Brand Problems Swept Under The Rug
17810121325
  • explorerx4explorerx4 Member Posts: 20,976
    'tolerance' seems like it should be more than just the thickness of a floor mat.
    i just checked the distance between the bottom of the gas pedal and the distance between the pedal and the back of the firewall area on a couple of my cars.
    basically, 3 1/2 to 4 1/2 inches for both measurements.
    btw, since some other manufacturers don't have this issue, those brands won't be the ones paying.
  • mcdawggmcdawgg Member Posts: 1,722
    "btw, since some other manufacturers don't have this issue, those brands won't be the ones paying"
    Wanna bet? If Toyota has to make modifications (they are discussing putting in programming to not allow the accelerator and the brake to be pressed at the same time, which is possible due to the electronic throttles. You can be sure the NTSB or some other agency will require all makers to do this. You know the tire pressure monitoring systems? Same thing. You will pay for it.
    I know other cars I've had in the past have had issues like this, one comes to mind (not a Toyota) that the mat slid up and made the accelerator stick down for a moment. I immediately went and bought some floor mat clips to solve the problem. All the new cars now have hooks, but you MUST use them!
    So where does "fault tolerant" end?
    When Toyota recalls 3.8 million vehicles and installs a decent accelerator. I was in the auto section at WalMart. They had a lot of universal rubber floor mats. They should be able to stick those into a vehicle without having to worry about the accelerator getting hung up because of Poor design. My 2007 Toyota Sequoia has plenty of room for several mats. I don't see letting Toyota off the hook on this one. They knew it was an issue several years ago and kept the same crappy design.
    I think this issue fits this thread to a T. Toyota trying to sweep problems under the rug.
    Then why do all manufacturers now have the hooks to hold the mats in place? Why do the good aftermarket mats have a grommet hole for the hooks? Because it is not safe in ANY car to allow mats to move, and they can, if they are not hooked in place. Some mats are worse than others, and can really slide around if not hooked. Also, it is NOT safe to use more than one floor mat. Again, why would all the manufacturers have a hook that is to be used to hold the mat in place?
    I bet you with a crappy aftermarket mat not secured and on top that it could move and interfere with the pedals on any car - it COULD happen. I had an old car years ago not a Toyota that this DID happen to me (no harm done, thankfully, but it could have been bad if I was in traffic, etc.)
    Toyota issued a recall in 2008 for the all-weather floor mats, which are fine IF you use the hooks and don't put one mat on top of another. I should know - I have the supposedly bad mats, and they NEVER move (3 years experience with them). So I wouldn't say they are covering anything up - this was done with in cooperation with the NTSB.
    This horrible accident was a dealer screw-up (the dealer's loaner car had the wrong mats, and they were on top of another, not hooked). Go after the dealer, they are at fault here. Due to it's high profile, this accident is just drawing tons of attention, and the witch hunt is on. Being #1 in anything, it seems people either hate you or love you, so Toyota is now the target of the haters. It's just a big witch hunt.
    Finally, I sure hope you use the clips and don't stack up mats in your car - it's not safe!! Like I said, I have experienced this about 12 years ago.
    The 2007 recall must not have worked too well since the federal say it has 102 reports of jammed accelerators in Toyota and Lexus models, including 13 crashes, five deaths and 17 injuries. (USA Today)
    Note that there's a safety advisory on the current problem. No recall will be issued until Toyota comes up with a fix that the NHTSA approves.
    In that USA Today link, Toyota doesn't recommend paper mats either, since they can slide around. I bet all the "courtesy" paper mats the mechanics use will get tossed in the dumpster now.
    And yeah, it is sort of fun to pick on number one.
  • imidazol97imidazol97 Member Posts: 27,731
    I don't see any way an extra mat would interfer with the pedal on my leSabres. The design of the pedal and the placement are good designs and safe. It's going to go back to that pedal design and placement so that there is little clearance between the floor and the pedal in Toyotas.
    Yep, I love the way society is lately - blame everyone else. :mad: Just follow the directions and/or use some common sense, and you will have no problems.
    You mean like not having kids near a door that might pop open on your mini van. Or don't get rear ended in a Pinto.
    Your posts all sound like damage control for ToyLex. There have been several posters here over the last several years with Prius doing the same thing. And of course the zealots are out trying to make them feel like idiots. If the NHTSA has 102 complaints, you can bet there are 1000s that did not complain. It is sad that 5 people died before Toyota got nailed.
    By the way all the rubber mats at Walmart did not have any holes. People are not used to having hooks for floor mats. I hate the big hook on my Sequoia. My foot gets caught getting out of the vehicle. Another safety hazard I should report to the NHTSA.
    ...a few years ago, this man's two young kids locked themselves in the trunk of an old Camry and were later found suffocated. He tried to sue Toyota for the car not having a release latch inside the trunk and lost. No cars made at the time that particular Camry was manufactured had inside trunk releases.
    Does your Sequoia accelerator pedal sit physically close to the horizontal floor so that an additional smaller area mat like the allweather mats could slide toward the firewall and impinge the pedal and cause it to move toward the accelerate position?
    I find it would be impossible in my leSabres. Looks like GM has the engineering right for safety.
    What is troubling about the Toyota problem is that some posters sound like they believe there is more to the problem than physical mat encroachment against the pedals; they sound like there's a software or computer problem.
    I recall months or longer ago when some discussion was about recalls or TSBs and someone was pointing out that some recalls were for trivial things like Lexus' floor mat problem while other companies had recalls for "real" car problems... I note that the floor mat problem was a "real" problem after all. I regret so many accidents have occurred and people injured. I keep thinking about the shifting or acceleration lag problem that occurred with some Toyota Lexus and Avalone cars and really showed up in the Camrys. Some blame physical engineering problems in the transmission and others point to control/computer software.
    No, he was only talking about floor mats. My heart breaks for the people who were killed and their friends and families but we should all take a little more personal responsibility for our own mistakes.
    If his posts sound like damage control, yours sound like an ad for some ambulance chasing class action attorney.
    2013 LX 570 2016 LS 460
  • stickguystickguy Member Posts: 53,868
    I can certainly see how the mat could get the gas pedal stuck. I guess I would have to crawl around in the footwell of an ES with some mats to see how it could slide up and pin the gas full down, and also impede the brake at the same time.
    but what does sound odd is that the evet lasted many minutes, right? with a skilled driver at the wheel, doing every thing he could. But, in all that time, he never intentionally (or even accidnetally) moved the mat to dislodge it?
    It obviously was loose enough to slide around, yo uwould think that he might have reached underneath to try and yank the gas pedal, or kicked at the mats.
    But, maybe it was just moving too fast?
    I used to have a car with mats that would slide forward and bunch up, but if anything, they eiter kept you from pressing down all the way on the pedal. I remember tugging them back with my foot a lot.
    the real telling incident will be the first person that has a runaway car after they had their mats confiscated. ALso hard to believe that all 102 reported events (although some were probably pedal misapplication!) were using 2 sets of mats like that.
    I will note an important contradiction in your argument.
    First you say Toyota's design has to be fault-tolerant.
    Then you say the cheap mats you can buy at Wal Mart - do NOT have to be fault-tolerant? That it's Toyota's job to compensate for the incompetency of others?
    Why don't they put holes for anchors on those?
    Better yet, why be so cheap in the first place? Buy an OE mat. They're not that expensive.
    Why give the manfacturer of those cheap mats a pass, and blame Toyota?
    Isn't that enabling the aftermarket manufacturers to keep making dangerous crap!?
    Do you really think Toyota is at fault because {el cheapo carpets} sells a cheap non-OE mat? Why not go after {el cheapo carpets}?
    You want to see a fault-tolerant aftermarket rubber mat? > MacNeil's Weather Tech mats.
    Good quality, form-fitting, fully custom, and (GET THIS!) yes they include holes for anchors in their designs.
    I just noticed an ad for them last night - Big Bold letters advertising SAFETY and highlighting those anchor holes.
    Check it out:
    http://www.weathertech.com/store/mvproduct.aspx?ItemGroupId=3&VehId=639&Year=200- - - 9&CustomerVehId=0
    Note their Camry floor mats have not one but TWO holes for the anchors!
    Yes, indeed, we need fault tolerant designs.
    Toyota provides that. Both the car, and the carpeted mats, and the rubber mats. Toyota is fault-tolerant.
    MacNeil is fault-tolerant.
    The .99 cent plastic mats you find at Dollar Tree - SORRY, not fault-tolerant.
    So...let's go sue Toyota, folks! Makes so much sense! :sick:
    Good points. Yes, the Weathertech mats are very nice. I have a set for one Camry, and OEM Toyota all-weathers in the other. I would not use anything that did not have the ability to be anchored and also be the correct size. Because of my concern for safety and my ability to read directions, I will not have a problem.
    There has to be a limit to fault-tolerant - at the rate we are going, it will be NO cars for anyone!
    Responding to another post, I don't work for Toyota, a supplier, dealership, or a company that has ANYTHING to do with Toyota. Family doesn't either. I don't own Toyota stock directly, although some of my funds might include Toyota stock - I don't know for sure, so I hope that clears things up.
    i'm of the opinion that an extra mat on the floor should not interfere with any of the pedals. maybe even one extra plush mat could cause a problem.
  • dougb_serkdougb_serk Member Posts: 7
    simply absurd, out of control, and speaks I think, of a lot more of our problems in this world. Thankyou, mcdawgg, for a little sense in this thread.
    I, too, hate to hear of someone hurt or killed in any accident. But this insanity has to stop. It is NOT Toyota's fault these people died. There is nothing wrong with the car used as designed. Lets quit feeding the lawyers and learn a little more common sense for ourselves. Lets take a little blame for our own screwups instead of suing anybody and everybody. Lets concentrate on a SMARTER world, instead of a litigious society where everyone and everything else is always at fault. Im so sick of this type of thing.... this is a freaking floormat issue, for gods sake...and it will end up costing millions. God help us when we get to serious and important issues.
    sometimes you have to measure things by the effect, not the cause.
    I had a car 12+ years ago that did not have hooks, and even with only one mat on the floor, it would interfere with the accelerator pedal. One time, it kept the pedal down, which could have turned out real bad! I was able to reach down and pull the mat back. After that, I went and bought some clips to keep them in place. Funny, I never heard about anyone wanting to sue Mazda or force a recall. I know I couldn't have been the only one that this happened to! Maybe I should go back to Mazda now and tell them that they caused me mental anguish or something!
    Toyota has had hooks for at least 12 years, and they tell you to use only one mat and use the hooks.
    Well, I'm glad someone else agrees with me. The dealer was the problem here, not Toyota, so go after the dealer.
    I'll go further. Even the dealer isnt at fault. The man at the wheel made multiple mistakes. This car could have been brought under control. Thats the cold hard truth.
    the speed limit is 65. plenty of people exceed it and don't die.
    why do you think that is?
    Maybe you should work the 911 lines. You could have saved those lives by telling them how to stop the car. I find it hard to believe that someone with his experience would not have tried to get the car our of gear at the very least. I will wait to hear what the NHTSA has to say. I don't think Toyota is off the hook. The dealer is partially to blame for the wrong floor mats on a loaner car.
    Toyota spokesman John Hanson said at this point, there are no changes imminent for start-stop buttons, not even a warning label. The three-second activation time was quite deliberate."That feature is a safety feature in (and of) itself," he said. "we want to make sure the engine is not shut off inadvertantly by touching the button." Toyota is yet to announce how it plans to deal with a permanent fix on the accelerator problem that would let people put their floor mats back in the cars.
    http://content.usatoday.com/communities/driveon/post/2009/10/68500247/1
    Actually there was an earlier notice about a TSB and the pedals on the Toyota. I recall someone in the past mocking that there was a complaint, TSB, or whatever, so trivial about floor mats while other cars have "real" recalls about bad things; mat problems weren't bad. (>God help us when we get to serious and important issues.)
    However, we see now, with 120 complaints documents, that floor mat interference with accelerator is important. So the floor mats in a Toyota complain should have put the "best car company in the world" on notice to redesign the pedal and its location to mitigate interference from the commonly used extra mats. A solution is not suggesting people not use extra mats or suggesting they use hooks.
    Actually when this problem is put together with other under the rug problems through the Toyo lines about acceleration lag over the last few years, I agree with a few other people who suggest there may be more to this problem than just mats impinging accelerators and forcing them to the floor.
    Personally, I've never been a fan of keyless ignition. Too much chance for an electronic hiccup. Airliners have gone heavily electronic, but most have manual back up systems as well. IMO the key is a car's manual back up in case something goes haywire, like rebooting a computer.
  • longo2longo2 Member Posts: 347
    Former Toyota lawyer, Dimitrios Biller of Los Angeles, swooped into U.S. District Court in Marshall, Texas, to drop off four taped-shut boxes of documents. Biller submitted them as evidence in one of 16 rollover-accident cases against the automaker that have been reopened, according to a statement from Robert Riggs, spokesman for Dallas lawyer Todd Tracy. Neither Biller or his attorneys were available for comment yesterday, but we have a good idea what's in those boxes: all the documents that back up Biller's allegations that Toyota destroyed evidence that should have been disclosed in 300 rollover cases -- plus other misdeeds. Toyota officials offered no new comment yesterday, but has steadfastly denied wrongdoing through the whole wretched affair.
    Toyota has been going after Biller for disclosing secrets it believes were covered by attorney-client privilege. Biller fought back by filing his own lawsuit alleging Toyota destroyed or hid evidence and test results. With lawyer Tracy ready to ask the court today to let him see what's inside of those boxes, you can bet Toyota will be there to oppose letting anyone take a peek except maybe the judge. And maybe not even him.
    Looks like Toyotas' got more stuff under their rug than we all thought! :mad:
  • uplanderguyuplanderguy Member Posts: 17,049
    When I first heard this story, I first thought 'why didn't the driver put the car in neutral?', and then I actually thought the guy may have wanted this to happen. But on the other hand, I didn't understand how the brakes could not stop the car.
    In the northeast, where I live, it's not uncommon for people to use a second mat on top of the factory mat, in winter weather. Hell, my Cobalt's factory mats are light gray, like the interior, so I've had cheapo carpet mats on top of them since day one. You'd have to have several inches of mats to jam the gas pedal, though.
    I have to wonder if the support of Toyota in this case would be the same if the manufacturer was GM, Ford, or Chrysler.
    I think that while the accident apparently could have been avoided, Toyota may at least be guilty of just-plain dumb design in making a gas pedal hang so low and be so easily susceptible to an aftermarket floor mat.
    Bill
  • grandtotalgrandtotal Member Posts: 1,207
    So, are your cheapo mats transparent so that you can see the factory mats? If not why don't you have the factory mats in storage when you have the cheapo mats installed?
    i live in the northeast also, and agree with uplandeguy. it is pretty common to put one mat on top of the other. why remove the first set when you have a perfectly good place to keep them already?
    Well, if you don't read the manual or do read it and don't follow the instructions, then you shouldn't complain when you get hurt. Unfortunately these types are usually the ones that howl the loudest because they feel they are special and don't have to follow the rules.
    my view is you shouldn't design such an important feature, pedal design, to have that small safety margin.
    That's exactly the point. I would think to avoid issues like these manufacturers would tend to idiot proof their vehicles. That Toyota pedal design is definitely not idiot proof.
    I wonder if Toyotas placement of the pedals is due to the feature of knee airbags? I've never owned a Toyota before but are these airbag housings good size where the bulk up the dashboard therefore ergonomically the pedals need to be lower for access? No other automaker offers knee bags so maybe that is why Toyota is an anomly in this.
    Just a thought.
    Maybe, but 2004-2009 Prius does not have knee airbags. I doubt whether Tacoma or Tundra do either.
    They say you can't simply turn off the car w/o the wheel locking-up which would be very dangerous at 100 mph. But if you only click the key back one position, the engine should shut off but the wheel should still turn, though the power steering would be inactive.
    You could shift the car into neutral.
    You could shift the car into reverse which would destroy the transmission, (imagine the sound that would make at 100 mph!) but would stop the car ultimately saving your life. I think I'd rather face a rather hefty car repair bill than be dead.
    Did the driver try the handbrake?
    Did the driver panic and simply not realize it was a stuck floor mat and reach down and pull it out or fail to ask his passenger to do it for him? I've had this situation happen before and it's often after I've been to a full-service car wash when the attendants are in a hurry and fail to place the mats properly. Sometime the mat is actually laid over the accelerator pedal. At that point, it's at a slow speed and not too much of a hazard.
    I don't know how Toyota/Lexus cars operate. Do they have some kind of override preventing the cars from being shifted into neutral or reverse over a certain speed? Can they not simply be turned-off when the car is moving?
    I agree that Toylex has some problem areas with their lineup. The accelerator pedal for sure is poorly designed. The whole electronic ignition concept is flawed in my opinion. What happens if you are standing next to your car with the fob in your pocket and junior hits the ignition button? I still have a big question mark in my head on the transmission shifter. Can you shift out of gear at 100+ MPH? Logic says you should be able to. No one has tried it and reported on this thread the results. I am thinking the transmission ECU may not allow you to shift out of gear at high speed.
    That is another point to think about. All those fancy airbags did not save anyone in the car.
  • 210delray210delray Member Posts: 4,721
    You can't lock up the steering wheel unless you remove the key, PLUS the key can only be removed if the transmission is in the Park position (standard automotive practice). With a pushbutton start, I would doubt the steering column would lock if you simply turn off the engine. You'd still probably have to put the tranny in Park.
    At least on my 2004 Camry with conventional ignition switch, you can easily put the car in neutral at 60 mph -- I just tried it. But I'm not going to go 100 mph just to prove a point.
    Handbrake would be ineffective at 100 mph+. You need full braking power on all 4 wheels.
    I have no doubt the driver did panic. Reports are the dealer put the wrong mats in this loaner car, mats that were longer than standard. Because the car was a loaner, the driver would be much less familiar with the car, but he'd presumably have less incentive to worry about damaging it.
    The knee airbags do not require a larger knee bolster to contain them, so that is not the reason the accelerator pedal is closer to the floor.
    A crash sequence starting at 100+ mph and ending in a fire is well beyond the design capabilities of any airbags being used today.
  • andre1969andre1969 Member Posts: 26,110
    I'm not sure how modern cars are, and it may vary, but with my '79 New Yorker, you can't even turn the key all the way to the off position if it's in gear, so there's no worry about locking up the steering. However, on a car with a push-button start, I'm not sure how it works.
    As for shifting into reverse, I don't think modern cars will let you do that at speed. The transmissions are too "smart". Heck, even my '57 DeSoto won't let you shift into reverse if it's moving forward more than 10 mph. But my grandmother's '85 Buick LeSabre would! (don't ask me how I know that :blush: )
    Junior will only turn on the accessories like the radio in that case. The footbrake must be depressed and the tranny in Park before the engine will start. The car won't move unless the pedal remains depressed and the car is shifted out of Park.
    Presumably, Junior will be too short to reach the brake pedal, and Junior shouldn't be in the front seat unrestrained in the first place.
    At 120MPH nothing is going to save you if you hit something solid.
    Also my car won't start unless the fob is IN the car, standing next to the car is not enough.
    Good point. I'm not familiar enough with cars with pushbutton ignition switches.
    When I drive my son's Prius with this setup, I always have the fob in my pocket (or he does if he's in the car).
    In this accident they rolled several times before ending up in the drainage ditch. I have seen Nascar drivers roll and flip going way over 120 MPH and get out and walk away. The report says they were killed on impact. My question is what good is an airbag if it does not protect you in a high speed crash? They glanced off of another car before rolling. I think it was the fire that killed them. I am trying to picture a car with umpteen airbags that should have ALL inflated not protecting the people inside.
    Airbags (and crush zones for that matter) in today's passenger cars are NOT designed for that level of impact. You know the scene of the crash. Do you think anyone in a production vehicle could have survived, even without fire, in a crash of that magnitude?
    NASCAR cars are purpose-built to withstand high-speed rollovers, but it's still possible to die in racing, even today.
    I don't disagree, but that has more to do with the design of the mat itself, not just the car.
    What needs to stop is these cheap JC Whitney style pieces that creates these hazards in the first place.
    I was just vacuuming out my Grand Marquis at lunchtime and it would have to be one really thick mat to get jammed under the accelerator pedal. I'd have to stack at least three carpeted mats on top of each other to jam it. The only other way I could see it happening is for the mat to be all curled up in a cylinder. Is there very little clearance between the accelerator pedal and floor in a Toyota/Lexus? By the way, the Grand Marquis' mat does have a grommet and hook system to keep it from sliding around.
    That about sums it up. I think both sides will agree on that one.
    But ... does this mean Toyota should be liable? Or the idiot?
    The very phrase fault-tolerant implies Toyota is being expected to compensate for an error that is something or someone else's fault, i.e. that same idiot they're trying to proof against.
    So, go after the manufacturer with deep pockets, or the at-fault idiot?
    That is where the two camps do not agree.
    Sure, more fault-tolerant designs avoid these situations entirely, but that's how we end up with step ladders that have a giant STOP warning on the top rung. I'm sure some idiot would have kept on going - right past the last rung in the ladder! :D
    If they did - would it be the ladder manufacturer's fault for not putting STOP there?
    Remember, Toyota provides the hooks. The OE rubber mats and carpeted mats have grommets. They basically didn't forget the STOP sticker.
    This pic is close, it tells you not to climb the back side, the side WITHOUT THE STEPS! DUH!
    The funny thing is this - they put it there because someone actually climbed the wrong side of the ladder!
    Toyota: I wish you luck proofing your cars to the intelligence level of the guy who climbed the wrong side of that ladder.
    Uhh no other automaker offers knee airbags?
    Man, many automakers do now and I doubt Toyota was the first to offer knee airbags. In fact I would be surprised if more then a couple of the vehicles included in this recall have knee airbags. The 2007 Camry has them and so does the ES350 but do any other Toyotas? I think the Land Cruiser/LX470 do and probably some of the other Lexus models but that is it.
    Kia had knee airbags in the Sportage before any Toyota had them.
    Funny thing, I felt, was that Kia didn't really ever do well in crash tests, even with those.
