Visitor Agreement.
red
let me know
scott
if you feel that the truck has not been properly rust proofed, then the BBB will surely help you resolve the issue.
dealers will usually take care of any warranty related items that they know they will get reimbursed for, and then again......
red
Ever since the odometer rolled over 1,000 miles on my 2000 ext cab.
1. Steering wheel squeaking/whining- 8th repair attempt; dealer screwed up alignment after 2nd attempt- has not been right since. 2. Front suspension knocking - 2nd attempt. 3. Rubber trim falling off around door/frame interface causing excessive wind noise. 4. Rear seat shakes when foled upright- turns out a rubber damper was missing. 5. Cold start- loud tapping coming from the block. 6. Electronis whine/whistle during accelerations. 7. Power window fails to go up occassionally. 8. Abnormal tread wear...the list goes on...
Well, after a weekend of driving with one new tire and one new rim, it seems to be better, but not fully fixed. I take it back again later this week to try out another tire and or rim. I just can't get over the difference of those Generals. I do here a lot of people who don't like Generals, and not just here, but other places. Yet, I've never had problems with them. Then again, this problem could totally be the rims, but if the dealer wants to replace tires too, so be it.
If you have a friend who owns a repair shop, they can order the Michelins for around $95 a piece. Retail will go for $115 to $125 each.
The Generals are worth about $35 a piece retail and $25 wholesale. Tells a real good story about what they are worth.
John
Hunter
My 2 cents...
Attorney's won't say they gotta a check for me. GM writes it after negotiations and sents it directly to me; they also pay the attorney fees.
As for "ebbgreatdane", the name of this discussion is Silverado Problems, I'm not afraid of posting comments about what I've been through so far, if it helps anyone, maybe a good thing will come of it.
Also, anyone having problems with the paint chipping? Have gotten a few chips in odd places, hood & top side of wheel well, and have not made contact with anything that I am aware of. Paint appears very thin to reveal the primer.
Your steering looseness can be attributed to your upper intermediate steering shaft which needs to be replaced. This also is coverend under warranty. The rattle is most noticeable when making slow turns over rough roads. TSB No. Clunking Noise Under Hood/Felt In Steering Wheel (Replace Upper Strg Shaft Assm) #00-02-35-003
jsm6
i second the intermediate steering shaft. this was my problem as well and oby steered me in the direction of the Tsb as well, which helped when it came time to show the service department what they needed to do to repair the problem.
i've also got a couple small chips on the top of the hood and one on top of the bed rail for no aparent reason. thank god for touch up paint and acetone.
Left vehicle in my garage for 10 days in August. When I tried to start it on day 11, motor turned over hard like the battery was low.
Dealer says there is a thermostatically triggered fan in the audio module to control temperature, presumably based on component temperature. I wonder if that fan ran since it was hot in the garage and drained the battery - certainly something that should not have happened.
I have heard of the ABS module running, but that sound comes from under the driver's seat.
Anyone heard of this sound module problem or have suggestions??? Thanks
I have a 2001 black Silverado and it seems that i can scratch the paint just by looking at it wrong. Is this possibly bad paint, or are these hairline scratches just more noticeable on black?
I think its just because its a dark color. My dads Black 92 S-10 is the same way
Blair
2000 2500 4Door 4W SB
Did you buy your 2000 in '99? If so your 2+ year old factory battery could be the culprit.
John
700 miles on my 1500 and nothing wrong yet. It'll come, I'm sure.
I had a block of styrofoam lodged in the axle. Dealer says its a bad universal joint...."probably one of the bearings is bad/went dry." Said he saw the same problem on another one just this week. What the hell is this? Anyone else have this problem? My truck is babied....has 25K on it, and I think this is garbage to have a powertrain related problem this early.
Also, any of y'all having problems with your power windows? Mine seem like they are being carved/etched as I raise them...glass doesn't seem to be sitting in the track quite right.
Anyone else had a dealer fix for this?
By the way, I noticed that fan whirring too...I think its designed to cool the factory radio head unit down when it gets hot....stops when you open the door, because the accessory power feature stops then too.
If I lived in Death Valley or the desert, I would hear it all the time.
Mike L
I am now having a problem where the lite will go out that shows you are in 2 HI (or whatever) and moments later the message center shows a warning "Service 4 Wheel Drive". If I stop the vehicle and restart the condition is reset (which makes me think it is electrical)... I have also seen examples where I had to "tap" the 2 HI button to get the lite to comeback on and stay on. If I can get this lie to stay on then the message center never records the failure. Once the error has been displayed in the message center it can only be reset by turning off the key and re-starting. Once this happens I cannot switch to 4 wheel drive or get any mode to stay lit.
I drive 18 miles to work and rarely does the light come on... but on longer trips it comes on frequently.
I stopped by the dealer and they stated that there would not be an error stored in the computer and it would probably cost quite a bit to trouble shoot... any ides?
The vehicle doesn't have any problems or make any noises but I am concerned I will damage the vehicle.
Thanks in advance for any ideas!
My truck is really acting up last few days, if anyone has a solution before it gets worse & I take it in to the dealer let me know.
Its a "Starting problem" The truck starts fine in the morning or after its been sitting a long while ( or right after you shut it off... & turn it on again) , But after driving it, if you shut it off... and come back after 20 minutes or so it just won't start. All I get is cranking ( on another occasion I did get a start out of it on a 6th or 7th try once, it was like the 7th try when I turned the key it didn't even struggle and started right up at the touch of the key). Also once, I did try pressing the pedal all the way down "as maybe it was flooded" but no luck.
Notes: I did a tuneup about a few months ago, its got ~68K mi. Its' a 5.7L V-8 with a TBI Rochester carb. I did a top end cleaning today to see if it will help. I also checked for loose fittings as I pressure cleaned the engine compartment a while ago.
Thanks in advance !:
drej,(with his fingers crossed when he starts the truck)
Honestly it sounds like possibly the idle plate is sticking closed. When you try to start your warm vehicle there isn't enough vacuum to pull in the right mixture of gas and air to start your truck normally. As it cools, your automatic choke will provide a cold engine plenty of gas to get it started and cut off to allow air in. When it heats up, you start the process all over again as you truck returns to it's normal idle position.
Try https://www.howstuffworks.com and do a search for carburetors. You'll find a ton of info.
John
If a code is stored in the ECM, you can retrieve it by shorting the A and B pins together in the diagnostic connector under the steering column. Turn the ignition key to "on" but do not start the truck. The check engine light will give a one flash, pause, two flash and repeat three times. This is the self-check to show that the ECM is functioning normally. Also known as code 12. After a brief pause with no illumination, the check engine light (CEL) will flash each stored code three times. After all codes are flashed, the code 12 will repeat. If no codes are stored, the 12 will just keep coming up.
Good luck,
Jim
Problems:
1) slapping noise from engine at cold start
2) flat spot during acceleration when using light throttle (I tend to drive very conservatively around town), engine sort of bogs down, reminiscent of bad accelerator pump on Rochester 2GC carb.
3) bed rails kind of soft – they dented from me kneeling on them while tightening tarp covering Impala parts. Chevy – not like a rock – like a soft-shelled crab. I guess my knees are kinda knobby.
Anyone else out there with similar complaints? I am especially interested in/worried about the slapping noise. Otherwise the truck is powerful, smooth, and quiet. I am actually happy with the Firestone Steeltex tires – 55lbs. Front, 60lbs. Rear – I have offroaded them in both snow and mud with excellent results and they are fine on the highway – very quiet. I was skeptical about them and took a “wait and see” attitude. I’ll use them until they wear out and then try something more deluxe.
I don't know if I'm correct in this or not, but you may not be able to get codes from the ALDL on your truck. Your truck, being a 95, may have OBDII diagnostics which would not allow you to gather codes without a scanner. Good luck.
Valky
