Kia Sedona problems
I believe the SRS system has it's own codes, so maybe they can pull it.
perhaps you have a problem with your "clock spring", a device in the steering wheel that maintains continuity between all steering wheel mounted controls (radio, cruise, horn) and airbag to the car's wiring harness for those circuits as you turn your wheel from one extent to the other.
then again, it could be a bad bag, or wiring to say the passenger bag. it's hard to say what's wrong.
The gas pump auto shut off didn't work. That is why most pumps have stickers that say "do not top off tanks".
If there was no overflow hole, the gas would pool in the compartment surrounding the fill neck of your gas tank. Nothing like driving around with a pint or quart of fuel sloshing around...talk about a fire hazard! So, the gas drains down to the ground and you drive off.
(You aren't leaving your van running or talking on the cell phone are you? Both are BIG no-no's due to ignition source and static electricity). Likewise, getting in/out of vehicle can cause a static discharge.
The other thing that can happen when the auto shut off doesn't work is that it can rapidly splash out of the fill pipe and soak you. So, if you are trying to top off the tank (remember that sticker?) don't stand directly in front of the fill pipe. Stand one side or the other.
There cannot be a direct to air vent hole in the tank or lines, you would slosh gas out around every conrner! There is a tank venting for vapors but thats not under the middle door either. Gas is not supposed to come out of a sealed, pressurized system. I would have to guess a 'breach' in the fuel line to cause two symptoms like that. Not a broken line either as that would be very serious, and the van would stall due to no gas. Yours kept running. The fuel injection system, being subject to high pressure would be very suseptible to a pressure loss, even a pinhole, or a crack in the line. My biggest concern is that I recently had the rear coolant lines replaced due to a corrosion breach and subsequent leak. Whats to say this doesnt happen to other lines IE fuel or brake lines! Mine was not dangerous (except to the engine itself), those two are possibly fire or crash.
Also on a similar note, we had a 2000 Sportage that we had to have the plate replaced on top of the gas tank. The one with the hose cluster and the sensor for empty-full. Still didnt fix the gas smell, finally they had to replace the entire tank there was SO much rust and corrosion the new plate would not seat and seal. This was in 2003, ONLY 3 years old. Your 04 is at least 2.5 years old....?
If you can, share the 'afterwards' details.
As luck would have it I was only a block away from home!!! (I was at Hershey park last weekend which is about 95 miles away from me...glad it did not happen then!!!)
Anyway...I thought that the OEM battery had gone bad. I got my son to jump me and I drove it home.
I went out and bought a new battery and installed it. The old one was past the 3 year mark...so it was not eligible for the free replacement. The van was fine for about 1/2 hour...and then the battery light and brake light went on :mad:
I put a volt meter across the battery terminals and, sure enough, the alternator was not working!!!
I should have thought of that first...but I had forgotten about the alternator issue with the '02 and some '03 Sedonas. It did not dawn on me that the alternator would go bad this soon (not quite 30K on vehicle). I took it in and the dealer replaced the alternator and belt under warranty...the van is running great once again! They also put a heat shroud around my battery and reprogrammed the vehicle.
This also has helped my AM radio reception immensely! I had always had a problem with most AM stations and noise (had taken it in for this before and was told...NORMAL)! The electrical interference from the old alternator was causing this problem after all.
I did pull off to the side of the road (I wasn't getting anywhere fast anyway and I did not want to get stuck in the middle of the highway.) to let the van run to burn off some of the gas. I figured that was the problem since it was running just fine before the fill-up. I sat there for approx 10 minutes and then tried the highway when it was totally clear and there was just a little hesitating for about a mile or so. Hasn't had a problem since.
I was thinking of taking it to the dealer to have them look at it but haven't as of yet.
This van gives you a real bang for your buck and has been great and a real pleasure to drive, I love it.
I just am curious as to why this happened and if it is serious.
Thanks for your responses.
Your local parts store should be able to test the alternator in the car in a matter of minutes. Depending on your mileage it could be under warrenty. There was a service bullentin on this a couple years ago. See post #1251 for the TSB number, and may help with the Service Manager doing the work under warrenty.
Good Luck
I stopped bringing it in for repair because the service manager told me NOT to return the car there for any of the above repairs because "everything is normal" I have since brought it to another dealership whice was just as bad,
Anyway, in March my attorny sent a certified mechanic out to inspect my vehicle. He couldn't believe that all these problems happened within the first 3,000 miles saying in his report that this vehicle has the characteristics of a vehicle that would have 100,000 miles. The cars are a complete joke in my book. I also have kept every gas receipt and am getting on average 12.5 miles/gal.
Sometimes after a 10 mile drive thr front rims are so hot you can barely touch them with your hand,other times they are as cool as can be. I have a large groning noise from the front breaks every time I step on them (again, the dealership says this is all normal) and at speeds of 50MPH a step hard on the breaks for a quick stop and the vehicle veers way off to the right. Again, according to the dealership, after test driving the vehicle (a grand total of 1.5 miles after I had dropped it off) they say the symptom could not be duplicated so everything is normal.Kia has to be held accountable for this.
search the forum.
does anyone knows how to reset the air bag light? mine came on, went out, and then came back on again, and stayed on. someone told me that it has to be reset. by the way, where can i get kia how to books? are there any out there?
thanks. louie.
I just had to replace my airconditioning condensor and i had both good and bad news to report. First the bad news.
If you have a FAT BELLY and you push your FAT BELLY against the front of your car while you are working on it you will push the HORNS into the Condensor and the metal STUD on the rear of the horn will punch a very nice HOLE in your air conditioning condensor tubes !!!
I was told my air conditioning was not working since it had a HOLE somewhere and I found the hole ! Ha HA. I wonder why the mechanic could not find the hole ?
The Kia Factory is charging a enormous price for the replacement part of $ 471 !. My parts advisor helped me find one on the internet for $ 120 !!
When it arrived , guess what? I was made at the Kia supplier and had the Kia supplier Kia Part number etc,etc
so it was IDENTICAL to the OEM part. It WAS and OEM part.
We installed it and it fit and worked perfectly. We charged up the Freom and I will start using it.
I bought it from karen.segars@brightauto.com and they were great to deal with.
It was actually IMPORTED by a WHOLESALER who then Sold it to Karen! So Karen made money and the wholesaler made money at $ 120.
This kind of makes you wonder HOW MUCH MONEY DOES PETER BUTTERFIELD NEED TO MAKE on spare parts until he feels he has gottne his " Pound of Flesh " from his customers. PEte Butterfield is the President of Kia Motors USA the Kia distributor for the Kias we are buying here in America.
Hey- if you get TIRED of how much Peter is overc\arging us, you can buy Kias in Canada for a few thousand dollars less since the Kia Canada does not mark the cars up as much as Peter does.
I do not know Peter personally, but I can assume he does not read this forum since the customers who have the really bad problems never seem to hear from Peter about fixing the root cause of their problems.
Anyway - I got AC again !
And my dealer did my AC recharge for FREE !! as he
agreed they problably punched the hole in it.
By the way- Tips to the WISE - Move the darn horns higher.
I took the bolts out and rotated my horns UP so the are in front of the solid metal Radiator support and not hanging down waiting for a BELLY to push thme into my radiators.
I am back to enjoying my smooth running 2002 Kia V6.
Thanks for the tip on brightauto.com...that may come in handy in the future. As to the markup on parts... dealerships, as you know, do not make much money these days on the new car sale (unless they snag an uninformed customer)...so, unfortunately for us, they try to make up for it on the service and parts areas.
1. Had to replace the fuel sensor in March $200
2. Replace the alternator last week - $$850
3. Replaced the cat conv - $200 @ meineke
Here's the next problem that I need some help on:
The check engine light came on 1 week after the alternator was replaced. I took it to the KIA dealer and they said it was the pre cat $1,100 estimate to repair (mostly part, i've check around and no one has this part). I'm a little paranoid to replace it because of 3 reasons: 1) the service manager was going to charge me $1000 for the alternator when he gave me an estimate of $850, so I argued with him for 20 mintues and he finally he adjusted the bill after saying he discovered that their estimation system was in error - I'm hoping the precat is not a made up problem in retaliation. 2) I was going to shop the car for trade after I got the alternator fixed, so I cleaned the car including the engine. I asked the service manager if I could have done damage to the engine by washing it and he said no. 3) I don't won't to get into a "process of elimination" to find the problem of the check engine light and have to put more thant $1,000in 02 KIA - the service manager said that he gets very specific codes and this one points to the pre-cat.
The car occassionally hesitates when applying the gas, but drives OK for the most part.
Does anyone have any reassuring words or can they direct me to a cheaper resolution.
Thanks and I appreciate this forum. :sick:
As far as this " pre Cat" I do not know what they are talking about. But I would see about researching this on the internet , I found my A/C part for $ 120 and the dealer price was $ 578. I am presently trying to find the Front Shock Strut on a bargain price so I can rebuild the front end to get back the New Car ride. The biggest concern I have now about the Kia is the 3rd party parts and repair is not very good yet. BUT - I think in your case- do the scan tool and solve just that problem, then sell the car. Right now it is probably worth $ 6-8 K on a trade and you could get a year old Sedona for $ 10K with about 20 K miles on it. Then you could get out of the repair trap for less money than the repair bills. I'll bet you can reset the engine light and then trade the car in that day!
The Kia dealers and other large dealers are getting very cheap prices from the daily rental companies that are selling Sedonas that are a year old.
I am pretty happy with my car. But I learned a heck of alot more about the car than I ever planned to! Due to the very very poor dealer repair staffs. I have been to 3 dealers so far.
I have to say that my EX has been relatively Trouble-free since new. No brake problems, or AC problems, or Alternator problems,-- just that persistant Klunking over small bumps that wasn't there when new. The last time to the dealer, they repositioned the strut in the tower, added washers, and then charged me for realignment because they said the tires were wearing uneven on the front. Still does It!!
On a recent trip to Cincinnati, Ohio, I had the oil changed at Castrucci Kia ($24.95) after a $5 off coupon, and asked them about the front-end noise problem. After all there are many more pot-holes in Ohio than we have here in Florida. Their answer was "Yes, we know about the problem, but there is nothing that can be done about it". It seems that Kia would research this problem, and offer a solution.
Also, on the emissions problem --- I thought every Mfgr. had to warrant their emission parts for 100K? Isn't the Cat Converter part of that system?
Boxwrench
But here are the most significant ones for Kia
the Front Shock is $ 188
The Shock rests on what they call a "Strut Mount"
which is the rubber lump you see on the Fender when you have the hood open with the bolts by it.
I think we need the Strut Mounts for sure.
The Driver side Shock feels like it is gone also.
Kia Part 0K52Y 34380 RUBBER-STRUT MTG,FRT QTY-2 $61.85
Maybe we should all buy Moog Brand so they get a
reward for setting up the Kia Parts!
Maybe the Moog will last longer too!
Moog Part # MOK90222 Strut Mount $ 68.00
These may help with steering feel.
Tie Rod Ends- Left & Right Side, Outer.
Moog MOES3618 Tie Rod End $18.39 each
Moog MOES3621 $18.39 each
I am getting close to doing this repair.
They don't have a Chilton manual out yet, but you can go to the Kia website and use their shop manual for free. It was on as a paid site for awhile. (I know I subscribed) but is now back to being free. Just go up the kia.com under kia owners and look for tech manual.
Maybe the strut mounts are all my van needs. The struts really seem to work OK.
Does Moog make the parts for Kia? Or are they truly aftermarket parts.
Have you looked into Monroe Struts if they are available?
Boxwrench
thx, TS
We own a 2003 Kia Sedona EX. For the last couple of years we hear a roaring noise (sounds like a motorcycle running) coming from the rear of the car(passenger side). It happens only when the AC is on especially on long trips. It lasts for a few seconds and then keeps coming on.
We had it looked at by 2 Kia service centers but they were unable to duplicate the noise or find anything wrong. I also called Kia customer service- they have no clue.
Does anyone have had this problem. Any clues.
I had posted this one earlier. I had the same problem and found out that it was the seat belt latch chip that was causing my airbag light to come on. I had it replaced under warranty and it hasn't been on since.
this could also explain why you are finding that "NO ONE ELSE HAS ANY PROBLEMS WITH THEM !
During the warmer months I get intermittent occurrences of raw gasoline smell inside my vehicle. it is not from the road surface or other vehicles. by the time i get it to the dealer they cant duplicate the problem.
Has anyone heard of this.
Pss no its not a gas cap.. It is not the obvious.
Now I have 111K on it and it's out of warranty.
Boxwrench
