Postwar Studebakers
11516182021152
  • jljacjljac Member Posts: 649
    edited May 2011
    I hadn't heard of the Arrowbile, aka Aerobile. Pretty radical design for 1937!
    Next we are going to hear that Ford thought of that idea first in 1929 by building the Ford Tri-Motor, and then I will have to do research to find out if Studebaker designers working on their spare time had anything to do with designing it.
    edited May 2011
    Yeah a Corvette engine is different than a Biscayne. Cylinder heads, camshaft, lifters, and in some cases pistons or block webbing. Also the block is stamped to the VIN of the car for this very reason---so you know you don't have a Biscayne engine.
    There really is no such thing as an Avanti engine. It's a Studebaker engine in an Avanti. So I guess one could take an engine out of an Avanti and put it in a Hawk and say "that's an Avanti engine"---in THAT sense, okay! :)
    Otherwise, you can "make" an Avanti engine in your garage no problem. To make a Corvette engine would require quite a bit more fabrication, including re-stamping, machining and a lotta new parts.
    Again, it's a case of Studebaker making a good deal out of very little. That's what Studebaker did all the time.
    edited May 2011
    I learn all sorts of new things here. I thought that the Biscayne was the cheap six-cylinder Chevrolet model. At least our 1963 was, which my mother hated driving because she had been spoiled by driving the 1951 Studebaker Champion which had overdrive transmission, easier steering and was nice and warm in the winter.
    I still don't understand why the Corvette engine was so much different than the Chevrolet engine but the Avanti engine is just another Studebaker motor, unless it is an R-3 or R-4, in which event all the credit goes to to the outsider, Andy Granatelli although he was employed by Studebaker at the time.
    In defense of Andy, he did not spend his spare time working on designs for the competition or undercutting Raymond Lowey by re designing the Avanti as Virgil Exner did when employed by Raymond Lowey when designing the 1947 Studebaker models.
    As a result of what I learned here, I now know that the first Chevy Corvettes were powered by Chevy Biscayne motors and that our 1963 Chevy Biscayne was powered by a Corvette motor. If my Mom knew that, she might have appreciated it more. Maybe not.
  • uplanderguyuplanderguy Member Posts: 17,145
    edited May 2011
    Net result: 250 hp. out of 327 cubic inches. Corvette has "Corvette" valve covers. Not seeing the difference here. Even the standard '64 Chevrolet could be had with a 300 hp. 327 V8--also available in Corvette. Different engines? I'm respectfully calling b*lls**t here.
    edited May 2011
    That 1963 Biscayne could have come with a six, a 283, two versions of the 327 or three different versions of the 409.
    I don't remember the Corvette engines being any different? If it had the base 250 HP 327, I thought the engines were no different than a 250 hore 327 that came in an Impala.
    I don't think there were any differences at least not in those engines.
    Now the earlier 283's with 2 4 barrels, those may have been beefed up?
    edited May 2011
    Here's a very good article that should clear up your (and a lot of other people's) confusion on this subject:
    Engine Used in the Avanti
    I found this article helpful in clarifying my own research on the subject.
    As the author sums it up: "There is no such thing as an Avanti block, head or crank as there would be with a Corvette"
    edited May 2011
    So GM, the king of interchangeability, in its Chevrolet division made two different 327 cubic-inch engines, with 250 hp and 300 hp, that were different engines than 327's with the same horsepower in their passenger cars of the same mode year? OK. I'll give you that 'Vettes had snazzier-looking "Corvette" valve covers as opposed to the '50's style script "Chevrolet" red covers on the others. (Sort of like how R1's had chrome valve covers and other Stude V8's did not.)
    Read the article--LOL!
    The horse is dead, stop beating it, your host begs you. :P
    Okay, if you read the article I will NEVER bring this up again, promise, unless somebody asks me directly.
    Nice bit of two-steppin' here.
    I don't deny a single thing in that article. I do deny that a 250 or 300-hp 327 in a base Chevy is a different engine than the same displacement and horsepower in the same year Corvette. It makes absolutely no sense.
    I do believe engines available in 'Vettes that weren't available in Chevy passenger cars, like the various "L" engines of later years, were "Corvette-only" engines. If they weren't available in any other model, they are "Corvette engines".
    I'm still not exactly certain what the original discussion was about. An Avanti engine is one that was standard in Avantis and optional on Larks and Hawks. An acquaintance who sells far more Studebakers than any other source has recently said an R1 will add 15% to a Lark's value and an R2, 50%, despite his issuance of this data to the price guides which he concedes (and I've noticed) haven't changed this data in eons.
    This article about the Avanti engine does show all the changes that made the weakest Avanti engine (R-1) stronger and different than the strongest Studebaker engine of 1962. Different pistons, valves, camshaft, distributor, intake manifoild , vibration damper and carburators. The fact that most of these parts can be used in earlier Studebaker engines is not seen as a drawback for those of us still driving them nearly 50 years later.
    The original discussion was about how there is no such thing as an Avanti engine block. I think the article pretty much spells out why this is so and why it differs from the special internal parts, castings and heads used by GM for its high performance engines.
    As for an R2 engine boosting the value of a Lark 50%, well that's one man's opinion I guess. If he sells them, then one might naturally expect him to be on the high side.
    Remember, one sale does not make a market. Many a man has made this fatal error.
    Since he sells on eBay, he's not setting the prices; the market is.
  • imidazol97imidazol97 Member Posts: 27,787
    edited May 2011
    I started it by referencing the comment in the movie that the shiny black Lark was a Super Lark because it had an AVanti motor. Oddly, I felt that I recalled that there was such a car named thus in my youth gone by. I always had a soft spot for Studebakers after having cut my teeth, literally, on a 1950 Studebaker. It replaced a postwar Chevrolet that looked like something from Bonnie and Clyde.
    I learned to drive that Studebaker when I was 11 or 12 after my brother had me drive his 1950 Ford flathead as a one gear vehicle; he had me start it up in third gear. It lugged and moved right out. That way I didn't have to shift. In 1963 - 1965 I would see that Studebaker parked at a house when I was home from college so it was still running after we traded it.
    Not that this particular person is the end-all of all Corvette engine knowledge during the time the Avanti was being built, but I think it's interesting. He is the original owner of a 300-hp 327 '62 Impala:
    "Admittedly, the Avanti engine could be ordered in any Lark in 63 and 64. But I don't think there's very much that's unique to the 62-64 Corvette engines either, except for some trim items and whatever was required to make it fit into the Corvette. Both the 250 and 300 hp versions of the 327 were available in both Corvettes and full-size Chevys. There are a number of differences between the two engines, the most obvious being the much larger Carter AFB on the 300 hp unit.
    I still own a 62 Impala equipped with the 300 hp 327 that I bought new. The 300 hp 327 was a commonly ordered option in both Corvettes and big Chevies. It has the same compression ratio, 2.5-inch rams horn manifolds and dual exhausts as the Corvette. The parts book shows the same cylinder heads were used on both Vettes and big Chevies with the 300-327 in 62 and 63.
    Clearly, some later years of Corvettes were available with Vette-unique engines, but I don't believe that was true while the Avanti was in production."
  • andre1969andre1969 Member Posts: 26,140
    you guys have me curious...what IS the difference between a 250 hp Corvette 327 and a regular 250 hp 327?
    BTW, my Dad had a beat-up '62 Corvette when I was a little kid, and when he blew up the engine, my granddad helped him throw a 70's 400 smallblock in there. I'm sure that would be considered a BIG no-no these days!
    On a C2 Corvette 327 engine there should be a partial VIN stamping on the block. I don't know what other differences to look for though.
    edited May 2011
    I'm having a hard time believing that the blocks are different between an Impala 327/250 or 327/300, and a Corvette with the same displacement and horsepower. The question would be, "Why?". I think most of the differences would be cosmetic, like valve covers and probably air cleaners, or things that would be different due to fitting in the engine compartment...much like an "Avanti" V8 over a regular Studebaker V8.
    Stude V8's don't have anything like a partial serial no. on the block, but then, with the production paperwork available at the Stude Museum, it's still easy to check to see if your car still has the engine it was built with (my Avanti-powered Lark does, as does the '64 Daytona sitting in my garage waiting to be picked up and shipped to its new owner in Australia).
    Just got another bit of correspondence from the fellow who's the original owner of a '62 Impala 327/300HP:
    "At the risk of beating a dead horse (again), I think it's important to compare what Stude was doing with Avanti engines in 1962 and 63 with what Chevy was doing with Corvette engines in 62 and 63. Comparing the uniqueness of 1963 Avanti engines with the uniqueness of 1970 Corvette engines doesn't seem very sensible -- who knows what Stude would have put into Avantis if they were still building them in 1970?
    Anyway, I dug out a 1963 Chevy parts book and looked up a few critical engine parts for 1962 and 63. The following parts were common to both big Chevy and Corvette engines with the same horsepower rating: block, heads, cam, valves, and water pump. Two crankshafts were listed for 62-63 Corvettes, one of which was also used in high performance Chevys. The second one was unique to the Corvette, though it appears that that unique crank was only used in fuel-injected engines. The listing was a little confusing -- Chevy parts books are not as easy to use as Stude parts books.
    Clearly, the FI engines were unique to Corvettes, but those aside, I couldn't find much else to differentiate Corvette engines from the high-performance engines that were available in big Chevies in 1962 and 63."
    I wonder if the block is really an identical part, but maybe the there's a sequence of numbers in the serial # or something that specifies "Corvette-only" on the blocks that were allocated for Corvettes?
    And, perhaps it's one of those things where, if the Corvette hadn't become such an icon, nobody would have even cared?
    edited May 2011
    Might be, Andre. The basic conversation started with a discussion of, basically, how the 'Avanti' engine isn't anything really special, but the 'Corvette' engine was.
    On another subject, I read today that a '56 Golden Hawk, in #2 condition, sold for $80K very recently at auction. This is down from the $99K one sold a couple months back at auction, but this is two in a short period of time. I'd never pay that for one, but I think it does show that Studes sometimes bring more than Big Three makes, despite the old, rehashed conventional wisdom.
    edited May 2011
    I like Corvettes but don't know much about them. The VIN stamping on Corvette blocks was an answer to a question I asked a while back in another topic. There was a discussion about market value on a 454/390hp Corvette for sale. I asked if the "matching numbers" documentation would be very important for that car since that particular engine was not a high-end, high performance option. The surprising (to me) answer was "yes" because Corvette owners/fans are all about the numbers - even if it's not one of the wild L-88 bruisers. Compared to a first gen Mustang with a base 6 engine and three speed manual, a proper conversion to a small block V8 + four speed can make a vintage Mustang worth more.
    Shifty explained how the VIN stamping on Corvette engines from that era drives the appetite for precise numbers-matching examples -- at least to get serious Corvette money. Vintage Ferrari and Porsche fans are apparently less afflicted with all that. (edited to add this link to a Project Cars post about Corvette engines.)
    But regarding the 327/ 250hp or 300hp Corvette engines, I don't know what else beyond the block stamping might possibly be different from other Chevy 327 engines - if anything. It's difficult to sort that part out based solely on factory advertised hp ratings. Advertised hp ratings seemed intended more for marketing than engineering purposes.
    Btw, congrats on the Daytona sale. Are you shopping for another car or just making room in the garage? :shades: This may not be a bad time to shop for a collectible depending what you're looking for.
    edited May 2011
    Believe it or not, matching engine no. (well, verified to production order) is important to lovers of Avanti-powered Studebakers as well. Long available has been a $10 multi-page list that shows every serial no. an "Avanti" engine was installed in, other options, colors, and engine no. If an Avanti-powered Studebaker shows up on eBay, and it doesn't have its original engine, that's quickly all over the Studebaker Drivers' Club site.
    My '64 Daytona is more of a fixer-upper than I'd hoped. I bought it sight-unseen (only photos) in 2009. The car was sold new in my hometown by my friend, the Studebaker dealer, who remembered the car and the owners. I remember the car in town back 'til about 1974. It was a sentimental purchase, and I love the '64 styling. But it's more than I can tackle. My '63 Daytona Skytop is a much-nicer car that I've owned since 1988. The same buyer has expressed interest in it too, for next year. If we can work out a deal, I'd sell it too, and buy a nice, solid '63-66 Stude two-door sedan, any engine, that doesn't need much work at all, and I'd enjoy having the extra $$ from the sale to figure some way to help put my daughter into college in the fall of 2012!
    "My '63 Daytona Skytop is a much-nicer car that I've owned since 1988."
    In the book 50 Years of American Automobiles: 1939-1989 by the Editors of Consumer Guide http://www.amazon.com/50-Years-American-Automobiles-1939-1989/dp/0881765929 there is a photo of a white Skytop Lark which appears to be powered by an “R-series Jet Thrust engine developed for the Avanti” (proper name). I was wondering if it is your car. If so, it is a nice photo.
    I think the car pictured is probably the one that was owned by S. Ray Miller of Mishawaka, IN, and currently owned by Gary Williams of Wadsworth, OH. It is white with a black Skytop and is an R2 4-speed. Mine is white with a white Skytop, and is an R1 automatic. Gary's is super-sharp and is now mounted on Cragar mags...looks great.
    edited May 2011
    There are actually a couple differences between an R1 or R2 installed in an Avanti and one installed in a Lark or Hawk. Water pump for one, I'm told, and also the stamped engine nos. on an Avanti begin with "R" and the nos. for the "Avanti" engines installed in a Lark or Hawk start with "JT" (for 'Jet Thrust'). Same engines though, but it does enable an Avanti owner to tell if their R1 or R2 really started out in an Avanti or a Lark or Hawk. Again, with the very complete build records available, it's easy to tell if the engine in your car is the original engine or not.
    Correction...I've just read that the car was bid to $80K but the crazy owner didn't accept the bid!
    edited May 2011
    It seems like you won the argument about the Avanti engine then because nobody said that the Corvette had a unique engine block that was only used for the Corvette and that seems to be the standard of review.
    But now I wonder if the motors in the Avanti IIs are properly called Corvette engines, or Avanti GM engines, or Avanti Chevrolet engines.
    This is too much for me to decide now because the Los Angeles Angels of Anaheim are playing a baseball game I want to see today. :shades:
    I wasn't trying to win an argument, but it just didn't make sense to me...particularly in the period when Avantis were being built also.
    Enjoy the game! I've gotten all sweaty today waxing my wife's Chevy van...even the roof...here in OH where today's the first nice, non-rainy day we've had in two weeks!
    Even a base engine stamped by the factory with a partial Corvette VIN number is a "Corvette engine" unique to that particular car. And it's already been pointed out that the FI 327 was one example of a Corvette engine which was unique in more than just VIN stamping. It depends on how people define "numbers matching" and "unique" examples.
    I also agree that a collectible car which is already "done" or in excellent original condition is much better than a similar car which needs fixed up. It's a funny thing because the first story I ever read about a collector of modern post war cars was around 1975. (I don't think they were called muscle cars back then.) The collector was from NY and showed off a beautiful 1963 Corvette with knock off wheels that he rarely drove.
    That guy was unusual for 2 reasons: he had no interest in the pre war stuff which was most of the car hobby back then and he had no interest in "restoring" cars. He would search for very well-kept, well-optioned stock cars and make an offer. Looking back now, I think he was a smart fellow ahead of the curve which didn't come around for a long time!
    Oh, yes...the college funding part is definitely a priority and puts all else into perspective. My nephew is less than 15 credit hours shy of his undergrad degree and it's crunch time for the coming fall/winter. Surprising now what a public college education can cost in the long run, loans and all that. Good luck to your daughter this fall and the rest of the way.
  • bhill2bhill2 Member Posts: 2,639
    edited May 2011
    Oh but I think that you won the argument whether you wanted to or not. The original statement was that there was no such thing as an Avanti engine, because the Avanti used the same engine as the Studebaker (Lark). This was contrasted to Chevy, where the engine in the Corvette was upgraded (rods, heads, etc) over the one installed in the passenger cars. However, one of the posts in the discussion had a link to an article indicating that Studebaker didn't have the resources to do two different engines, and so built them all to the higher Avanti standard. Therefore, it's not that there are no Avanti engines, it's that they are all Avanti engines. In other words, it's as if every engine available in the Corvette but installed in an Impala (or Bel Air, or Biscayne) had been built to Corvette standards
    ...I was at a show for my Cadillac-LaSalle Club chapter held at a local Cadillac dealer and a Studillac showed up. This one was a gold and red 1957 Hawk with a Cadillac engine.
    By the way, I had my 1989 Cadillac Brougham out for the first time since November and she ran like a champ! :shades:
    She ran like an early '60's Studebaker pickup???! :)
    Sorry...lame Studebaker humor there!
    '89 Brougham...does that have the silver lower bodysides or is it earlier than that?
    Earlier than that. I think the 1990-92 Brougham had that feature. The 1990-92 Brougham also went to composite headlights.
    Good, then. I didn't like the huge headlights and silver lower trim on those cars!
    One thing I liked about the Brougham which started in I think '84 or '85 was the body side molding which was the color of the car. Most times, cars look better without the side molding, but with the Brougham it blended in so well, and didn't detract from the other trim on the car, like the rocker trim, etc. Good feature.
    Remember the Brougham coupe? I think they still called it a Fleetwood then. Wasn't crazy about that tiny quarter window, but had the great exterior trim of a Fleetwood and that wonderful Brougham interior!
    Here's a 40-sec. video I enjoy, called "The Judge Gets Sentenced"!
    A '63 Lark with factory R2 (factory front fender badges read "Avanti Supercharged") beats a '70 GTO Judge. The Stude's driver was over 70 years old at the time.
    http://www.youtube.com/watch?v=XIyX7lWj7ws&feature=related
    edited May 2011
    For what it's worth, I trust the Parts Book over hearsay, much as I trust information in a carmaker's sales brochure over something I see in a Consumer Guide book or the like, many years later.
    The standards applicable to the Avanti engine changed during the discussion. The hoop was moved as the ball was in flight. The discussion began at post #855 which says this.
    Technically, there's no such thing as an Avanti engine. It's a regular Studebaker block through and through with a few bolt-ons, unlike say a Corvette engine which would have internal strengthening and special heads, etc.
    After the differences between the R-series engines and the standard 289 Studebaker engines were discussed, the rules were changed and the degree of difficulty in was increased to require that Studebaker must have a complete engine block to make it a unique Avanti engine at post #869 which says this:
    In summary Chevrolet took its engine and modified its engine for the Corvette and Studebaker did the same for the Jet Thrust R-series known as the Avanti engines which were standard equipment for all Avantis but were available as an option for other models. It is not correct to say that all Studebaker V-8s are Avanti engines.
    There is a big difference between Chevrolet and Studebaker V-8s because Studebaker did not have to redesign or strengthen its engine block as Chevrolet did repeatedly. Studebaker got its block right the first time although it was introduced four years before the Chevrolet engine.. As wikipedia states, the Chevrolet engine had to be redesigned just to get from 265 to 283 cubic inches.
    http://en.wikipedia.org/wiki/Chevrolet_small-block_engine
    The 265 ci V-8 was bored out to 3.875 in (98 mm) in 1957, giving it a 283 cu in (4.6 L) displacement. The first 283 motors used the stock 265 blocks. However, the overbore to these blocks resulted in thin cylinder walls. Future 283 blocks were recast to accept the 3.875 bore.
    edited May 2011
    ...in the parking lot outside the Wal-Mart lawn and garden center today. Our town isn't very big (28K population) but just when I think I've seen every Studebaker there is around, one will pop up. This car looked solid as a rock, was a "Regal" (nice original seats), and was mounted on white 'sporty' wheels that had 'Ford' centers. A mid-fortiesh woman and her husband pulled next to my late-model dullsmobile (!) and said, "What kind of car is that?" I said "Studebaker" and she said, "I told my husband that! My grandparents had one!". They then proceeded to walk over and look at it.
    What's sort-of ironic is, although I didn't grow up in the town I live in now, I've talked to several Studebaker folks who lived there back then and have also taken note of this while at the Studebaker National Museum archives...our town's Studebaker dealership, Jim Lee's, sat on the exact spot Wal-Mart is on now!
    An old car will add a bright spot to many a person's day when encountered unexpectedly. That Lark certainly added to mine.
    edited May 2011
    Here's a Hawk from a busy gas station along I-70 near Columbus this morning.
    Later in the afternoon at a car show nearer home I saw a completely restored Hawk completely black with deep red seats. Sorry, no pictures. I think it's the one I posted a few months back when I saw it around the Greater Dayton area on the move under its own power.
    http://i86.photobucket.com/albums/k110/imidazol97/hawk2.jpg
    Gran Turismo Hawks are my favorite Studebaker of all. Thanks for posting!
    My hometown Studebaker-Packard-Benz dealer (pop. 9,200 in 1950) now lives quite near the intersection of I-70 and I-270 on the SW side of Columbus. Small world.
    This was shot at the Pilot station on Hwy 42 and I-70, not far away!
    One of the posters on Edmunds posted a link to a Studebaker site with pictures of their Lark taken in bucolic country scenes. Was that your pictures? This was before this Studebaker topic was started. Might have been in Mystery Cars after I posted a Studebaker picture from a local cruise-in.
    If it was a white Lark Daytona Hardtop with sunroof ("Skytop"), in a fall setting (pumpkins, etc.) it was my car. I have a friend who's a TV cameraman and a wonderful photographer, and he took those pictures two years ago.
    The essence of my statement is contained in the article hyperlinked to message #864:
    Studebaker did not have the financial resources to produce the variety of parts required in order to make their engines application specific. Given the quantity of units produced, it might not have been cost effective anyhow. Consequently, they engineered their engines for worst case scenarios and light duty applications resulted in gross over design.
    You are right that not every all Studebaker V-8s are Avanti engines. What I should have said is that, unlike in the Chevy, if you got an engine available in the Avanti (i.e. R-series) in your Lark or Hawk, it was an Avanti engine (that is, built to the standards used for an engine going into an Avanti).
    That sounds right. I remember lots of orange and the colors of fall in the background.
    I like seeing cars that are original, just the way I saw them when I was young and they were new. I remember that yours was.
    I like 'stock' best of all in an old car, too. My cars have had some upgrades under the hood, but outside and inside look the way they did when built.
  • fintailfintail Member Posts: 58,886
    I am the same as you. Even the idea of Cragar wheels like on a car you previously mentioned turns me off. I can deal with upgrades like electronic ignition, radial tires, even hidden stereo and AC systems, but when it comes to seating, paint, chrome trim etc, some things are best the way they were originally designed.
    Followed a red with white 55 Chev to a local cruise in yesterday evening. After he opened the hood it had a 400 cu. in. engine. I think 265 was the biggest in 1965...
    A Valiant sitting nearby had a huge V8 crammed under the hood.
    edited May 2011
    I can deal with resto-mod stuff, if it looks stock. But mess with the suspension settings or tires, and it is all lost.
    I am not a big fan of 70s-80s style hot rods either. The tri-Chevy with a big engine was played out a long time ago.
    I try to stay stock, but the original Saginaw green had too much blue it it, so I chose a slightly greener green and whiter-white.
    My car had optional wheel covers like the Golden Hawk when I got it, but after they got stolen (when the entire car was stolen) , I went back to stock wheel covers which are so nice that people often ask me if they are custom.
    They guy who painted my car decided that he liked the look of Studebakers too, so he bought a pretty good 1962 GT Hawk, painted it the color of Campbell's soup and totally customized it including the engine and drive train. Then when he tried to sell it, nobody wanted to buy it. Serves him right so far as I am concerned. He wanted me to find him another Studebaker, but I am not looking very hard.
  • texasestexases Member Posts: 11,212
    "painted it the color of Campbell's soup"
    Probably shouldn't have chosed 'split pea'... :P
