need to look elsewhere?......any help would be appreciated...Thanks
That's odd because the '97 model uses a different OBD standard that displays two digit codes. However, you can easily display them without a code reader.
To determine which Diagnostic Trouble Code(s) are stored in the PCM of your '97 TJ turn the ignition key to the "On" position three times in succession (i.e., On, Off, On, Off, On), within five seconds The Malfunction Indicator (Check Engine) Lamp will flash the appropriate number of times to indicate the DTC number, with a short pause between the first and second digits (e.g., 2 flashes of the MIL, followed by a short pause, followed by 5 more flashes, indicates error code 25) The appropriate DTC will also be displayed in the odometer window Note: All DTCs consist of 2 digits. If more than one DTC is stored in the PCM's memory, the procedure above will display all codes in succession. Regardless of how many codes are stored, Code 55 will always be the final code to be displayed. Code 55 indicates the "completion of the fault code display on the Check Engine lamp".
Post what you get by this method and I'll look to see if they correspond to the P codes you've got.
Been a couple years since I posted last but I thought I'd drop a line since my '98 just got a new clutch at 120K. Bought it new back in March of that year and it's been a good Jeep. AC has a leak somewhere, and looks like the exhaust manifold's cracked again (yay), and I had to buy Bestop seat covers since the driver's seat has a widening tear...but c'mon, it's over 12 years old now and I have decided to hang on to it and put the money in. Why not? it still has the character it did when I bought it. I think I will take out the carpet and have it rhino'd this winter too.
I need some advice as soon as possible. I own a 2001 Wrangler. Never had any problems til now. I get in and try to start it, but I just hear 2 rapid clicks when I turn the key, nothing else. Trying to jump it gets nowhere. I get it towed to a local Jeep repair place. After 2 days, they finally tell me a piece is broken in the steering column, and that piece isn't made any more. They said they will have to custom order a whole new column, cost 500 dollars and take another 5 days to do. This sounds mega fishy to me, but what else can I do?
-Paul
please help
-Paul
SUVs and Smart Shopper
-Paul
I can help you with that, go here: Jeep Manuals
-Paul
ANY HELP ON THIS --- WE ARE STUMPED ??????????
IF THERE IS NO AIR IN THE LINE ------ WHAT SHOULD WE CHECK NEXT ?? ONLY 93K MI. AND NEVER HAD ANY PROBLEMS BEFORE THIS ????
THANKS
-Paul
Please don't SHOUT!
-Paul
Any help would be appreciated !!!
APPRECIATE THE INFO !!!!
Mac?????
-Paul
Good to see mac's still here. Did Tom disappear?
Tom is still around, but sounds like he's not having much luck with his ride.
His Impala that is, not the Jeep.
tsjay, "Long term reliability of the Impala" #1, 20 Apr 2010 6:02 pm
-Paul
Man, they must be having a snowball fight in you-know-where...
Mine: 1995 318ti Club Sport 2020 C43 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
-Paul
Take it to an accredited Jeep dealership or to a reputable independent repair shop.
