Visitor Agreement.
There are online directions for replacing the bulb behind the HVAC plate (assuming this is the manual control not the climatronic one). Google "HVAC light Passat" and you'll find those.
Does your vehicle have the homelink system built into the visor? There is a relationship between that and having the vanity lights go out.
Does the rest of your electronics work, like the cruise control?
Post more info and let's see what we can figure out.
* Battery drains overnight
* Brake Lights remain on when headlights are on (work normally with headlights off)
* Alarm goes off randomly (and annoyingly according to my neighbors!)
Wet environment, but no apparent leaks. Please share your thoughts!
PS....I also noticed that the wipers "swish" the windshield once when the car turns on...not sure if this is related...
The tail light problem was caused by a 17-year-old that replaced the bulbs with the wrong type (single element rather than dual element). : )
The battery drain and random alarm were caused by a shorted control module (computor) that controls the door locks and alarm system. $500 repair. Woof.
Before system shutting itself down the brakes were activating ABS even on dry surface. It made stopping interesting.
Space under seats seems to be dry so I do not think it is water damage. Could it be ABS sensors being blocked by debris? The car was driven through some deep snow.
Krzys
I'd go to an auto parts store that has a free OBD reader to borrow, and see what codes you can pull. Post with what you find.
It started after driving through deep snow on unplowed streets.
Krzys
Thanks!!
Ed
It’s been very hot in the UK the last few days and I have found condensation on and possibly the inside the dashboard! I have tried to source potential crack in seals to no result!
The water droplets have now gone, and it seems dry, but, there are no lights coming on the dash. I have checked the other electrics and fuses to find that everything works (lights ok, cd/radio ok, windscreen wipers ok etc..) apart from Windows.
The engine almost fires up, but does not. I believe the circuit board would engage the two
I have noticed that the mileage information has converted to Kilometres! And I have a message reading "Def." Does anyone know what this means?
I have been advised by a Breakdown service to use rice cakes to absorb the moisture from the inside of the car Is there anything else I could try before taking the whole dash apart to check the printed circuits!?
Thanks in advance for any advice.
Good luck with this. VW doesn't care about fixing problems and VW American stands behind them.
1. the heat doesnt work---all the fixings for the heat to work is running fine but there is just not hot air coming out the fans blow hard and everything but no heat...the heated seats work perfectly but no hot air im seeing that it could be a couple things like a clogged hose or faulty heater core but im not sure because everything else works fine...
2. the radio goes out as volume goes up----ive noticed that on certain volume levels the volume on the monsoon radio would cause it to go out, now the radio would still be lit up but id have to turn it off then back then turn the volume down for it to work now if i didnt turn the volume down wit would play for a couple seconds then cut off again like it was blowing a fuse or something or busting the sound decible level causing it to go into some type of fail safe or something....
3.none of the streering wheel functions work nor does the horn----now i dont typically use the horn so i didnt notice it at first but i was excited that i had steering whell functions and i noticed those off the bat the cruise control light comes on but doesnt set nor will the volume change if you select a different one one the wheel...now they all light up when you turn on the headlights at not but still dont function...also turning the wheel does nothing as well, now with the horn i press it to no result but when i lock the door with my actual key you can hear a little horn toot which confuses me why the horn wont work
now with all this being said everything else work completely fine...everything lights up no fuses are blown windows work sunroof all the locks everything else electrical works fine to my knowledge so any help in how to fix them would be greatly appreciated.....
The car is still used by my eldest but it was interesting ordeal.
Krzys
has dvd but once you start to drive....dvd image stops playing for safety issue..you can hear the dvd playing but no image....Can I get around this...
and can I get a Back up camera for my Passat..
Live in careteret NJ...can any one recommend a good parts and electric man for this task..
Back up camera
Install dvd players on both heads rest.
and get my in dash monitor to play dvd ...even if in motion
Thanks for your time sound system is Fender..radio does not have
brand but...I guess that's what it is...I'm going to ask dealer to install
back up camera...I don't think they are going to bypass that feature..
Do you know of any good place here in Jersey city area.
1) AC is only moderately cool. Can I get freon to add to the AC system? Is this something I can easily do myself?
2) Cruise control does not engage. Everything else on the steering wheel works (knock on wood). I will try replacing the fuses. If that doesn't work, what should I try next?
3) Driver's side front blinker only works sometimes. It's not burnt out, because it does work occasionally. Is this a wiring/ electrical issue? The side one does work, so it's not as much a safety problem, but the fast clicking really annoys me!
4) The car was rear-ended and has a new hatch. Neither the key nor the remote open the hatch, I can only open it with the inside door button. A minor inconvenience, but if there is an easy fix I'm all ears.
Other than that, the car is awesome! Thanks for the help.
I have a problem with my car, had this car for almost 4 years and now the tail light doesn't;t work properly. My back up light, and flashers works,.. Only brake lights work and not my lights that you have when your driving at night,,, I changed all the builbs, and cant see whats the problem, :mad:
THANKS
One thing I noticed was that I could get the car to start again without waiting. I would open and close the back door on the passenger side, or the other back door, or the front passenger door, or even the hatch (using the key). I would also flip a rocker switch that's inside the compartment in the center armrest (I have no clue what this switch does, and I've read the manual cover-to-cover; it's a round switch about three-quarters of an inch diameter, and when the top half is pressed, there's a red light.). None of these things worked 100% of the time, but if I tried enough of them, I could always get the car to start without waiting. That is, it always worked until two days ago, and now the car sits in the garage.
I haven't yet checked to see if all the drains (plenum, sunroof) are open, but that's on my agenda. What I did do is pull up the carpeting on the left side, examine the wiring, remove the CCM and examine it. I fully expected to encounter standing water, but to my surprise, everything under the carpet is dry. There's no sign of water intrusion at all, at least to my untrained eye.
Is it possible that the CCM would fail without getting wet? Would it fail all at once, or gradually over time (as the problem happened more and more frequently)? If I take the CCM to a dealer, can they check to see whether it's good or bad? Is it possible the problem could be something else that would cause exactly the same symptoms as a failed CCM?
Thank you in advance for any help. I debated between buying this car and buying an Audi A6 one model year older, and I'm starting to think I made the wrong choice.
...and then tonight, my dash lights and tail light dont work anymore,, every other lights i have works,,, includint volt gauge,
Could you please help me if you know something ,
About 2 days after I pulled out the CCM, looked at it, and put it back, I decided on a whim to try to start the car. To my complete surprise, it started right up!
What's more, it's been starting perfectly reliably ever since then. All the things that didn't work before have been working flawlessly. I still hold my breath when I shut off the engine, looking to see whether the interior lights come on, but they have every single time so far.
I guess just removing the CCM and putting it back must have cleaned an oxidized connector or something. This saved me about $350, which is what the dealer told me a new CCM would cost.
And the icing on the cake is that I have noticed significantly better gas milage since I R&R'd the CCM. I used to the the fuel warning light coming on after about 240 miles. On the current tank of gas, the light didn't come on until I had about 320 miles. Time will tell if this this improved milage sticks around or the milage diminishes, but for now I'm thrilled with my car.
As for the back-up camera, the unit should have a "video in" RCA or manufacturer style plug for such a thing. It is triggered to send video signal to screen when the car is put into reverse ... so there's that connection as well. However, with factory video in your car, the wiring and connections/triggers should already be in place ... just add the camera, maybe.
My problem usually resolved itself after the car sat for awhile. The last time, however, it didn't start after sitting for several hours. I'd previously had some luck when I tinkered with the CCM, simply removing it and plugging it back in. After doing that, the problem didn't come back for several weeks. It eventually came back with a vengeance, though. So I ordered a new Comfort Control Module from the dealer ($379.59, tax included, just for the part), and left the car where it was. Four days later I went back to the car, and it still wouldn't start. I removed the old CCM, plugged in the new one, and still nothing. I about lost it. However, having read through this thread in its entirety in the past, I knew that sometimes it's not the CCM, but the wires that go to the CCM. So I started twisting, pulling and kneading wires, and next thing I knew, the car started right up. I drove it home, put the old CCM back in, put the new CCM back in the box, and I haven't had a single problem in the six weeks since then.
Somewhere farther back in this thread you'll find instructions or a link to another site that has instructions for replacing the CCM. It's located under the carpet in the footwell on the left side (driver's side in the USA) of the front seat. When water leaks into the interior, the CCM (a circuit board) can get wet, or the wiring can get wet. Water wasn't the culprit in my case, at least not that I could tell, but you can also find suggestions for unplugging drain holes in the engine compartment and the sunroof, which when plugged will allow water into your interior.
If you inspect all the wiring, jiggle it around, whatever, and the problem doesn't go away, or if you see evidence of water on the unit, I'd be happy to sell you my new CCM for less than you can get it for from the dealer. I used it for about 30 minutes before putting the old one back in, so I know it's good. Being an electrical part, the dealer wouldn't let me return it once the package was opened. If you're interested, the part number, which you should check on yours to be sure it's the same one, is 1C0-959-799-C-081. I'd be happy to send you pics of the unit and a copy of the invoice.
Good luck to you, and if you have any more questions, I'll hopefully be able to answer them.
Here's the site where I learned how to replace the CCM. They have a 1998 Passat, but the CCM and the wires are identical to my 1992 Passat wagon. When I moved the driver's seat all the way back, I could push the carpet back far enough to pull out the large plastic box that holds the CCM, and I can get to the thick bundle of wires alongside the door opening. I still haven't bothered to put it all back together, so I'm driving with a large plastic box on my floor, and the trim strip from the door opening loose.
http://natnkat.wordpress.com/writing/how-to-repair-the-comfort-control-module-cc- m-for-the-volkswagen-passat/
I see in one of their photos that the part number on their CCM is slightly different than mine. Mine is 1C0-959-799-C-091, and theirs is 1J0-959-799-K-something (the picture cuts off). If the wiring isn't your problem, make a note of your particular CCM part number.
Did you ever solve yours?
Beware, though. The CCM problem can also be wiring. In my case it was wiring, and just kneading the bundle of wires fixed it for me. Which is why I have a brand-new CCM I'm willing to sell. Contact me of you're interested, but thoroughly check the wires first.
Finally, check the operation of your door lock on the driver's side. Make sure the electrical portion is actually letting the car know the door is open. (Otherwise I have had it happen, on a Jetta most recently, where the door lock is the culprit, and the car thinks someone has climbed in without opening, and unlocking the door, then the anti-theft kicks in.)
Changed numerous Ccm's and respliced many wire looms and most times you can take care of it. Just be careful, and take your time. There are about 70+ wires, spliced down to 30 something, and then down to the ccm plug. So be thorough.
Good luck guys!
king regards donald
