It says:
"Some customers may comment on a 1-2 shift shudder at light to moderate acceleration. Typically, the throttle plate angle parameter is 12-20% at time of condition with vehicle speed of approximately 24-40 km/h (15-25 mph). The customer may describe the condition as slip or delayed shift into second."
Are you in Minnesota? I contacted a lemon law lawyer here in MN. and they will not get back to me. I am frustrated that car dealerships can tell you alot of lies and send you off w/a car that has major problems.
Good morning, I was reading your post. I seen that you purchased your vehicle from a Ford dealer; however, have you tried taking your vehicle to an authorized GM dealer? If not I would recommend doing so to have your vehicle diagnoised. Please keep me posted on your progress.
Christina
GM Customer Service
Toni
I would be happy to locate a dealer for you; however, you will need to speak specifically with the dealer for service pricing information. If you would like to e-mail me with your zip code, I am happy to assist you in finding a service department.
Christina
GM Customer Service
It's great to have the 5 year / 100,000 mile powertrain warranty for 2007+ years. You need it. Was never a fan of buying the Automakers extended warranty but will always do. My daughter, sister in law and our '07 Lexus ES350 all have extended warranties taking the cars into 100,000 miles. Will buy on my next new car.
I would gladly join in a suit to have this problem rectified. We pay a good amount of money to drive our cars and this should not be happening to so many Impala owners.
I bought a new Impala LS in 2000, its first year. I was told by some friends that buying a new model car in its first year is not a good idea. They were right. For the first two years it seemed that everything that could go wrong, did. My Impala was in for repairs at least on a monthly basis. It was under warranty - so, financially , at least, it wasn't a problem - however, it was very time consuming, and frustrating. GM, (as a good will gesture?) gave me a three year warranty extension at half price. One of the treated problems during this time was intermittent rough shifting - two clunks shifting up and two lesser clunks shifting down. The service manager (now a friend after so many visits) said it was a computer problem and a new computer was installed. The shifting remained smooth after that for about four years. Then it began showing the old misbehavior. After about a year goes by, and While an AAA mechanic was installing a new battery in the Impala, I mentioned my transmission problem. He replied that this new battery would fix it. I laughed, but he was serious. When he finished, I drove away with the Impala smoothly shifting! It remained that way for about six months. One explanation I heard of this "cure" is that the electronic system, being disconnected to install the new battery, made the computer reboot and that cleared out a computer error. I have since tried a reboot by disconnecting the battery negative cable for a half hour, but with no success at eliminating the intermittent rough shifting. Any thoughts, ideas?
Thanks for the input
I am having problems with intermittent jerking into motion after a full stop mine is a 2006 Impala LS. When I pay this car off, I am trading or selling this thing and going back to Toyota. The dealer shop does not know what to do about this problem so I am left with a note and a very likely warranty claim in the future.
MODERATOR /ADMINISTRATOR
Review your vehicle
1. complete tune-up. (no more mis-fire)
2. added sea-foam trans cleaner and drove car. changed fluid and filter.
3. dropped trans and changed TCC solenoid.
4. completely removed cat-converter (added straight pipe for time being)
since the repairs, this car runs and shift great in every gear but 3rd. no slipping, no hard shift, no nothing. it just wont shift from 2nd to 3rd unless i let off the gas. driving the car like normal, after it shifts into 2nd, it gets up to about 50mph and high rpm then i can just barely let off the gas pedal and it will shift just fine into 3rd and then goes rite into OD no probs. the only other thing i can thinnk of is changing the pressure solenoid but not sure if that would fix or not. any suggestions please....
Review your vehicle
I did get the problem fixed. Mine was jumping gear right from 1st after a stop. It was a tranny issue. They had to replace a few solonoids and it solved the problem. The job normally can run 1500, but I got mine done alot cheaper cause it was right after I purchased the car and I was so angry that was happening.
Now I have a 'whistling' sound every time I accelerate and that's driving me crazy. I am going to get that checked out soon.
Please keep us posted on any information regarding the whistling sound.
Thank you,
Caron, GM Customer Service
I have an appt this Friday to have it checked out I will let you know what I find out.
Thanks !
Toni
Glad to hear you have an appointment on Friday. I look forward to hearing from you after the appointment.
Thank you,
I brought it in and they could find nothing wrong with it. How odd. I guess that is very good news, no money out of my pocket, but I am still hearing the whistling noise whenever I accelerate and it stops when I let off.
Thank you for the update and I am glad to hear there is nothing wrong with your vehicle. If you still have concerns, please feel free to get a second opinion.
Thank you,
I have a 2003 Impala LS and it has a knocking coming from the transmission housing cant figure it out i would figure if it had a bearing going out it would leak fluid???? Maybe im just mechanically stupid. Has anyone had this problem before or know what it could be. Any input would be awesome.
thank you
Little cracks in a flywheel are not uncommon at all. Take it to a machine shop and let them evaluate it. Most often, a flywheel with cracks in it can be resurfaced and used again.
